Date/Time: Thu, 28 Nov 2024 11:03:22 +0000
Logon failed again, the same message popped up. Why does it happen so often?
View Count: 382
[2023-05-11 03:56:12]
User113238 - Posts: 16
https://www.sierrachart.com/image.php?Image=168377721356.png
[2023-05-11 05:00:11]
Sierra_Chart Engineering - Posts: 17201
This would be caused by using an older version of Sierra Chart. However, we see that you are running an up-to-date version of Sierra Chart at this time. Do you still have this issue? We cannot reproduce.
[2023-05-11 05:17:19]
The problem is still there.
https://www.sierrachart.com/image.php?Image=1683782177675.png
However, downloading $INX is not a problem.
https://www.sierrachart.com/image.php?Image=1683782524662.png
Date Time Of Last Edit: 2023-05-11 05:23:27
[2023-05-11 10:11:17]
Most likely you have custom symbols or changes to symbol settings causing the problem.
After that disable custom symbol settings:
Global Symbol Settings: Disabling Custom Symbol Settings
Date Time Of Last Edit: 2023-05-11 10:11:37
[2023-05-11 13:41:48]
I followed all your instructions but the issue persists.
I do not have customized symbols or even session time settings.
Date Time Of Last Edit: 2023-05-11 13:45:31
[2023-05-11 13:47:45]
Can we give you a call to look into this? Make sure your current telephone number is here:
https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo
Date Time Of Last Edit: 2023-05-11 13:47:55
[2023-05-11 14:02:19]
I found something changed. I used to type "XLB" to download data and it worked for the past five years.
But now, it will cause the problem I mentioned above. I have to type "XLB-NQTV" to make it work. Why?
[2023-05-11 14:07:08]
Those two symbols are actually different. One is NASDAQ TotalView and the other is the full consolidated tape.
Both symbols will work.
The other thing to do is to update Sierra Chart to the current version and see if that makes a difference but the version you have should be sufficient.
Instructions:
[2023-05-11 14:51:00]
User called and issue resolved. An update of Sierra Chart was necessary.
Date Time Of Last Edit: 2023-05-11 14:51:08
[2023-05-11 16:14:24]
User691948 - Posts: 3
Same issue here. Download QQQ failed. waiting for your new update.
[2023-05-11 16:19:07]
Downloaded latest version 2502 problem fixed.
