Date/Time: Tue, 26 Nov 2024 13:36:46 +0000
Connectivity issues
View Count: 655
[2023-04-06 14:57:03] |
User312718 - Posts: 23 |
I'm having a problem connecting.
[2023-04-06 17:16:26] |
John - SC Support - Posts: 36286 |
We need some additional information. Are you getting an error message, if so, what does it say? What are you having a problem connecting to? Anything else that will help us understand the issue. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-06 19:57:29] |
Sierra_Chart Engineering - Posts: 17179 |
We see that you are using Gain Capital. Who is your introducing broker? What exchanges are you trading. And we will help you with an alternative. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-06 20:13:41] |
StoneX Futures Support - Posts: 8 |
The issue is resolved on our side (StoneX). Please check again.
[2023-04-11 15:08:30] |
This is what keeps popping up. TradeActivity files query time: 0.059440 seconds. Entries: 0. Current queries: 2 | 2023-04-08 12:34:42.146 TradeActivity files query time: 0.000674 seconds. Entries: 0. Current queries: 1 | 2023-04-08 12:34:42.147 TradeActivity files query time: 0.025783 seconds. Entries: 42. Current queries: 1 | 2023-04-08 12:35:04.476 TradeActivity files query time: 0.000535 seconds. Entries: 0. Current queries: 2 | 2023-04-08 12:35:04.505 TradeActivity files query time: 0.027252 seconds. Entries: 42. Current queries: 1 | 2023-04-08 12:35:05.992 TradeActivity files query time: 0.004873 seconds. Entries: 42. Current queries: 1 | 2023-04-08 12:35:08.922 TradeActivity files query time: 0.004853 seconds. Entries: 42. Current queries: 1 | 2023-04-08 12:35:10.359 TradeActivity files query time: 0.005224 seconds. Entries: 42. Current queries: 1 | 2023-04-08 12:35:12.660 TradeActivity files query time: 0.004214 seconds. Entries: 42. Current queries: 1 | 2023-04-08 12:35:15.467 TradeActivity files query time: 0.120393 seconds. Entries: 42. Current queries: 1 | 2023-04-09 12:35:05.565 GAIN Capital/OEC | ALERT: Your password expired. We encourage you to change it. | 2023-04-10 02:03:26.095 SC Data - All Services | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 | 2023-04-10 02:03:27.162 SC Data - All Services | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 | 2023-04-10 02:03:27.162 TradeActivity files query time: 0.128991 seconds. Entries: 42. Current queries: 1 | 2023-04-10 02:03:29.351 GAIN Capital/OEC | ALERT: Your password expired. We encourage you to change it. | 2023-04-10 17:36:01.495 SC Data - All Services | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 | 2023-04-10 17:36:05.356 SC Data - All Services | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 | 2023-04-10 17:36:05.356 TradeActivity files query time: 0.119382 seconds. Entries: 42. Current queries: 1 | 2023-04-10 22:00:32.972 GAIN Capital/OEC | ALERT: Your password expired. We encourage you to change it. | 2023-04-11 07:31:07.258 SC Data - All Services | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 | 2023-04-11 07:31:14.167 SC Data - All Services | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 | 2023-04-11 07:31:14.167 SC Data - All Services | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 | 2023-04-11 07:37:29.117 SC Data - All Services | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 2 | 2023-04-11 07:37:29.117 GAIN Capital/OEC | ALERT: Your password expired. We encourage you to change it. | 2023-04-11 07:37:58.980 SC Data - All Services | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 | 2023-04-11 07:37:59.857 SC Data - All Services | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 | 2023-04-11 07:37:59.857 Sending 1 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:00:23 | 2023-04-11 15:00:26.559 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:00:27.037 * Sending 1 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:00:23 | 2023-04-11 15:00:36.544 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:00:37.016 * Sending 1 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:00:23 | 2023-04-11 15:00:46.548 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:00:47.044 * Sending 1 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:00:23 | 2023-04-11 15:00:56.547 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:00:57.023 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:01:06.556 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:01:07.042 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:01:16.546 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:01:17.661 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:01:26.545 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:01:27.024 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:01:36.546 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:01:37.024 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:01:46.546 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:01:47.017 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:01:56.550 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:01:57.032 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:02:06.555 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:02:07.027 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:02:16.547 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:02:17.024 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:02:26.552 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:02:27.023 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:02:36.567 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:02:37.044 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:02:46.577 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:02:47.402 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:02:56.591 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:02:57.072 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:03:06.584 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:03:07.423 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:03:16.600 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:03:17.076 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:03:26.605 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:03:27.382 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:03:36.609 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:03:37.087 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:03:46.621 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:03:47.105 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:03:56.618 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:03:57.093 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:04:06.616 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:04:07.088 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:04:16.611 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:04:17.091 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:04:26.607 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:04:27.744 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:04:36.607 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:04:37.090 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:04:46.607 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:04:47.076 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:04:56.615 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:04:57.095 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:05:06.617 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:05:07.082 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:05:16.614 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:05:17.096 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:05:26.615 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:05:27.743 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:05:36.616 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:05:37.095 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:05:46.611 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:05:47.097 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:05:56.625 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:05:57.107 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:06:06.627 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:06:07.107 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:06:16.633 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:06:17.118 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:06:26.630 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:06:27.105 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:06:36.623 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:06:37.402 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:06:46.632 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:06:47.104 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:06:56.638 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:06:57.120 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:07:06.639 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:07:07.117 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:07:16.638 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:07:17.119 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:07:26.638 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:07:27.121 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:07:36.660 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:07:37.138 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:07:46.672 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:07:47.151 * Sending 2 order fills to server. First fill date-time UTC: 2023-04-11 15:00:23. Last fill date-time UTC: 2023-04-11 15:01:03 | 2023-04-11 15:07:56.675 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-11 15:07:58.417 * |
Attachment Deleted. Screenshot 2023-04-11 110536.png / V - Attached On 2023-04-11 15:07:26 UTC - Size: 55.07 KB - 84 views |
[2023-04-11 15:20:32] |
We apologize for this. 1. Disable this option or set it to No (the option may not exist in your version): Global Settings >> General Trade Settings >> Send Order Fills to SC Web Server. 2. Exit from Sierra Chart 3. Delete this file: /TradeActivityLogs/OrderFillsToSend.data from within the Sierra Chart installation folder, if the file exists. This step is unnecessary if the Send Order Fills to SC Web Server option does not exist in your version. 4. Start Sierra Chart it again. The cause of the issue was a misconfiguration, of login data that Sierra Chart received last week which was promptly corrected. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-11 19:54:18] |
That seemed to have worked. Thank you for your help.
[2023-11-20 14:47:09] |
