Date/Time: Wed, 27 Nov 2024 03:40:34 +0000
Missing NG Spread
View Count: 427
[2023-09-22 19:32:29]
User664240 - Posts: 206
Your Missing NGV-NGX 2023 form NGV-NGX23
imageice_screenshot_20230922-152457.png / V - Attached On 2023-09-22 19:31:50 UTC - Size: 10.87 KB - 78 views
[2023-09-23 12:55:47]
Is there a fix forthcoming as it's imperative this is rectified prior to Sunday's open as the October contract sets prices for the following month across the country for physical NG deliveries. Please let me know what your timeline is if any so I can plan accordingly.
[2023-09-23 17:57:43]
Sierra_Chart Engineering - Posts: 17190
What is the exact problem you are having? We see a chart for this spread:
https://www.sierrachart.com/image.php?Image=1695491819281.png
Also, it does not make sense for spread data to be missing. That is not something that can ever happen. There is nothing that would ever have to be fixed. The data is always going to be available.
[2023-09-23 19:58:57]
Perhaps you did not read my text, and just looked at the spread I highlighted in my uploaded image.being that it's not possible to highlight something that's missing I was hoping you would clearly see what was missing(NGV23-NGX23.FUT_SPREAD_NYMEX)after reading my text.
In short the list should be...
OCT23_OCT26
OCT23-NOV23
OCT23-NOV24
OCT23-NOV25
NOT -------------
OCT23-OCT26
OCT23-NOV24
OCT23-NOV25
(See Crude oil uploaded image as an example or look again at the NG image December contracts You will see the OCT-DEC chain begins with NGV23-NGZ23 not NGV23-NGZ24.
More Specifically with the correct symbols
NGV23-NGV26 (END OF THE OCT-OCT CHAIN Now OCT-NOV should begin with NOV 2023 not NOV 2024)
NGV23-NGX23....This is the missing spread
Date Time Of Last Edit: 2023-09-23 22:41:57
imageice_screenshot_20230923-084346.png / V - Attached On 2023-09-23 19:58:42 UTC - Size: 6.36 KB - 68 views
[2023-09-24 20:37:22]
SC support PLEASE give this your utmost attention as the Market will be opening in 1.5hrs.
[2023-09-24 20:52:02]
Do you see it in this file:
ftp://ftp.cmegroup.com/SBEFix/Production/secdef.dat.gz
We are checking.
[2023-09-24 20:54:17]
CME does not have:
NGV3-NGX3
You can check yourself. They use single digit years.
Date Time Of Last Edit: 2023-09-24 20:54:33
[2023-09-24 20:56:23]
They do have TAS symbols:
NGTV3-NGTX3
[2023-09-25 00:11:14]
I'm not sure what this means or what your point is here.
CME does not have:
NGV3-NGX3
Basically your saying if they don't have it then it doesn't exist??
Why not follow up with the CME as the spread definitively exist which is clearly illustrated by the TAS contract which can't exist with out the underlying.
Well I took it upon myself to call the GCC to further aid me in illustrating to you that SC is not properly accessing the symbols from the file you reverenced and I know that because I'm seeing it correctly displayed in two separate DATA sources.
Tom from the CME graciously check the security file you referenced and has sent me the following excerpt clearly showing the spread
Hello William,
Thank you for contacting the CME Global Command Center (GCC).
NGV23-NGX23
Instrument from the security definition file provided below:
35=d | 5799=00000000 | 980=A | 779=20230924110514000721 | 1180=386 | 1300=78 | 462=16 | 207=XNYM | 1151=NG | 6937=NG | 55=NGV23-NGX23 | 48=194132 | 22=8 | 167=FUT | 461=FMMXSX | 200=202310 | 15=USD | 762=SP | 9779=N | 1142=F | 562=1 | 1140=1999 | 969=1.000000000 | 9787=0.001000000 | 996=CTRCT | 1150=-242.000000000 | 731=00000011 | 5796=20230922 | 1143=25.000000000 | 864=2 | 865=5 | 1145=20191031213000000000 | 865=7 | 1145=20230927183000000000 | 1141=2 | 1022=GBX | 264=10 | 1022=GBI | 264=2 | 870=1 | 871=24 | 872=00000000000011000010010000000011 | 1234=0 | 555=2 | 602=108278 | 603=8 | 624=1 | 623=1 | 602=150611 | 603=8 | 624=2 | 623=1 |
He suggested if you have further issues to call the GCC desk and they will help resolve this..
GCC in the U.S. at +1 800 438 8616,
Date Time Of Last Edit: 2023-09-25 00:12:48
[2023-09-25 03:49:25]
We are looking into this now.
