Date/Time: Wed, 23 Apr 2025 03:09:20 +0000
help me
View Count: 378
[2023-04-03 20:02:25]
User255976 - Posts: 1
I would like to know if the following could be configured:
1) To have all the time selected " crosshair" and when I click with the left mouse button, to be able to move the screen in all directions as if it were "hand ".
2) Can I have a 24 hr chart and mark an IB that is from 8:00 to 9:00 GMT ?
3) Could I have the following in a small window?
Average daily range for the last 10 days (24 hrs)
Average daily range of the night session for the last 10 days (24 hrs)
Average range of IB 8:00 to 9:00 GMT
Thank you
[2023-04-04 16:38:11]
John - SC Support - Posts: 39428
1. Set the option for Tools >> Tool Settings >> Chart Values >> Always On when Chart Values Tool Selected to Yes and the option for Tools >> Tool Settings >> Chart Values >> Action When Other Tools Selected to Always On When Using Other Tools.
Then select the Hand tool and you will have the Crosshairs and use the Hand tool to move the chart around.
Refer to the documentation for these settings starting at the following:
Chart Drawing Tools: Always On When Chart Values Tool Selected (Tool Settings >> Chart Values >> Chart Values)
2. You would have to use a second chart that has bars of not more than 1 hour (and bars that are evenly divisible into 1 hour (10 minutes, 30 minutes, but not 45 minutes)). Then setup the Initial Balance study on that chart. Refer to the following:
Initial Balance
then use the Study/Price Overlay to get the information onto the 24 hour chart. Refer to the following:
Study/Price Overlay Study
3. You would have to create those particular items and then you can use the Text Display for Study to put the information into a specific chart where that window is detached and made smaller so that you can just view the information you want. Refer to the following:
Working With Charts: Creating an Inset Chart
Text Display For Study
Date Time Of Last Edit: 2023-04-04 16:38:31