Good morning, I was unable to connect and then I updated the version but now I'm unable to enter a trade. Attached is the message log. I feel like there might be a setting under global settings that needs to be changed. Thank you Symbol settings could not be loaded because there are no applicable files to load. | 2023-11-20 07:48:28.101 Requested symbol settings for service code sc_futures_direct.dtc.trading. Request ID: 1. | 2023-11-20 07:48:28.102 Reading Internal Order ID file. | 2023-11-20 07:48:28.109 Reading Trade Orders file. | 2023-11-20 07:48:28.160 Reading Trade Positions file. | 2023-11-20 07:48:28.160 Reading Trade Account Data files. | 2023-11-20 07:48:28.160 Software version: 2564 64-bit | 2023-11-20 07:48:28.162 Primary Thread ID: 8476 | 2023-11-20 07:48:28.162 Usage end date: 2023-11-27 | 2023-11-20 07:48:28.162 Enabled for: Advanced Features 2. | 2023-11-20 07:48:28.162 Enabled for: Sierra Chart Historical Data Service. | 2023-11-20 07:48:28.162 Enabled for: Denali Real-Time Exchange Data Feed. | 2023-11-20 07:48:28.162 Enabled for: Delayed Denali Exchange Data Feed. | 2023-11-20 07:48:28.162 Enabled for exchange2: CME | 2023-11-20 07:48:28.162 Allow Support for Sierra Chart Data Feeds is enabled. | 2023-11-20 07:48:28.162 Current selected Data/Trading service: Generic | 2023-11-20 07:48:28.162 Custom symbol settings values: enabled | 2023-11-20 07:48:28.162 Chart Update Interval: 500 | 2023-11-20 07:48:28.162 Intraday Data Storage Time Unit: 0 | 2023-11-20 07:48:28.162 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2023-11-20 07:48:28.162 2023-11-20 12:48:28 Local computer time in UTC | 2023-11-20 07:48:28.162 2023-11-20 07:48:28 Local computer time in SC Time Zone | 2023-11-20 07:48:28.162 2023-11-20 12:48:27 Server time in UTC | 2023-11-20 07:48:28.162 Local computer UTC time and Server UTC time difference: 0 seconds. | 2023-11-20 07:48:28.162 Program path: C:\SierraChart\ | 2023-11-20 07:48:28.162 Data Files path: C:\SierraChart\Data\ | 2023-11-20 07:48:28.162 OS Version Number: 10.0 | 2023-11-20 07:48:28.162 Locale Setting: C | 2023-11-20 07:48:28.162 DLLs: UserContributedStudies_64.dll | 2023-11-20 07:48:28.162 Allowed protected custom studies: | 2023-11-20 07:48:28.162 Crash reporter started: true | 2023-11-20 07:48:28.162 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-11-20 07:48:28.203 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-11-20 07:48:28.280 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-11-20 07:48:28.281 Received 5 login tokens. | 2023-11-20 07:48:28.457 Symbol settings received. Request ID: 1. | 2023-11-20 07:48:30.117 Requested user files to download. | 2023-11-20 07:48:30.718 Generic | Connected to server complete. | 2023-11-20 07:48:32.722 No download requests in the queue to start downloads for. | 2023-11-20 07:48:32.722 No download requests in the queue to start downloads for. | 2023-11-20 07:48:32.722 No download requests in the queue to start downloads for. | 2023-11-20 07:48:32.722 No download requests in the queue to start downloads for. | 2023-11-20 07:48:32.722 Files to Open on Startup | Opening file: ExampleChartbook.cht | 2023-11-20 07:48:35.944 XAUUSD 1 Min #1 | Reloading chart. | 2023-11-20 07:48:35.964 XAUUSD Daily #2 | Reloading chart. | 2023-11-20 07:48:35.981 US30 1 Min #3 | Reloading chart. | 2023-11-20 07:48:35.999 USOil 1 Min #4 | Reloading chart. | 2023-11-20 07:48:36.020 ESM22-CME 1 Min #5 | Reloading chart. | 2023-11-20 07:48:36.040 SPX500 Daily #6 | Reloading chart. | 2023-11-20 07:48:36.060 EURUSD Daily #7 | Reloading chart. | 2023-11-20 07:48:36.080 EURUSD 5 Min #8 | Reloading chart. | 2023-11-20 07:48:36.101 ESM22-CME #9 | Reloading chart. | 2023-11-20 07:48:36.114 ESM22-CME 1 Min #10 | Reloading chart. | 2023-11-20 07:48:36.275 AAPL-NQTV 5 Min #11 | Reloading chart. | 2023-11-20 07:48:36.315 Repeating the loading process because the chart parameters changed. | 2023-11-20 07:48:36.333 Restarting the loading process. | 2023-11-20 07:48:36.333 Enabling compression for file: C:\SierraChart\Data\ESM22_FUT_CME.scid | 2023-11-20 07:48:36.339 Repeating the loading process because the chart parameters changed. | 2023-11-20 07:48:36.357 Restarting the loading process. | 2023-11-20 07:48:36.357 Repeating the loading process because the chart parameters changed. | 2023-11-20 07:48:36.375 Restarting the loading process. | 2023-11-20 07:48:36.375 ESM22_FUT_CME 1 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM22_FUT_CME.scid | 2023-11-20 07:48:36.376 ESM22_FUT_CME #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM22_FUT_CME.scid | 2023-11-20 07:48:36.378 ESM22_FUT_CME 1 Min #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM22_FUT_CME.scid | 2023-11-20 07:48:36.379 ESZ23_FUT_CME 1 Min #5 | Reloading chart. | 2023-11-20 07:48:36.530 Enabling compression for file: C:\SierraChart\Data\ESZ23_FUT_CME.scid | 2023-11-20 07:48:36.533 ESZ23_FUT_CME 1 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ23_FUT_CME.scid | 2023-11-20 07:48:36.535 ESZ23_FUT_CME #9 | Reloading chart. | 2023-11-20 07:48:36.610 ESZ23_FUT_CME #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ23_FUT_CME.scid | 2023-11-20 07:48:36.612 ESZ23_FUT_CME 1 Min #10 | Reloading chart. | 2023-11-20 07:48:36.777 ESZ23_FUT_CME 1 Min #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ23_FUT_CME.scid | 2023-11-20 07:48:36.779 Using Bid/Ask average for last trade price for XAUUSD | 2023-11-20 07:48:36.961 Using symbol data fast lookup vector | 2023-11-20 07:48:36.961 SC Data with Depth | Starting real-time market data updates for: XAUUSD. ID: 1 Service code: fxcm | 2023-11-20 07:48:36.961 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-11-20 07:48:36.963 SC Data with Depth | Requesting security definition data for: XAUUSD. ID: 1 | 2023-11-20 07:48:36.965 Starting DelayedDownloadMonitoringTimer | 2023-11-20 07:48:36.965 Starting HDTimeoutTimer | 2023-11-20 07:48:36.965 Added historical Intraday data request for XAUUSD to the queue. | 2023-11-20 07:48:36.965 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2023-11-20 07:48:36.965 Triggering next historical data download in queue. | 2023-11-20 07:48:36.967 Delaying start of download for XAUUSD. | 2023-11-20 07:48:36.971 DTC Client socket (1) | Creating socket. | 2023-11-20 07:48:36.982 DTC Client socket (1) | New receive buffer size: 0 | 2023-11-20 07:48:36.982 DTC Client socket (1) | Connecting to IP: 142.215.18.101. | 2023-11-20 07:48:36.982 Added historical Daily data request for XAUUSD to the queue. | 2023-11-20 07:48:36.991 Triggering next historical data download in queue. | 2023-11-20 07:48:36.991 Using Bid/Ask average for last trade price for US30 | 2023-11-20 07:48:37.007 SC Data with Depth | Starting real-time market data updates for: US30. ID: 2 Service code: fxcm | 2023-11-20 07:48:37.007 SC Data with Depth | Requesting security definition data for: US30. ID: 2 | 2023-11-20 07:48:37.007 Added historical Intraday data request for US30 to the queue. | 2023-11-20 07:48:37.007 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2023-11-20 07:48:37.007 Triggering next historical data download in queue. | 2023-11-20 07:48:37.007 SC Data with Depth | Network connection to server complete. | 2023-11-20 07:48:37.019 SC Data with Depth | Starting socket receive thread. | 2023-11-20 07:48:37.019 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-11-20 07:48:37.020 Using Bid/Ask average for last trade price for USOil | 2023-11-20 07:48:37.076 SC Data with Depth | Starting real-time market data updates for: USOil. ID: 3 Service code: fxcm | 2023-11-20 07:48:37.076 SC Data with Depth | Requesting security definition data for: USOil. ID: 3 | 2023-11-20 07:48:37.076 Added historical Intraday data request for USOil to the queue. | 2023-11-20 07:48:37.076 Intraday data recording state for symbol USOil is set to download 'Pending'. | 2023-11-20 07:48:37.076 Triggering next historical data download in queue. | 2023-11-20 07:48:37.076 Mapping ESZ23_FUT_CME to ESZ23. Service code: cme | 2023-11-20 07:48:37.080 Denali Data Feed | Starting real-time market data updates for: ESZ23_FUT_CME (ESZ23). ID: 4 Service code: cme | 2023-11-20 07:48:37.080 Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 10048 | 2023-11-20 07:48:37.081 DTC Client socket (2) | Creating socket. | 2023-11-20 07:48:37.082 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-20 07:48:37.082 DTC Client socket (2) | Connecting to IP: 142.215.18.147. | 2023-11-20 07:48:37.082 Denali Data Feed | Requesting security definition data for: ESZ23_FUT_CME (ESZ23). ID: 4 | 2023-11-20 07:48:37.083 Added historical Intraday data request for ESZ23_FUT_CME to the queue. | 2023-11-20 07:48:37.083 Intraday data recording state for symbol ESZ23_FUT_CME is set to download 'Pending'. | 2023-11-20 07:48:37.083 Triggering next historical data download in queue. | 2023-11-20 07:48:37.083 Added historical Daily data request for SPX500 to the queue. | 2023-11-20 07:48:37.085 Triggering next historical data download in queue. | 2023-11-20 07:48:37.085 Using Bid/Ask average for last trade price for SPX500 | 2023-11-20 07:48:37.085 SC Data with Depth | Starting real-time market data updates for: SPX500. ID: 5 Service code: fxcm | 2023-11-20 07:48:37.085 SC Data with Depth | Requesting security definition data for: SPX500. ID: 5 | 2023-11-20 07:48:37.085 Added historical Daily data request for EURUSD to the queue. | 2023-11-20 07:48:37.088 Triggering next historical data download in queue. | 2023-11-20 07:48:37.088 Using Bid/Ask average for last trade price for EURUSD | 2023-11-20 07:48:37.088 SC Data with Depth | Starting real-time market data updates for: EURUSD. ID: 6 Service code: fxcm | 2023-11-20 07:48:37.089 SC Data with Depth | Requesting security definition data for: EURUSD. ID: 6 | 2023-11-20 07:48:37.089 Added historical Intraday data request for EURUSD to the queue. | 2023-11-20 07:48:37.092 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2023-11-20 07:48:37.092 Triggering next historical data download in queue. | 2023-11-20 07:48:37.092 SC Data with Depth | Setting DTC encoding to Binary VLS | 2023-11-20 07:48:37.103 SC Data with Depth | Sending logon request message. | 2023-11-20 07:48:37.103 Denali Data Feed | Network connection to server complete. | 2023-11-20 07:48:37.120 Denali Data Feed | Starting socket receive thread. | 2023-11-20 07:48:37.120 Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-11-20 07:48:37.120 Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-11-20 07:48:37.185 Denali Data Feed | Sending logon request message. | 2023-11-20 07:48:37.185 Mapping AAPL-NQTV to AAPL-NQTV. Service code: nasdaq_exchange.data | 2023-11-20 07:48:37.330 Delayed Data Feed | Starting real-time market data updates for: AAPL-NQTV (AAPL-NQTV). ID: 7 Service code: nasdaq_exchange.data | 2023-11-20 07:48:37.330 Delayed Data Feed | Connecting to the server ds31.sierracharts.com. Port 10043 | 2023-11-20 07:48:37.332 Delayed Data Feed | Requesting security definition data for: AAPL-NQTV (AAPL-NQTV). ID: 7 | 2023-11-20 07:48:37.333 Added historical Intraday data request for AAPL-NQTV to the queue. | 2023-11-20 07:48:37.333 Intraday data recording state for symbol AAPL-NQTV is set to download 'Pending'. | 2023-11-20 07:48:37.333 Triggering next historical data download in queue. | 2023-11-20 07:48:37.333 DTC Client socket (3) | Creating socket. | 2023-11-20 07:48:37.359 DTC Client socket (3) | New receive buffer size: 0 | 2023-11-20 07:48:37.359 DTC Client socket (3) | Connecting to IP: 142.215.18.107. | 2023-11-20 07:48:37.359 Delayed Data Feed | Network connection to server complete. | 2023-11-20 07:48:37.392 Delayed Data Feed | Starting socket receive thread. | 2023-11-20 07:48:37.392 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-11-20 07:48:37.392 SC Data with Depth | Received logon response. | 2023-11-20 07:48:37.415 SC Data with Depth | Server Name: SC Realtime Server. | 2023-11-20 07:48:37.415 SC Data with Depth | Server protocol version: 8. Client protocol version: 8 | 2023-11-20 07:48:37.415 SC Data with Depth | Successfully connected. | 2023-11-20 07:48:37.415 SC Data with Depth | Trading is not supported. | 2023-11-20 07:48:37.415 SC Data with Depth | Restarting real-time data updates for symbol: EURUSD | 2023-11-20 07:48:37.416 SC Data with Depth | Restarting real-time data updates for symbol: SPX500 | 2023-11-20 07:48:37.416 SC Data with Depth | Restarting real-time data updates for symbol: US30 | 2023-11-20 07:48:37.416 SC Data with Depth | Restarting real-time data updates for symbol: USOil | 2023-11-20 07:48:37.416 SC Data with Depth | Restarting real-time data updates for symbol: XAUUSD | 2023-11-20 07:48:37.416 Delayed Data Feed | Setting DTC encoding to Binary VLS | 2023-11-20 07:48:37.435 Delayed Data Feed | Sending logon request message. | 2023-11-20 07:48:37.435 SC Data with Depth | Received security definition for symbol EURUSD | 2023-11-20 07:48:37.539 SC Data with Depth | Received security definition for symbol SPX500 | 2023-11-20 07:48:37.539 SC Data with Depth | Received security definition for symbol US30 | 2023-11-20 07:48:37.539 SC Data with Depth | Received security definition for symbol USOil | 2023-11-20 07:48:37.539 SC Data with Depth | Received security definition for symbol XAUUSD | 2023-11-20 07:48:37.539 Denali Data Feed | Received logon response. | 2023-11-20 07:48:37.682 Denali Data Feed | Server Name: SC Realtime Server. | 2023-11-20 07:48:37.682 Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-11-20 07:48:37.682 Denali Data Feed | Successfully connected. | 2023-11-20 07:48:37.682 Denali Data Feed | Trading is not supported. | 2023-11-20 07:48:37.682 Denali Data Feed | Restarting real-time data updates for symbol: ESZ23_FUT_CME -> ESZ23 | 2023-11-20 07:48:37.682 Delayed Data Feed | Received logon response. | 2023-11-20 07:48:37.747 Delayed Data Feed | Server Name: SC Realtime Server. | 2023-11-20 07:48:37.747 Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-11-20 07:48:37.747 Delayed Data Feed | Successfully connected. | 2023-11-20 07:48:37.747 Delayed Data Feed | Trading is not supported. | 2023-11-20 07:48:37.747 Delayed Data Feed | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV | 2023-11-20 07:48:37.747 Denali Data Feed | Received security definition for symbol ESZ23_FUT_CME | 2023-11-20 07:48:37.808 Delayed Data Feed | Received security definition for symbol AAPL-NQTV | 2023-11-20 07:48:37.875 HD Request # 1 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2023-11-20 07:48:42.992 HD Request # 1 | Download start date-time: 2023-05-18 08:48:42.000000. File last date-time: 2023-01-12 10:16:01.540000 | 2023-11-20 07:48:42.992 HD Request # 1 | Using server: ds12.sierracharts.com port 10149 | 2023-11-20 07:48:42.992 Socket (4) | Creating socket. | 2023-11-20 07:48:42.993 Socket (4) | New receive buffer size: 0 | 2023-11-20 07:48:42.993 Socket (4) | Connecting to IP: 142.215.18.101. | 2023-11-20 07:48:42.993 HD Request # 1 | Setting DTC encoding to Binary VLS | 2023-11-20 07:48:43.081 HD Request # 1 | Sending historical data logon request message. | 2023-11-20 07:48:43.081 HD Request # 1 | Requesting Intraday data. Start date-time: 2023-05-18 08:48:42. Record interval: 0. Symbol: XAUUSD | 2023-11-20 07:48:43.316 HD Request # 1 | Decompressing data. | 2023-11-20 07:48:43.354 HD Request # 1 | Receiving Intraday data for XAUUSD starting at 2023-05-18 08:48:42.005000 | 2023-11-20 07:48:43.480 HD Request # 1 | Timestamp of first Intraday data file record written: 2023-05-18 08:48:42.005000. | 2023-11-20 07:48:43.599 ESZ23 3560 Trades #1 | Reloading chart. | 2023-11-20 07:48:49.630 ESZ23 Point & Figure 1-4 #3 | Reloading chart. | 2023-11-20 07:48:49.780 ESZ23 36 Trades #5 | Reloading chart. | 2023-11-20 07:48:49.917 ESZ23 Daily #8 | Reloading chart. | 2023-11-20 07:48:49.928 NQZ23 10 Min #9 | Reloading chart. | 2023-11-20 07:48:49.953 ESZ23 1 Min #11 | Reloading chart. | 2023-11-20 07:48:49.973 ESZ23 #14 | Reloading chart. | 2023-11-20 07:48:49.993 ESZ23 5000 Volume #12 | Reloading chart. | 2023-11-20 07:48:50.025 ESZ23 10 Min #16 | Reloading chart. | 2023-11-20 07:48:50.047 ESZ23 Point & Figure 1-8 #18 | Reloading chart. | 2023-11-20 07:48:50.084 ESZ23 1250 Volume #15 | Reloading chart. | 2023-11-20 07:48:50.122 ESZ23 60 Min #20 | Reloading chart. | 2023-11-20 07:48:50.157 ESZ23 500 Volume #23 | Reloading chart. | 2023-11-20 07:48:50.432 ESZ23 250 Volume #24 | Reloading chart. | 2023-11-20 07:48:50.681 ESZ23 10 Min #22 | Reloading chart. | 2023-11-20 07:48:50.712 NQZ23 Point & Figure 1-8 #26 | Reloading chart. | 2023-11-20 07:48:50.743 ESZ23 Point & Figure 1-4 #27 | Reloading chart. | 2023-11-20 07:48:50.773 ESZ23 3560 Trades #2 | Reloading chart. | 2023-11-20 07:48:50.924 NQZ23 Point & Figure 1-4 #4 | Reloading chart. | 2023-11-20 07:48:50.986 NQZ23 Point & Figure 1-8 #6 | Reloading chart. | 2023-11-20 07:48:51.048 ESZ23 #7 | Reloading chart. | 2023-11-20 07:48:51.478 ESZ23 15000 Volume #10 | Reloading chart. | 2023-11-20 07:48:51.531 Repeating the loading process because the chart parameters changed. | 2023-11-20 07:48:51.550 Restarting the loading process. | 2023-11-20 07:48:51.550 Repeating the loading process because the chart parameters changed. | 2023-11-20 07:48:51.572 Restarting the loading process. | 2023-11-20 07:48:51.572 ESZ23_FUT_CME #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-20 07:48:51.574 ESZ23 Daily #8 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ23_FUT_CME.dly | 2023-11-20 07:48:51.686 ESZ23_FUT_CME 3560 Trades #1 | Reloading chart. | 2023-11-20 07:48:51.982 ESZ23 3560 Trades #1 | Chart Data Loading Thread: Load canceled. | 2023-11-20 07:48:51.983 Restarting the loading process. | 2023-11-20 07:48:51.983 ESZ23_FUT_CME Point & Figure 1-4 #3 | Reloading chart. | 2023-11-20 07:48:51.994 ESZ23_FUT_CME 3560 Trades #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ23_FUT_CME.scid | 2023-11-20 07:48:51.994 Loading market depth data. | 2023-11-20 07:48:51.997 ESZ23 Point & Figure 1-4 #3 | Chart Data Loading Thread: Load canceled. | 2023-11-20 07:48:51.999 Restarting the loading process. | 2023-11-20 07:48:52.010 Enabling compression for file: C:\SierraChart\Data\ESZ23_FUT_CME.dly | 2023-11-20 07:48:52.013 ESZ23_FUT_CME Daily #8 | Reloading chart. | 2023-11-20 07:48:52.014 Loading market depth data. | 2023-11-20 07:48:52.057 ESZ23_FUT_CME Daily #8 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ23_FUT_CME.dly | 2023-11-20 07:48:52.062 ESZ23_FUT_CME Point & Figure 1-4 #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ23_FUT_CME.scid | 2023-11-20 07:48:52.064 ESZ23_FUT_CME 36 Trades #5 | Reloading chart. | 2023-11-20 07:48:52.067 Enabling compression for file: C:\SierraChart\Data\NQZ23_FUT_CME.scid | 2023-11-20 07:48:52.071 ESZ23 36 Trades #5 | Chart Data Loading Thread: Load canceled. | 2023-11-20 07:48:52.081 NQZ23_FUT_CME 10 Min #9 | Reloading chart. | 2023-11-20 07:48:52.085 Restarting the loading process. | 2023-11-20 07:48:52.085 NQZ23 10 Min #9 | Chart Data Loading Thread: Load canceled. | 2023-11-20 07:48:52.089 ESZ23_FUT_CME 1 Min #11 | Reloading chart. | 2023-11-20 07:48:52.090 Restarting the loading process. | 2023-11-20 07:48:52.090 ESZ23 1 Min #11 | Chart Data Loading Thread: Load canceled. | 2023-11-20 07:48:52.091 Restarting the loading process. | 2023-11-20 07:48:52.093 ESZ23_FUT_CME #14 | Reloading chart. | 2023-11-20 07:48:52.096 ESZ23 #14 | Chart Data Loading Thread: Load canceled. | 2023-11-20 07:48:52.096 ESZ23_FUT_CME 36 Trades #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ23_FUT_CME.scid | 2023-11-20 07:48:52.096 NQZ23_FUT_CME 10 Min #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQZ23_FUT_CME.scid | 2023-11-20 07:48:52.097 Restarting the loading process. | 2023-11-20 07:48:52.097 ESZ23_FUT_CME 1 Min #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ23_FUT_CME.scid | 2023-11-20 07:48:52.098 ESZ23_FUT_CME 5000 Volume #12 | Reloading chart. | 2023-11-20 07:48:52.102 ESZ23 5000 Volume #12 | Chart Data Loading Thread: Load canceled. | 2023-11-20 07:48:52.102 Restarting the loading process. | 2023-11-20 07:48:52.103 ESZ23_FUT_CME #14 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ23_FUT_CME.scid | 2023-11-20 07:48:52.104 ESZ23_FUT_CME 5000 Volume #12 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ23_FUT_CME.scid | 2023-11-20 07:48:52.105 ESZ23_FUT_CME 10 Min #16 | Reloading chart. | 2023-11-20 07:48:52.107 ESZ23 10 Min #16 | Chart Data Loading Thread: Load canceled. | 2023-11-20 07:48:52.107 ESZ23_FUT_CME Point & Figure 1-8 #18 | Reloading chart. | 2023-11-20 07:48:52.108 Loading market depth data. | 2023-11-20 07:48:52.108 ESZ23 Point & Figure 1-8 #18 | Chart Data Loading Thread: Load canceled. | 2023-11-20 07:48:52.108 Restarting the loading process. | 2023-11-20 07:48:52.108 Restarting the loading process. | 2023-11-20 07:48:52.109 Loading market depth data. | 2023-11-20 07:48:52.111 ESZ23_FUT_CME 10 Min #16 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ23_FUT_CME.scid | 2023-11-20 07:48:52.111 ESZ23_FUT_CME Point & Figure 1-8 #18 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ23_FUT_CME.scid | 2023-11-20 07:48:52.111 ESZ23_FUT_CME 1250 Volume #15 | Reloading chart. | 2023-11-20 07:48:52.118 ESZ23 1250 Volume #15 | Chart Data Loading Thread: Load canceled. | 2023-11-20 07:48:52.118 Restarting the loading process. | 2023-11-20 07:48:52.119 ESZ23_FUT_CME 1250 Volume #15 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ23_FUT_CME.scid | 2023-11-20 07:48:52.122 ESZ23_FUT_CME 60 Min #20 | Reloading chart. | 2023-11-20 07:48:52.124 ESZ23 60 Min #20 | Chart Data Loading Thread: Load canceled. | 2023-11-20 07:48:52.124 Restarting the loading process. | 2023-11-20 07:48:52.125 ESZ23_FUT_CME 60 Min #20 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ23_FUT_CME.scid | 2023-11-20 07:48:52.127 ESZ23_FUT_CME 500 Volume #23 | Reloading chart. | 2023-11-20 07:48:52.240 ESZ23 500 Volume #23 | Chart Data Loading Thread: Load canceled. | 2023-11-20 07:48:52.240 Restarting the loading process. | 2023-11-20 07:48:52.240 ESZ23_FUT_CME 500 Volume #23 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ23_FUT_CME.scid | 2023-11-20 07:48:52.242 ESZ23_FUT_CME 250 Volume #24 | Reloading chart. | 2023-11-20 07:48:52.245 ESZ23 250 Volume #24 | Chart Data Loading Thread: Load canceled. | 2023-11-20 07:48:52.245 Restarting the loading process. | 2023-11-20 07:48:52.247 ESZ23_FUT_CME 10 Min #22 | Reloading chart. | 2023-11-20 07:48:52.249 ESZ23 10 Min #22 | Chart Data Loading Thread: Load canceled. | 2023-11-20 07:48:52.249 ESZ23_FUT_CME 250 Volume #24 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ23_FUT_CME.scid | 2023-11-20 07:48:52.250 Restarting the loading process. | 2023-11-20 07:48:52.252 NQZ23_FUT_CME Point & Figure 1-8 #26 | Reloading chart. | 2023-11-20 07:48:52.254 NQZ23 Point & Figure 1-8 #26 | Chart Data Loading Thread: Load canceled. | 2023-11-20 07:48:52.254 ESZ23_FUT_CME 10 Min #22 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ23_FUT_CME.scid | 2023-11-20 07:48:52.254 Restarting the loading process. | 2023-11-20 07:48:52.254 ESZ23_FUT_CME Point & Figure 1-4 #27 | Reloading chart. | 2023-11-20 07:48:52.256 ESZ23 Point & Figure 1-4 #27 | Chart Data Loading Thread: Load canceled. | 2023-11-20 07:48:52.256 NQZ23_FUT_CME Point & Figure 1-8 #26 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQZ23_FUT_CME.scid | 2023-11-20 07:48:52.257 Restarting the loading process. | 2023-11-20 07:48:52.257 ESZ23_FUT_CME 3560 Trades #2 | Reloading chart. | 2023-11-20 07:48:52.290 Loading market depth data. | 2023-11-20 07:48:52.290 ESZ23 3560 Trades #2 | Chart Data Loading Thread: Load canceled. | 2023-11-20 07:48:52.290 ESZ23_FUT_CME Point & Figure 1-4 #27 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ23_FUT_CME.scid | 2023-11-20 07:48:52.291 Restarting the loading process. | 2023-11-20 07:48:52.291 Loading market depth data. | 2023-11-20 07:48:52.291 NQZ23_FUT_CME Point & Figure 1-4 #4 | Reloading chart. | 2023-11-20 07:48:52.292 Loading market depth data. | 2023-11-20 07:48:52.292 NQZ23 Point & Figure 1-4 #4 | Chart Data Loading Thread: Load canceled. | 2023-11-20 07:48:52.292 ESZ23_FUT_CME 3560 Trades #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ23_FUT_CME.scid | 2023-11-20 07:48:52.292 Restarting the loading process. | 2023-11-20 07:48:52.292 Loading market depth data. | 2023-11-20 07:48:52.293 NQZ23_FUT_CME Point & Figure 1-4 #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQZ23_FUT_CME.scid | 2023-11-20 07:48:52.293 NQZ23_FUT_CME Point & Figure 1-8 #6 | Reloading chart. | 2023-11-20 07:48:52.295 Loading market depth data. | 2023-11-20 07:48:52.295 NQZ23 Point & Figure 1-8 #6 | Chart Data Loading Thread: Load canceled. | 2023-11-20 07:48:52.295 Restarting the loading process. | 2023-11-20 07:48:52.295 Loading market depth data. | 2023-11-20 07:48:52.296 NQZ23_FUT_CME Point & Figure 1-8 #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQZ23_FUT_CME.scid | 2023-11-20 07:48:52.296 ESZ23_FUT_CME #7 | Reloading chart. | 2023-11-20 07:48:52.296 ESZ23_FUT_CME #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-20 07:48:52.300 ESZ23_FUT_CME 15000 Volume #10 | Reloading chart. | 2023-11-20 07:48:52.342 ESZ23 15000 Volume #10 | Chart Data Loading Thread: Load canceled. | 2023-11-20 07:48:52.342 Restarting the loading process. | 2023-11-20 07:48:52.344 ESZ23_FUT_CME 15000 Volume #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ23_FUT_CME.scid | 2023-11-20 07:48:52.350 Requesting market depth updates for: ESZ23_FUT_CME if supported. NumLevels=100 | 2023-11-20 07:48:52.497 Starting DelayedDownloadMonitoringTimer | 2023-11-20 07:48:52.526 Starting HDTimeoutTimer | 2023-11-20 07:48:52.526 Added historical Daily data request for ESZ23_FUT_CME to the queue. | 2023-11-20 07:48:52.526 Triggering next historical data download in queue. | 2023-11-20 07:48:52.528 HD Request # 2 | Downloading Historical Daily chart data for ESZ23_FUT_CME. Starting date: 1973-12-02. Service: generic.dtc.data | 2023-11-20 07:48:52.532 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ23_FUT_CME.2023-11-20.depth | 2023-11-20 07:48:52.583 Denali Data Feed | Clearing market depth for ESZ23_FUT_CME | 2023-11-20 07:48:52.583 Mapping NQZ23_FUT_CME to NQZ23. Service code: cme | 2023-11-20 07:48:52.592 Denali Data Feed | Starting real-time market data updates for: NQZ23_FUT_CME (NQZ23). ID: 8 Service code: cme | 2023-11-20 07:48:52.592 Denali Data