Date/Time: Thu, 28 Nov 2024 07:42:00 +0000
Using Apex Funded account, purchased Denali data yet historical data not loading
View Count: 448
[2023-05-16 14:24:53] |
User595055 - Posts: 6 |
The market data is spotty and only loads data when I've been logged in. In troubleshooting, deleting and redownloading only began to load data once I re-logged in and doesnt pull the historical data unless I was logged in at that time. Redownloaded current version of Sierra and refreshed my log in information, tried to switch to Sierra all services then retry log in to Rhithmic/Apex account but problem still persists.
[2023-05-16 14:28:09] |
This began to happen after my trial version of TotalView ended if that helps.
[2023-05-16 15:38:39] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-16 15:47:03] |
ESM3.CME is the symbol. Trading MESM3.CME Software version: 2502 64-bit | 2023-05-16 15:44:04.502 Primary Thread ID: 26248 | 2023-05-16 15:44:04.502 Usage end date: 2023-06-05 | 2023-05-16 15:44:04.502 Enabled for: Advanced Features 2. | 2023-05-16 15:44:04.502 Enabled for: Sierra Chart Historical Data Service. | 2023-05-16 15:44:04.502 Enabled for: Denali Real-Time Exchange Data Feed. | 2023-05-16 15:44:04.502 Enabled for: Delayed Denali Exchange Data Feed. | 2023-05-16 15:44:04.502 Enabled for exchange2: CME | 2023-05-16 15:44:04.502 Enabled for exchange2: fairx_exchange.data | 2023-05-16 15:44:04.502 Allow Support for Sierra Chart Data Feeds is enabled. | 2023-05-16 15:44:04.502 Current selected Data/Trading service: Rithmic Direct - DTC | 2023-05-16 15:44:04.502 Custom symbol settings values: enabled | 2023-05-16 15:44:04.502 Chart Update Interval: 10 | 2023-05-16 15:44:04.502 Intraday Data Storage Time Unit: 0 | 2023-05-16 15:44:04.502 Time Zone: +00:00:00 (UTC+00) | 2023-05-16 15:44:04.502 2023-05-16 15:44:04 Local computer time in UTC | 2023-05-16 15:44:04.502 2023-05-16 15:44:04 Local computer time in SC Time Zone | 2023-05-16 15:44:04.502 2023-05-16 14:21:43 Server time in UTC | 2023-05-16 15:44:04.502 Local computer UTC time and Server UTC time difference: 1 seconds. | 2023-05-16 15:44:04.502 Program path: C:\SierraChart\ | 2023-05-16 15:44:04.502 Data Files path: C:\SierraChart\Data\ | 2023-05-16 15:44:04.502 OS Version Number: 10.0 | 2023-05-16 15:44:04.502 Locale Setting: C | 2023-05-16 15:44:04.502 DLLs: TWFX_FREE_64.dll, TWFX_FREE_SWS_64.dll, TWFX_FREE_ZZS_64.dll, UserContributedStudies_64.dll | 2023-05-16 15:44:04.502 Allowed protected custom studies: TWFX_Free, zyp_app | 2023-05-16 15:44:04.502 Crash reporter started: true | 2023-05-16 15:44:04.502 File >> Disconnect selected. | 2023-05-16 15:44:46.587 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-05-16 15:44:46.587 DTC Client socket (4) | CloseSocket call. | 2023-05-16 15:44:46.587 Rithmic Direct - DTC | Disconnected from the server. | 2023-05-16 15:44:46.587 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2023-05-16 15:44:46.587 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-05-16 15:44:46.598 DTC Client socket (1) | CloseSocket call. | 2023-05-16 15:44:46.599 DTC Client socket (1) | Max send buffers used during socket life: 4 | 2023-05-16 15:44:46.599 DTC Client socket (1) | Max send buffer size during socket life: 3671 | 2023-05-16 15:44:46.599 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-05-16 15:44:46.599 Rithmic Direct - DTC | Disconnected. | 2023-05-16 15:44:46.599 DTC Client socket (4) | Socket gracefully closed by remote side. | 2023-05-16 15:44:46.638 DTC Client socket (4) | Closed. | 2023-05-16 15:44:46.638 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-05-16 15:44:46.651 DTC Client socket (1) | Closed. | 2023-05-16 15:44:46.651 Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated | 2023-05-16 15:44:53.452 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 | 2023-05-16 15:44:53.455 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-05-16 15:44:53.525 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-05-16 15:44:53.525 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2023-05-16 15:44:53.525 Rithmic Direct - DTC | Network connection to server complete. | 2023-05-16 15:44:53.582 Rithmic Direct - DTC | Starting socket receive thread. | 2023-05-16 15:44:53.582 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-05-16 15:44:53.582 Rithmic Direct - DTC | Sending logon request message. | 2023-05-16 15:44:53.582 Rithmic Direct - DTC | Received logon response. | 2023-05-16 15:44:53.772 Rithmic Direct - DTC | Server Name: . | 2023-05-16 15:44:53.772 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2023-05-16 15:44:53.772 Rithmic Direct - DTC | Successfully connected. | 2023-05-16 15:44:53.772 Rithmic Direct - DTC | Trading is supported. | 2023-05-16 15:44:53.772 Rithmic Direct - DTC | Order cancel and replace is supported. | 2023-05-16 15:44:53.772 Rithmic Direct - DTC | OCO Orders supported. | 2023-05-16 15:44:53.772 Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2023-05-16 15:44:53.772 Rithmic Direct - DTC | Connected to server complete. | 2023-05-16 15:44:53.772 Triggering next historical data download in queue. | 2023-05-16 15:44:53.772 Triggering next historical data download in queue. | 2023-05-16 15:44:53.772 Triggering next historical data download in queue. | 2023-05-16 15:44:53.772 Triggering next historical data download in queue. | 2023-05-16 15:44:53.772 Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2023-05-16 15:44:53.772 No download requests in the queue to start downloads for. | 2023-05-16 15:44:53.779 No download requests in the queue to start downloads for. | 2023-05-16 15:44:53.779 No download requests in the queue to start downloads for. | 2023-05-16 15:44:53.779 No download requests in the queue to start downloads for. | 2023-05-16 15:44:53.779 Using symbol data fast lookup vector | 2023-05-16 15:44:53.779 Rithmic Direct - DTC | Starting real-time market data updates for: MESM3.CME. ID: 1 Service code: rithmic.trading | 2023-05-16 15:44:53.779 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50529 | 2023-05-16 15:44:53.779 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-05-16 15:44:53.780 DTC Client socket (2) | New receive buffer size: 5242880 | 2023-05-16 15:44:53.780 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-05-16 15:44:53.780 Rithmic Direct - DTC | Requesting security definition data for: MESM3.CME. ID: 1 | 2023-05-16 15:44:53.780 Rithmic Direct - DTC | Starting real-time market data updates for: ESM3.CME. ID: 2 Service code: rithmic.trading | 2023-05-16 15:44:53.780 Rithmic Direct - DTC | Requesting security definition data for: ESM3.CME. ID: 2 | 2023-05-16 15:44:53.780 Added historical Intraday data request for ESM3.CME to the queue. | 2023-05-16 15:44:53.780 Intraday data recording state for symbol ESM3.CME is set to download 'Pending'. | 2023-05-16 15:44:53.780 Triggering next historical data download in queue. | 2023-05-16 15:44:53.780 Delaying start of download for ESM3.CME. | 2023-05-16 15:44:53.799 Rithmic Direct - DTC | Network connection to server complete. | 2023-05-16 15:44:53.866 Rithmic Direct - DTC | Starting socket receive thread. | 2023-05-16 15:44:53.866 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-05-16 15:44:53.866 Rithmic Direct - DTC | Sending logon request message. | 2023-05-16 15:44:53.866 Rithmic Direct - DTC | Starting real-time market data updates for: ESZ2.CME. ID: 3 Service