Date/Time: Mon, 21 Apr 2025 13:11:43 +0000
cant conect to new data services
View Count: 402
[2023-05-15 20:39:08]
User956873 - Posts: 23
ive just upgraded to services package 11 but for some reason it wont connect to the data
[2023-05-15 21:13:46]
Sierra_Chart Engineering - Posts: 19285
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
[2023-05-16 07:25:29]
i have just sent the error code log by the button send for analysis
[2023-05-16 10:22:30]
This is the issue:
CQG WebAPI | Logon unsuccessful. Server message: Username or password is incorrect. | 2023-05-16 03:15:28.623
Refer to 5 here:
CQG Trading Platform Service: Common Error Messages
To access historical and streaming market data independent from your Trading service. Follow these instructions.
Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services".
Press "OK"
And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
You can then use the data provided by Sierra Chart independent of your trading service.
Date Time Of Last Edit: 2023-05-16 10:22:54
[2023-05-16 10:38:03]
ive sent you a new error message
[2023-05-16 12:11:46]
At this point contact your broker for help. We have no control over these and cannot help:
CQG WebAPI | Sending market data logon message. | 2023-05-16 06:34:04.391
CQG WebAPI | Logon unsuccessful. Server message: Too many failed logon attempts. Contact your FCM. | 2023-05-16 06:34:04.687
[2025-03-03 15:22:41]
my data feed not working again
[2025-03-03 17:33:38]
John - SC Support - Posts: 39362
The exchange(s) you had active did not renew on March 1, 2025, due to insufficient funds in your account at that time. You can re-activate the exchange(s) at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=RecurringServices