The symbols are definitely faulty on the CME side. That particular symbol uses a two digit year from the CME which we have not seen before and all of the other NG contracts do not:
You can see the actual data here:
35=d5799=00000000980=A779=202309241105050002211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV2748=8822=8167=FUT461=FCMXSX200=20271015=USD1142=F562=11140=1999969=1.0000000009787=0.001000000996=MMBTU1147=10000.0000000001150=3777.000000000731=000000115796=202309221148=1.0000000001143=50.0000000001146=10.0000000009779=N864=2865=51145=20141125223000000000865=71145=202709281830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100000000001111234=05792=1231
35=d5799=00000000980=A779=202309241105070006711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV2548=86922=8167=FUT461=FCMXSX200=20251015=USD1142=F562=11140=1999969=1.0000000009787=0.001000000996=MMBTU1147=10000.0000000001150=3879.000000000731=000000115796=202309221148=1.0000000001143=50.0000000001146=10.0000000009779=N864=2865=51145=20121128223000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100000000001111234=05791=3455792=10648
35=d5799=00000000980=A779=202309241105080008711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV448=93522=8167=FUT461=FCMXSX200=20241015=USD1142=F562=11140=1999969=1.0000000009787=0.001000000996=MMBTU1147=10000.0000000001150=3362.000000000731=000000115796=202309221148=1.0000000001143=50.0000000001146=10.0000000009779=N864=2865=51145=20111128223000000000865=71145=202409261830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100000000001111234=05791=64105792=45515
35=d5799=00000000980=A779=202309241105060000711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV2648=97322=8167=FUT461=FCMXSX200=20261015=USD1142=F562=11140=1999969=1.0000000009787=0.001000000996=MMBTU1147=10000.0000000001150=3869.000000000731=000000115796=202309221148=1.0000000001143=50.0000000001146=10.0000000009779=N864=2865=51145=20131126223000000000865=71145=202609281830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100000000001111234=05791=115792=2002
35=d5799=00000000980=A779=202309241105100003211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV2848=253322=8167=FUT461=FCMXSX200=20281015=USD1142=F562=11140=1999969=1.0000000009787=0.001000000996=MMBTU1147=10000.0000000001150=3700.000000000731=000000115796=202309221148=1.0000000001143=50.0000000001146=10.0000000009779=N864=2865=51145=20151125223000000000865=71145=202809271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100000000001111234=05792=667
35=d5799=00000000980=A779=202309241105070002211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3248=329022=8167=FUT461=FCMXSX200=20321015=USD1142=F562=11140=1999969=1.0000000009787=0.001000000996=MMBTU1147=10000.0000000001150=3740.000000000731=000000115796=202309221148=1.0000000001143=50.0000000001146=10.0000000009779=N864=2865=51145=20191126223000000000865=71145=203209281830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100000000001111234=05792=2
35=d5799=00000000980=A779=202309241105080009711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3448=379122=8167=FUT461=FCMXSX200=20341015=USD1142=F562=11140=1999969=1.0000000009787=0.001000000996=MMBTU1147=10000.0000000001150=3993.000000000731=000000115796=202309221148=1.0000000001143=50.0000000001146=10.0000000009779=N864=2865=51145=20211126223000000000865=71145=203409271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100000000001111234=0
35=d5799=00000000980=A779=202309241105150008211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV34-HHV3448=1093322=8167=FUT461=FMMXSX200=20341015=USD762=RI9779=N1142=F562=11140=999969=0.2500000009787=0.001000000996=MMBTU1150=0.000000000731=000000115796=202309221143=100.000000000864=2865=51145=20211126223000000000865=71145=203409271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=3791603=8624=1623=1602=2784603=8624=2623=1
35=d5799=00000000980=A779=202309241105070001711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3348=1353122=8167=FUT461=FCMXSX200=20331015=USD1142=F562=11140=1999969=1.0000000009787=0.001000000996=MMBTU1147=10000.0000000001150=3874.000000000731=000000115796=202309221148=1.0000000001143=50.0000000001146=10.0000000009779=N864=2865=51145=20201125223000000000865=71145=203309281830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100000000001111234=0
35=d5799=00000000980=A779=202309241105050002711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3548=1507622=8167=FUT461=FCMXSX200=20351015=USD1142=F562=11140=1999969=1.0000000009787=0.001000000996=MMBTU1147=10000.0000000001150=4252.000000000731=000000115796=202309221148=1.0000000001143=50.0000000001146=10.0000000009779=N864=2865=51145=20221128223000000000865=71145=203509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100000000001111234=0
35=d5799=00000000980=A779=202309241105160003211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV32-HHV3248=1971722=8167=FUT461=FMMXSX200=20321015=USD762=RI9779=N1142=F562=11140=999969=0.2500000009787=0.001000000996=MMBTU1150=0.000000000731=000000115796=202309221143=100.000000000864=2865=51145=20191126223000000000865=71145=203209281830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=3290603=8624=1623=1602=2190603=8624=2623=1
35=d5799=00000000980=A779=202309241105080002711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3148=2094422=8167=FUT461=FCMXSX200=20311015=USD1142=F562=11140=1999969=1.0000000009787=0.001000000996=MMBTU1147=10000.0000000001150=3685.000000000731=000000115796=202309221148=1.0000000001143=50.0000000001146=10.0000000009779=N864=2865=51145=20181128223000000000865=71145=203109261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100000000001111234=05792=4
35=d5799=00000000980=A779=202309241105140008211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV33-HHV3348=2384722=8167=FUT461=FMMXSX200=20331015=USD762=RI9779=N1142=F562=11140=999969=0.2500000009787=0.001000000996=MMBTU1150=0.000000000731=000000115796=202309221143=100.000000000864=2865=51145=20201125223000000000865=71145=203309281830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=13531603=8624=1623=1602=11212603=8624=2623=1
35=d5799=00000000980=A779=202309241105180000711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NNV348=2679822=8167=FUT461=FMMXSX200=20231015=USD762=AE9779=N1142=F562=11140=1999969=0.2500000009787=0.001000000996=MMBTU1150=0.000000000731=000000115796=202309221143=10.000000000864=2865=51145=20211001213000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=8602=785498603=8624=2623=1
35=d5799=00000000980=A779=202309241105130004711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGX648=2728222=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1596.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20221101213000000000865=71145=202309271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=108278603=8624=1623=1602=967603=8624=2623=1
35=d5799=00000000980=A779=202309241105180008711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGG748=2752522=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-806.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230201223000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=477603=8624=2623=1
35=d5799=00000000980=A779=202309241105110002211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGF748=3792422=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1512.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230103223000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=1804603=8624=2623=1
35=d5799=00000000980=A779=202309241105130001711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGV648=3833122=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=10.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220721213000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=973603=8624=2623=1
35=d5799=00000000980=A779=202309241105140002211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGM548=3886422=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1001.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20210601213000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=885603=8624=2623=1
