Date/Time: Thu, 28 Nov 2024 10:57:28 +0000
Real time data
View Count: 397
[2023-05-03 10:38:25] |
User644443 - Posts: 10 |
Hi, I am not receiving real time data. I have logged into my cqg account and back out then restarted sierra and nothing. Any more tips for this? I have paid for cme data via exchanges, anything else i can try? Cheers. |
[2023-05-03 14:52:07] |
Everything on your account looks good, so you should be getting the data for any symbol traded on the CME Exchange. If you are still having an issue, then please get us your Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-03 21:56:00] |
Hey, I have tried the above disconnect and re-connect prior to me contacting you but nothing. I will attach the message log: You will see from the log I am trying to connect to E-Mini S&P 500- Software version: 2459 64-bit | 2023-05-03 22:47:15.777 Primary Thread ID: 12716 | 2023-05-03 22:47:15.777 Usage end date: 2023-05-29 | 2023-05-03 22:47:15.777 Enabled for: Advanced Features 2. | 2023-05-03 22:47:15.777 Enabled for: Sierra Chart Historical Data Service. | 2023-05-03 22:47:15.777 Enabled for: Denali Real-Time Exchange Data Feed. | 2023-05-03 22:47:15.777 Enabled for: Delayed Denali Exchange Data Feed. | 2023-05-03 22:47:15.777 Enabled for exchange2: CME | 2023-05-03 22:47:15.777 Enabled for exchange2: fairx_exchange.data | 2023-05-03 22:47:15.777 Allow Support for Sierra Chart Data Feeds is disabled. | 2023-05-03 22:47:15.777 Current selected Data/Trading service: SC Data - All Services | 2023-05-03 22:47:15.777 Custom symbol settings values: enabled | 2023-05-03 22:47:15.777 Chart Update Interval: 500 | 2023-05-03 22:47:15.777 Intraday Data Storage Time Unit: 0 | 2023-05-03 22:47:15.777 Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2023-05-03 22:47:15.777 2023-05-03 21:47:15 Local computer time in UTC | 2023-05-03 22:47:15.777 2023-05-03 22:47:15 Local computer time in SC Time Zone | 2023-05-03 22:47:15.777 2023-05-03 09:42:49 Server time in UTC | 2023-05-03 22:47:15.777 Local computer UTC time and Server UTC time difference: 0 seconds. | 2023-05-03 22:47:15.777 Program path: C:\Sierra\ | 2023-05-03 22:47:15.777 Data Files path: C:\Sierra\Data\ | 2023-05-03 22:47:15.777 OS Version Number: 10.0 | 2023-05-03 22:47:15.778 Locale Setting: C | 2023-05-03 22:47:15.778 DLLs: UserContributedStudies_64.dll | 2023-05-03 22:47:15.779 Allowed protected custom studies: | 2023-05-03 22:47:15.779 Crash reporter started: true | 2023-05-03 22:47:15.779 ESH23-CME 10 Min #2 | Reloading chart. | 2023-05-03 22:48:55.697 SC DTC Delayed Exchange Data | Starting real-time market data updates for: ESH23-CME (ESH23). ID: 2 Service code: cme | 2023-05-03 22:48:57.868 SC DTC Delayed Exchange Data | Requesting security definition data for: ESH23-CME (ESH23). ID: 2 | 2023-05-03 22:48:57.868 SC DTC Delayed Exchange Data | Real-time data for symbol ESH23-CME is currently unavailable. | 2023-05-03 22:48:58.156 SC DTC Delayed Exchange Data | Received security definition for symbol ESH23-CME | 2023-05-03 22:48:58.156 |
[2023-05-04 03:02:38] |
User584084 - Posts: 262 |
1) Under Global Settings >> Data/Trade Service Settings >> Common Settings, Try "Allow Support for Sierra Chart Data Feed" = Yes. Yours is set to disabled. 2) The current ES contract is ESM23-CME (June 2023). Change your chart symbol in chart settings from ESH23-CME (March 2023 is expired) to ESM23-CME (June 2023). Date Time Of Last Edit: 2023-05-04 03:03:51
[2023-05-04 06:50:24] |
Really not sure why i loaded one singular chart of the old contract, my chartbook is using the correct one. It would appear that allowing the support for the data feed has corrected my issue. Many thanks. |
