Date/Time: Thu, 28 Nov 2024 12:46:42 +0000
Sierra chart not connecting
View Count: 374
[2023-05-02 16:44:26]
ssangha84 - Posts: 122
Hello, my Sierra chart is not connect for the last couple of hours. Here is the message log:
Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated | 2023-05-02 12:36:30.222
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 | 2023-05-02 12:36:30.234
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-05-02 12:36:30.238
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-05-02 12:36:30.239
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2023-05-02 12:36:30.239
HTTPS connection ID:27 to www.rithmic.com:443 for request ID:27 (4) | Creating socket. Using TLS 1.2. | 2023-05-02 12:36:50.319
HTTPS connection ID:27 to www.rithmic.com:443 for request ID:27 (4) | New receive buffer size: 32768 | 2023-05-02 12:36:50.319
HTTPS connection ID:27 to www.rithmic.com:443 for request ID:27 (4) | Connecting to IP: 38.79.0.89. | 2023-05-02 12:36:50.319
HTTPS connection ID:27 to www.rithmic.com:443 for request ID:27 (4) | New receive buffer size: 65536 | 2023-05-02 12:36:50.778
HTTPS connection ID:27 to www.rithmic.com:443 for request ID:27 (4) | Socket gracefully closed by remote side. | 2023-05-02 12:36:50.897
HTTPS connection ID:27 to www.rithmic.com:443 for request ID:27 (4) | CloseSocket call. | 2023-05-02 12:36:50.898
HTTPS connection ID:27 to www.rithmic.com:443 for request ID:27 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-05-02 12:36:50.899
HTTPS connection ID:27 to www.rithmic.com:443 for request ID:27 (4) | Closed. | 2023-05-02 12:36:50.899
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2023-05-02 12:36:51.289 *
DTC Client socket (1) | CloseSocket call. | 2023-05-02 12:36:51.291
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-05-02 12:36:51.291
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-05-02 12:36:51.291
DTC Client socket (1) | Closed. | 2023-05-02 12:36:51.291
DTC Client socket (0) | CloseSocket call. | 2023-05-02 12:36:51.380
Rithmic Direct - DTC | Disconnected. | 2023-05-02 12:36:51.380
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-05-02 12:36:51.380
Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated | 2023-05-02 12:36:55.426
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 | 2023-05-02 12:36:55.433
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-05-02 12:36:55.433
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-05-02 12:36:55.433
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2023-05-02 12:36:55.433
[2023-05-02 17:40:02]
John - SC Support - Posts: 36350
We can not say why there would be a problem connecting to Rithmic. Have you tried a different server?
[2023-05-02 17:55:11]
Yes. I tried CQG as well. Still not connecting:
CQG WebAPI | Connecting to server api.cqg.com | 2023-05-02 13:49:16.274
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2023-05-02 13:49:16.274
CQG WebSocket socket (3) | Creating socket. Using TLS 1.2. | 2023-05-02 13:49:16.275
CQG WebSocket socket (3) | New receive buffer size: 5242880 | 2023-05-02 13:49:16.275
CQG WebSocket socket (3) | Connecting to IP: 208.48.16.17. | 2023-05-02 13:49:16.275
F.US.CLEM23 [CS] 1 Min #10 | Reloading chart. | 2023-05-02 13:49:16.290
F.US.CLEM23 [CS] 1 Min #9 | Reloading chart. | 2023-05-02 13:49:16.317
Loaded depth data records for F.US.CLEM23 2023-04-26 from 2023-04-26 10:06:46.060000 to 2023-04-26 11:07:36.556000. | 2023-05-02 13:49:16.376
F.US.CLEM23 [CS] 1 Min #6 | StartDateTimeForLoadingOrderFills: 2023-03-31 09:49:00 | 2023-05-02 13:49:16.428
Chart #6 has tagged chart #3 for full recalculation. Chartbook: Oil Default.cht | 2023-05-02 13:49:16.448
F.US.CLEM23 [CS] 1 Min #6 | Reloading chart. | 2023-05-02 13:49:16.685
F.US.CLEM23 [CS] 1 Min #4 | Reloading chart. | 2023-05-02 13:49:17.337
F.US.CLEM23 [CS] 5 Min #1 | StartDateTimeForLoadingOrderFills: 2023-03-31 09:45:00 | 2023-05-02 13:49:17.501
F.US.CLEM23 [CS] 1 Min #5 | Reloading chart. | 2023-05-02 13:49:18.050
F.US.CLEM23 [CS] 15 Min #7 | Reloading chart. | 2023-05-02 13:49:18.156
Loading market depth data. | 2023-05-02 13:49:18.452
F.US.CLEM23 [CS] 1 Min #10 | StartDateTimeForLoadingOrderFills: 2023-03-31 09:49:00 | 2023-05-02 13:49:18.546
Loaded depth data records for F.US.CLEM23 2023-04-26 from 2023-04-26 10:06:46.060000 to 2023-04-26 11:07:36.556000. | 2023-05-02 13:49:18.600
F.US.CLEM23 [CS] 1 Min #9 | StartDateTimeForLoadingOrderFills: 2023-03-31 09:49:00 | 2023-05-02 13:49:18.600
F.US.CLEM23 [CS] 1 Min #6 | StartDateTimeForLoadingOrderFills: 2023-03-31 09:49:00 | 2023-05-02 13:49:18.710
Chart #6 has tagged chart #3 for full recalculation. Chartbook: Oil Default.cht | 2023-05-02 13:49:18.728
F.US.CLEM23 [CS] 5 Min #1 | Reloading chart. | 2023-05-02 13:49:19.108
F.US.CLEM23 [CS] 1 Min #5 | StartDateTimeForLoadingOrderFills: 2023-03-31 09:49:00 | 2023-05-02 13:49:19.274
F.US.CLEM23 [CS] 15 Min #7 | StartDateTimeForLoadingOrderFills: 2022-01-20 04:30:00 | 2023-05-02 13:49:19.456
F.US.CLEM23 [CS] 5 Min #1 | StartDateTimeForLoadingOrderFills: 2023-03-31 09:45:00 | 2023-05-02 13:49:20.151
F.US.CLEM23 [CS] 1 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: Oil Default.cht | 2023-05-02 13:49:20.272