35=d5799=00000000980=A779=202309241105110001211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGH648=4273522=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-271.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220301223000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=1021603=8624=2623=1
35=d5799=00000000980=A779=202309241105160009211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGG748=4415222=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1323.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230201223000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=477603=8624=2623=1
35=d5799=00000000980=A779=202309241105110000711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV6-NGG748=4610822=8167=FUT461=FMMXSX200=20261015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-816.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230201223000000000865=71145=202609281830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=973603=8624=1623=1602=477603=8624=2623=1
35=d5799=00000000980=A779=202309241105120006211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV31-HHV3148=4894922=8167=FUT461=FMMXSX200=20311015=USD762=RI9779=N1142=F562=11140=999969=0.2500000009787=0.001000000996=MMBTU1150=0.000000000731=000000115796=202309221143=100.000000000864=2865=51145=20181128223000000000865=71145=203109261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=20944603=8624=1623=1602=25368603=8624=2623=1
35=d5799=00000000980=A779=202309241105130007711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGH448=5730622=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-577.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20200228223000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=950603=8624=2623=1
35=d5799=00000000980=A779=202309241105110003711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGG748=6080722=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-2048.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230201223000000000865=71145=202309271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=108278603=8624=1623=1602=477603=8624=2623=1
35=d5799=00000000980=A779=202309241105140006211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGZ448=6117722=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1541.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20201201223000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=913603=8624=2623=1
35=d5799=00000000980=A779=202309241105120005211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGF748=6553122=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-2237.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230103223000000000865=71145=202309271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=108278603=8624=1623=1602=1804603=8624=2623=1
35=d5799=00000000980=A779=202309241105140008711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGU448=6599922=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-629.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20200901213000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=938603=8624=2623=1
35=d5799=00000000980=A779=202309241105180001711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-HHV348=7113822=8167=FUT461=FMMXSX200=20231015=USD762=RI9779=N1142=F562=11140=999969=0.2500000009787=0.001000000996=MMBTU1150=0.000000000731=000000115796=202309221143=100.000000000864=2865=51145=20171128223000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=45319603=8624=2623=1
35=d5799=00000000980=A779=202309241105180008211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGH548=7622522=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-601.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20210226223000000000865=71145=202409261830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=935603=8624=1623=1602=896603=8624=2623=1
35=d5799=00000000980=A779=202309241105150001211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGH548=8146822=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1326.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20210226223000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=896603=8624=2623=1
35=d5799=00000000980=A779=202309241105180005711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGZ448=8147922=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-816.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20201201223000000000865=71145=202409261830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=935603=8624=1623=1602=913603=8624=2623=1
35=d5799=00000000980=A779=202309241105130007711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-HHV448=8506322=8167=FUT461=FMMXSX200=20241015=USD762=RI9779=N1142=F562=11140=999969=0.2500000009787=0.001000000996=MMBTU1150=0.000000000731=000000115796=202309221143=100.000000000864=2865=51145=20171215223000000000865=71145=202409261830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=935603=8624=1623=1602=42555603=8624=2623=1
35=d5799=00000000980=A779=202309241105160007711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV9-HHV948=8620622=8167=FUT461=FMMXSX200=20291015=USD762=RI9779=N1142=F562=11140=999969=0.2500000009787=0.001000000996=MMBTU1150=0.000000000731=000000115796=202309221143=100.000000000864=2865=51145=20171215223000000000865=71145=202909261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=249731603=8624=1623=1602=43278603=8624=2623=1
35=d5799=00000000980=A779=202309241105150000211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV30-HHV3048=8718522=8167=FUT461=FMMXSX200=20301015=USD762=RI9779=N1142=F562=11140=999969=0.2500000009787=0.001000000996=MMBTU1150=0.000000000731=000000115796=202309221143=100.000000000864=2865=51145=20171215223000000000865=71145=203009261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=100980603=8624=1623=1602=43509603=8624=2623=1
35=d5799=00000000980=A779=202309241105160004211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGG548=8761422=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1704.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20210129223000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=899603=8624=2623=1
35=d5799=00000000980=A779=202309241105110003711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-HHV548=8797522=8167=FUT461=FMMXSX200=20251015=USD762=RI9779=N1142=F562=11140=999969=0.2500000009787=0.001000000996=MMBTU1150=0.000000000731=000000115796=202309221143=100.000000000864=2865=51145=20171215223000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=43050603=8624=2623=1
35=d5799=00000000980=A779=202309241105120003211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV6-HHV648=8824422=8167=FUT461=FMMXSX200=20261015=USD762=RI9779=N1142=F562=11140=999969=0.2500000009787=0.001000000996=MMBTU1150=0.000000000731=000000115796=202309221143=100.000000000864=2865=51145=20171215223000000000865=71145=202609281830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=973603=8624=1623=1602=44023603=8624=2623=1
35=d5799=00000000980=A779=202309241105130002211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV7-HHV748=8841222=8167=FUT461=FMMXSX200=20271015=USD762=RI9779=N1142=F562=11140=999969=0.2500000009787=0.001000000996=MMBTU1150=0.000000000731=000000115796=202309221143=100.000000000864=2865=51145=20171215223000000000865=71145=202709281830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=88603=8624=1623=1602=44216603=8624=2623=1
35=d5799=00000000980=A779=202309241105130005211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGX648=9072522=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-354.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20221101213000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=967603=8624=2623=1
35=d5799=00000000980=A779=202309241105170007211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV6-NGX648=9128922=8167=FUT461=FMMXSX200=20261015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-364.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20221101213000000000865=71145=202609281830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=973603=8624=1623=1602=967603=8624=2623=1
