Date/Time: Thu, 28 Nov 2024 01:44:33 +0000
Disappearing Drawings
View Count: 379
[2023-06-10 06:43:43]
User871209 - Posts: 86
I have a quote board with about 20 symbols, I draw on all my charts S/R zones using Extending Rectangles, on many of these charts when I come back to them the extending rectangles disappear as if they had been erased or just lost.
What can be the reason for the drawings not staying with the charts?
The charts are not Futures so it should not be the changing symbol rollover. (attached Chart Settings / Chart Drawings)
On some charts, I believe these Extending Rectangles appear out of place maybe from other symbols charts are being copied to the wrong chart. (Picture attached with Manage Drawings Box)
Please let me know,
Regards,
Date Time Of Last Edit: 2023-06-10 07:05:31
imagepp.JPG / V - Attached On 2023-06-10 06:46:23 UTC - Size: 53.51 KB - 101 views
imagedd.JPG / V - Attached On 2023-06-10 07:05:26 UTC - Size: 100.11 KB - 77 views
[2023-06-10 08:53:52]
Sierra_Chart Engineering - Posts: 17199
Look for them in Manage Chart Drawings Window:
Chart Drawing Tools: Manage Chart Drawings
And at the top of that window be sure to select All Symbols and not a specific symbol.
Once you add a drawing to a chart, it will remain unless you delete it. There really is no other possibility. Also do make sure to save the Chartbook when you close it.
Date Time Of Last Edit: 2023-06-10 08:54:17