code: rithmic.trading | 2023-05-16 15:44:53.955 Rithmic Direct - DTC | Requesting security definition data for: ESZ2.CME. ID: 3 | 2023-05-16 15:44:53.955 Added historical Intraday data request for ESZ2.CME to the queue. | 2023-05-16 15:44:53.955 Intraday data recording state for symbol ESZ2.CME is set to download 'Pending'. | 2023-05-16 15:44:53.955 Triggering next historical data download in queue. | 2023-05-16 15:44:53.955 Requesting market depth updates for: MESM3.CME if supported. | 2023-05-16 15:44:53.959 Separate subscription for market depth updates not supported. MESM3.CME | 2023-05-16 15:44:53.959 Rithmic Direct - DTC | Received logon response. | 2023-05-16 15:44:54.051 Rithmic Direct - DTC | Server Name: . | 2023-05-16 15:44:54.051 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2023-05-16 15:44:54.051 Rithmic Direct - DTC | Successfully connected. | 2023-05-16 15:44:54.051 Rithmic Direct - DTC | Trading is not supported. | 2023-05-16 15:44:54.051 Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2023-05-16 15:44:54.051 Rithmic Direct - DTC | Restarting real-time data updates for symbol: ESM3.CME | 2023-05-16 15:44:54.051 Rithmic Direct - DTC | Restarting real-time data updates for symbol: ESZ2.CME | 2023-05-16 15:44:54.051 Rithmic Direct - DTC | Restarting real-time data updates for symbol: MESM3.CME. Market Depth data restarted. | 2023-05-16 15:44:54.051 Requesting market depth updates for: ESM3.CME if supported. | 2023-05-16 15:44:54.061 Rithmic Direct - DTC | Market Depth data has been rejected for symbol: MESM3.CME. permission denied | 2023-05-16 15:44:54.141 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ2.CME.2022-09-11.depth | 2023-05-16 15:44:54.142 Rithmic Direct - DTC | Received security definition for symbol ESM3.CME | 2023-05-16 15:44:54.142 Rithmic Direct - DTC | Received security definition for symbol MESM3.CME | 2023-05-16 15:44:54.142 Rithmic Direct - DTC | Market Depth data has been rejected for symbol: ESM3.CME. permission denied | 2023-05-16 15:44:54.142 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESM3.CME.2023-05-16.depth | 2023-05-16 15:44:54.444 Requesting market depth updates for: ESZ2.CME if supported. | 2023-05-16 15:44:58.962 Rithmic Direct - DTC | Market Depth data has been rejected for symbol: ESZ2.CME. permission denied | 2023-05-16 15:44:59.032 HD Request # 9 | Downloading Intraday chart data for ESM3.CME to the file ESM3.CME.scid. Service: rithmic.trading | 2023-05-16 15:44:59.042 HD Request # 9 | Download start date-time: 2023-05-16 15:44:46.000000. File last date-time: 2023-05-16 15:44:46.000002 | 2023-05-16 15:44:59.042 HD Request # 9 | Using server: rsc.rithmic.com port 50530. Use encryption. | 2023-05-16 15:44:59.043 Socket (3) | Creating socket. Using TLS 1.2. | 2023-05-16 15:44:59.043 Socket (3) | New receive buffer size: 5242880 | 2023-05-16 15:44:59.043 Socket (3) | Connecting to IP: 216.57.156.163. | 2023-05-16 15:44:59.043 HD Request # 9 | Sending historical data logon request message. | 2023-05-16 15:44:59.095 Socket (3) | CloseSocket call. | 2023-05-16 15:44:59.261 Socket (3) | Shutdown started. Waiting for graceful close. | 2023-05-16 15:44:59.261 HD Request # 9 | Error downloading historical Intraday data for ESM3.CME. Historical data logon error: permission denied | 2023-05-16 15:44:59.294 Added historical Intraday data request for ESM3.CME to the queue. | 2023-05-16 15:44:59.294 Triggering next historical data download in queue. | 2023-05-16 15:44:59.294 Historical data download thread signaled to stop. | 2023-05-16 15:44:59.294 HD Request # 9 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds. Delay: 123.5 years) and wrote 0 records for ESM3.CME | 2023-05-16 