Date/Time: Thu, 28 Nov 2024 20:46:41 +0000
futures contract back adjustment amount
View Count: 450
[2023-03-29 03:34:36]
sand - Posts: 1
hi sierra chart,
using a daily historical chart to get the back adjustment amount, i have followed the instructions exactly as provided in the "controlling rollover amount for back adjustments" section on the "continuous futures contract charts" page. the message log, however, never shows the detailed information, including the back adjust amount, shown in the instructions. please advise how to fix this problem. thanks.
[2023-03-29 18:14:45]
John - SC Support - Posts: 36350
Did you set the option for Global Settings >> General Settings >> Log >> Detailed Continuous Futures Contract Chart Logging to Yes?
Is your Continuous Futures Contract setup as a Back-Adjusted option?
Please make sure you go through each item at the following link explicitly and let us know if you continue to have an issue:
Continuous Futures Contract Charts: Controlling Rollover Amount for Back Adjustments
Also make sure you look through the rest of the Message Log, they may not be exactly at the end of the log, depending on what else is occurring in the system at that moment.
Date Time Of Last Edit: 2023-03-30 11:11:57
