Date/Time: Tue, 26 Nov 2024 22:13:40 +0000
Using Denali Data with IBKR
View Count: 483
[2023-10-09 12:31:15]
elster - Posts: 4
I have followed the instructions from here:
Integrating Denali Feed with Interactive Brokers for Trading
I can use Sierra Chart with IBKR perfectly fine and the DOM works with IBKR. The charts are poor as the data is incorrect. So I have the Denali data feed.
I can use Sierra Chart with Denali data feed and it works perfectly for the data [SC Data - All Services].
When I change the "Current Selected Service List" to Interactive brokers it does not take the data from Denali feed. Meaning it goes back to the poor IBKR feed.
I have 2 instances running (I am not sure if that is relevant).
How can I route orders to IBKR but not have their data. Following the guides above it doesn't combine the data.
[2023-10-09 14:40:02]
Sierra_Chart Engineering - Posts: 17185
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2023-10-10 19:17:01]
elster - Posts: 4
Please find the below the Message Log Using ES-202312-CME
Software version: 2528 64-bit | 2023-10-10 15:12:29.413
Primary Thread ID: 9320 | 2023-10-10 15:12:29.413
Usage end date: 2023-11-26 | 2023-10-10 15:12:29.413
Enabled for: Advanced Features 2. | 2023-10-10 15:12:29.413
Enabled for: Sierra Chart Historical Data Service. | 2023-10-10 15:12:29.413
Enabled for: Denali Real-Time Exchange Data Feed. | 2023-10-10 15:12:29.413
Enabled for: Delayed Denali Exchange Data Feed. | 2023-10-10 15:12:29.413
Enabled for exchange2: CME | 2023-10-10 15:12:29.413
Enabled for exchange2: fairx_exchange.data | 2023-10-10 15:12:29.413
Allow Support for Sierra Chart Data Feeds is enabled. | 2023-10-10 15:12:29.413
Current selected Data/Trading service: Interactive Brokers | 2023-10-10 15:12:29.413
Custom symbol settings values: enabled | 2023-10-10 15:12:29.413
Chart Update Interval: 10 | 2023-10-10 15:12:29.413
Intraday Data Storage Time Unit: 0 | 2023-10-10 15:12:29.413
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2023-10-10 15:12:29.413
2023-10-10 19:12:29 Local computer time in UTC | 2023-10-10 15:12:29.413
2023-10-10 15:12:29 Local computer time in SC Time Zone | 2023-10-10 15:12:29.413
2023-10-10 11:32:17 Server time in UTC | 2023-10-10 15:12:29.413
Local computer UTC time and Server UTC time difference: 1 seconds. | 2023-10-10 15:12:29.413
Program path: C:\SierraChart\ | 2023-10-10 15:12:29.413
Data Files path: C:\SierraChart\Data\ | 2023-10-10 15:12:29.413
OS Version Number: 10.0 | 2023-10-10 15:12:29.413
Locale Setting: C | 2023-10-10 15:12:29.413
DLLs: UserContributedStudies_64.dll | 2023-10-10 15:12:29.414
Allowed protected custom studies: | 2023-10-10 15:12:29.414
Crash reporter started: true | 2023-10-10 15:12:29.414
ES-202312-CME 1 Min #1 | Reloading chart. | 2023-10-10 15:13:26.786
Mapping ES-202312-CME to ESZ23. Service code: cme | 2023-10-10 15:13:26.826
Denali Data Feed | Starting real-time market data updates for: ES-202312-CME (ESZ23). ID: 8 Service code: cme | 2023-10-10 15:13:26.826
Denali Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10048 | 2023-10-10 15:13:26.826
Denali Data Feed | Requesting security definition data for: ES-202312-CME (ESZ23). ID: 8 | 2023-10-10 15:13:26.826
Added historical Intraday data request for ES-202312-CME to the queue. | 2023-10-10 15:13:26.827
Intraday data recording state for symbol ES-202312-CME is set to download 'Pending'. | 2023-10-10 15:13:26.827
Triggering next historical data download in queue. | 2023-10-10 15:13:26.827
Delaying start of download for ES-202312-CME. | 2023-10-10 15:13:26.835
DTC Client socket (1) | Creating socket. | 2023-10-10 15:13:26.858
DTC Client socket (1) | New receive buffer size: 0 | 2023-10-10 15:13:26.858
