Date/Time: Thu, 28 Nov 2024 08:04:26 +0000
have you missed me
View Count: 357
[2023-05-17 13:44:19]
User849502 - Posts: 351
Hi John,
I can't get NQ to load more than to last sept. You see both have the exact same settings. ES is fine. I have gone over every chart settings tab and both match, but nq won't load. Help please John!
karen
imagenqwontload.PNG / V - Attached On 2023-05-17 13:44:09 UTC - Size: 336.72 KB - 77 views
[2023-05-17 15:29:24]
John - SC Support - Posts: 36350
Follow the instructions at the following link:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Instructions to Download/View More Historical Intraday Data
[2023-05-17 18:38:32]
John, I have done all this. Can't you see my screenshot of the data limit page
I have followed every single step already.
[2023-05-17 20:26:13]
Did you set the "Days to Load for Intraday Chart Data Type" to a high number as called out in steps 2 and 3?
This is not something you would typically leave at that value, but you need to try it and see if you can get the data downloaded going back as far as you are wanting.
If you still are not getting anywhere, then follow these instructions to get us your Message Log by opening just that NQ chart:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Tell us about *one* symbol only.
