Date/Time: Wed, 27 Nov 2024 16:32:43 +0000
time session problem
View Count: 306
[2023-07-17 13:48:29]
User230502 - Posts: 3
Hi support
Since the Sierra update I have had a time zone problem..
The time zone information, **global setting + <> **chart setting are correct set but having an initial balance open at 8:30am instead of 8:00 gives me a problem --
Screen MP + Screen Chart
Likewise my overnight starts at 2:00 a.m. but from 2o'clock to 8:35am I have no data...
To summarize : no overnight data and a lag of 30 min for the opening of the initial balance
In parallel on all Eurex contracts the time zone is correct, expect on ONE contract that I Trade which is FGBL (Bund)
Screen DAX
Could you help to reset this crucial information…
Best regards
[2023-07-17 19:39:06]
John - SC Support - Posts: 36322
What is the symbol of one chart for which you are having an issue?
For that chart, what are your Session Times and Time Zone (in chart settings) set to?
Also, please give us a screenshot of what you are seeing by following these instructions:
[2023-07-18 13:27:32]
It's on FGBL only
Time zone : Brussels
Session time : Use global time zone
all the other contract like Dax or STOX work very well but not the FGBL
Private File
Private File
[2023-07-18 13:46:50]
What are your Session Times set to. We need to know all of the following:
- Session Start Time
- Session End Time
- Use Evening Session
- Evening Start Time
- Evening End Time
Also, what is the Bar Period for the chart?
[2023-07-18 13:56:46]
I use 30 min for the market profil and for chart it's 1 min
imageCapture session time.PNG / V - Attached On 2023-07-18 13:55:19 UTC - Size: 24.75 KB - 77 views
[2023-07-18 16:56:39]
You need to adjust your Session Times, as they can not overlap, and your Evening Session is set to cover the full 24 hours.
Given your Session Start and End Times, you would want to use the following for your Evening Session:
- Evening Start Time: 22:00:00
- Evening End Time: 01:59:59