DTC Client socket (1) | Connecting to IP: 142.215.17.187. | 2023-10-10 15:13:26.858
Denali Data Feed | Network connection to server complete. | 2023-10-10 15:13:26.981
Denali Data Feed | Starting socket receive thread. | 2023-10-10 15:13:26.981
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-10-10 15:13:26.981
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-10-10 15:13:27.130
Denali Data Feed | Sending logon request message. | 2023-10-10 15:13:27.130
Denali Data Feed | Received logon response. | 2023-10-10 15:13:27.979
Denali Data Feed | Server Name: SC Realtime Server. | 2023-10-10 15:13:27.979
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-10-10 15:13:27.979
Denali Data Feed | Successfully connected. | 2023-10-10 15:13:27.979
Denali Data Feed | Trading is not supported. | 2023-10-10 15:13:27.979
Denali Data Feed | Restarting real-time data updates for symbol: ES-202312-CME -> ESZ23 | 2023-10-10 15:13:27.979
Denali Data Feed | Received security definition for symbol ES-202312-CME | 2023-10-10 15:13:28.197
HD Request # 50 | Downloading Intraday chart data for ES-202312-CME to the file ES-202312-CME.scid. Service: cme | 2023-10-10 15:13:33.848
HD Request # 50 | Download start date-time: 2023-09-22 16:59:30.000000. File last date-time: 2023-09-22 16:59:30.000000 | 2023-10-10 15:13:33.849
HD Request # 50 | Using server: ds26.sierracharts.com port 10149 | 2023-10-10 15:13:33.849
Socket (3) | Creating socket. | 2023-10-10 15:13:33.884
Socket (3) | New receive buffer size: 0 | 2023-10-10 15:13:33.884
Socket (3) | Connecting to IP: 142.215.17.188. | 2023-10-10 15:13:33.884
HD Request # 50 | Setting DTC encoding to Binary VLS | 2023-10-10 15:13:34.134
HD Request # 50 | Sending historical data logon request message. | 2023-10-10 15:13:34.134
HD Request # 50 | Requesting Intraday data. Start date-time: 2023-09-22 16:59:30. Record interval: 0. Symbol: ESZ23 | 2023-10-10 15:13:34.728
HD Request # 50 | Decompressing data. | 2023-10-10 15:13:34.845
HD Request # 50 | Receiving Intraday data for ES-202312-CME starting at 2023-09-22 16:59:30.025000 | 2023-10-10 15:13:34.978
HD Request # 50 | Timestamp of first Intraday data file record written: 2023-09-22 16:59:30.025000. | 2023-10-10 15:13:35.338
File >> Disconnect selected. | 2023-10-10 15:14:24.290
IB TWS socket (2) | CloseSocket call. | 2023-10-10 15:14:24.290
Denali Data Feed | Waiting for socket receive thread to end | 2023-10-10 15:14:24.290
IB TWS socket (2) | Shutdown started. Waiting for graceful close. | 2023-10-10 15:14:24.290
DTC Client socket (1) | CloseSocket call. | 2023-10-10 15:14:24.290
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-10-10 15:14:24.290
Denali Data Feed | Disconnected from the server. | 2023-10-10 15:14:24.290
Interactive Brokers | Disconnected. | 2023-10-10 15:14:24.290
HD Request # 50 | Active download canceled. | 2023-10-10 15:14:24.290
Historical data download thread signaled to stop. | 2023-10-10 15:14:24.290
Socket (3) | CloseSocket call. | 2023-10-10 15:14:24.290
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-10-10 15:14:24.291
IB TWS socket (2) | Socket gracefully closed by remote side. | 2023-10-10 15:14:24.291
IB TWS socket (2) | Closed. | 2023-10-10 15:14:24.291
HD Request # 50 | Received 14637679 Intraday data records from 2023-09-22 16:59:30.025000 to 2023-10-10 09:39:23.825013 (17.7 days. Delay: 5.6 hours) and wrote 14637679 records for ES-202312-CME | 2023-10-10 15:14:24.292
HD Request # 50 | Completion time: 51s. | 2023-10-10 15:14:24.292
HD Request # 50 | Intraday data download complete for ES-202312-CME. Unique request ID: 50 | 2023-10-10 15:14:24.292
Removing historical data download ID 50. | 2023-10-10 15:14:24.292
