Date/Time: Wed, 27 Nov 2024 02:41:59 +0000
Traded 5 MNQ but DOM increments were in $5.00 each, which is equivalent to 10 MNQ
View Count: 254
[2023-09-26 17:16:58]
HansB - Posts: 3
Hello SC Support,
I entered a long today 14877.25 in MNQ, 5 contracts. Service Order ID 2266517. Even though the position was 5 MNQ, the P&L increment was $5.00/tick, which would be for 10 MNQ, not for 5 MNQ.
I then took a loss on the trade, getting stopped out at 14,854.50. Same Service Order ID 2266517. This should have resulted in a loss of 22.75 points. But if you look at the 1st screenshot I have attached, my stop out lost me double this amount, equal to 45.5 pts, as if I was trading 10 MNQ. The 2nd screenshot shows the time stamps for the entry and the exit.
I had similar trade occurs for two more trades, where I traded 1 MNQ but the DOM was calculating as if I had 2 MNQ. The end result was similar - I had real losses as if I was trading 2X the number of contracts.
Could you please take a look? Thanks for your help.
Private File
Private File
[2023-09-26 18:12:33]
John - SC Support - Posts: 36309
Check the "Chart >> Symbol >> Currency Value per Tick" and ensure that it is set to 0.50.