CQG WebSocket socket (3) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2023-05-02 13:49:37.307 *
CQG WebSocket socket (3) | CloseSocket call. | 2023-05-02 13:49:37.314
CQG WebSocket | WebSocket closed. | 2023-05-02 13:49:37.314
CQG WebAPI | WebSocket closed. | 2023-05-02 13:49:37.314
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-05-02 13:49:37.314
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-05-02 13:49:37.314
CQG WebSocket socket (3) | Closed. | 2023-05-02 13:49:37.314
CQG WebSocket socket (0) | CloseSocket call. | 2023-05-02 13:49:37.408
CQG WebAPI | Disconnected. | 2023-05-02 13:49:37.408
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-05-02 13:49:37.409
CQG WebAPI | Connecting to server api.cqg.com | 2023-05-02 13:49:39.496
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2023-05-02 13:49:39.496
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2023-05-02 13:49:39.506
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2023-05-02 13:49:39.506
CQG WebSocket socket (1) | Connecting to IP: 208.48.16.17. | 2023-05-02 13:49:39.506
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2023-05-02 13:50:00.550 *
CQG WebSocket socket (1) | CloseSocket call. | 2023-05-02 13:50:00.554
CQG WebSocket | WebSocket closed. | 2023-05-02 13:50:00.554
CQG WebAPI | WebSocket closed. | 2023-05-02 13:50:00.554
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-05-02 13:50:00.554
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-05-02 13:50:00.554
CQG WebSocket socket (1) | Closed. | 2023-05-02 13:50:00.554
CQG WebSocket socket (0) | CloseSocket call. | 2023-05-02 13:50:00.684
CQG WebAPI | Disconnected. | 2023-05-02 13:50:00.684
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-05-02 13:50:00.684
CQG WebAPI | Connecting to server api.cqg.com | 2023-05-02 13:50:02.719
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2023-05-02 13:50:02.719
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2023-05-02 13:50:02.720
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2023-05-02 13:50:02.720
CQG WebSocket socket (1) | Connecting to IP: 208.48.16.17. | 2023-05-02 13:50:02.720
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2023-05-02 13:50:23.757 *
CQG WebSocket socket (1) | CloseSocket call. | 2023-05-02 13:50:23.760
CQG WebSocket | WebSocket closed. | 2023-05-02 13:50:23.760
CQG WebAPI | WebSocket closed. | 2023-05-02 13:50:23.760
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-05-02 13:50:23.760
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-05-02 13:50:23.760
CQG WebSocket socket (1) | Closed. | 2023-05-02 13:50:23.760
CQG WebSocket socket (0) | CloseSocket call. | 2023-05-02 13:50:23.952
CQG WebAPI | Disconnected. | 2023-05-02 13:50:23.952
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-05-02 13:50:23.952
CQG WebAPI | Connecting to server api.cqg.com | 2023-05-02 13:50:26.018
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2023-05-02 13:50:26.018
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2023-05-02 13:50:26.019
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2023-05-02 13:50:26.019
CQG WebSocket socket (1) | Connecting to IP: 208.48.16.17. | 2023-05-02 13:50:26.019
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2023-05-02 13:50:47.170 *
CQG WebSocket socket (1) | CloseSocket call. | 2023-05-02 13:50:47.177
CQG WebSocket | WebSocket closed. | 2023-05-02 13:50:47.177
CQG WebAPI | WebSocket closed. | 2023-05-02 13:50:47.177
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-05-02 13:50:47.177
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-05-02 13:50:47.177
CQG WebSocket socket (1) | Closed. | 2023-05-02 13:50:47.177
CQG WebSocket socket (0) | CloseSocket call. | 2023-05-02 13:50:47.470
CQG WebAPI | Disconnected. | 2023-05-02 13:50:47.470
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-05-02 13:50:47.470
CQG WebAPI | Connecting to server api.cqg.com | 2023-05-02 13:50:49.632
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2023-05-02 13:50:49.632
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2023-05-02 13:50:49.633
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2023-05-02 13:50:49.633
CQG WebSocket socket (1) | Connecting to IP: 208.48.16.17. | 2023-05-02 13:50:49.633
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2023-05-02 13:51:10.810 *
CQG WebSocket socket (1) | CloseSocket call. | 2023-05-02 13:51:10.812
CQG WebSocket | WebSocket closed. | 2023-05-02 13:51:10.812
CQG WebAPI | WebSocket closed. | 2023-05-02 13:51:10.812
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-05-02 13:51:10.812
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-05-02 13:51:10.812
CQG WebSocket socket (1) | Closed. | 2023-05-02 13:51:10.812
CQG WebSocket socket (0) | CloseSocket call. | 2023-05-02 13:51:10.985
CQG WebAPI | Disconnected. | 2023-05-02 13:51:10.985
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-05-02 13:51:10.985
[2023-05-03 13:36:48]
In both cases you are getting the following error:
This indicates a general network issue. Refer to the following:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