35=d5799=00000000980=A779=202309241105110007211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV8-HHV848=9184722=8167=FUT461=FMMXSX200=20281015=USD762=RI9779=N1142=F562=11140=999969=0.2500000009787=0.001000000996=MMBTU1150=0.000000000731=000000115796=202309221143=100.000000000864=2865=51145=20171215223000000000865=71145=202809271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=2533603=8624=1623=1602=43104603=8624=2623=1
35=d5799=00000000980=A779=202309241105120000211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGZ348=9557222=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-660.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20191129223000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=116631603=8624=2623=1
35=d5799=00000000980=A779=202309241105070001211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3048=10098022=8167=FUT461=FCMXSX200=20301015=USD1142=F562=11140=1999969=1.0000000009787=0.001000000996=MMBTU1147=10000.0000000001150=3686.000000000731=000000115796=202309221148=1.0000000001143=50.0000000001146=10.0000000009779=N864=2865=51145=20171128223000000000865=71145=203009261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100000000001111234=05792=14
35=d5799=00000000980=A779=202309241105180000211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGG548=10261422=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-979.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20210129223000000000865=71145=202409261830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=935603=8624=1623=1602=899603=8624=2623=1
35=d5799=00000000980=A779=202309241105100007211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV35-HHV3548=10283622=8167=FUT461=FMMXSX200=20351015=USD762=RI9779=N1142=F562=11140=999969=0.2500000009787=0.001000000996=MMBTU1150=0.000000000731=000000115796=202309221143=100.000000000864=2865=51145=20221128223000000000865=71145=203509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=15076603=8624=1623=1602=13757603=8624=2623=1
35=d5799=00000000980=A779=202309241105130004711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGM448=10429822=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-478.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20200529213000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=945603=8624=2623=1
35=d5799=00000000980=A779=202309241105120004211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGX448=10677922=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-380.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20201030213000000000865=71145=202409261830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=935603=8624=1623=1602=923603=8624=2623=1
35=d5799=00000000980=A779=202309241105080003711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV348=10827822=8167=FUT461=FCMXSX200=20231015=USD1142=F562=11140=1999969=1.0000000009787=0.001000000996=MMBTU1147=10000.0000000001150=2637.000000000731=000000115796=202309221148=1.0000000001143=50.0000000001146=10.0000000009779=N864=2865=51145=20101124223000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100000000001111234=05791=526415792=25403
35=d5799=00000000980=A779=202309241105160005711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGX448=11191022=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1105.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20201030213000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=923603=8624=2623=1
35=d5799=00000000980=A779=202309241105110001711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV6-NGK748=11770422=8167=FUT461=FMMXSX200=20261015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=394.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230428213000000000865=71145=202609281830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=973603=8624=1623=1602=399603=8624=2623=1
35=d5799=00000000980=A779=202309241105150005211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGK448=12265322=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-349.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20200430213000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=946603=8624=2623=1
35=d5799=00000000980=A779=202309241105160002711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGF448=12297522=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-918.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20180405213000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=56044603=8624=2623=1
35=d5799=00000000980=A779=202309241105180004711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGF548=12312122=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1079.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20180405213000000000865=71145=202409261830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=935603=8624=1623=1602=902603=8624=2623=1
35=d5799=00000000980=A779=202309241105150007211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGF648=12316122=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1016.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20180405213000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=1018603=8624=2623=1
35=d5799=00000000980=A779=202309241105120002211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV6-NGF748=12319622=8167=FUT461=FMMXSX200=20261015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1005.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20180405213000000000865=71145=202609281830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=973603=8624=1623=1602=1804603=8624=2623=1
35=d5799=00000000980=A779=202309241105140001211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV7-NGF848=12323922=8167=FUT461=FMMXSX200=20271015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1025.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20180405213000000000865=71145=202709281830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=88603=8624=1623=1602=3777603=8624=2623=1
35=d5799=00000000980=A779=202309241105110002211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV28-NGF2948=12338622=8167=FUT461=FMMXSX200=20281015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1025.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20180405213000000000865=71145=202809271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=2533603=8624=1623=1602=249058603=8624=2623=1
35=d5799=00000000980=A779=202309241105100006211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV29-NGF3048=12346722=8167=FUT461=FMMXSX200=20291015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1025.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20180405213000000000865=71145=202909261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=249731603=8624=1623=1602=37857603=8624=2623=1
35=d5799=00000000980=A779=202309241105170000211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGJ648=12391422=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-892.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220331213000000000865=71145=202309271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=108278603=8624=1623=1602=1008603=8624=2623=1
35=d5799=00000000980=A779=202309241105120003711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGJ648=12393122=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-167.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220331213000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=1008603=8624=2623=1
35=d5799=00000000980=A779=202309241105110005211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGK748=12584822=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-113.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230428213000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=399603=8624=2623=1
35=d5799=00000000980=A779=202309241105170006711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGX548=12637222=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1609.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20211029213000000000865=71145=202309271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=108278603=8624=1623=1602=864603=8624=2623=1
