Date/Time: Thu, 28 Nov 2024 17:33:17 +0000
E-mini futures lack of intraday data
View Count: 309
[2023-04-11 14:52:02]
User75439 - Posts: 18
I'm using IB as my account and data service.
For some reason I do not see any Intra day data for emini futures.
(I do see intra day data for other products : Currency, USO, Stocks).
Please advise
[2023-04-11 15:56:38]
John - SC Support - Posts: 36350
Make sure you are using the proper symbol. One way is to use "File >> Find Symbol" and update/open a chart from that window.
You can also refer to the following information for IB symbols:
Interactive Brokers Symbols
If it is not a symbol issue then we would need to see your Message Log by following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Tell us about *one* symbol only.
[2023-04-11 20:55:00]
Sierra_Chart Engineering - Posts: 17204
You really need to use the Denali Data Feed . Complete the agreements here and activate the exchange you need:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliCME
This will bypass all of the data issues from Interactive Brokers. Let us know if you need help.
Full documentation is here:
Once that is all done:
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
Date Time Of Last Edit: 2023-04-11 20:55:23
