Date/Time: Wed, 27 Nov 2024 07:28:31 +0000
[User Discussion] - Cutting Vertical Lines
View Count: 242
[2023-09-10 14:08:06]
User676363 - Posts: 72
I would like to use the vertical line to simply label some candles so I don't want the line running through the candles.
If I cut the line under a candle, I want it to draw from bottom to top and the label to appear the bottom.
If I cut the line above a candle, I want it to draw from top to bottom and the label to appear at the top.
Or perhaps an option to draw line from top / bottom that works in combination with the Labels tab in the Vertical Line Properties dialog.
I was thinking I could cut the line but I can't, so that would be nice.
I can use a typical line and just draw it vertically, but what I like about the vertical lines is that they include the time and price and if moved, they update.
So I would sort of like to have a way to cut/extend the vertical lines just like we can do with most other lines.
Same for the OHLC lines - it would be nice to be able to cut them anywhere like the other tools.
If anybody has a creative solution with another tool, I'm happy to try something else until all of the tools have the cut feature implemented.
Perhaps if the regular line tool had a time, date, and price option that would do the trick as well or even if the chart calculator tool had a date option, that might work.
Thank you.