15:44:59.294 HD Request # 9 | Completion time: 0s. | 2023-05-16 15:44:59.294 HD Request # 10 | Downloading Intraday chart data for ESM3.CME to the file ESM3.CME.scid. Service: rithmic.trading | 2023-05-16 15:44:59.294 HD Request # 10 | Download start date-time: 2023-05-16 15:44:46.000000. File last date-time: 2023-05-16 15:44:46.000002 | 2023-05-16 15:44:59.295 HD Request # 10 | Using server: rsc.rithmic.com port 50530. Use encryption. | 2023-05-16 15:44:59.295 Socket (4) | Creating socket. Using TLS 1.2. | 2023-05-16 15:44:59.295 Socket (4) | New receive buffer size: 5242880 | 2023-05-16 15:44:59.295 Socket (4) | Connecting to IP: 216.57.156.163. | 2023-05-16 15:44:59.295 Socket (3) | Socket gracefully closed by remote side. | 2023-05-16 15:44:59.313 Socket (3) | Closed. | 2023-05-16 15:44:59.313 HD Request # 10 | Sending historical data logon request message. | 2023-05-16 15:44:59.346 Socket (4) | CloseSocket call. | 2023-05-16 15:44:59.524 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-05-16 15:44:59.524 HD Request # 10 | Error downloading historical Intraday data for ESM3.CME. Historical data logon error: permission denied | 2023-05-16 15:44:59.525 Added historical Intraday data request for ESM3.CME to the queue. | 2023-05-16 15:44:59.525 Triggering next historical data download in queue. | 2023-05-16 15:44:59.525 Historical data download thread signaled to stop. | 2023-05-16 15:44:59.525 HD Request # 10 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds. Delay: 123.5 years) and wrote 0 records for ESM3.CME | 2023-05-16 15:44:59.525 HD Request # 10 | Completion time: 0s. | 2023-05-16 15:44:59.525 HD Request # 11 | Downloading Intraday chart data for ESM3.CME to the file ESM3.CME.scid. Service: rithmic.trading | 2023-05-16 15:44:59.525 HD Request # 11 | Download start date-time: 2023-05-16 15:44:46.000000. File last date-time: 2023-05-16 15:44:46.000002 | 2023-05-16 15:44:59.526 HD Request # 11 | Using server: rsc.rithmic.com port 50530. Use encryption. | 2023-05-16 15:44:59.526 Socket (3) | Creating socket. Using TLS 1.2. | 2023-05-16 15:44:59.526 Socket (3) | New receive buffer size: 5242880 | 2023-05-16 15:44:59.526 Socket (3) | Connecting to IP: 216.57.156.163. | 2023-05-16 15:44:59.526 Socket (4) | Socket gracefully closed by remote side. | 2023-05-16 15:44:59.578 Socket (4) | Closed. | 2023-05-16 15:44:59.578 HD Request # 11 | Sending historical data logon request message. | 2023-05-16 15:44:59.580 Socket (3) | CloseSocket call. | 2023-05-16 15:44:59.757 Socket (3) | Shutdown started. Waiting for graceful close. | 2023-05-16 15:44:59.757 HD Request # 11 | Error downloading historical Intraday data for ESM3.CME. Historical data logon error: permission denied | 2023-05-16 15:44:59.787 Historical data download thread signaled to stop. | 2023-05-16 15:44:59.787 HD Request # 11 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds. Delay: 123.5 years) and wrote 0 records for ESM3.CME | 2023-05-16 15:44:59.787 HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2023-05-16 15:44:46.000002 | 2023-05-16 15:44:59.787 HD Request # 11 | Receiving Intraday data for ESM3.CME starting at 2023-05-16 15:44:55.000000 | 2023-05-16 15:44:59.788 Added 76 Time and Sales records to Intraday data file for ESM3.CME after download. | 2023-05-16 15:44:59.788 HD Request # 11 | Timestamp of first Intraday data file record written: 2023-05-16 15:44:55.000000. | 2023-05-16 15:44:59.788 HD Request # 11 | Completion time: 0s. | 2023-05-16 15:44:59.788 HD Request # 11 | Intraday data download complete for ESM3.CME. Unique request ID: 5 | 2023-05-16 15:44:59.788 Removing historical data download ID 5. | 2023-05-16 15:44:59.788 Real-time Intraday