Date/Time: Wed, 27 Nov 2024 16:38:28 +0000
VOLQ-NQGI
View Count: 420
[2023-07-20 17:50:00]
GreyLock58 - Posts: 169
When I started a new chart with VOLQ-NQGI, everthing is fine. But, when I set the same symbol in the QuoteBoard, there is no NetChange %, only 0.00%. It does not change. In the chart, no problem, it shows the correct Chg%. Please advise...Thanks
[2023-07-20 18:02:49]
John - SC Support - Posts: 36322
We are not seeing any inconsistency.
We believe that what you are viewing in the Chart Header is the Bar Change Percent and not the Daily Change %. In the Chart Header the Daily Change % is prefaced with "DChg%", whereas the bar change is just "Chg%".
On the Quote Board there is only the Daily Change. In both cases for us, we see zeros, which makes sense for an Index, as they are not going to give this information.
[2023-07-21 12:57:07]
Sierra_Chart Engineering - Posts: 17195
There really should be a daily price change and percentage for the indices. We need to look into this.
[2023-07-21 13:19:56]
The daily price change will be supported as of Monday, for the NASDAQ global indices.
Date Time Of Last Edit: 2023-07-21 13:20:02