Real-time Intraday chart data file updates started for ES-202312-CME | 2023-10-10 15:14:24.292
Intraday chart data file opened for ES-202312-CME | 2023-10-10 15:14:24.292
HD Request # 50 | Enabling Intraday chart updating for symbol. | 2023-10-10 15:14:24.292
Triggering next historical data download in queue. | 2023-10-10 15:14:24.292
No download requests in the queue to start downloads for. | 2023-10-10 15:14:24.292
Socket (3) | Socket gracefully closed by remote side. | 2023-10-10 15:14:24.469
Socket (3) | Closed. | 2023-10-10 15:14:24.469
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-10-10 15:14:24.524
DTC Client socket (1) | Closed. | 2023-10-10 15:14:24.525
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-10-10 15:14:29.393
IB TWS socket (1) | Creating socket. | 2023-10-10 15:14:29.393
IB TWS socket (1) | New receive buffer size: 0 | 2023-10-10 15:14:29.393
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-10-10 15:14:29.393
Interactive Brokers | Sending API sign: API | 2023-10-10 15:14:29.897
Interactive Brokers | Sending client version: v100..176 +PACEAPI. Waiting for acceptance. | 2023-10-10 15:14:29.897
Interactive Brokers | TWS server version: 176 | 2023-10-10 15:14:29.901
Interactive Brokers | TWS time: 20231010 15:14:30 EST | 2023-10-10 15:14:29.901
Interactive Brokers | Connected. Sending Start API command. | 2023-10-10 15:14:30.161
Interactive Brokers | Waiting for account information. | 2023-10-10 15:14:30.161
Interactive Brokers | Next valid order ID: 450 | 2023-10-10 15:14:30.164
IB Account information received. | 2023-10-10 15:14:30.164
Interactive Brokers | Received 1 Trade Accounts from TWS. | 2023-10-10 15:14:30.164
Interactive Brokers | Connected to Live account. | 2023-10-10 15:14:30.164
Updated verified funded futures trading account ending date to: 2023-11-09 19:14:30 | 2023-10-10 15:14:30.164
Interactive Brokers | Connected to server complete. | 2023-10-10 15:14:30.164
Triggering next historical data download in queue. | 2023-10-10 15:14:30.165
Subscribing to symbol for symbol alert. MCLV23-NYMEX | 2023-10-10 15:14:30.165
Using symbol data fast lookup vector | 2023-10-10 15:14:30.165
Interactive Brokers | Starting real-time market data updates for: MCLV23-NYMEX. ID: 1 | 2023-10-10 15:14:30.165
Interactive Brokers | Subscribing to Symbol: MCLV23, SecurityType: NYMEX, Expiration: , Exchange: , Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2023-10-10 15:14:30.165
Interactive Brokers | Requesting security definition data for: MCLV23-NYMEX. ID: 1 | 2023-10-10 15:14:30.165
Updated verified funded futures trading account ending date to: 2023-11-09 19:14:30 | 2023-10-10 15:14:30.165
Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2023-10-10 15:14:30.165
Message from IB: Market data farm connection is OK:uscrypto. IB Error Code: 2104. Request ID: -1. | 2023-10-10 15:14:30.165
Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2023-10-10 15:14:30.165
Message from IB: Market data farm connection is OK:usfuture.nj. IB Error Code: 2104. Request ID: -1. | 2023-10-10 15:14:30.165
Message from IB: Market data farm connection is OK:usbond. IB Error Code: 2104. Request ID: -1. | 2023-10-10 15:14:30.165
Message from IB: Market data farm connection is OK:usfarm.nj. IB Error Code: 2104. Request ID: -1. | 2023-10-10 15:14:30.165
Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2023-10-10 15:14:30.165
Message from IB: Market data farm connection is OK:usopt. IB Error Code: 2104. Request ID: -1. | 2023-10-10 15:14:30.165
Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2023-10-10 15:14:30.165
Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2023-10-10 15:14:30.165
