Date/Time: Tue, 26 Nov 2024 21:32:08 +0000
synchronize chartbooks between sub-instances
View Count: 240
[2023-10-17 02:32:38]
User121314 - Posts: 17
let's say, i have in my Sierra chart main instance about 3 chart-book, namely CB-M1, CB-M2, and CB-M3.
when i created two sub-instances [sub-instance-2 and sub-instance-3], then these chart-books where copied into the sub-instances. The chart-books in the sub-instances where also named same as the main instance, as CB-M1, CB-M2, and CM-M3.
let's say, i used sub-instance-2 on day-1 using CB-M2 and sub-instance-3 using CB-M3 and made changes to both the Chart-books in the sub-instances
Question:
- To use the latest chart-books (CB-M2 and CB-M3), i should always use sub-instance-2 with CB-M22 and sub-instance-3 with CB-M3- corrent?
- if that is the case, is there anyway that i rename the sub-instance-2 to something like "sub-instance-2 CB-2"- this will help me to make sure that i always use sub-instance-2 to open CB-M2 chart-book. and same with sub-instance-3 & CB-M3.
- when i change CB-M2 and CB-M3 in Sub-instance-2 and -3 respectively, then the chart-books CB-M2 & CB-M3 in main-instance do not get updated automatically, right?
- in this case, then there is NO reason to maintain those Chart-books in main-instances because those where changed/updated in the sub-instances, right?
- if there a way that i can synchronize these chart book in individual sub-instances to main instances. this way, i can always point back to the main instances chartbooks in case, i mess-up with the sub-instance chart-books.
[2023-10-17 17:36:51]
John - SC Support - Posts: 36308
What you need to understand is that when a sub-instance is first created, the chartbooks and settings from the Main Instance are copied to the sub-instance. But from that point forward the sub-instances are completely separate, and any changes you make in a sub-instance does NOT propagate to any other instance (main or otherwise). Refer to the following:
Using DTC Server for Data and Trading in Another Sierra Chart Instance: Each Sub Instance is Independent
How you want to handle the chartbooks from there is up to you.
Sub-Instances can NOT be renamed. Sierra Chart has specific naming that is used to find the sub-instances, so do not change the folder names.
Correct - per what we stated above.
This is a personal choice as to how you want to work. But the general idea is correct - in that if you are going to work with those chartbooks only in those sub-instances, then you would not need them in the other instances.
It is just a matter of copying them to the main instance Data folder. You just have to exit from all of your Sierra Chart instances first in order to ensure that the files are not being updated/modified when you copy them.
