Date/Time: Tue, 04 Nov 2025 13:03:46 +0000
Numbers Bars Historical Low/High Pullback color
View Count: 478
[2023-08-21 19:48:29]
Dan the Man - Posts: 111
How can the Numbers Bars Historical Low/High Pullback color be based of weather it is a positive or a negative.
It is confusing when the +/- number is the same color.
I would like to be able to have the colors set to green if it is positive number and to red if it is a negative number.
Please see attached image.
Kind Regards,
imageNumbers Bars Historical Low High Pullback color.png / V - Attached On 2023-08-21 19:48:24 UTC - Size: 174.05 KB - 140 views
[2023-08-21 19:48:56]
John - SC Support - Posts: 42737
There is only the one option to color the High one color and the Low the other color. There is no support for coloring based on +/-.