Message from IB: HMDS data farm connection is OK:ushmds.nj. IB Error Code: 2106. Request ID: -1. | 2023-10-10 15:14:30.165
Message from IB: HMDS data farm connection is OK:cashhmds. IB Error Code: 2106. Request ID: -1. | 2023-10-10 15:14:30.165
Message from IB: HMDS data farm connection is OK:fundfarm. IB Error Code: 2106. Request ID: -1. | 2023-10-10 15:14:30.165
Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2023-10-10 15:14:30.165
Message from IB: Sec-def data farm connection is OK:secdefeu. IB Error Code: 2158. Request ID: -1. | 2023-10-10 15:14:30.165
No download requests in the queue to start downloads for. | 2023-10-10 15:14:30.165
Message from IB: Error validating request.-'b1' : cause - Please enter exchange. IB Error Code: 321. Request ID: 1. Symbol: MCLV23-NYMEX | 2023-10-10 15:14:30.166
Message from IB: Error validating request.-'bV' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 1. Symbol: MCLV23-NYMEX | 2023-10-10 15:14:30.166
Interactive Brokers | Starting real-time market data updates for: APLD. ID: 2 | 2023-10-10 15:14:30.166
Interactive Brokers | Subscribing to Symbol: APLD, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2023-10-10 15:14:30.166
Interactive Brokers | Requesting security definition data for: APLD. ID: 2 | 2023-10-10 15:14:30.166
Interactive Brokers | Starting real-time market data updates for: DIS. ID: 3 | 2023-10-10 15:14:30.166
Interactive Brokers | Subscribing to Symbol: DIS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2023-10-10 15:14:30.166
Interactive Brokers | Requesting security definition data for: DIS. ID: 3 | 2023-10-10 15:14:30.166
Interactive Brokers | Starting real-time market data updates for: HYDI. ID: 4 | 2023-10-10 15:14:30.166
Interactive Brokers | Subscribing to Symbol: HYDI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2023-10-10 15:14:30.166
Interactive Brokers | Requesting security definition data for: HYDI. ID: 4 | 2023-10-10 15:14:30.166
Interactive Brokers | Starting real-time market data updates for: IBKR. ID: 5 | 2023-10-10 15:14:30.166
Interactive Brokers | Subscribing to Symbol: IBKR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2023-10-10 15:14:30.166
Interactive Brokers | Requesting security definition data for: IBKR. ID: 5 | 2023-10-10 15:14:30.166
Interactive Brokers | Starting real-time market data updates for: LTCH. ID: 6 | 2023-10-10 15:14:30.166
Interactive Brokers | Subscribing to Symbol: LTCH, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2023-10-10 15:14:30.166
Interactive Brokers | Requesting security definition data for: LTCH. ID: 6 | 2023-10-10 15:14:30.166
Interactive Brokers | Starting real-time market data updates for: S. ID: 7 | 2023-10-10 15:14:30.166
Interactive Brokers | Subscribing to Symbol: S, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2023-10-10 15:14:30.166
Interactive Brokers | Requesting security definition data for: S. ID: 7 | 2023-10-10 15:14:30.166
Mapping ES-202312-CME to ESZ23. Service code: cme | 2023-10-10 15:14:30.177
Denali Data Feed | Starting real-time market data updates for: ES-202312-CME (ESZ23). ID: 8 Service code: cme | 2023-10-10 15:14:30.177
Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048 | 2023-10-10 15:14:30.177
Denali Data Feed | Requesting security definition data for: ES-202312-CME (ESZ23). ID: 8 | 2023-10-10 15:14:30.177
Added historical Intraday data request for ES-202312-CME to the queue. | 2023-10-10 15:14:30.177
Intraday data recording state for symbol ES-202312-CME is set to download 'Pending'. | 2023-10-10 15:14:30.177
Triggering next historical data download in queue. | 2023-10-10 15:14:30.177
Delaying start of download for ES-202312-CME. | 2023-10-10 15:14:30.189