chart data file updates started for ESM3.CME | 2023-05-16 15:44:59.788 Intraday chart data file opened for ESM3.CME | 2023-05-16 15:44:59.788 HD Request # 11 | Enabling Intraday chart updating for symbol. | 2023-05-16 15:44:59.788 Triggering next historical data download in queue. | 2023-05-16 15:44:59.788 Delaying start of download for ESZ2.CME. | 2023-05-16 15:44:59.788 Socket (3) | Socket gracefully closed by remote side. | 2023-05-16 15:44:59.816 Socket (3) | Closed. | 2023-05-16 15:44:59.816 Chart #18 has tagged chart #24 for full recalculation. Chartbook: PAWS.Cht | 2023-05-16 15:44:59.956 Chart #18 has tagged chart #25 for full recalculation. Chartbook: PAWS.Cht | 2023-05-16 15:44:59.956 ESM3.CME 60 Min #24 | Performing a full recalculation because it has been tagged. Chartbook: PAWS.Cht | 2023-05-16 15:45:00.029 ESM3.CME 1 Day #25 | Performing a full recalculation because it has been tagged. Chartbook: PAWS.Cht | 2023-05-16 15:45:00.074 Chart #25 has tagged chart #18 for full recalculation. Chartbook: PAWS.Cht | 2023-05-16 15:45:00.075 ESM3.CME/MESM3.CME 5 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: PAWS.Cht | 2023-05-16 15:45:00.129 Chart #18 has tagged chart #24 for full recalculation. Chartbook: PAWS.Cht | 2023-05-16 15:45:00.130 Circular chart reference detected. Charts: 25, 18. Chartbook: PAWS.Cht. | 2023-05-16 15:45:00.130 ESM3.CME 60 Min #24 | Performing a full recalculation because it has been tagged. Chartbook: PAWS.Cht | 2023-05-16 15:45:00.202 Opened cached Intraday file: C:\SierraChart\Data\ESM3.CME.scid. Thread ID: 11900 | 2023-05-16 15:45:01.666 HD Request # 12 | Downloading Intraday chart data for ESZ2.CME to the file ESZ2.CME.scid. Service: rithmic.trading | 2023-05-16 15:45:10.052 HD Request # 12 | Download start date-time: 2022-12-16 14:29:59.000000. File last date-time: 2022-12-16 14:29:59.597000 | 2023-05-16 15:45:10.052 HD Request # 12 | Using server: rsc.rithmic.com port 50530. Use encryption. | 2023-05-16 15:45:10.052 Socket (3) | Creating socket. Using TLS 1.2. | 2023-05-16 15:45:10.052 Socket (3) | New receive buffer size: 5242880 | 2023-05-16 15:45:10.053 Socket (3) | Connecting to IP: 216.57.156.163. | 2023-05-16 15:45:10.053 HD Request # 12 | Sending historical data logon request message. | 2023-05-16 15:45:10.105 Socket (3) | CloseSocket call. | 2023-05-16 15:45:10.275 Socket (3) | Shutdown started. Waiting for graceful close. | 2023-05-16 15:45:10.275 HD Request # 12 | Error downloading historical Intraday data for ESZ2.CME. Historical data logon error: permission denied | 2023-05-16 15:45:10.278 Added historical Intraday data request for ESZ2.CME to the queue. | 2023-05-16 15:45:10.278 Triggering next historical data download in queue. | 2023-05-16 15:45:10.278 Historical data download thread signaled to stop. | 2023-05-16 15:45:10.278 HD Request # 12 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds. Delay: 123.5 years) and wrote 0 records for ESZ2.CME | 2023-05-16 15:45:10.278 HD Request # 12 | Completion time: 0s. | 2023-05-16 15:45:10.278 HD Request # 13 | Downloading Intraday chart data for ESZ2.CME to the file ESZ2.CME.scid. Service: rithmic.trading | 2023-05-16 15:45:10.278 HD Request # 13 | Download start date-time: 2022-12-16 14:29:59.000000. File last date-time: 2022-12-16 14:29:59.597000 | 2023-05-16 15:45:10.279 HD Request # 13 | Using server: rsc.rithmic.com port 50530. Use encryption. | 2023-05-16 15:45:10.279 Socket (4) | Creating socket. Using TLS 1.2. | 2023-05-16 15:45:10.279 Socket (4) | New receive buffer size: 5242880 | 2023-05-16 15:45:10.279 Socket (4) | Connecting to IP: 216.57.156.163. | 2023-05-16 15:45:10.279 Socket (3) | Socket gracefully closed by remote side. | 