35=d5799=00000000980=A779=202309241105180002211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGX548=12640622=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-884.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20211029213000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=864603=8624=2623=1
35=d5799=00000000980=A779=202309241105170002711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGK748=13102022=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=404.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230428213000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=399603=8624=2623=1
35=d5799=00000000980=A779=202309241105150008711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGH648=13120322=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-788.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220301223000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=1021603=8624=2623=1
35=d5799=00000000980=A779=202309241105110005211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGJ648=13178722=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=350.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220331213000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=1008603=8624=2623=1
35=d5799=00000000980=A779=202309241105170000211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGK548=13450622=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-143.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20210430213000000000865=71145=202409261830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=935603=8624=1623=1602=886603=8624=2623=1
35=d5799=00000000980=A779=202309241105130001711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGQ548=13501522=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1181.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20210730213000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=876603=8624=2623=1
35=d5799=00000000980=A779=202309241105110006211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGX548=13541222=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-367.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20211029213000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=864603=8624=2623=1
35=d5799=00000000980=A779=202309241105100006711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGK748=13574522=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-838.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230428213000000000865=71145=202309271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=108278603=8624=1623=1602=399603=8624=2623=1
35=d5799=00000000980=A779=202309241105170000711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGG448=13750922=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-851.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20200131223000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=56065603=8624=2623=1
35=d5799=00000000980=A779=202309241105150000711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGX648=13933922=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-871.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20221101213000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=967603=8624=2623=1
35=d5799=00000000980=A779=202309241105130002211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGQ548=13957422=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-456.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20210730213000000000865=71145=202409261830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=935603=8624=1623=1602=876603=8624=2623=1
35=d5799=00000000980=A779=202309241105110002711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGF748=14467322=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-995.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230103223000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=1804603=8624=2623=1
35=d5799=00000000980=A779=202309241105130006711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGQ648=14589122=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-440.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220729213000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=992603=8624=2623=1
35=d5799=00000000980=A779=202309241105150001711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGQ448=14912022=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-649.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20200731213000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=939603=8624=2623=1
35=d5799=00000000980=A779=202309241105140002711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGH648=15002922=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1513.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220301223000000000865=71145=202309271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=108278603=8624=1623=1602=1021603=8624=2623=1
35=d5799=00000000980=A779=202309241105110007211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV26-NGV2748=15056122=8167=FUT461=FMMXSX200=20261015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=92.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230519213000000000865=71145=202609281830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=973603=8624=1623=1602=88603=8624=2623=1
35=d5799=00000000980=A779=202309241105150005211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGK548=15526422=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-868.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20210430213000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=886603=8624=2623=1
35=d5799=00000000980=A779=202309241105150009711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGQ648=16141022=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=77.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220729213000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=992603=8624=2623=1
35=d5799=00000000980=A779=202309241105180008711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGN448=16686722=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-610.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20200630213000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=944603=8624=2623=1
35=d5799=00000000980=A779=202309241105170003211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NNV448=16928022=8167=FUT461=FMMXSX200=20241015=USD762=AE9779=N1142=F562=11140=1999969=0.2500000009787=0.001000000996=MMBTU1150=0.000000000731=000000115796=202309221143=10.000000000864=2865=51145=20221003213000000000865=71145=202409261830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=935603=8624=1623=8602=52957603=8624=2623=1
35=d5799=00000000980=A779=202309241105170006211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGF648=17380222=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-2258.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20211231223000000000865=71145=202309271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=108278603=8624=1623=1602=1018603=8624=2623=1
35=d5799=00000000980=A779=202309241105120009711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGV448=17981122=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-725.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20200930213000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=935603=8624=2623=1
35=d5799=00000000980=A779=202309241105170003711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGQ648=18017722=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1165.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220729213000000000865=71145=202309271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=108278603=8624=1623=1602=992603=8624=2623=1
35=d5799=00000000980=A779=202309241105120005711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGV648=18563022=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-507.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220930213000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=973603=8624=2623=1
