Date/Time: Wed, 27 Nov 2024 03:43:56 +0000
Candle wicks
View Count: 403
[2023-09-26 16:45:03] |
User478380 - Posts: 184 |
Hi Please see attached file Thanks |
[2023-09-26 18:10:20] |
John - SC Support - Posts: 36309 |
To change the colors of part of the candlestick for a Heikin-Ashi study, you need to change the Subgraphs for the Heikin-Ashi study itself. In this particular case, you want to change the Primary color for the "Low" subgraph. This will change the wicks and the outline for the candle. You can also change the "Size/Width" to adjust the width of the outline. The width of the wicks is controlled by the "Last" width setting (but not the color). Refer to the following: Chart Studies: Subgraphs Tab >> Color For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-26 18:43:28] |
Hi, Not entirely sure what I need to change in the attached screen... |
ha bars.png / V - Attached On 2023-09-26 18:43:23 UTC - Size: 41.77 KB - 79 views |
[2023-09-26 20:10:02] |
Select the "HA Low" subgraph and you will see two color squares. Change the one to the left to change the color of the wicks and outline of the down candlesticks.
For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-09-26 20:10:20
[2023-09-26 21:48:13] |
no change see attached pls |
wicks 2.png / V - Attached On 2023-09-26 21:48:07 UTC - Size: 82.91 KB - 73 views |
[2023-09-27 14:13:48] |
Do you have another study on the chart that could be affecting the way the colors of the candlesticks is drawn?
[2023-09-27 14:19:26] |
I have other studies but none that I think affect the bar colour. Is there a way of determining what studies affect bar colour in the list I have please ? Thanks
[2023-09-27 15:41:14] |
Please attach a copy of the chart to this thread and we will take a look. Follow these instructions to do this: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