2023-05-16 15:45:10.326 Socket (3) | Closed. | 2023-05-16 15:45:10.326 HD Request # 13 | Sending historical data logon request message. | 2023-05-16 15:45:10.334 Socket (4) | CloseSocket call. | 2023-05-16 15:45:10.499 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-05-16 15:45:10.499 HD Request # 13 | Error downloading historical Intraday data for ESZ2.CME. Historical data logon error: permission denied | 2023-05-16 15:45:10.502 Added historical Intraday data request for ESZ2.CME to the queue. | 2023-05-16 15:45:10.502 Triggering next historical data download in queue. | 2023-05-16 15:45:10.502 Historical data download thread signaled to stop. | 2023-05-16 15:45:10.502 HD Request # 13 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds. Delay: 123.5 years) and wrote 0 records for ESZ2.CME | 2023-05-16 15:45:10.502 HD Request # 13 | Completion time: 0s. | 2023-05-16 15:45:10.502 HD Request # 14 | Downloading Intraday chart data for ESZ2.CME to the file ESZ2.CME.scid. Service: rithmic.trading | 2023-05-16 15:45:10.502 HD Request # 14 | Download start date-time: 2022-12-16 14:29:59.000000. File last date-time: 2022-12-16 14:29:59.597000 | 2023-05-16 15:45:10.502 HD Request # 14 | Using server: rsc.rithmic.com port 50530. Use encryption. | 2023-05-16 15:45:10.503 Socket (3) | Creating socket. Using TLS 1.2. | 2023-05-16 15:45:10.503 Socket (3) | New receive buffer size: 5242880 | 2023-05-16 15:45:10.503 Socket (3) | Connecting to IP: 216.57.156.163. | 2023-05-16 15:45:10.503 Socket (4) | Socket gracefully closed by remote side. | 2023-05-16 15:45:10.558 Socket (4) | Closed. | 2023-05-16 15:45:10.558 HD Request # 14 | Sending historical data logon request message. | 2023-05-16 15:45:10.564 Socket (3) | CloseSocket call. | 2023-05-16 15:45:10.731 Socket (3) | Shutdown started. Waiting for graceful close. | 2023-05-16 15:45:10.731 HD Request # 14 | Error downloading historical Intraday data for ESZ2.CME. Historical data logon error: permission denied | 2023-05-16 15:45:10.737 Historical data download thread signaled to stop. | 2023-05-16 15:45:10.737 HD Request # 14 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds. Delay: 123.5 years) and wrote 0 records for ESZ2.CME | 2023-05-16 15:45:10.737 HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2022-12-16 14:29:59.597000 | 2023-05-16 15:45:10.738 HD Request # 14 | Completion time: 0s. | 2023-05-16 15:45:10.738 HD Request # 14 | Intraday data download complete for ESZ2.CME. Unique request ID: 6 | 2023-05-16 15:45:10.738 Removing historical data download ID 6. | 2023-05-16 15:45:10.738 Real-time Intraday chart data file updates started for ESZ2.CME | 2023-05-16 15:45:10.738 Intraday chart data file opened for ESZ2.CME | 2023-05-16 15:45:10.738 HD Request # 14 | Enabling Intraday chart updating for symbol. | 2023-05-16 15:45:10.738 Triggering next historical data download in queue. | 2023-05-16 15:45:10.738 No download requests in the queue to start downloads for. | 2023-05-16 15:45:10.738 Chart #8 has tagged chart #5 for full recalculation. Chartbook: PAWS.Cht | 2023-05-16 15:45:10.775 Chart #7 has tagged chart #21 for full recalculation. Chartbook: PAWS.Cht | 2023-05-16 15:45:10.777 Chart #7 has tagged chart #4 for full recalculation. Chartbook: PAWS.Cht | 2023-05-16 15:45:10.777 ESZ2.CME [CBV] Flex Renko Inv 9-2-12 #5 | Performing a full recalculation because it has been tagged. Chartbook: PAWS.Cht | 2023-05-16 15:45:10.777 Chart #5 has tagged chart #27 for full recalculation. Chartbook: PAWS.Cht | 2023-05-16 15:45:10.785 Chart #5 has tagged chart #29 for full recalculation. Chartbook: PAWS.Cht | 2023-05-16 15:45:10.785 Chart #2 has tagged chart #5 for full recalculation. Chartbook: