Date/Time: Mon, 13 Jan 2025 06:23:47 +0000
Czech / German Language Translations and Language Support
View Count: 37811
[2014-07-18 23:37:03] |
Update - 2017-04-11: We have set up this page here for Additional Language Support for customizing the menus with different languages:
Additional Language Support Sierra Chart supports the ability to customize the names of menu commands. This is done through Global Settings >> Customize Menu Items. These new translated names are stored in the MenuCustomizations.XML file in the Sierra Chart program folder. With the help of someone from the Czech Republic we have created translated menus for the Czech language. The file is attached. It is named MenuCustomizations.Czech.xml . To use this file follow these instructions: 1. Exit from Sierra Chart. 2. Save the file to your Sierra Chart program folder. Usually C:\SierraChart 3. Rename the file to MenuCustomizations.xml 4. Start Sierra Chart and you will see the translated names on the menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-17 16:41:18
MenuCustomizations.Czech.xml - Attached On 2014-09-22 03:29:57 UTC - Size: 46.64 KB - 1031 views |
[2014-07-30 11:17:00] |
User51760 - Posts: 108 |
Hello Support Team, I am willing translating the menus into German. As a long-term project I am also willing translating the Sierra Chart documentation as a German version, given you considering that helpful. Any idea or advice? Thank you for your consideration, Best, Chris |
[2014-07-30 18:58:26] |
This will be great if you can translate the menus. You just need to enter the menu translations through Global Settings >> Customize Menu Items. When done you will then need to attach the MenuCustomizations.XML file in the Sierra Chart folder here, so others can use it. We do not recommend translating the documentation because that is an absolutely enormous task . Also the documentation is updated every day. It is easy enough to translate a webpage using this: https://translate.google.com/ Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-30 19:59:30
[2014-09-22 03:33:24] |
Post #1 has been updated with a new MenuCustomizations.Czech.xml file which contains Czech language translations for some new and previously untranslated menu commands .
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-22 03:34:20
[2014-10-24 18:37:22] |
A helpful person from the Czech Republic created a Czech language glossary for Sierra Chart users. It can be found here: SLOVNÃÄEK POJMÅ® / Czech Glossary Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-11-15 02:53:41] |
This is a YouTube video posted by someone in the Czech Republic who uses Sierra Chart and is creating instructional videos for Sierra Chart: http://youtu.be/EMX6gfjrpT8 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-11-18 22:31:32] |
Another new YouTube video: http://youtu.be/wWFl7NI1gsc Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-11 11:26:15] |
Hello Support-Team, please find attached the file MenuCustomizations_German_scversion_1222.xml. The xml.file is coming from Sierra Chart Version 1222. Trying to find matching terms and staying consistent in using them. Sometimes the translation is more descriptive than literally. I kept terms like "Chart" or "Quote Board", since they are well known in German. Please everybody feels free using the file. Although I did my best it comes without guarantee for correctness. To use this file follow these instructions from Sierra Chart Engineering: 1. Exit from Sierra Chart. 2. Save the file to your Sierra Chart program folder. Usually C:\SierraChart 3. Rename the file to MenuCustomizations.xml 4. Start Sierra Chart and you will see the translated names on the menu. Regards, Chris Date Time Of Last Edit: 2015-01-11 11:49:56
MenuCustomizations_German_scversion_1222.xml - Attached On 2015-01-11 11:21:22 UTC - Size: 50.08 KB - 972 views |
[2015-01-11 18:52:56] |
Thank you for this contribution. We have renamed the title of this thread to indicate that there is now a German translation.
[2015-02-12 03:18:22] |
More Czech language videos: http://youtu.be/jgFiuU6aWa8 http://youtu.be/vUHuaDeR2r8 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-14 01:27:10
[2015-02-27 01:02:50] |
ganz - Posts: 1048 |
Hi All FYI: One could translate it to Russian as well. Перевод на русский также доступен. http://s13.postimg.org/54vhlidd3/sc_transl1.png It was tested on Debian 7 using wine 1.4.1 thnx to SC Team. |
[2015-07-22 09:21:54] |
tomtr27 - Posts: 22 |
Hallo User51560 Danke für die deutsche übersetzung. Nach dem Kopieren der Datei und umbenennung, habe ich neu gestartet ! Nur jetzt macht die Platform reconect alle 5 Sekunden ! Also Connect Failed. Was könnte das sein ? Danke und Gruss Tom |
[2015-07-22 09:23:58] |
Hallo nocheinmal Habe die Platform mehrmals neu gestartet. Nun läuft SIe. Danke auch Tom |
[2015-07-22 13:13:15] |
Bitte, gerne - bald will ich die Überarbeitung für Version 1270 fertig haben - hope to get ready with translation for version 1270 soon... Chris |
[2015-07-22 14:50:57] |
Hallo das ist hilfreich mit der Übersetzung. Nur in den Menüs ist alles immer noch in English. Echt schlimm das in der heutigen Zeit !Ich kann die Plattform so nicht benutzen. Steh da grad echt auf dem Schlauch. Agena Trader ist auf deutsch. Aber unausgegorene Hobby Plattform..... geht auch nicht. Hat jemand einen Tipp vielleicht für eine Plattform auf Deutsch ! wäre dankbar für Hinweise. |
[2015-07-22 14:52:54] |
Hallo das ist hilfreich mit der Übersetzung. Nur in den Menüs ist alles immer noch in English. Echt schlimm das in der heutigen Zeit !Ich kann die Plattform so nicht benutzen. Steh da grad echt auf dem Schlauch. Agena Trader ist auf deutsch. Aber unausgegorene Hobby Plattform..... geht auch nicht. Hat jemand einen Tipp vielleicht für eine Plattform auf Deutsch ! wäre dankbar für Hinweise. Nochmals gepostet dieser Google Translator übersetzt nur Kauderwelsch. Verstehe da keinen Satz nach dem Übersetzen. Nicht zu gebrauchen diese Translator im Netz !! |
[2015-07-22 18:35:43] |
Hello, User453567, please send me an email to chrisus@gmx.com to not congest this thread. Chris |
[2017-03-14 14:12:42] |
User481049 - Posts: 2 |
а можно ещё раз как на русский перевести меню!
[2017-03-15 02:21:44] |
ganz, In regards to: FYI: One could translate it to Russian as well.
Do you have an XML file with the Russian translations? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-15 06:16:29] |
нет! я нашёл папку MenuCustomizations.xml у меня такой нет!! у меня есть папки! English_customizable и English когда открываешь выдаёт это - <?xml version="1.0" encoding="WINDOWS-1252"?> -<NotepadPlus> -<Native-Langue version="6.5.2" filename="english_customizable.xml" name="English"> -<Menu> -<Main> <!-- Main Menu Entries --> -<Entries> <Item name="&File" menuId="file"/> <Item name="&Edit" menuId="edit"/> <Item name="&Search" menuId="search"/> <Item name="&View" menuId="view"/> <Item name="E&ncoding" menuId="encoding"/> <Item name="&Language" menuId="language"/> <Item name="Se&ttings" menuId="settings"/> <Item name="Macro" menuId="macro"/> <Item name="Run" menuId="run"/> <Item name="Plugins" idName="Plugins"/> <Item name="Window" idName="Window"/> но там нечего не меняется ! ??? |
[2017-03-17 20:40:34] |
We will be responding to this as soon as possible. Just give us about another day or two.
[2017-03-21 03:45:31] |
We will work on a Russian translation for the menus to make this easy. Just give us a couple of weeks please. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-11 06:29:07] |
We have set up this page here for Additional Language Support for customizing the menus with different languages: Additional Language Support Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
