Date/Time: Thu, 28 Nov 2024 16:37:02 +0000
Replaying linked charts
View Count: 397
[2023-04-14 08:17:57]
nicktrader - Posts: 713
I would like to jump in a M3 chart bar by bar. At the same time, the candles in M15 and M60 and also M1 should also follow these movements.
I have tried it with "To Next Time Increment" (with the Setting in Unit "00:03:00.000") but this didn't work properly. In the M3 Chart the candles are not jumped every 3 minutes?
Is there a way to do this?
Many thanks
[2023-04-14 16:08:19]
John - SC Support - Posts: 36350
Jumping "To Next Time Increment" does not move the chart forward by the amount set. Rather, it jumps to the next time interval that you have set. For example, with a 3 minute interval, it is going to jump to the next time that is evenly divisible by 3, such as 5:03, 5:06, 5:09, etc.
This should work. If it is not working properly for you, then let us know.
Additionally, the other charts that you have set to replay should do the same jump. We just tested this and it is working properly for us.
[2023-04-15 05:24:52]
Thank you John, but unfortunately I do not see the sense in it.
I want to jump e.g. a M3 chart bar by bar, but if I have this method (To Next Bar), the bar in M15 or M60 will also jump. And that is not what I want.
If bar by bar in M3, then in M15 or M60 the bars should only change by 3min and that's what I was hoping for with the method "To Next Time Increment".
The method "To Next Bar" would actually be the right choice, but then only the current chart should "jump" and the other linked charts only by this "time factor" of the current chart.
Many thanks
[2023-04-17 14:56:18]
We are not understanding why the option "To Next Time Increment" is not working for you. It should give you exactly what you are stating you want. When you jump forward by a 3 minute time increment, it will move you to the beginning of the next 3 minute bar and it will move the other charts to that same time location, keeping everything in sync.
[2023-04-17 15:28:28]
I am sorry, John. Everything works fine now. Last time I was shown completely wrong times. Maybe I had set a wrong time.
Thanks for the clarification, John.
