Date/Time: Tue, 04 Nov 2025 07:55:42 +0000
Ticket 1685925964287
View Count: 396
[2023-06-05 14:15:14]
User104854 - Posts: 460
I received this ticket from you
'Starting at the date 2023-06-07, you will begin to receive delayed data for the CME, CBOT, NYMEX, COMEX Exchanges for the following reason:'
I have logged into my live trading account through Teton in the past 30 days including today. Is there a way to confirm this through my Sierra Chart account?
Anyway I assume that since I've logged in I will not receive delayed data on 2023-06-07. Please confirm this. Thank you.
I'm also with Stage 5 and use Teton and I just read that I don't even need to connect because Sierra Chart will automatically recognize it.
Date Time Of Last Edit: 2023-06-05 14:23:09
[2023-06-05 14:20:08]
Sierra_Chart Engineering - Posts: 21299
Yes this is confirmed:
[2023-06-05 14:25:37]
Thank you for the quick reply.
So I will not get delayed data on the 7th then? The ticket says that I will and maybe it should say that I will unless I log into my live account by then.
Also I'm with Stage 5 and use Teton and I just read that I don't even need to connect because Sierra Chart will automatically recognize it. Is this true?
Appreciate it. Just don't want any surprises on the 7th. Thanks.
[2023-06-05 16:29:29]
John - SC Support - Posts: 42737
You can always view your "Verified Until" date at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
Since that date is now set to July 5, 2023, you are good to get real-time data until that date.
If you stay connected to your Stage 5 account, then your "Verified Until" date will constantly update, so you would not need to do anything special to make a connection.