35=d5799=00000000980=A779=202309241105130003211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGK648=18814122=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-868.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220429213000000000865=71145=202309271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=108278603=8624=1623=1602=996603=8624=2623=1
35=d5799=00000000980=A779=202309241105130006211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGF648=19026422=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1533.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20211231223000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=1018603=8624=2623=1
35=d5799=00000000980=A779=202309241105140007211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV23-NGX2348=19413222=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-242.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20191031213000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=150611603=8624=2623=1
35=d5799=00000000980=A779=202309241105150009211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGV648=19729122=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1232.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220930213000000000865=71145=202309271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=108278603=8624=1623=1602=973603=8624=2623=1
35=d5799=00000000980=A779=202309241105150008211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGK648=19850022=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=374.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220429213000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=996603=8624=2623=1
35=d5799=00000000980=A779=202309241105150000211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGM548=19990022=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-276.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20210601213000000000865=71145=202409261830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=935603=8624=1623=1602=885603=8624=2623=1
35=d5799=00000000980=A779=202309241105180009211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGK648=20993022=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-143.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220429213000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=996603=8624=2623=1
35=d5799=00000000980=A779=202309241105120008211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGN548=22202422=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-413.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20210630213000000000865=71145=202409261830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=935603=8624=1623=1602=878603=8624=2623=1
35=d5799=00000000980=A779=202309241105130009211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGJ748=22469022=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-866.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230331213000000000865=71145=202309271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=108278603=8624=1623=1602=472603=8624=2623=1
35=d5799=00000000980=A779=202309241105120004211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGJ748=22730622=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=376.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230331213000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=472603=8624=2623=1
35=d5799=00000000980=A779=202309241105160000211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV6-NGJ748=22733522=8167=FUT461=FMMXSX200=20261015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=366.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230331213000000000865=71145=202609281830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=973603=8624=1623=1602=472603=8624=2623=1
35=d5799=00000000980=A779=202309241105160008211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGJ748=23359922=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-141.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230331213000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=472603=8624=2623=1
35=d5799=00000000980=A779=202309241105170009711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGJ548=23478022=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-161.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20210331213000000000865=71145=202409261830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=935603=8624=1623=1602=892603=8624=2623=1
35=d5799=00000000980=A779=202309241105140004711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGV548=24548322=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-517.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20210930213000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=869603=8624=2623=1
35=d5799=00000000980=A779=202309241105090009711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV2948=24973122=8167=FUT461=FCMXSX200=20291015=USD1142=F562=11140=1999969=1.0000000009787=0.001000000996=MMBTU1147=10000.0000000001150=3712.000000000731=000000115796=202309221148=1.0000000001143=50.0000000001146=10.0000000009779=N864=2865=51145=20161128223000000000865=71145=202909261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100000000001111234=05792=54
35=d5799=00000000980=A779=202309241105140004711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGN548=25142622=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1138.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20210630213000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=878603=8624=2623=1
35=d5799=00000000980=A779=202309241105120003711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGU648=25367222=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=106.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220831213000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=978603=8624=2623=1
35=d5799=00000000980=A779=202309241105170002711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGZ648=25397522=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1258.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20221130223000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=953603=8624=2623=1
35=d5799=00000000980=A779=202309241105120001711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV6-NGM748=25602822=8167=FUT461=FMMXSX200=20261015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=292.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230531213000000000865=71145=202609281830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=973603=8624=1623=1602=395603=8624=2623=1
35=d5799=00000000980=A779=202309241105110009711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV6-NGZ648=26042222=8167=FUT461=FMMXSX200=20261015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-751.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20221130223000000000865=71145=202609281830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=973603=8624=1623=1602=953603=8624=2623=1
35=d5799=00000000980=A779=202309241105150006211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGM648=27114422=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=248.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220531213000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=995603=8624=2623=1
35=d5799=00000000980=A779=202309241105160005211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGG648=27241822=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-2068.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220201223000000000865=71145=202309271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=108278603=8624=1623=1602=1000603=8624=2623=1
35=d5799=00000000980=A779=202309241105180004711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGM748=27809722=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=302.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230531213000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=395603=8624=2623=1
35=d5799=00000000980=A779=202309241105170009211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGU548=28288222=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-431.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20210831213000000000865=71145=202409261830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=935603=8624=1623=1602=875603=8624=2623=1
