Date/Time: Tue, 26 Nov 2024 04:47:09 +0000
Customized Buttons
View Count: 367
[2023-09-25 08:23:16] |
Tin43 - Posts: 90 |
I customized some buttons. Horizontal rays with specific colors, text, etc and some other tools in general.. What I want to do is to eliminate my configurations, my buttons, and reset the values for each tool to default. I want to start fresh. Apologies for my English. Thanks in advance. |
[2023-09-25 17:15:46] |
John - SC Support - Posts: 36286 |
There really is not a "fast" way to remove all the customized Control Bar buttons. You would have to go to the "Global Settings >> Customize Control Bars >> Control Bar x" and then remove the buttons from that control bar that you no longer want. If you want the default settings for a particular control bar, then add it back from the list on the left. You would have to do this for each control bar that you have customized buttons on. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-25 17:26:59] |
Tin43 - Posts: 90 |
I understood what you said but that it's not what i want. I did that and yes, all buttons disappeared.. but the configurations of the drawings tools still there.. I want that to set to default. For example Custom Drawing Tool 1 -- CDT1 and not PDH (Previous Day High that I named) And every time I select the Horizontal Ray is a ray with a specific width, color and a text attached to it... I want to set all to default. sorry if I explained me wrong from before. |
[2023-09-25 21:47:00] |
Sierra_Chart Engineering - Posts: 17179 |
There is not a way to do this. Unless you delete the entire global configuration file in Sierra Chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-09-25 21:47:17
[2023-12-28 20:02:59] |
User45989 - Posts: 54 |
Is there no way to edit the configuration of any of the Custom Drawing Tools?
Date Time Of Last Edit: 2023-12-28 20:05:06
[2023-12-28 20:30:23] |
You can edit the configurations of Drawing Tools. There is just not a way to set them to a "Default", except by editing each one. If you are asking about something else, then please give us more information. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-28 20:55:54] |
I am looking to edit the configuration of a CDT - what you see in the menu when you are assigning a CDT to a button for example - how would I change the tool and settings that CDT1 is using?
[2023-12-28 21:23:14] |
After adding the "Custom Drawing Tool" to the right side, select the "Set Custom Tool" button on the bottom. Refer to the instructions here: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