DTC Client socket (2) | Creating socket. | 2023-10-10 15:14:30.214
DTC Client socket (2) | New receive buffer size: 0 | 2023-10-10 15:14:30.214
DTC Client socket (2) | Connecting to IP: 142.215.18.148. | 2023-10-10 15:14:30.214
Interactive Brokers | Next valid order ID: 450 | 2023-10-10 15:14:30.266
Denali Data Feed | Network connection to server complete. | 2023-10-10 15:14:30.334
Denali Data Feed | Starting socket receive thread. | 2023-10-10 15:14:30.334
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-10-10 15:14:30.334
Interactive Brokers | Next valid order ID: 450 | 2023-10-10 15:14:30.365
Interactive Brokers | Requesting Trade Positions snapshot and updates for account: U104* | 2023-10-10 15:14:30.410
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-10-10 15:14:30.479
Denali Data Feed | Sending logon request message. | 2023-10-10 15:14:30.479
Interactive Brokers | Begin Trade Positions processing. | 2023-10-10 15:14:31.267
Interactive Brokers | Sending request for contract details for contract ID 499640681 | 2023-10-10 15:14:31.267
Interactive Brokers | Sending request for contract details for contract ID 399364021 | 2023-10-10 15:14:31.267
Interactive Brokers | Sending request for contract details for contract ID 366244320 | 2023-10-10 15:14:31.267
Interactive Brokers | Sending request for contract details for contract ID 375858281 | 2023-10-10 15:14:31.267
Interactive Brokers | Received Trade Positions download end message for account U104* | 2023-10-10 15:14:31.267
Interactive Brokers | Received Trade Positions. Performing final processing. | 2023-10-10 15:14:31.267
Denali Data Feed | Received logon response. | 2023-10-10 15:14:31.301
Denali Data Feed | Server Name: SC Realtime Server. | 2023-10-10 15:14:31.301
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-10-10 15:14:31.301
Denali Data Feed | Successfully connected. | 2023-10-10 15:14:31.301
Denali Data Feed | Trading is not supported. | 2023-10-10 15:14:31.301
Denali Data Feed | Restarting real-time data updates for symbol: ES-202312-CME -> ESZ23 | 2023-10-10 15:14:31.301
Interactive Brokers | Received contract details for symbol S-STK-SMART-USD | 2023-10-10 15:14:31.366
Interactive Brokers | Received contract details for symbol VUAA-STK-SMART-EUR | 2023-10-10 15:14:31.466
Denali Data Feed | Received security definition for symbol ES-202312-CME | 2023-10-10 15:14:31.508
Interactive Brokers | Received contract details for symbol VUKG-STK-SMART-GBP | 2023-10-10 15:14:31.566
Interactive Brokers | Received contract details for symbol VWCE-STK-SMART-EUR | 2023-10-10 15:14:31.666
Interactive Brokers | All contract details received for symbols used for trading. Starting timer to request trading data. | 2023-10-10 15:14:31.666
HD Request # 51 | Downloading Intraday chart data for ES-202312-CME to the file ES-202312-CME.scid. Service: cme | 2023-10-10 15:14:36.856
HD Request # 51 | Download start date-time: 2023-10-10 09:39:23.000000. File last date-time: 2023-10-10 09:39:23.825013 | 2023-10-10 15:14:36.857
HD Request # 51 | Using server: ds28.sierracharts.com port 10150 | 2023-10-10 15:14:36.857
Socket (3) | Creating socket. | 2023-10-10 15:14:36.889
Socket (3) | New receive buffer size: 0 | 2023-10-10 15:14:36.889
Socket (3) | Connecting to IP: 142.215.18.147. | 2023-10-10 15:14:36.889
HD Request # 51 | Setting DTC encoding to Binary VLS | 2023-10-10 15:14:37.128
HD Request # 51 | Sending historical data logon request message. | 2023-10-10 15:14:37.128
HD Request # 51 | Requesting Intraday data. Start date-time: 2023-10-10 09:39:23. Record interval: 0. Symbol: ESZ23 | 2023-10-10 15:14:37.723
HD Request # 51 | Decompressing data. | 2023-10-10 15:14:37.838