35=d5799=00000000980=A779=202309241105180001711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGZ648=28397222=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1983.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20221130223000000000865=71145=202309271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=108278603=8624=1623=1602=953603=8624=2623=1
35=d5799=00000000980=A779=202309241105170003711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGM748=28659322=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-940.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230531213000000000865=71145=202309271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=108278603=8624=1623=1602=395603=8624=2623=1
35=d5799=00000000980=A779=202309241105120001211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGM748=28665822=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-215.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230531213000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=395603=8624=2623=1
35=d5799=00000000980=A779=202309241105130005211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGV548=29047522=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1242.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20210930213000000000865=71145=202309271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=108278603=8624=1623=1602=869603=8624=2623=1
35=d5799=00000000980=A779=202309241105120001211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGZ648=29158922=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-741.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20221130223000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=953603=8624=2623=1
35=d5799=00000000980=A779=202309241105170002711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGZ548=29270522=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-2001.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20211130223000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=863603=8624=2623=1
35=d5799=00000000980=A779=202309241105160006711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGJ548=29277622=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-886.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20210331213000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=892603=8624=2623=1
35=d5799=00000000980=A779=202309241105140005211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGU548=30261522=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1156.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20210831213000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=875603=8624=2623=1
35=d5799=00000000980=A779=202309241105180007711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGU648=30265622=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1136.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220831213000000000865=71145=202309271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=108278603=8624=1623=1602=978603=8624=2623=1
35=d5799=00000000980=A779=202309241105180000711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGG648=30841822=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-826.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220201223000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=1000603=8624=2623=1
35=d5799=00000000980=A779=202309241105150008711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGF548=31325022=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1804.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20201231223000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=902603=8624=2623=1
35=d5799=00000000980=A779=202309241105160002711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGG648=31724722=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1343.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220201223000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=1000603=8624=2623=1
35=d5799=00000000980=A779=202309241105120004711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGU648=32734422=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-411.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220831213000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=978603=8624=2623=1
35=d5799=00000000980=A779=202309241105120006211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGH748=32914722=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-741.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230228223000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=485603=8624=2623=1
35=d5799=00000000980=A779=202309241105110003711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV6-NGH748=32916622=8167=FUT461=FMMXSX200=20261015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-234.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230228223000000000865=71145=202609281830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=973603=8624=1623=1602=485603=8624=2623=1
35=d5799=00000000980=A779=202309241105160005711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGM648=32923022=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-994.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220531213000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=995603=8624=2623=1
35=d5799=00000000980=A779=202309241105130000211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGM648=32927522=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-269.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220531213000000000865=71145=202409261830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=935603=8624=1623=1602=995603=8624=2623=1
35=d5799=00000000980=A779=202309241105160001211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGH748=33376222=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1466.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230228223000000000865=71145=202309271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=108278603=8624=1623=1602=485603=8624=2623=1
35=d5799=00000000980=A779=202309241105130006711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGZ548=33753222=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-759.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20211130223000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=863603=8624=2623=1
35=d5799=00000000980=A779=202309241105140000211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGH748=33842822=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-224.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230228223000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=485603=8624=2623=1
35=d5799=00000000980=A779=202309241105120007711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGZ548=34625822=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1276.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20211130223000000000865=71145=202409261830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=935603=8624=1623=1602=863603=8624=2623=1
35=d5799=00000000980=A779=202309241105110009711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGJ448=34637822=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-337.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20200331213000000000865=71145=202309271830000000001141=21022=GBX264=101022=GBI264=2870=1871=24872=000000000000110000100100000000111234=0555=2602=108278603=8624=1623=1602=948603=8624=2623=1
35=d5799=00000000980=A779=202309241105140005711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGN648=39638822=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-404.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220630213000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=994603=8624=2623=1
35=d5799=00000000980=A779=202309241105100009211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGN648=40636322=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=113.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220630213000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=994603=8624=2623=1