Feed | Requesting security definition data for: NQZ23_FUT_CME (NQZ23). ID: 8 | 2023-11-20 07:48:52.592 Added historical Intraday data request for NQZ23_FUT_CME to the queue. | 2023-11-20 07:48:52.592 Intraday data recording state for symbol NQZ23_FUT_CME is set to download 'Pending'. | 2023-11-20 07:48:52.592 Triggering next historical data download in queue. | 2023-11-20 07:48:52.592 Denali Data Feed | Received security definition for symbol NQZ23_FUT_CME | 2023-11-20 07:48:52.708 Requesting market depth updates for: NQZ23_FUT_CME if supported. NumLevels=100 | 2023-11-20 07:48:52.713 Denali Data Feed | Clearing market depth for NQZ23_FUT_CME | 2023-11-20 07:48:52.833 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NQZ23_FUT_CME.2023-11-20.depth | 2023-11-20 07:48:52.834 HD Request # 2 | Requesting historical Daily data for ESZ23 starting at 1973-12-01. SC External HD service. | 2023-11-20 07:48:52.948 HD Request # 2 | Receiving historical Daily data for ESZ23_FUT_CME starting at 2021-06-04. | 2023-11-20 07:48:53.074 HD Request # 2 | Writing historical Daily data to the file ESZ23_FUT_CME.dly. | 2023-11-20 07:48:53.074 HD Request # 2 | Bytes received: 31209 | 2023-11-20 07:48:53.077 HD Request # 2 | Received 621 Daily data records from 2021-06-04 00:00:00 to 2023-11-17 00:00:00 (2.5 years) and wrote 621 records for ESZ23_FUT_CME | 2023-11-20 07:48:53.077 HD Request # 2 | Completion time: 1s. | 2023-11-20 07:48:53.077 HD Request # 2 | Daily data download complete for ESZ23_FUT_CME. Unique request ID: 10 | 2023-11-20 07:48:53.077 Removing historical data download ID 10. | 2023-11-20 07:48:53.077 No download requests in the queue to start downloads for. | 2023-11-20 07:48:53.077 ESZ23_FUT_CME[M] Daily #8 | Reloading chart. | 2023-11-20 07:48:53.529 ESZ23_FUT_CME[M] Daily #8 | Reloading chart. | 2023-11-20 07:49:02.015 Socket (4) | CloseSocket call. | 2023-11-20 07:50:07.463 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-11-20 07:50:07.463 Historical data download thread signaled to stop. | 2023-11-20 07:50:07.463 HD Request # 1 | Received 46603940 Intraday data records from 2023-05-18 08:48:42.005000 to 2023-11-20 07:50:05.588000 (186.0 days. Delay: 1.9 seconds) and wrote 46603940 records for XAUUSD | 2023-11-20 07:50:07.463 HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2023-11-20 12:50:05.588000 | 2023-11-20 07:50:07.468 Added 2 Time and Sales records to Intraday data file for XAUUSD after download. | 2023-11-20 07:50:07.468 HD Request # 1 | Completion time: 1m 25s. | 2023-11-20 07:50:07.468 HD Request # 1 | Intraday data download complete for XAUUSD. Unique request ID: 1 | 2023-11-20 07:50:07.468 Removing historical data download ID 1. | 2023-11-20 07:50:07.468 Real-time Intraday chart data file updates started for XAUUSD | 2023-11-20 07:50:07.468 Intraday chart data file opened for XAUUSD | 2023-11-20 07:50:07.469 HD Request # 1 | Enabling Intraday chart updating for symbol. | 2023-11-20 07:50:07.469 Triggering next historical data download in queue. | 2023-11-20 07:50:07.469 HD Request # 3 | Downloading Historical Daily chart data for XAUUSD. Starting date: 2023-01-10. Service: fxcm | 2023-11-20 07:50:07.469 HD Request # 3 | Using server: ds13-2.sierracharts.com port 10150 | 2023-11-20 07:50:07.470 Socket (5) | Creating socket. | 2023-11-20 07:50:07.490 Socket (5) | New receive buffer size: 0 | 2023-11-20 07:50:07.490 Socket (5) | Connecting to IP: 162.251.232.245. | 2023-11-20 07:50:07.490 Socket (4) | Socket gracefully closed by remote side. | 2023-11-20 07:50:07.498 Socket (4) | Closed. | 2023-11-20 07:50:07.498 HD Request # 3 | Setting DTC encoding to Binary VLS | 2023-11-20 07:50:07.648 HD Request # 3 | Sending historical data logon request message. | 2023-11-20 07:50:07.648 HD Request # 3 | Requesting historical Daily data starting at 2023-01-10. | 2023-11-20 07:50:07.756 HD Request # 3 | Decompressing data. | 2023-11-20 07:50:07.830 HD Request # 3 | Receiving historical Daily data for XAUUSD starting at 2023-01-10. | 2023-11-20 07:50:07.901 HD Request # 3 | Writing historical Daily data to the file XAUUSD.dly. | 2023-11-20 07:50:07.901 Socket (5) | CloseSocket call. | 2023-11-20 07:50:07.957 Socket (5) | Shutdown started. Waiting for graceful close. | 2023-11-20 07:50:07.957 Historical data download thread signaled to stop. | 2023-11-20 07:50:07.957 HD Request # 3 | Received 224 Daily data records from 2023-01-10 00:00:00 to 2023-11-20 00:00:00 (315.0 days) and wrote 224 records for XAUUSD | 2023-11-20 07:50:07.957 HD Request # 3 | Completion time: 0s. | 2023-11-20 07:50:07.957 HD Request # 3 | Daily data download complete for XAUUSD. Unique request ID: 2 | 2023-11-20 07:50:07.957 Removing historical data download ID 2. | 2023-11-20 07:50:07.957 Triggering next historical data download in queue. | 2023-11-20 07:50:07.957 HD Request # 4 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2023-11-20 07:50:07.957 HD Request # 4 | Download start date-time: 2023-05-18 08:50:07.000000. File last date-time: 2023-01-12 10:16:01.565000 | 2023-11-20 07:50:07.957 HD Request # 4 | Using server: ds4.sierracharts.com port 10149 | 2023-11-20 07:50:07.957 Socket (4) | Creating socket. | 2023-11-20 07:50:07.975 Socket (4) | New receive buffer size: 0 | 2023-11-20 07:50:07.975 Socket (4) | Connecting to IP: 142.215.18.102. | 2023-11-20 07:50:07.975 Socket (5) | Socket gracefully closed by remote side. | 2023-11-20 07:50:08.033 Socket (5) | Closed. | 2023-11-20 07:50:08.033 HD Request # 4 | Setting DTC encoding to Binary VLS | 2023-11-20 07:50:08.063 HD Request # 4 | Sending historical data logon request message. | 2023-11-20 07:50:08.063 HD Request # 4 | Requesting Intraday data. Start date-time: 2023-05-18 08:50:07. Record interval: 0. Symbol: US30 | 2023-11-20 07:50:08.288 HD Request # 4 | Decompressing data. | 2023-11-20 07:50:08.326 XAUUSD[M] Daily #2 | Reloading chart. | 2023-11-20 07:50:08.396 HD Request # 4 | Receiving Intraday data for US30 starting at 2023-05-18 08:50:07.639000 | 2023-11-20 07:50:08.456 HD Request # 4 | Timestamp of first Intraday data file record written: 2023-05-18 08:50:07.639000. | 2023-11-20 07:50:08.612 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 20816 | 2023-11-20 07:50:09.368 Socket (4) | CloseSocket call. | 2023-11-20 07:51:02.502 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-11-20 07:51:02.502 Historical data download thread signaled to stop. | 2023-11-20 07:51:02.502 HD Request # 4 | Received 35432196 Intraday data records from 2023-05-18 08:50:07.639000 to 2023-11-20 07:50:59.888000 (186.0 days. Delay: 2.6 seconds) and wrote 35432196 records for US30 | 2023-11-20 07:51:02.502 HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2023-11-20 12:50:59.888000 | 2023-11-20 07:51:02.507 HD Request # 4 | Completion time: 55s. | 2023-11-20 07:51:02.507 HD Request # 4 | Intraday data download complete for US30. Unique request ID: 3 | 2023-11-20 07:51:02.507 Removing historical data download ID 3. | 2023-11-20 07:51:02.507 Real-time Intraday chart data file updates started for US30 | 2023-11-20 07:51:02.507 Intraday chart data file opened for US30 | 2023-11-20 07:51:02.507 HD Request # 4 | Enabling Intraday chart updating for symbol. | 2023-11-20 07:51:02.507 Triggering next historical data download in queue. | 2023-11-20 07:51:02.507 HD Request # 5 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2023-11-20 07:51:02.507 HD Request # 5 | Download start date-time: 2023-05-18 08:51:02.000000. File last date-time: 2023-02-22 09:55:50.635000 | 2023-11-20 07:51:02.507 HD Request # 5 | Using server: ds12.sierracharts.com port 10150 | 2023-11-20 07:51:02.507 Socket (5) | Creating socket. | 2023-11-20 07:51:02.507 Socket (5) | New receive buffer size: 0 | 2023-11-20 07:51:02.507 Socket (5) | Connecting to IP: 142.215.18.101. | 2023-11-20 07:51:02.507 Socket (4) | Socket gracefully closed by remote side. | 2023-11-20 07:51:02.537 Socket (4) | Closed. | 2023-11-20 07:51:02.538 HD Request # 5 | Setting DTC encoding to Binary VLS | 2023-11-20 07:51:02.594 HD Request # 5 | Sending historical data logon request message. | 2023-11-20 07:51:02.594 HD Request # 5 | Requesting Intraday data. Start date-time: 2023-05-18 08:51:02. Record interval: 0. Symbol: USOil | 2023-11-20 07:51:02.820 HD Request # 5 | Decompressing data. | 2023-11-20 07:51:02.858 HD Request # 5 | Receiving Intraday data for USOil starting at 2023-05-18 08:51:03.063000 | 2023-11-20 07:51:02.976 HD Request # 5 | Timestamp of first Intraday data file record written: 2023-05-18 08:51:03.063000. | 2023-11-20 07:51:03.126 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 20816 | 2023-11-20 07:51:10.029 Socket (5) | CloseSocket call. | 2023-11-20 07:51:23.886 Socket (5) | Shutdown started. Waiting for graceful close. | 2023-11-20 07:51:23.886 Historical data download thread signaled to stop. | 2023-11-20 07:51:23.886 HD Request # 5 | Received 11626281 Intraday data records from 2023-05-18 08:51:03.063000 to 2023-11-20 07:51:21.336000 (186.0 days. Delay: 2.6 seconds) and wrote 11626281 records for USOil | 2023-11-20 07:51:23.887 HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2023-11-20 12:51:21.336000 | 2023-11-20 07:51:23.892 Added 1 Time and Sales records to Intraday data file for USOil after download. | 2023-11-20 07:51:23.892 HD Request # 5 | Completion time: 21s. | 2023-11-20 07:51:23.892 HD Request # 5 | Intraday data download complete for USOil. Unique request ID: 4 | 2023-11-20 07:51:23.892 Removing historical data download ID 4. | 2023-11-20 07:51:23.892 Real-time Intraday chart data file updates started for USOil | 2023-11-20 07:51:23.892 Intraday chart data file opened for USOil | 2023-11-20 07:51:23.892 HD Request # 5 | Enabling Intraday chart updating for symbol. | 2023-11-20 07:51:23.892 Triggering next historical data download in queue. | 2023-11-20 07:51:23.892 HD Request # 6 | Downloading Intraday chart data for ESZ23_FUT_CME to the file ESZ23_FUT_CME.scid. Service: cme | 2023-11-20 07:51:23.892 HD Request # 6 | Download start date-time: 2023-05-18 08:51:23.000000. File last date-time: 00:00:00.000000 | 2023-11-20 07:51:23.892 HD Request # 6 | Using server: ds26.sierracharts.com port 10149 | 2023-11-20 07:51:23.893 Socket (4) | Creating socket. | 2023-11-20 07:51:23.893 Socket (4) | New receive buffer size: 0 | 2023-11-20 07:51:23.893 Socket (4) | Connecting to IP: 142.215.17.188. | 2023-11-20 07:51:23.893 Socket (5) | Socket gracefully closed by remote side. | 2023-11-20 07:51:23.922 Socket (5) | Closed. | 2023-11-20 07:51:23.922 HD Request # 6 | Setting DTC encoding to Binary VLS | 2023-11-20 07:51:23.980 HD Request # 6 | Sending historical data logon request message. | 2023-11-20 07:51:23.980 HD Request # 6 | Requesting Intraday data. Start date-time: 2023-05-18 08:51:23. Record interval: 0. Symbol: ESZ23 | 2023-11-20 07:51:24.227 HD Request # 6 | Decompressing data. | 2023-11-20 07:51:24.262 HD Request # 6 | Receiving Intraday data for ESZ23_FUT_CME starting at 2023-05-18 08:58:13.027000 | 2023-11-20 07:51:24.351 HD Request # 6 | Timestamp of first Intraday data file record written: 2023-05-18 08:58:13.027000. | 2023-11-20 07:51:24.439 ESZ23_FUT_CME[M] Point & Figure 1-4 #27 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-20 07:51:24.758 ESZ23_FUT_CME[M] 250 Volume #24 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-20 07:51:24.928 ESZ23_FUT_CME[M] 500 Volume #23 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-20 07:51:25.092 Opened cached Intraday file: C:\SierraChart\Data\USOil.scid. Thread ID: 20816 | 2023-11-20 07:51:25.162 ESZ23_FUT_CME[M] 3560 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-20 07:51:25.443 ESZ23_FUT_CME[M] 15000 Volume #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-20 07:51:25.583 ESZ23_FUT_CME[M] 1 Min #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-20 07:51:25.698 ESZ23_FUT_CME[M] Point & Figure 1-4 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-20 07:51:25.955 ESZ23_FUT_CME[M] 36 Trades #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-20 07:51:26.512 ESZ23_FUT_CME[M] Point & Figure 1-8 #18 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-20 07:51:27.481 ESZ23_FUT_CME[M] 5000 Volume #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-20 07:51:28.261 ESZ23_FUT_CME[M] 1250 Volume #15 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-20 07:51:28.932 Socket (4) | CloseSocket call. | 2023-11-20 07:56:09.834 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-11-20 07:56:09.834 Historical data download thread signaled to stop. | 2023-11-20 07:56:09.835 HD Request # 6 | Received 58360215 Intraday data records from 2023-05-18 08:58:13.027000 to 2023-11-20 07:55:36.275001 (186.0 days. Delay: 33.6 seconds) and wrote 58360215 records for ESZ23_FUT_CME | 2023-11-20 07:56:09.835 HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2023-11-20 12:55:36.275001 | 2023-11-20 07:56:09.840 Added 110 Time and Sales records to Intraday data file for ESZ23_FUT_CME after download. | 2023-11-20 07:56:09.840 HD Request # 6 | Completion time: 4m 46s. | 2023-11-20 07:56:09.841 HD Request # 6 | Intraday data download complete for ESZ23_FUT_CME. Unique request ID: 5 | 2023-11-20 07:56:09.841 Removing historical data download ID 5. | 2023-11-20 07:56:09.841 Real-time Intraday chart data file updates started for ESZ23_FUT_CME | 2023-11-20 07:56:09.841 Intraday chart data file opened for ESZ23_FUT_CME | 2023-11-20 07:56:09.841 HD Request # 6 | Enabling Intraday chart updating for symbol. | 2023-11-20 07:56:09.841 Triggering next historical data download in queue. | 2023-11-20 07:56:09.841 HD Request # 7 | Downloading Historical Daily chart data for SPX500. Starting date: 2023-02-16. Service: fxcm | 2023-11-20 07:56:09.842 HD Request # 7 | Using server: ds13-2.sierracharts.com port 10150 | 2023-11-20 07:56:09.842 Socket (5) | Creating socket. | 2023-11-20 07:56:09.844 Socket (5) | New receive buffer size: 0 | 2023-11-20 07:56:09.844 Socket (5) | Connecting to IP: 162.251.232.245. | 2023-11-20 07:56:09.844 Socket (4) | Socket gracefully closed by remote side. | 2023-11-20 07:56:09.868 Socket (4) | Closed. | 2023-11-20 07:56:09.868 HD Request # 7 | Setting DTC encoding to Binary VLS | 2023-11-20 07:56:10.005 HD Request # 7 | Sending historical data logon request message. | 2023-11-20 07:56:10.005 HD Request # 7 | Requesting historical Daily data starting at 2023-02-16. | 2023-11-20 07:56:10.120 HD Request # 7 | Decompressing data. | 2023-11-20 07:56:10.196 HD Request # 7 | Receiving historical Daily data for SPX500 starting at 2023-02-16. | 2023-11-20 07:56:10.244 HD Request # 7 | Writing historical Daily data to the file SPX500.dly. | 2023-11-20 07:56:10.244 Socket (5) | CloseSocket call. | 2023-11-20 07:56:10.287 Socket (5) | Shutdown started. Waiting for graceful close. | 2023-11-20 07:56:10.287 Socket (5) | Socket gracefully closed by remote side. | 2023-11-20 07:56:10.360 Socket (5) | Closed. | 2023-11-20 07:56:10.360 Historical data download thread signaled to stop. | 2023-11-20 07:56:10.554 HD Request # 7 | Received 198 Daily data records from 2023-02-16 00:00:00 to 2023-11-20 00:00:00 (278.0 days) and wrote 198 records for SPX500 | 2023-11-20 07:56:10.554 HD Request # 7 | Completion time: 1s. | 2023-11-20 07:56:10.554 HD Request # 7 | Daily data download complete for SPX500. Unique request ID: 6 | 2023-11-20 07:56:10.554 Removing historical data download ID 6. | 2023-11-20 07:56:10.554 Triggering next historical data download in queue. | 2023-11-20 07:56:10.554 HD Request # 8 | Downloading Historical Daily chart data for EURUSD. Starting date: 2023-02-16. Service: fxcm | 2023-11-20 07:56:10.556 HD Request # 8 | Using server: ds4.sierracharts.com port 10149 | 2023-11-20 07:56:10.556 Socket (4) | Creating socket. | 2023-11-20 07:56:10.556 Socket (4) | New receive buffer size: 0 | 2023-11-20 07:56:10.556 Socket (4) | Connecting to IP: 142.215.18.102. | 2023-11-20 07:56:10.556 HD Request # 8 | Setting DTC encoding to Binary VLS | 2023-11-20 07:56:10.639 HD Request # 8 | Sending historical data logon request message. | 2023-11-20 07:56:10.639 HD Request # 8 | Requesting historical Daily data starting at 2023-02-16. | 2023-11-20 07:56:10.856 HD Request # 8 | Decompressing data. | 2023-11-20 07:56:10.889 HD Request # 8 | Receiving historical Daily data for EURUSD starting at 2023-02-16. | 2023-11-20 07:56:10.947 HD Request # 8 | Writing historical Daily data to the file EURUSD.dly. | 2023-11-20 07:56:10.947 Socket (4) | CloseSocket call. | 2023-11-20 07:56:10.982 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-11-20 07:56:10.982 Socket (4) | Socket gracefully closed by remote side. | 2023-11-20 07:56:11.019 Socket (4) | Closed. | 2023-11-20 07:56:11.019 Historical data download thread signaled to stop. | 2023-11-20 07:56:11.278 HD Request # 8 | Received 198 Daily data records from 2023-02-16 00:00:00 to 2023-11-20 00:00:00 (278.0 days) and wrote 198 records for EURUSD | 2023-11-20 07:56:11.278 HD Request # 8 | Completion time: 1s. | 2023-11-20 07:56:11.278 HD Request # 8 | Daily data download complete for EURUSD. Unique request ID: 7 | 2023-11-20 07:56:11.278 Removing historical data download ID 7. | 2023-11-20 07:56:11.278 Triggering next historical data download in queue. | 2023-11-20 07:56:11.279 HD Request # 9 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2023-11-20 07:56:11.279 HD Request # 9 | Download start date-time: 2023-05-18 08:56:11.000000. File last date-time: 2023-02-22 09:55:50.478000 | 2023-11-20 07:56:11.279 HD Request # 9 | Using server: ds12.sierracharts.com port 10150 | 2023-11-20 07:56:11.279 Socket (4) | Creating socket. | 2023-11-20 07:56:11.279 Socket (4) | New receive buffer size: 0 | 2023-11-20 07:56:11.279 Socket (4) | Connecting to IP: 142.215.18.101. | 2023-11-20 07:56:11.279 HD Request # 9 | Setting DTC encoding to Binary VLS | 2023-11-20 07:56:11.373 HD Request # 9 | Sending historical data logon request message. | 2023-11-20 07:56:11.373 HD Request # 9 | Requesting Intraday data. Start date-time: 2023-05-18 08:56:11. Record interval: 0. Symbol: EURUSD | 2023-11-20 07:56:11.601 HD Request # 9 | Decompressing data. | 2023-11-20 07:56:11.640 HD Request # 9 | Receiving Intraday data for EURUSD starting at 2023-05-18 08:56:11.061000 | 2023-11-20 07:56:11.948 HD Request # 9 | Timestamp of first Intraday data file record written: 2023-05-18 08:56:11.061000. | 2023-11-20 07:56:11.968 Chart #2 has tagged chart #11 for full recalculation. Chartbook: ES.cht | 2023-11-20 07:56:12.833 Opened cached Intraday file: C:\SierraChart\Data\ESZ23_FUT_CME.scid. Thread ID: 20816 | 2023-11-20 07:56:13.019 SPX500[M] Daily #6 | Reloading chart. | 2023-11-20 07:56:13.312 EURUSD[M] Daily #7 | Reloading chart. | 2023-11-20 07:56:13.315 ESZ23_FUT_CME[M] 1 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2023-11-20 07:56:13.472 Socket (4) | CloseSocket call. | 2023-11-20 07:57:00.855 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-11-20 07:57:00.855 Historical data download thread signaled to stop. | 2023-11-20 07:57:00.882 HD Request # 9 | Received 30011052 Intraday data records from 2023-05-18 08:56:11.061000 to 2023-11-20 07:56:58.756000 (186.0 days. Delay: 2.1 seconds) and wrote 30011052 records for EURUSD | 2023-11-20 07:57:00.882 HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2023-11-20 12:56:58.756000 | 2023-11-20 07:57:00.887 Added 7 Time and Sales records to Intraday data file for EURUSD after download. | 2023-11-20 07:57:00.887 HD Request # 9 | Completion time: 49s. | 2023-11-20 07:57:00.887 HD Request # 9 | Intraday data download complete for EURUSD. Unique request ID: 8 | 2023-11-20 07:57:00.887 Removing historical data download ID 8. | 2023-11-20 07:57:00.887 Real-time Intraday chart data file updates started for EURUSD | 2023-11-20 07:57:00.887 Intraday chart data file opened for EURUSD | 2023-11-20 07:57:00.887 HD Request # 9 | Enabling Intraday chart updating for symbol. | 2023-11-20 07:57:00.887 Triggering next historical data download in queue. | 2023-11-20 07:57:00.887 HD Request # 10 | Downloading Intraday chart data for AAPL-NQTV to the file AAPL-NQTV.scid. Service: nasdaq_exchange.data | 2023-11-20 07:57:00.887 HD Request # 10 | Download start date-time: 2023-05-18 08:57:00.000000. File last date-time: 2023-02-22 09:40:49.541001 | 2023-11-20 07:57:00.887 HD Request # 10 | Using server: ds3.sierracharts.com port 10149 | 2023-11-20 07:57:00.887 Socket (4) | Socket gracefully closed by remote side. | 2023-11-20 07:57:00.889 Socket (4) | Closed. | 2023-11-20 07:57:00.889 Socket (5) | Creating socket. | 2023-11-20 07:57:00.906 Socket (5) | New receive buffer size: 0 | 2023-11-20 07:57:00.906 Socket (5) | Connecting to IP: 142.215.18.104. | 2023-11-20 07:57:00.906 HD Request # 10 | Setting DTC encoding to Binary VLS | 2023-11-20 07:57:00.985 HD Request # 10 | Sending historical data logon request message. | 2023-11-20 07:57:00.985 HD Request # 10 | Requesting Intraday data. Start date-time: 2023-05-18 08:57:00. Record interval: 0. Symbol: AAPL-NQTV | 2023-11-20 07:57:01.224 HD Request # 10 | Decompressing data. | 2023-11-20 07:57:01.261 HD Request # 10 | Receiving Intraday data for AAPL-NQTV starting at 2023-05-18 08:57:14.954000 | 2023-11-20 07:57:01.377 HD Request # 10 | Timestamp of first Intraday data file record written: 2023-05-18 08:57:14.954000. | 2023-11-20 07:57:01.503 Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid. Thread ID: 20816 | 2023-11-20 07:57:08.531 Socket (5) | CloseSocket call. | 2023-11-20 07:57:26.159 Socket (5) | Shutdown started. Waiting for graceful close. | 2023-11-20 07:57:26.159 Historical data download thread signaled to stop. | 2023-11-20 07:57:26.159 Socket (5) | Socket gracefully closed by remote side. | 2023-11-20 07:57:26.191 Socket (5) | Closed. | 2023-11-20 07:57:26.192 HD Request # 10 | Received 13525620 Intraday data records from 2023-05-18 08:57:14.954000 to 2023-11-20 07:42:04.608000 (186.0 days. Delay: 15.4 minutes) and wrote 13086784 records for AAPL-NQTV | 2023-11-20 07:57:26.249 HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2023-11-20 12:42:04.608000 | 2023-11-20 07:57:26.254 HD Request # 10 | Completion time: 26s. | 2023-11-20 07:57:26.254 HD Request # 10 | Intraday data download complete for AAPL-NQTV. Unique request ID: 9 | 2023-11-20 07:57:26.254 Removing historical data download ID 9. | 2023-11-20 07:57:26.254 Real-time Intraday chart data file updates started for AAPL-NQTV | 2023-11-20 07:57:26.254 Intraday chart data file opened for AAPL-NQTV | 2023-11-20 07:57:26.254 HD Request # 10 | Enabling Intraday chart updating for symbol. | 2023-11-20 07:57:26.254 Triggering next historical data download in queue. | 2023-11-20 07:57:26.254 HD Request # 11 | Downloading Intraday chart data for NQZ23_FUT_CME to the file NQZ23_FUT_CME.scid. Service: cme | 2023-11-20 07:57:26.254 HD Request # 11 | Download start date-time: 2023-05-18 08:57:26.000000. File last date-time: 00:00:00.000000 | 2023-11-20 07:57:26.254 HD Request # 11 | Using server: ds27.sierracharts.com port 10150 | 2023-11-20 07:57:26.254 Socket (4) | Creating socket. | 2023-11-20 07:57:26.275 Socket (4) | New receive buffer size: 0 | 2023-11-20 07:57:26.275 Socket (4) | Connecting to IP: 38.89.227.130. | 2023-11-20 07:57:26.275 HD Request # 11 | Setting DTC encoding to Binary VLS | 2023-11-20 07:57:26.352 HD Request # 11 | Sending historical data logon request message. | 2023-11-20 07:57:26.352 HD Request # 11 | Requesting Intraday data. Start date-time: 2023-05-18 08:57:26. Record interval: 0. Symbol: NQZ23 | 2023-11-20 07:57:26.679 HD Request # 11 | Decompressing data. | 2023-11-20 07:57:26.715 HD Request # 11 | Receiving Intraday data for NQZ23_FUT_CME starting at 2023-05-18 10:32:08.223000 | 2023-11-20 07:57:26.803 HD Request # 11 | Timestamp of first Intraday data file record written: 2023-05-18 10:32:08.223000. | 2023-11-20 07:57:26.922 NQZ23_FUT_CME[M] Point & Figure 1-8 #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-20 07:57:27.065 NQZ23_FUT_CME[M] Point & Figure 1-4 #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-20 07:57:27.148 NQZ23_FUT_CME[M] Point & Figure 1-8 #26 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-20 07:57:27.389 Opened cached Intraday file: C:\SierraChart\Data\AAPL-NQTV.scid. Thread ID: 6108 | 2023-11-20 07:57:30.335 Socket (4) | CloseSocket call. | 2023-11-20 07:58:18.100 Historical data download thread signaled to stop. | 2023-11-20 07:58:18.100 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-11-20 07:58:18.100 HD Request # 11 | Received 31464039 Intraday data records from 2023-05-18 10:32:08.223000 to 2023-11-20 07:58:07.994000 (185.9 days. Delay: 10.1 seconds) and wrote 31464039 records for NQZ23_FUT_CME | 2023-11-20 07:58:18.100 HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2023-11-20 12:58:07.994000 | 2023-11-20 07:58:18.106 Added 17 Time and Sales records to Intraday data file for NQZ23_FUT_CME after download. | 2023-11-20 07:58:18.106 HD Request # 11 | Completion time: 52s. | 2023-11-20 07:58:18.106 HD Request # 11 | Intraday data download complete for NQZ23_FUT_CME. Unique request ID: 11 | 2023-11-20 07:58:18.106 Removing historical data download ID 11. | 2023-11-20 07:58:18.106 Real-time Intraday chart data file updates started for NQZ23_FUT_CME | 2023-11-20 07:58:18.106 Intraday chart data file opened for NQZ23_FUT_CME | 2023-11-20 07:58:18.106 HD Request # 11 | Enabling Intraday chart updating for symbol. | 2023-11-20 07:58:18.106 No download requests in the queue to start downloads for. | 2023-11-20 07:58:18.106 Socket (4) | Socket gracefully closed by remote side. | 2023-11-20 07:58:18.132 Socket (4) | Closed. | 2023-11-20 07:58:18.132 Opened cached Intraday file: C:\SierraChart\Data\NQZ23_FUT_CME.scid. Thread ID: 20816 | 2023-11-20 07:58:20.760 ESZ23_FUT_CME[M] #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-20 08:14:49.968 NQZ23_FUT_CME[M] Point & Figure 1-8 #6 | StartDateTimeForLoadingOrderFills: 2023-05-18 10:32:08 | 2023-11-20 08:14:49.972 NQZ23_FUT_CME[M] Point & Figure 1-4 #4 | StartDateTimeForLoadingOrderFills: 2023-05-18 10:32:08 | 2023-11-20 08:14:49.973 ESZ23_FUT_CME[M] 3560 Trades #2 | StartDateTimeForLoadingOrderFills: 2023-05-18 08:58:13 | 2023-11-20 08:14:49.973 ESZ23_FUT_CME[M] 15000 Volume #10 | StartDateTimeForLoadingOrderFills: 2023-05-18 08:58:13 | 2023-11-20 08:14:49.974 ESZ23_FUT_CME[M] 1 Min #10 | StartDateTimeForLoadingOrderFills: 2023-11-19 16:15:00 | 2023-11-20 08:14:50.009 ESZ23_FUT_CME[M] Point & Figure 1-4 #27 | StartDateTimeForLoadingOrderFills: 2023-05-18 08:58:13 | 2023-11-20 08:14:50.012 NQZ23_FUT_CME[M] Point & Figure 1-8 #26 | StartDateTimeForLoadingOrderFills: 2023-05-18 10:32:08 | 2023-11-20 08:14:50.012 ESZ23_FUT_CME[M] 250 Volume #24 | StartDateTimeForLoadingOrderFills: 2023-05-18 08:58:13 | 2023-11-20 08:14:50.013 ESZ23_FUT_CME[M] Point & Figure 1-8 #18 | StartDateTimeForLoadingOrderFills: 2023-05-18 08:58:13 | 2023-11-20 08:14:50.062 ESZ23_FUT_CME[M] 5000 Volume #12 | StartDateTimeForLoadingOrderFills: 2023-05-18 08:58:13 | 2023-11-20 08:14:50.088 ESZ23_FUT_CME[M] 1250 Volume #15 | StartDateTimeForLoadingOrderFills: 2023-05-18 08:58:13 | 2023-11-20 08:14:50.113 ESZ23_FUT_CME[M] Point & Figure 1-4 #3 | StartDateTimeForLoadingOrderFills: 2023-05-18 08:58:13 | 2023-11-20 08:14:50.155 Chart #2 has tagged chart #11 for full recalculation. Chartbook: ES.cht | 2023-11-20 08:14:52.880 ESZ23_FUT_CME[M] 36 Trades #5 | StartDateTimeForLoadingOrderFills: 2023-05-18 08:58:13 | 2023-11-20 08:14:54.568 ESZ23_FUT_CME[M] 1 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2023-11-20 08:14:54.587 ESZ23_FUT_CME[M] 500 Volume #23 | StartDateTimeForLoadingOrderFills: 2023-05-18 08:58:13 | 2023-11-20 08:14:56.443 Saved Chartbook: ExampleChartbook.cht. Time: 0.0048 seconds. | 2023-11-20 09:42:06.525 Saved Chartbook: ES.cht. Time: 0.0874 seconds. | 2023-11-20 09:42:06.614 File >> Reconnect selected. | 2023-11-20 09:42:11.329 DTC Client socket (0) | CloseSocket call. | 2023-11-20 09:42:11.367 Denali Data Feed | Waiting for socket receive thread to end | 2023-11-20 09:42:11.368 DTC Client socket (2) | CloseSocket call. | 2023-11-20 09:42:11.368 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-11-20 09:42:11.368 Denali Data Feed | Disconnected from the server. | 2023-11-20 09:42:11.368 SC Data with Depth | Waiting for socket receive thread to end | 2023-11-20 09:42:11.369 DTC Client socket (1) | CloseSocket call. | 2023-11-20 09:42:11.369 SC Data with Depth | Disconnected from the server. | 2023-11-20 09:42:11.369 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-11-20 09:42:11.369 Delayed Data Feed | Waiting for socket receive thread to end | 2023-11-20 09:42:11.369 DTC Client socket (3) | CloseSocket call. | 2023-11-20 09:42:11.369 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2023-11-20 09:42:11.369 Delayed Data Feed | Disconnected from the server. | 2023-11-20 09:42:11.369 Generic | Disconnected. | 2023-11-20 09:42:11.369 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 09:42:11.369 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-11-20 09:42:11.407 DTC Client socket (1) | Closed. | 2023-11-20 09:42:11.407 DTC Client socket (3) | Socket gracefully closed by remote side. | 2023-11-20 09:42:11.427 DTC Client socket (3) | Closed. | 2023-11-20 09:42:11.427 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-20 09:42:11.472 DTC Client socket (2) | Closed. | 2023-11-20 09:42:11.472 Generic | Connected to server complete. | 2023-11-20 09:42:13.383 No download requests in the queue to start downloads for. | 2023-11-20 09:42:13.384 No download requests in the queue to start downloads for. | 2023-11-20 09:42:13.384 No download requests in the queue to start downloads for. | 2023-11-20 09:42:13.384 No download requests in the queue to start downloads for. | 2023-11-20 09:42:13.384 Mapping ESZ23_FUT_CME to ESZ23. Service code: cme | 2023-11-20 09:42:13.802 Using symbol data fast lookup vector | 2023-11-20 09:42:13.802 Denali Data Feed | Starting real-time market data updates for: ESZ23_FUT_CME (ESZ23). ID: 1 Service code: cme | 2023-11-20 09:42:13.802 Denali Data Feed | Connecting to the server ds13.sierracharts.com. Port 10048 | 2023-11-20 09:42:13.802 Denali Data Feed | Requesting security definition data for: ESZ23_FUT_CME (ESZ23). ID: 1 | 2023-11-20 09:42:13.802 Requesting market depth updates for: ESZ23_FUT_CME if supported. NumLevels=100 | 2023-11-20 09:42:13.802 Separate subscription for market depth updates not supported. ESZ23_FUT_CME | 2023-11-20 09:42:13.802 Added historical Intraday data request for ESZ23_FUT_CME to the queue. | 2023-11-20 09:42:13.802 Intraday data recording state for symbol ESZ23_FUT_CME is set to download 'Pending'. | 2023-11-20 09:42:13.802 Triggering next historical data download in queue. | 2023-11-20 09:42:13.802 Delaying start of download for ESZ23_FUT_CME. | 2023-11-20 09:42:13.820 DTC Client socket (1) | Creating socket. | 2023-11-20 09:42:13.824 DTC Client socket (1) | New receive buffer size: 0 | 2023-11-20 09:42:13.824 DTC Client socket (1) | Connecting to IP: 162.251.232.244. | 2023-11-20 09:42:13.824 Denali Data Feed | Network connection to server complete. | 2023-11-20 09:42:13.916 Denali Data Feed | Starting socket receive thread. | 2023-11-20 09:42:13.916 Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-11-20 09:42:13.916 Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-11-20 09:42:14.010 Denali Data Feed | Sending logon request message. | 2023-11-20 09:42:14.010 Using Bid/Ask average for last trade price for XAUUSD | 2023-11-20 09:42:14.045 SC Data with Depth | Starting real-time market data updates for: XAUUSD. ID: 2 Service code: fxcm | 2023-11-20 09:42:14.045 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-11-20 09:42:14.045 SC Data with Depth | Requesting security definition data for: XAUUSD. ID: 2 | 2023-11-20 09:42:14.045 Added historical Intraday data request for XAUUSD to the queue. | 2023-11-20 09:42:14.045 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2023-11-20 09:42:14.045 Triggering next historical data download in queue. | 2023-11-20 09:42:14.045 DTC Client socket (2) | Creating socket. | 2023-11-20 09:42:14.045 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-20 09:42:14.045 DTC Client socket (2) | Connecting to IP: 162.251.232.245. | 2023-11-20 09:42:14.045 Using Bid/Ask average for last trade price for US30 | 2023-11-20 09:42:14.046 SC Data with Depth | Starting real-time market data updates for: US30. ID: 3 Service code: fxcm | 2023-11-20 09:42:14.046 SC Data with Depth | Requesting security definition data for: US30. ID: 3 | 2023-11-20 09:42:14.046 Added historical Intraday data request for US30 to the queue. | 2023-11-20 09:42:14.046 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2023-11-20 09:42:14.046 Triggering next historical data download in queue. | 2023-11-20 09:42:14.046 Denali Data Feed | Received logon response. | 2023-11-20 09:42:14.106 Denali Data Feed | Server Name: RealTimeServer. | 2023-11-20 09:42:14.106 Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-11-20 09:42:14.106 Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. | 2023-11-20 09:42:14.106 Denali Data Feed | Failed connections: 1 | 2023-11-20 09:42:14.106 Denali Data Feed | Waiting for socket receive thread to end | 2023-11-20 09:42:14.106 DTC Client socket (1) | CloseSocket call. | 2023-11-20 09:42:14.106 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-11-20 09:42:14.106 Denali Data Feed | Disconnected from the server. | 2023-11-20 09:42:14.106 Denali Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-20 09:42:14.106 Using Bid/Ask average for last trade price for EURUSD | 2023-11-20 09:42:14.107 SC Data with Depth | Starting real-time market data updates for: EURUSD. ID: 4 Service code: fxcm | 2023-11-20 09:42:14.107 SC Data with Depth | Requesting security definition data for: EURUSD. ID: 4 | 2023-11-20 09:42:14.107 Using Bid/Ask average for last trade price for SPX500 | 2023-11-20 09:42:14.107 SC Data with Depth | Starting real-time market data updates for: SPX500. ID: 5 Service code: fxcm | 2023-11-20 09:42:14.107 SC Data with Depth | Requesting security definition data for: SPX500. ID: 5 | 2023-11-20 09:42:14.107 Mapping NQZ23_FUT_CME to NQZ23. Service code: cme | 2023-11-20 09:42:14.112 Denali Data Feed | Starting real-time market data updates for: NQZ23_FUT_CME (NQZ23). ID: 6 Service code: cme | 2023-11-20 09:42:14.112 Denali Data Feed | Requesting security definition data for: NQZ23_FUT_CME (NQZ23). ID: 6 | 2023-11-20 09:42:14.112 Requesting market depth updates for: NQZ23_FUT_CME if supported. NumLevels=100 | 2023-11-20 09:42:14.112 Separate subscription for market depth updates not supported. NQZ23_FUT_CME | 2023-11-20 09:42:14.112 Added historical Intraday data request for NQZ23_FUT_CME to the queue. | 2023-11-20 09:42:14.112 Intraday data recording state for symbol NQZ23_FUT_CME is set to download 'Pending'. | 2023-11-20 09:42:14.112 Triggering next historical data download in queue. | 2023-11-20 09:42:14.112 SC Data with Depth | Network connection to server complete. | 2023-11-20 09:42:14.145 SC Data with Depth | Starting socket receive thread. | 2023-11-20 09:42:14.145 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-11-20 09:42:14.145 Mapping AAPL-NQTV to AAPL-NQTV. Service code: nasdaq_exchange.data | 2023-11-20 09:42:14.146 Delayed Data Feed | Starting real-time market data updates for: AAPL-NQTV (AAPL-NQTV). ID: 7 Service code: nasdaq_exchange.data | 2023-11-20 09:42:14.146 Delayed Data Feed | Connecting to the server ds30.sierracharts.com. Port 10043 | 2023-11-20 09:42:14.146 Delayed Data Feed | Requesting security definition data for: AAPL-NQTV (AAPL-NQTV). ID: 7 | 2023-11-20 09:42:14.146 Added historical Intraday data request for AAPL-NQTV to the queue. | 2023-11-20 09:42:14.146 Intraday data recording state for symbol AAPL-NQTV is set to download 'Pending'. | 2023-11-20 09:42:14.146 Triggering next historical data download in queue. | 2023-11-20 09:42:14.146 Added historical Intraday data request for EURUSD to the queue. | 2023-11-20 09:42:14.147 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2023-11-20 09:42:14.147 Triggering next historical data download in queue. | 2023-11-20 09:42:14.147 DTC Client socket (3) | Creating socket. | 2023-11-20 09:42:14.164 DTC Client socket (3) | New receive buffer size: 0 | 2023-11-20 09:42:14.164 DTC Client socket (3) | Connecting to IP: 142.215.18.105. | 2023-11-20 09:42:14.164 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-11-20 09:42:14.185 DTC Client socket (1) | Closed. | 2023-11-20 09:42:14.185 Delayed Data Feed | Network connection to server complete. | 2023-11-20 09:42:14.213 Delayed Data Feed | Starting socket receive thread. | 2023-11-20 09:42:14.213 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-11-20 09:42:14.213 Using Bid/Ask average for last trade price for USOil | 2023-11-20 09:42:14.229 SC Data with Depth | Starting real-time market data updates for: USOil. ID: 8 Service code: fxcm | 2023-11-20 09:42:14.229 SC Data with Depth | Requesting security definition data