HD Request # 51 | Receiving Intraday data for ES-202312-CME starting at 2023-10-10 09:39:23.018000 | 2023-10-10 15:14:38.101
HD Request # 51 | Timestamp of first Intraday data file record written: 2023-10-10 09:39:23.825014. | 2023-10-10 15:14:38.456
Socket (3) | CloseSocket call. | 2023-10-10 15:14:40.839
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-10-10 15:14:40.839
Historical data download thread signaled to stop. | 2023-10-10 15:14:40.839
HD Request # 51 | Received 719297 Intraday data records from 2023-10-10 09:39:23.018000 to 2023-10-10 15:14:40.704000 (5.6 hours. Delay: 0.1 seconds) and wrote 719196 records for ES-202312-CME | 2023-10-10 15:14:40.839
HD Request # 51 | Completion time: 4s. | 2023-10-10 15:14:40.839
HD Request # 51 | Intraday data download complete for ES-202312-CME. Unique request ID: 51 | 2023-10-10 15:14:40.839
Removing historical data download ID 51. | 2023-10-10 15:14:40.839
Real-time Intraday chart data file updates started for ES-202312-CME | 2023-10-10 15:14:40.839
Intraday chart data file opened for ES-202312-CME | 2023-10-10 15:14:40.839
HD Request # 51 | Enabling Intraday chart updating for symbol. | 2023-10-10 15:14:40.839
Triggering next historical data download in queue. | 2023-10-10 15:14:40.839
No download requests in the queue to start downloads for. | 2023-10-10 15:14:40.839
Socket (3) | Socket gracefully closed by remote side. | 2023-10-10 15:14:40.956
Socket (3) | Closed. | 2023-10-10 15:14:40.956
Interactive Brokers | Stopping automatic Trade Position updates for account: U104* | 2023-10-10 15:14:41.655
Interactive Brokers | Requesting Trade Positions snapshot and updates for account: U104* | 2023-10-10 15:14:41.655
Message from IB: API client has been unsubscribed from account data. IB Error Code: 2100. Request ID: -1. | 2023-10-10 15:14:41.755
Interactive Brokers | Begin Trade Positions processing. | 2023-10-10 15:14:41.856
Interactive Brokers | Received Trade Positions download end message for account U104* | 2023-10-10 15:14:41.857
Interactive Brokers | Received Trade Positions. Performing final processing. | 2023-10-10 15:14:41.857
Opened cached Intraday file: C:\SierraChart\Data\ES-202312-CME.scid. Thread ID: 11268 | 2023-10-10 15:14:44.873
[2023-10-10 19:25:46]
John - SC Support - Posts: 36309
You have the correct symbol for the ES (ES-202312-CME), but not for MCL (MCLV23-NYMEX).
To start, open your Chartbooks and select "Edit >> Translate Symbols to Current Service". This will change the symbols to what is needed for Interactive Brokers.
Then, the next issue is that you are not setup to get real-time data from us for the MCL, which is traded on the NYMEX exchange of the CME Group. Right now you have only the "CME with Market Depth for Non-Professional Trading Acounts" exchange active, so you are only setup to get real-time data for the CME exchange of the CME Group. If you want the Market Depth for MCL, then you would want to activate the "NYMEX with Market Depth for Non-Professional Trading Accounts" to get this data.
If you do not want the Market Depth data for that exchange, then activate the "NYMEX Top-of-Book for Non-Professional Trading Accounts".
You can adjust your exchange selections at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
[2023-10-10 19:33:33]
elster - Posts: 4
Thank you. That is one issue fixed.
The other issue was when I changed the data to point back to interactive Brokers.
I have resolved this, just now. I need to go into the symbol and reselect it again for this to load. This then is giving me the DOM from IBKR and full data.
I'll monitor this to make sure, but the data seems to match up whereas before the IBKR data was not showing the correct volume.