35=d5799=00000000980=A779=202309241105130009211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGN648=41265022=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1129.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20220630213000000000865=71145=202309271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=108278603=8624=1623=1602=994603=8624=2623=1
35=d5799=00000000980=A779=202309241105130001711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV6-NGN748=413239522=8167=FUT461=FMMXSX200=20261015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=171.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230630213000000000865=71145=202609281830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=973603=8624=1623=1602=378603=8624=2623=1
35=d5799=00000000980=A779=202309241105100005211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGN748=413316322=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-336.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230630213000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=378603=8624=2623=1
35=d5799=00000000980=A779=202309241105140006211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGN748=413316422=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=181.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230630213000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=378603=8624=2623=1
35=d5799=00000000980=A779=202309241105160003711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGN748=413339622=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1061.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230630213000000000865=71145=202309271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=108278603=8624=1623=1602=378603=8624=2623=1
35=d5799=00000000980=A779=202309241105100005711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV6-NGQ748=4201398522=8167=FUT461=FMMXSX200=20261015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=147.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230801213000000000865=71145=202609281830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=973603=8624=1623=1602=373603=8624=2623=1
35=d5799=00000000980=A779=202309241105110009211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGQ748=4201406422=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1085.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230801213000000000865=71145=202309271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=108278603=8624=1623=1602=373603=8624=2623=1
35=d5799=00000000980=A779=202309241105100007211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGQ748=4201416622=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-360.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230801213000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=373603=8624=2623=1
35=d5799=00000000980=A779=202309241105170009711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGQ748=4201457322=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=157.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230801213000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=373603=8624=2623=1
35=d5799=00000000980=A779=202309241105180008711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NNV548=4203309222=8167=FUT461=FMMXSX200=20251015=USD762=AE9779=N1142=F562=11140=1999969=0.2500000009787=0.001000000996=MMBTU731=000000011143=10.0000000005796=20230922864=2865=51145=20231002213000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=8602=52918603=8624=2623=1
35=d5799=00000000980=A779=202309241105150005711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGV748=4209662622=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT731=000000011143=25.0000000005796=20230922864=2865=51145=20230929213000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=88603=8624=2623=1
35=d5799=00000000980=A779=202309241105180002211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV3-NGU748=4210134522=8167=FUT461=FMMXSX200=20231015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-1045.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230831213000000000865=71145=202309271830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=108278603=8624=1623=1602=90603=8624=2623=1
35=d5799=00000000980=A779=202309241105110003211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV5-NGU748=4210134722=8167=FUT461=FMMXSX200=20251015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=197.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230831213000000000865=71145=202509261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=869603=8624=1623=1602=90603=8624=2623=1
35=d5799=00000000980=A779=202309241105150001711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGV748=4211240722=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT731=000000011143=25.0000000005796=20230922864=2865=51145=20230929213000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=88603=8624=2623=1
35=d5799=00000000980=A779=202309241105170007711180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV6-NGU748=4213984522=8167=FUT461=FMMXSX200=20261015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=187.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230831213000000000865=71145=202609281830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=973603=8624=1623=1602=90603=8624=2623=1
35=d5799=00000000980=A779=202309241105140005211180=3861300=78462=16207=XNYM1151=NG6937=NG55=NGV4-NGU748=4214065822=8167=FUT461=FMMXSX200=20241015=USD762=SP9779=N1142=F562=11140=1999969=1.0000000009787=0.001000000996=CTRCT1150=-320.000000000731=000000115796=202309221143=25.000000000864=2865=51145=20230831213000000000865=71145=202409261830000000001141=11022=GBX264=10870=1871=24872=000000000000010000100100000000111234=0555=2602=935603=8624=1623=1602=90603=8624=2623=1
Sierra Chart does have this data recorded but the symbol is not correct:
NGV323-NGX323.FUT_SPREAD.NYMEX
[2023-09-25 03:55:14]
Sierra_Chart Engineering - Posts: 17190
We will be fixing this problem. But you do have access to the data now (See the symbol in the post above) . We will not be able to correct the symbols until Monday or Tuesday evening.
Date Time Of Last Edit: 2023-09-25 04:15:27
[2023-09-25 04:38:31]
User664240 - Posts: 206
let me summarize to illustrate how thoroughly confused I am
Posting the spread in the chart symbol window led to a blank chart
Searching for NG spreads led me to discover the "missing spread" based on a TWO digit year nomenclature(NGV23-NGX23) as has always been the SC nomenclature.
This leads SC support to the security file where all the current two digit representations of years are generated from a single digit year nomenclature. And therefore the spread in question was not found.
Which led me to contact the CME where a snippet of their security file containing two digit nomenclature NOT one digit per year as depicted in your security file posted above, clearly shows the spread..
IN summation there could be two distinct security files with two different nomenclatures leading to the same outcome ??
While in the meantime the COMBO symbol, NGV323-NGX323 using both nomenclatures works perfectly....
Wow..Good Luck with this.
Date Time Of Last Edit: 2023-09-25 04:39:15
[2023-09-25 04:56:54]
There is only one security definition file from the CME containing all of the symbols. And for some reason for the missing spread symbols on the Sierra Chart side, they are using two digit years, instead of the usual single digit year. This is very unusual. And this is very inconsistent on their part. Why they do that we do not know. We are not going to ask them about that as we can easily adapt to the problem.
And our function to convert from a single digit year to a two digit year, is now creating three digits for the year. We will patch that problem this evening but it is not going to get released until Monday or Tuesday evening because we have to correct the filenames.
None of this is difficult for us to resolve but we cannot do it while the market is open.
[2023-09-26 22:06:57]
The correct symbols are now in effect for NYMEX. So this will be the symbol to use:
NGV23-NGX23 (Plus the additional common characters).
You should see this listed now.
Date Time Of Last Edit: 2023-09-26 22:07:10