for: USOil. ID: 8 | 2023-11-20 09:42:14.229 Added historical Intraday data request for USOil to the queue. | 2023-11-20 09:42:14.229 Intraday data recording state for symbol USOil is set to download 'Pending'. | 2023-11-20 09:42:14.229 Triggering next historical data download in queue. | 2023-11-20 09:42:14.229 SC Data with Depth | Setting DTC encoding to Binary VLS | 2023-11-20 09:42:14.248 SC Data with Depth | Sending logon request message. | 2023-11-20 09:42:14.248 Delayed Data Feed | Setting DTC encoding to Binary VLS | 2023-11-20 09:42:14.275 Delayed Data Feed | Sending logon request message. | 2023-11-20 09:42:14.275 SC Data with Depth | Received logon response. | 2023-11-20 09:42:14.428 SC Data with Depth | Server Name: SC Realtime Server. | 2023-11-20 09:42:14.428 SC Data with Depth | Server protocol version: 8. Client protocol version: 8 | 2023-11-20 09:42:14.428 SC Data with Depth | Successfully connected. | 2023-11-20 09:42:14.428 SC Data with Depth | Trading is not supported. | 2023-11-20 09:42:14.428 SC Data with Depth | Restarting real-time data updates for symbol: EURUSD | 2023-11-20 09:42:14.428 SC Data with Depth | Restarting real-time data updates for symbol: SPX500 | 2023-11-20 09:42:14.428 SC Data with Depth | Restarting real-time data updates for symbol: US30 | 2023-11-20 09:42:14.428 SC Data with Depth | Restarting real-time data updates for symbol: USOil | 2023-11-20 09:42:14.428 SC Data with Depth | Restarting real-time data updates for symbol: XAUUSD | 2023-11-20 09:42:14.428 Delayed Data Feed | Received logon response. | 2023-11-20 09:42:14.588 Delayed Data Feed | Server Name: SC Realtime Server. | 2023-11-20 09:42:14.588 Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-11-20 09:42:14.588 Delayed Data Feed | Successfully connected. | 2023-11-20 09:42:14.588 Delayed Data Feed | Trading is not supported. | 2023-11-20 09:42:14.588 Delayed Data Feed | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV | 2023-11-20 09:42:14.588 SC Data with Depth | Received security definition for symbol EURUSD | 2023-11-20 09:42:14.614 SC Data with Depth | Received security definition for symbol SPX500 | 2023-11-20 09:42:14.614 SC Data with Depth | Received security definition for symbol US30 | 2023-11-20 09:42:14.614 SC Data with Depth | Received security definition for symbol USOil | 2023-11-20 09:42:14.614 SC Data with Depth | Received security definition for symbol XAUUSD | 2023-11-20 09:42:14.614 Delayed Data Feed | Received security definition for symbol AAPL-NQTV | 2023-11-20 09:42:14.713 Denali Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10048 | 2023-11-20 09:42:16.131 DTC Client socket (1) | Creating socket. | 2023-11-20 09:42:16.152 DTC Client socket (1) | New receive buffer size: 0 | 2023-11-20 09:42:16.152 DTC Client socket (1) | Connecting to IP: 142.215.17.189. | 2023-11-20 09:42:16.152 Denali Data Feed | Network connection to server complete. | 2023-11-20 09:42:16.193 Denali Data Feed | Starting socket receive thread. | 2023-11-20 09:42:16.193 Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-11-20 09:42:16.193 Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-11-20 09:42:16.253 Denali Data Feed | Sending logon request message. | 2023-11-20 09:42:16.253 Denali Data Feed | Received logon response. | 2023-11-20 09:42:16.725 Denali Data Feed | Server Name: SC Realtime Server. | 2023-11-20 09:42:16.725 Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-11-20 09:42:16.725 Denali Data Feed | Successfully connected. | 2023-11-20 09:42:16.725 Denali Data Feed | Trading is not supported. | 2023-11-20 09:42:16.725 Denali Data Feed | Restarting real-time data updates for symbol: ESZ23_FUT_CME -> ESZ23. Market Depth data restarted. | 2023-11-20 09:42:16.725 Denali Data Feed | Restarting real-time data updates for symbol: NQZ23_FUT_CME -> NQZ23. Market Depth data restarted. | 2023-11-20 09:42:16.725 Denali Data Feed | Clearing market depth for ESZ23_FUT_CME | 2023-11-20 09:42:16.848 Enabling compression for file: C:\SierraChart\Data\MarketDepthData\ESZ23_FUT_CME.2023-11-20.depth | 2023-11-20 09:42:16.848 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ23_FUT_CME.2023-11-20.depth | 2023-11-20 09:42:16.864 Denali Data Feed | Received security definition for symbol ESZ23_FUT_CME | 2023-11-20 09:42:16.876 Denali Data Feed | Clearing market depth for NQZ23_FUT_CME | 2023-11-20 09:42:16.876 Denali Data Feed | Received security definition for symbol NQZ23_FUT_CME | 2023-11-20 09:42:16.877 Enabling compression for file: C:\SierraChart\Data\MarketDepthData\NQZ23_FUT_CME.2023-11-20.depth | 2023-11-20 09:42:16.877 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NQZ23_FUT_CME.2023-11-20.depth | 2023-11-20 09:42:16.909 HD Request # 12 | Downloading Intraday chart data for ESZ23_FUT_CME to the file ESZ23_FUT_CME.scid. Service: cme | 2023-11-20 09:42:21.300 HD Request # 12 | Download start date-time: 2023-11-20 09:42:10.000000. File last date-time: 2023-11-20 09:42:10.313002 | 2023-11-20 09:42:21.300 HD Request # 12 | Using server: ds23.sierracharts.com port 10149 | 2023-11-20 09:42:21.301 Socket (4) | Creating socket. | 2023-11-20 09:42:21.321 Socket (4) | New receive buffer size: 0 | 2023-11-20 09:42:21.321 Socket (4) | Connecting to IP: 142.215.17.190. | 2023-11-20 09:42:21.321 HD Request # 12 | Setting DTC encoding to Binary VLS | 2023-11-20 09:42:21.401 HD Request # 12 | Sending historical data logon request message. | 2023-11-20 09:42:21.401 HD Request # 12 | Requesting Intraday data. Start date-time: 2023-11-20 09:42:10. Record interval: 0. Symbol: ESZ23 | 2023-11-20 09:42:21.643 HD Request # 12 | Decompressing data. | 2023-11-20 09:42:21.676 HD Request # 12 | Receiving Intraday data for ESZ23_FUT_CME starting at 2023-11-20 09:42:10.106000 | 2023-11-20 09:42:21.708 Socket (4) | CloseSocket call. | 2023-11-20 09:42:21.709 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-11-20 09:42:21.709 Historical data download thread signaled to stop. | 2023-11-20 09:42:21.709 HD Request # 12 | Timestamp of first Intraday data file record written: 2023-11-20 09:42:11.192000. | 2023-11-20 09:42:21.709 HD Request # 12 | Received 188 Intraday data records from 2023-11-20 09:42:10.106000 to 2023-11-20 09:42:18.097001 (8.0 seconds. Delay: 3.6 seconds) and wrote 175 records for ESZ23_FUT_CME | 2023-11-20 09:42:21.709 HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2023-11-20 14:42:18.097001 | 2023-11-20 09:42:21.714 Added 131 Time and Sales records to Intraday data file for ESZ23_FUT_CME after download. | 2023-11-20 09:42:21.714 HD Request # 12 | Completion time: 0s. | 2023-11-20 09:42:21.715 HD Request # 12 | Intraday data download complete for ESZ23_FUT_CME. Unique request ID: 12 | 2023-11-20 09:42:21.715 Removing historical data download ID 12. | 2023-11-20 09:42:21.715 Real-time Intraday chart data file updates started for ESZ23_FUT_CME | 2023-11-20 09:42:21.715 Intraday chart data file opened for ESZ23_FUT_CME | 2023-11-20 09:42:21.715 HD Request # 12 | Enabling Intraday chart updating for symbol. | 2023-11-20 09:42:21.715 Triggering next historical data download in queue. | 2023-11-20 09:42:21.715 HD Request # 13 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2023-11-20 09:42:21.715 HD Request # 13 | Download start date-time: 2023-11-20 09:42:10.000000. File last date-time: 2023-11-20 09:42:10.744000 | 2023-11-20 09:42:21.715 HD Request # 13 | Using server: ds13-2.sierracharts.com port 10150 | 2023-11-20 09:42:21.715 Socket (5) | Creating socket. | 2023-11-20 09:42:21.715 Socket (5) | New receive buffer size: 0 | 2023-11-20 09:42:21.715 Socket (5) | Connecting to IP: 162.251.232.245. | 2023-11-20 09:42:21.715 Socket (4) | Socket gracefully closed by remote side. | 2023-11-20 09:42:21.741 Socket (4) | Closed. | 2023-11-20 09:42:21.741 HD Request # 13 | Setting DTC encoding to Binary VLS | 2023-11-20 09:42:21.877 HD Request # 13 | Sending historical data logon request message. | 2023-11-20 09:42:21.877 Chart #2 has tagged chart #11 for full recalculation. Chartbook: ES.cht | 2023-11-20 09:42:21.953 HD Request # 13 | Requesting Intraday data. Start date-time: 2023-11-20 09:42:10. Record interval: 0. Symbol: XAUUSD | 2023-11-20 09:42:21.982 HD Request # 13 | Decompressing data. | 2023-11-20 09:42:22.056 HD Request # 13 | Receiving Intraday data for XAUUSD starting at 2023-11-20 09:42:10.018000 | 2023-11-20 09:42:22.130 Socket (5) | CloseSocket call. | 2023-11-20 09:42:22.130 Historical data download thread signaled to stop. | 2023-11-20 09:42:22.130 Socket (5) | Shutdown started. Waiting for graceful close. | 2023-11-20 09:42:22.130 HD Request # 13 | Timestamp of first Intraday data file record written: 2023-11-20 09:42:10.781000. | 2023-11-20 09:42:22.130 HD Request # 13 | Received 116 Intraday data records from 2023-11-20 09:42:10.018000 to 2023-11-20 09:42:21.310000 (11.3 seconds. Delay: 0.8 seconds) and wrote 111 records for XAUUSD | 2023-11-20 09:42:22.130 HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2023-11-20 14:42:21.310000 | 2023-11-20 09:42:22.135 Added 5 Time and Sales records to Intraday data file for XAUUSD after download. | 2023-11-20 09:42:22.135 HD Request # 13 | Completion time: 1s. | 2023-11-20 09:42:22.135 HD Request # 13 | Intraday data download complete for XAUUSD. Unique request ID: 13 | 2023-11-20 09:42:22.135 Removing historical data download ID 13. | 2023-11-20 09:42:22.135 Real-time Intraday chart data file updates started for XAUUSD | 2023-11-20 09:42:22.135 Intraday chart data file opened for XAUUSD | 2023-11-20 09:42:22.135 HD Request # 13 | Enabling Intraday chart updating for symbol. | 2023-11-20 09:42:22.135 Triggering next historical data download in queue. | 2023-11-20 09:42:22.135 HD Request # 14 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2023-11-20 09:42:22.135 HD Request # 14 | Download start date-time: 2023-11-20 09:42:10.000000. File last date-time: 2023-11-20 09:42:10.583000 | 2023-11-20 09:42:22.135 HD Request # 14 | Using server: ds4.sierracharts.com port 10149 | 2023-11-20 09:42:22.135 Socket (4) | Creating socket. | 2023-11-20 09:42:22.162 Socket (4) | New receive buffer size: 0 | 2023-11-20 09:42:22.162 Socket (4) | Connecting to IP: 142.215.18.102. | 2023-11-20 09:42:22.162 Socket (5) | Socket gracefully closed by remote side. | 2023-11-20 09:42:22.208 Socket (5) | Closed. | 2023-11-20 09:42:22.208 HD Request # 14 | Setting DTC encoding to Binary VLS | 2023-11-20 09:42:22.248 HD Request # 14 | Sending historical data logon request message. | 2023-11-20 09:42:22.248 ESZ23_FUT_CME[M] 1 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2023-11-20 09:42:22.384 HD Request # 14 | Requesting Intraday data. Start date-time: 2023-11-20 09:42:10. Record interval: 0. Symbol: US30 | 2023-11-20 09:42:22.472 HD Request # 14 | Decompressing data. | 2023-11-20 09:42:22.507 HD Request # 14 | Receiving Intraday data for US30 starting at 2023-11-20 09:42:10.077000 | 2023-11-20 09:42:22.540 Socket (4) | CloseSocket call. | 2023-11-20 09:42:22.541 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-11-20 09:42:22.541 Socket (4) | Socket gracefully closed by remote side. | 2023-11-20 09:42:22.574 Socket (4) | Closed. | 2023-11-20 09:42:22.574 Historical data download thread signaled to stop. | 2023-11-20 09:42:22.715 HD Request # 14 | Timestamp of first Intraday data file record written: 2023-11-20 09:42:11.238000. | 2023-11-20 09:42:22.715 HD Request # 14 | Received 104 Intraday data records from 2023-11-20 09:42:10.077000 to 2023-11-20 09:42:21.363000 (11.3 seconds. Delay: 1.4 seconds) and wrote 97 records for US30 | 2023-11-20 09:42:22.715 HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2023-11-20 14:42:21.363000 | 2023-11-20 09:42:22.720 Added 5 Time and Sales records to Intraday data file for US30 after download. | 2023-11-20 09:42:22.720 HD Request # 14 | Completion time: 0s. | 2023-11-20 09:42:22.720 HD Request # 14 | Intraday data download complete for US30. Unique request ID: 14 | 2023-11-20 09:42:22.720 Removing historical data download ID 14. | 2023-11-20 09:42:22.720 Real-time Intraday chart data file updates started for US30 | 2023-11-20 09:42:22.720 Intraday chart data file opened for US30 | 2023-11-20 09:42:22.720 HD Request # 14 | Enabling Intraday chart updating for symbol. | 2023-11-20 09:42:22.720 Triggering next historical data download in queue. | 2023-11-20 09:42:22.720 