Date/Time: Wed, 23 Apr 2025 03:24:10 +0000
Market Depth on Chart DOM
View Count: 465
[2023-03-30 13:46:57] |
ssangha84 - Posts: 128 |
Hello, I just recently got a new broker. With my old broker, I could see all the numbers under "buy and sell" on my chart dom. With my new broker, I can only see the numbers right where price is. Is there a setting that I can change to be able to see all of them?
[2023-03-30 15:38:31] |
John - SC Support - Posts: 39428 |
You can go through the information at the following link, but most likely this is due to the data you are receiving. Start here: File Menu: Not Receiving the Full Number of Market Depth Levels And if that does not resolve your issue then you need to check with your broker and see if you are setup to get the data from them that includes the Market Depth. Another option would be to us our Denali Exchange Data Feed instead of the Rithmic data. Refer to the following for the information on our Denali Data Feed: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