PAWS.Cht | 2023-05-16 15:45:10.786 Chart #6 has tagged chart #21 for full recalculation. Chartbook: PAWS.Cht | 2023-05-16 15:45:10.786 Chart #6 has tagged chart #4 for full recalculation. Chartbook: PAWS.Cht | 2023-05-16 15:45:10.786 ESM3.CME/MESM3.CME #29 | Performing a full recalculation because it has been tagged. Chartbook: PAWS.Cht | 2023-05-16 15:45:10.786 ESM3.CME/MESM3.CME 30 Min #27 | Performing a full recalculation because it has been tagged. Chartbook: PAWS.Cht | 2023-05-16 15:45:10.787 Socket (3) | Socket gracefully closed by remote side. | 2023-05-16 15:45:10.790 Socket (3) | Closed. | 2023-05-16 15:45:10.790 ESM3.CME/MESM3.CME 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: PAWS.Cht | 2023-05-16 15:45:10.858 Chart #12 has tagged chart #14 for full recalculation. Chartbook: PAWS.Cht | 2023-05-16 15:45:10.860 ESM3.CME/MESM3.CME 1 Min #21 | Performing a full recalculation because it has been tagged. Chartbook: PAWS.Cht | 2023-05-16 15:45:10.962 ESZ2.CME [CBV] Flex Renko Inv 9-2-12 #5 | Performing a full recalculation because it has been tagged. Chartbook: PAWS.Cht | 2023-05-16 15:45:10.964 Chart #5 has tagged chart #27 for full recalculation. Chartbook: PAWS.Cht | 2023-05-16 15:45:10.972 Chart #5 has tagged chart #29 for full recalculation. Chartbook: PAWS.Cht | 2023-05-16 15:45:10.972 ESM3.CME/MESM3.CME #29 | Performing a full recalculation because it has been tagged. Chartbook: PAWS.Cht | 2023-05-16 15:45:10.972 ESM3.CME/MESM3.CME 30 Min #27 | Performing a full recalculation because it has been tagged. Chartbook: PAWS.Cht | 2023-05-16 15:45:10.972 ESM3.CME/MESM3.CME #14 | Performing a full recalculation because it has been tagged. Chartbook: PAWS.Cht | 2023-05-16 15:45:11.059 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Creating socket. Using TLS 1.2. | 2023-05-16 15:45:13.760 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | New receive buffer size: 32768 | 2023-05-16 15:45:13.760 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Connecting to IP: 38.79.0.89. | 2023-05-16 15:45:13.760 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Socket gracefully closed by remote side. | 2023-05-16 15:45:14.254 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | CloseSocket call. | 2023-05-16 15:45:14.254 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-05-16 15:45:14.254 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Closed. | 2023-05-16 15:45:14.254 Date Time Of Last Edit: 2023-05-16 15:47:27
[2023-05-16 16:25:46] |
The reason you are not getting real-time data from the Denali Data Feed, and historical data from the Denali Data Feed in the case of when using an external Trading service (Rithmic, CQG, Interactive Brokers), from the CME Group of exchanges is that you activated the *Non-Professional* exchange fees. However, you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees. Refer to the "Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges" section here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Rithmic paper trading or trading evaluator accounts are not considered a live funded futures trading account. Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you do not have a funded trading account or one with a supported Trading service, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement Consider the above solution to avoid this problem in the future. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-17 23:38:56] |
I do have an account through AMP/CQG that has allowed me to do this up until now. Does that no longer qualify as my live funded account?
[2023-05-18 14:46:50] |
Sierra_Chart Engineering - Posts: 17199 |
Yes that does qualify. You just need to connect to that.