HD Request # 15 | Downloading Intraday chart data for NQZ23_FUT_CME to the file NQZ23_FUT_CME.scid. Service: cme | 2023-11-20 09:42:22.720 HD Request # 15 | Download start date-time: 2023-11-20 09:42:11.000000. File last date-time: 2023-11-20 09:42:11.050000 | 2023-11-20 09:42:22.720 HD Request # 15 | Using server: ds26.sierracharts.com port 10150 | 2023-11-20 09:42:22.721 Socket (4) | Creating socket. | 2023-11-20 09:42:22.736 Socket (4) | New receive buffer size: 0 | 2023-11-20 09:42:22.736 Socket (4) | Connecting to IP: 142.215.17.188. | 2023-11-20 09:42:22.736 HD Request # 15 | Setting DTC encoding to Binary VLS | 2023-11-20 09:42:22.816 HD Request # 15 | Sending historical data logon request message. | 2023-11-20 09:42:22.816 HD Request # 15 | Requesting Intraday data. Start date-time: 2023-11-20 09:42:11. Record interval: 0. Symbol: NQZ23 | 2023-11-20 09:42:23.063 HD Request # 15 | Decompressing data. | 2023-11-20 09:42:23.096 HD Request # 15 | Receiving Intraday data for NQZ23_FUT_CME starting at 2023-11-20 09:42:11.050000 | 2023-11-20 09:42:23.128 Socket (4) | CloseSocket call. | 2023-11-20 09:42:23.129 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-11-20 09:42:23.129 Historical data download thread signaled to stop. | 2023-11-20 09:42:23.129 HD Request # 15 | Timestamp of first Intraday data file record written: 2023-11-20 09:42:11.205000. | 2023-11-20 09:42:23.129 HD Request # 15 | Received 311 Intraday data records from 2023-11-20 09:42:11.050000 to 2023-11-20 09:42:22.508000 (11.5 seconds. Delay: 0.6 seconds) and wrote 310 records for NQZ23_FUT_CME | 2023-11-20 09:42:23.129 HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2023-11-20 14:42:22.508000 | 2023-11-20 09:42:23.134 Added 16 Time and Sales records to Intraday data file for NQZ23_FUT_CME after download. | 2023-11-20 09:42:23.135 HD Request # 15 | Completion time: 1s. | 2023-11-20 09:42:23.135 HD Request # 15 | Intraday data download complete for NQZ23_FUT_CME. Unique request ID: 15 | 2023-11-20 09:42:23.135 Removing historical data download ID 15. | 2023-11-20 09:42:23.135 Real-time Intraday chart data file updates started for NQZ23_FUT_CME | 2023-11-20 09:42:23.135 Intraday chart data file opened for NQZ23_FUT_CME | 2023-11-20 09:42:23.135 HD Request # 15 | Enabling Intraday chart updating for symbol. | 2023-11-20 09:42:23.135 Triggering next historical data download in queue. | 2023-11-20 09:42:23.135 HD Request # 16 | Downloading Intraday chart data for AAPL-NQTV to the file AAPL-NQTV.scid. Service: nasdaq_exchange.data | 2023-11-20 09:42:23.135 HD Request # 16 | Download start date-time: 2023-11-20 09:27:10.000000. File last date-time: 2023-11-20 09:27:10.354001 | 2023-11-20 09:42:23.135 HD Request # 16 | Using server: ds3.sierracharts.com port 10149 | 2023-11-20 09:42:23.135 Socket (5) | Creating socket. | 2023-11-20 09:42:23.149 Socket (5) | New receive buffer size: 0 | 2023-11-20 09:42:23.149 Socket (5) | Connecting to IP: 142.215.18.104. | 2023-11-20 09:42:23.149 Socket (4) | Socket gracefully closed by remote side. | 2023-11-20 09:42:23.164 Socket (4) | Closed. | 2023-11-20 09:42:23.164 HD Request # 16 | Setting DTC encoding to Binary VLS | 2023-11-20 09:42:23.223 HD Request # 16 | Sending historical data logon request message. | 2023-11-20 09:42:23.223 HD Request # 16 | Requesting Intraday data. Start date-time: 2023-11-20 09:27:10. Record interval: 0. Symbol: AAPL-NQTV | 2023-11-20 09:42:23.469 HD Request # 16 | Decompressing data. | 2023-11-20 09:42:23.503 HD Request # 16 | Receiving Intraday data for AAPL-NQTV starting at 2023-11-20 09:27:10.354000 | 2023-11-20 09:42:23.535 Socket (5) | CloseSocket call. | 2023-11-20 09:42:23.535 Socket (5) | Shutdown started. Waiting for graceful close. | 2023-11-20 09:42:23.535 Historical data download thread signaled to stop. | 2023-11-20 09:42:23.556 HD Request # 16 | Timestamp of first Intraday data file record written: 2023-11-20 09:27:19.759000. | 2023-11-20 09:42:23.556 HD Request # 16 | Received 3 Intraday data records from 2023-11-20 09:27:10.354000 to 2023-11-20 09:27:19.759000 (9.4 seconds. Delay: 15.1 minutes) and wrote 1 record for AAPL-NQTV | 2023-11-20 09:42:23.556 HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2023-11-20 14:27:19.759000 | 2023-11-20 09:42:23.561 HD Request # 16 | Completion time: 0s. | 2023-11-20 09:42:23.561 HD Request # 16 | Intraday data download complete for AAPL-NQTV. Unique request ID: 16 | 2023-11-20 09:42:23.561 Removing historical data download ID 16. | 2023-11-20 09:42:23.561 Real-time Intraday chart data file updates started for AAPL-NQTV | 2023-11-20 09:42:23.561 Intraday chart data file opened for AAPL-NQTV | 2023-11-20 09:42:23.561 HD Request # 16 | Enabling Intraday chart updating for symbol. | 2023-11-20 09:42:23.561 Triggering next historical data download in queue. | 2023-11-20 09:42:23.561 HD Request # 17 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2023-11-20 09:42:23.562 HD Request # 17 | Download start date-time: 2023-11-20 09:42:10.000000. File last date-time: 2023-11-20 09:42:10.863000 | 2023-11-20 09:42:23.562 HD Request # 17 | Using server: ds12.sierracharts.com port 10150 | 2023-11-20 09:42:23.562 Socket (5) | Socket gracefully closed by remote side. | 2023-11-20 09:42:23.567 Socket (5) | Closed. | 2023-11-20 09:42:23.567 Socket (4) | Creating socket. | 2023-11-20 09:42:23.587 Socket (4) | New receive buffer size: 0 | 2023-11-20 09:42:23.587 Socket (4) | Connecting to IP: 142.215.18.101. | 2023-11-20 09:42:23.587 HD Request # 17 | Setting DTC encoding to Binary VLS | 2023-11-20 09:42:23.670 HD Request # 17 | Sending historical data logon request message. | 2023-11-20 09:42:23.670 HD Request # 17 | Requesting Intraday data. Start date-time: 2023-11-20 09:42:10. Record interval: 0. Symbol: EURUSD | 2023-11-20 09:42:23.905 HD Request # 17 | Decompressing data. | 2023-11-20 09:42:23.939 HD Request # 17 | Receiving Intraday data for EURUSD starting at 2023-11-20 09:42:10.863000 | 2023-11-20 09:42:23.972 Socket (4) | CloseSocket call. | 2023-11-20 09:42:23.972 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-11-20 09:42:23.972 Historical data download thread signaled to stop. | 2023-11-20 09:42:23.999 HD Request # 17 | Timestamp of first Intraday data file record written: 2023-11-20 09:42:11.789000. | 2023-11-20 09:42:23.999 HD Request # 17 | Received 38 Intraday data records from 2023-11-20 09:42:10.863000 to 2023-11-20 09:42:22.125000 (11.3 seconds. Delay: 1.9 seconds) and wrote 37 records for EURUSD | 2023-11-20 09:42:23.999 HD Request # 17 | Add time&sales data | Remembered last file record date-time: 2023-11-20 14:42:22.125000 | 2023-11-20 09:42:24.003 Added 3 Time and Sales records to Intraday data file for EURUSD after download. | 2023-11-20 09:42:24.003 HD Request # 17 | Completion time: 1s. | 2023-11-20 09:42:24.003 HD Request # 17 | Intraday data download complete for EURUSD. Unique request ID: 17 | 2023-11-20 09:42:24.003 Removing historical data download ID 17. | 2023-11-20 09:42:24.003 Real-time Intraday chart data file updates started for EURUSD | 2023-11-20 09:42:24.003 Intraday chart data file opened for EURUSD | 2023-11-20 09:42:24.003 HD Request # 17 | Enabling Intraday chart updating for symbol. | 2023-11-20 09:42:24.003 Triggering next historical data download in queue. | 2023-11-20 09:42:24.003 HD Request # 18 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2023-11-20 09:42:24.003 HD Request # 18 | Download start date-time: 2023-11-20 09:42:10.000000. File last date-time: 2023-11-20 09:42:10.437000 | 2023-11-20 09:42:24.003 HD Request # 18 | Using server: ds13-2.sierracharts.com port 10149 | 2023-11-20 09:42:24.003 Socket (5) | Creating socket. | 2023-11-20 09:42:24.004 Socket (5) | New receive buffer size: 0 | 2023-11-20 09:42:24.004 Socket (5) | Connecting to IP: 162.251.232.245. | 2023-11-20 09:42:24.004 Socket (4) | Socket gracefully closed by remote side. | 2023-11-20 09:42:24.005 Socket (4) | Closed. | 2023-11-20 09:42:24.005 HD Request # 18 | Setting DTC encoding to Binary VLS | 2023-11-20 09:42:24.178 HD Request # 18 | Sending historical data logon request message. | 2023-11-20 09:42:24.178 HD Request # 18 | Requesting Intraday data. Start date-time: 2023-11-20 09:42:10. Record interval: 0. Symbol: USOil | 2023-11-20 09:42:24.283 HD Request # 18 | Decompressing data. | 2023-11-20 09:42:24.358 HD Request # 18 | Receiving Intraday data for USOil starting at 2023-11-20 09:42:10.514000 | 2023-11-20 09:42:24.432 Socket (5) | CloseSocket call. | 2023-11-20 09:42:24.432 Socket (5) | Shutdown started. Waiting for graceful close. | 2023-11-20 09:42:24.433 Historical data download thread signaled to stop. | 2023-11-20 09:42:24.436 HD Request # 18 | Timestamp of first Intraday data file record written: 2023-11-20 09:42:10.514000. | 2023-11-20 09:42:24.436 HD Request # 18 | Received 45 Intraday data records from 2023-11-20 09:42:10.514000 to 2023-11-20 09:42:22.277000 (11.8 seconds. Delay: 2.2 seconds) and wrote 45 records for USOil | 2023-11-20 09:42:24.436 HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2023-11-20 14:42:22.277000 | 2023-11-20 09:42:24.442 Added 3 Time and Sales records to Intraday data file for USOil after download. | 2023-11-20 09:42:24.442 HD Request # 18 | Completion time: 0s. | 2023-11-20 09:42:24.442 HD Request # 18 | Intraday data download complete for USOil. Unique request ID: 18 | 2023-11-20 09:42:24.442 Removing historical data download ID 18. | 2023-11-20 09:42:24.442 Real-time Intraday chart data file updates started for USOil | 2023-11-20 09:42:24.442 Intraday chart data file opened for USOil | 2023-11-20 09:42:24.442 HD Request # 18 | Enabling Intraday chart updating for symbol. | 2023-11-20 09:42:24.442 No download requests in the queue to start downloads for. | 2023-11-20 09:42:24.442 Socket (5) | Socket gracefully closed by remote side. | 2023-11-20 09:42:24.508 Socket (5) | Closed. | 2023-11-20 09:42:24.508 Opened cached Intraday file: C:\SierraChart\Data\ESZ23_FUT_CME.scid. Thread ID: 20816 | 2023-11-20 09:42:26.490 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 20816 | 2023-11-20 09:42:26.490 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 20816 | 2023-11-20 09:42:26.490 Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid. Thread ID: 20816 | 2023-11-20 09:42:26.490 Opened cached Intraday file: C:\SierraChart\Data\NQZ23_FUT_CME.scid. Thread ID: 20816 | 2023-11-20 09:42:26.490 Opened cached Intraday file: C:\SierraChart\Data\USOil.scid. Thread ID: 20816 | 2023-11-20 09:42:26.491 Opened cached Intraday file: C:\SierraChart\Data\AAPL-NQTV.scid. Thread ID: 20680 | 2023-11-20 09:42:28.778 |
[2023-11-20 15:06:12] |
Sierra_Chart Engineering - Posts: 17179 |
Who is your futures broker?
[2023-11-20 15:13:44] |
User312718 - Posts: 23 |
Daniels Trading. Right now the service is set to Generic but I feel like that needs to be changed.
Screenshot 2023-11-20 101225.png / V - Attached On 2023-11-20 15:13:05 UTC - Size: 21.25 KB - 58 views |
[2023-11-20 15:16:58] |
Does Daniels Trading have you set up on Teton order routing, CQG, OEC or Rithmic? Do you know which one among these four.
[2023-11-20 17:10:32] |
I believe it's CQG
[2023-11-20 17:10:33] |
I believe it's CQG
[2023-11-20 17:15:59] |
StoneX Futures Support - Posts: 8 |
If your StoneX account starts with DTR, FOL, GCL, or GCG, you would have received an email notice that your username is now your email address, effective this weekend. You would generally enter your username in lower case letters. Contact us at GFSupport <at> StoneX. com for help. Your password should be the same. If you need to reset your password or unlock your account, go to https://my.stonex.com.
[2023-11-20 19:49:05] |
If it is CQG, then you would follow the instructions here: CQG Trading Platform Service: Setup Instructions ---- If it is on the OEC system, then that is no longer supported in newer versions of Sierra Chart. In this case: To access historical and streaming market data independent from your Trading service. Follow these instructions. Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services". Press "OK" And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command: Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service) You can then use the data provided by Sierra Chart independent of your trading service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
