Date/Time: Wed, 27 Nov 2024 19:29:05 +0000
VbP study request
View Count: 497
[2023-06-26 17:17:09]
ertrader - Posts: 672
Hi Support.
Would it be possible to add/update one of the following options:
1) Update the numbers bars studies (Numbers Bars Calculated Values and Numbers Bars Calculated Values 2) so they work on a VbP study in addition to Numbers bars (using based on option in the studies)
or
2) Create 2 new studies that return the same data as the numbers bars calculated studies but work on a VbP. (VbP calculated values and if needed VbP calculated values 2)
[2023-06-26 18:02:39]
Sierra_Chart Engineering - Posts: 17198
1. No, those studies are not meant to be based on other studies.
2. We recommend developing this yourself. Refer to:
ACSIL Interface Members - sc.Subgraph Array: Numeric Information Table Graph Draw Type
[2023-06-30 20:34:28]
Yes, I have written my own study now. However, to complete it, there are 2 additional calls needed in: sc.GetStudyProfileInformation in the member: n_ACSIL::s_StudyProfileInformation
Can you please add the following members to the sc.GetStudyProfileInformation and member s_StudyProfileInformation?
1) Positive delta sum
2) Negative delta sum
Date Time Of Last Edit: 2023-07-02 13:54:51
[2023-07-02 04:34:25]
Nevermind. I coded this myself.
[2023-07-02 07:14:35]
Ok.
[2023-07-02 13:42:18]
Here is the study. It works and returns correct values. However, it's performance is about 70-100ms on an NQ chart with a 60 minute VbP study applied.
Do you have any suggestions on ways to improve performance?
PositiveDeltaSum and NegativeDeltaSum are not available within the GetStudyProfileInformation function so they have to be summed from:
sc.GetVolumeAtPriceDataForStudyProfile()
#include "sierrachart.h"
SCDLLName("VatPriceDataV3")
SCSFExport scsf_VatPriceDataV3(SCStudyInterfaceRef sc)
  SCSubgraphRef PositiveDeltaSum      = sc.Subgraph[0];
  SCSubgraphRef NegativeDeltaSum      = sc.Subgraph[1];
  SCInputRef INStudyID           = sc.Input[0];
  if (sc.SetDefaults)
    // Set the configuration and defaults
    sc.GraphName = "VbP Delta Sum V3";
    sc.AutoLoop = true;
    sc.GraphRegion = 1;
    INStudyID.Name="Study ID";
    INStudyID.SetInt(0);
    INStudyID.SetIntLimits(0,10000);
    PositiveDeltaSum.Name = "Positive Delta Sum";
    PositiveDeltaSum.DrawStyle = DRAWSTYLE_IGNORE;
    PositiveDeltaSum.LineWidth = 2;
    NegativeDeltaSum.Name = "Negative Delta Sum";
    NegativeDeltaSum.DrawStyle = DRAWSTYLE_IGNORE;
    NegativeDeltaSum.LineWidth = 2;
    return;
  const int StudyID             = INStudyID.GetInt();
  int PricesCount = sc.GetNumPriceLevelsForStudyProfile(StudyID, 0);
  int PositiveDeltaSumValue, NegativeDeltaSumValue;
  SCFloatArrayRef BidVolume      = sc.Subgraph[1].Arrays[0];
  SCFloatArrayRef AskVolume      = sc.Subgraph[1].Arrays[1];
  SCFloatArrayRef AskBidDelta      = sc.Subgraph[1].Arrays[2];
  for (int PriceIndex = 0; PriceIndex < PricesCount; PriceIndex++)
    s_VolumeAtPriceV2 VolumeAtPrice;
    int Result = sc.GetVolumeAtPriceDataForStudyProfile
    (StudyID
      , 0
      , PriceIndex
      , VolumeAtPrice
    if(PriceIndex ==0)
      PositiveDeltaSumValue = 0;
      NegativeDeltaSumValue = 0;
    BidVolume[PriceIndex] = VolumeAtPrice.BidVolume;
    AskVolume[PriceIndex] = VolumeAtPrice.AskVolume;
    AskBidDelta[PriceIndex] = AskVolume[PriceIndex] - BidVolume[PriceIndex];
    if(AskBidDelta[PriceIndex]>0) PositiveDeltaSumValue = PositiveDeltaSumValue + AskBidDelta[PriceIndex];
    else NegativeDeltaSumValue = NegativeDeltaSumValue + AskBidDelta[PriceIndex];
    PositiveDeltaSum[sc.Index] = PositiveDeltaSumValue;
    NegativeDeltaSum[sc.Index] = NegativeDeltaSumValue;
Date Time Of Last Edit: 2023-07-04 17:15:39
[2023-07-06 00:41:38]
Do you have any suggestions on ways to improve performance? If not, could this be added to sc.GetStudyProfileInformation?
[2023-07-06 01:34:26]
ForgivingComputers.com - Posts: 960
If you don't care about previous bars, then this should speed things up:
if (sc.Index < sc.ArraySize)
return;
[2023-07-06 15:41:12]
Great.. thank you! That took about 10ms off so definitely in the right direction.
