Date/Time: Wed, 27 Nov 2024 22:47:29 +0000
Can't verify username for Teton at AMP Futures.
View Count: 460
[2023-06-21 18:29:59]
Spartan79 - Posts: 54
Hi.
I'm trying to set up Teton order routing at AMP Futures, however when I try to verify Sierra Account Name / Username I get this message:
Failed to verify
Unable to Verify Sierra Account Name / Username – Common Reasons:
AMP Portal email address and Sierra email address are not the same.
The Sierra Account Name / Username provided is not linked to the AMP Portal email address.
The email I use for both is the same. I contacted AMP and they said I need to contact Sierra support.
Thank you.
[2023-06-22 17:45:04]
Any comment on that? Can you do anything?
[2023-06-23 09:02:32]
Sierra_Chart Engineering - Posts: 17198
There is nothing we can do to help with this. We recommend using a different broker than AMP for Teton order routing. Many are supported:
Sierra Chart Teton Futures Order Routing: Setup Instructions
If you need to change your account information:
To change your Account Information (name, e-mail address, mailing address, telephone number, password), login to the Account Management system located here:
https://www.sierrachart.com/UserControlPanel.php
Or, for automatic login, select "Help >> Account Control Panel", on the Sierra Chart menu.
On the Account Control Panel page, click the "Manage Account Information" link.
