Date/Time: Wed, 27 Nov 2024 19:41:57 +0000
[Locked] - Simple MAs Not working on Renko continues contract charts
View Count: 342
[2023-07-06 16:33:49] |
User360283 - Posts: 504 |
All charts are MESU23 Continues 50, 100, 200 Day Simple MA om all charts MAs nor working only on Renko charts MAs working on 15 and 60 minute charts Help please Thanks |
[2023-07-06 17:14:43] |
I reset and reloaded charts 50 100 200 MAs now appearing on Renko 25-24-1 But not appearing on Renko 49-48-1 ??? Will this be resolved when Rollover occurs? Thanks |
[2023-07-06 17:40:17] |
John - SC Support - Posts: 36344 |
We are not seeing an issue when adding the Simple Moving Average with Flex Renko set to "49-48-1". How many days worth of data do you have loaded? Keep in mind the "Length" of the study is the number of bars and it will not show anything until there are at least the number of bars in the chart as the length of the study. That is, if you have less than 200 bars in the chart, you will not see the SMA for a length of 200. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-06 17:52:42] |
Where to set Days to Load ??? Thanks |
[2023-07-06 18:40:41] |
Refer to the following: Chart Settings: Days to Load for Intraday Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Load Data Limiting Method: Days to Load menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-06 21:36:27] |
I set days to lewd to 400 MAs appeared as lines as set. Thanks I tried to change MAs to Transparent Fill Bottom. MAs vanished! I tried many different Transparent Fill Bottom settings. Nothing Ideas please Thanks |
[2023-07-07 13:36:23] |
"Transparent Fill Bottom" will create a colored area below the Moving Average Line. If you are setting this and then seeing nothing, then we wonder if your "Transparency Level for Fill Styles" is set to "100". A value of 100 means completely transparent (so you will not see anything). Refer to the following: Chart Studies: Subgraphs Tab >> Transparency Level for Fill Styles Offhand, we do not recommend using Transparencies, as they use a lot of CPU usage. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
