Date/Time: Wed, 27 Nov 2024 08:39:47 +0000
DOM
View Count: 264
[2023-09-01 18:08:07] |
User668751 - Posts: 6 |
I customized a trading DOM, but every time I try to use a new one it seems to go back to old settings. How do I get my new trading DOM setting on any trading DOM i pull up.I trade different ways,but im doing something wrong
Private File |
[2023-09-01 21:08:06] |
John - SC Support - Posts: 36309 |
When you open a Trading DOM it will always be in the default format. In order to keep a Trading DOM with the customizations you want, you need to keep the Trading DOM open when you save the Chartbook and not close it. Then when you open the Chartbook the customized Trading DOM will be there. If you then want to use that Trading DOM for another symbol, duplicate the Trading DOM and change the symbol. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-02 01:08:52] |
Thank you for your help
