Date/Time: Fri, 18 Sep 2026 12:06:42 +0000
CONNEXIONS
View Count: 1800
[2014-06-17 08:25:05]
User45578 - Posts: 50
i have Transact as dataprovider,until now i was workink whith two computers on the same box,and i was working on the two whith the same account from Transact!last days one of mine computer is still working well whith Transact but whith the second one i cant connect whith Transact ,but only whith data from FXCM .What heppens ?
[2014-06-17 08:43:11]
We need see the Message Log when you try to connect to TransAct. Provide it by following these instructions here:
https://www.sierrachart.com/index.php?l=PostingInformation.php#log
[2014-06-17 11:43:54]
Error creating the file folder: C:\SierraChart\Data\. Windows error code 3: Le chemin d’accès spécifié est introuvable. | 2014-06-17 10:13:34
Software version: 1137 | 2014-06-17 10:13:38
Usage end date: 2015-02-07 | 2014-06-17 10:13:38
Enabled for: Advanced Features. | 2014-06-17 10:13:38
Enabled for: Advanced Features 2. | 2014-06-17 10:13:38
Enabled for: Sierra Chart Historical Data Service. | 2014-06-17 10:13:38
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-06-17 10:13:38
Active service: TransAct | 2014-06-17 10:13:38
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2014-06-17 10:13:38
2014-06-17 10:13:38 Local computer clock time | 2014-06-17 10:13:38
2014-06-17 08:13:38 GMT time | 2014-06-17 10:13:38
2014-06-17 10:13:38 Time zone adjusted time | 2014-06-17 10:13:38
Time difference to server time: 1 seconds. | 2014-06-17 10:13:38
Program path: C:\A-SierraChart-old\ | 2014-06-17 10:13:38
Data Files path: C:\SierraChart\Data\ | 2014-06-17 10:13:38
OS Version Number: 6.2 | 2014-06-17 10:13:38
Checking for new symbol settings for ta | 2014-06-17 10:13:38
Requesting symbol settings for ta. Overwrite = on. | 2014-06-17 10:13:39
Symbol settings received. | 2014-06-17 10:13:39
Processed received symbol settings | 2014-06-17 10:13:39
TransAct - Starting server: C:\A-SierraChart-old\Transact\TransactToSierraBridge.exe | 2014-06-17 10:13:43
TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-17 10:13:45
The network socket is connected. | 2014-06-17 10:13:45
TransAct: Connected to server. | 2014-06-17 10:13:45
DTC Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2014-06-17 10:13:45
DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-06-17 10:13:45
TransAct: Sending logon request message. | 2014-06-17 10:13:45
TransAct: Market data feed reported to be lost. | 2014-06-17 10:13:46
Transact Futures Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2014-06-17 10:13:46
Transact Futures - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-06-17 10:13:46
Transact Futures - Connection error: Unknown Error Code: 60. | 2014-06-17 10:13:46
Socket has been shutdown and closed. | 2014-06-17 10:13:46
Transact Futures: Disconnected from the server. | 2014-06-17 10:13:46
Current selected Data/Trading service: SC Historical Data | 2014-06-17 11:09:29
Checking for new symbol settings for ddf | 2014-06-17 11:09:29
Requesting symbol settings for ddf. Overwrite = on. | 2014-06-17 11:09:32
Symbol settings received. | 2014-06-17 11:09:35
Processed received symbol settings | 2014-06-17 11:09:36
SC Historical Data: Connected. Historical Intraday data will be requested. | 2014-06-17 11:09:42
Chartbook file not found: C:\SierraChart\Data\ELEMENTSDAX.cht | 2014-06-17 11:09:58
Chartbook file not found: C:\SierraChart\Data\indices generaux.cht | 2014-06-17 11:10:09
Chartbook file not found: C:\SierraChart\Data\indices generaux.cht | 2014-06-17 11:10:33
Current selected Data/Trading service: CQG Trading | 2014-06-17 11:11:57
Checking for new symbol settings for cqg | 2014-06-17 11:11:57
SC Historical Data: Disconnected | 2014-06-17 11:11:57
CQG Trading FIX: Not connecting to trading server because Username is not specified. | 2014-06-17 11:11:57
CQG Trading: Not connecting to market data server because there is no Username set. | 2014-06-17 11:11:57
CQG Trading: Market data session connected. | 2014-06-17 11:11:57
Requesting symbol settings for cqg. Overwrite = on. | 2014-06-17 11:11:57
Symbol settings received. | 2014-06-17 11:11:58
Processed received symbol settings | 2014-06-17 11:11:58
The data feed was lost. There was no activity for at least 60.0 seconds. | 2014-06-17 11:12:57
Connection to the external service has been lost. | 2014-06-17 11:12:57
CQG Trading: Disconnected. | 2014-06-17 11:12:57
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 11:12:57
Current selected Data/Trading service: SC Forex Data (FXCM) | 2014-06-17 11:13:00
Checking for new symbol settings for fxcm | 2014-06-17 11:13:00
CQG Trading: Disconnected. | 2014-06-17 11:13:00
Requesting symbol settings for fxcm. Overwrite = on. | 2014-06-17 11:13:00
Symbol settings received. | 2014-06-17 11:13:01
Processed received symbol settings | 2014-06-17 11:13:01
SC Forex Data (FXCM): Connecting to the server ds5.sierracharts.com. Port 443 | 2014-06-17 11:13:05
Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-06-17 11:13:06
The network socket is connected. | 2014-06-17 11:13:06
SC Forex Data (FXCM): Connected to server. | 2014-06-17 11:13:06
SC Forex Data (FXCM): Sending logon request message. | 2014-06-17 11:13:06
SC Forex Data (FXCM) Server Info - Server Name: . Server Version: . Provider Name: . | 2014-06-17 11:13:06
SC Forex Data (FXCM) - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-06-17 11:13:06
SC Forex Data (FXCM) - Successfully connected. | 2014-06-17 11:13:06
Socket closed. Windows error code 10053: Une connexion établie a été abandonnée par un logiciel de votre ordinateur hôte. | 2014-06-17 12:35:30
Socket has been shutdown and closed. | 2014-06-17 12:35:30
Connection to the external service has been lost. | 2014-06-17 12:35:30
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 12:35:30
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 12:35:30
SC Forex Data (FXCM): Connecting to the server ds3.sierracharts.com. Port 443 | 2014-06-17 12:35:36
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 12:35:47
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 12:35:47
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 12:35:47
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 12:35:47
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 12:35:47
SC Forex Data (FXCM): Connecting to the server ds4.sierracharts.com. Port 443 | 2014-06-17 12:35:52
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 12:36:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 12:36:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 12:36:03
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 12:36:03
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 12:36:03
SC Forex Data (FXCM): Connecting to the server ds5.sierracharts.com. Port 443 | 2014-06-17 12:36:08
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 12:36:19
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 12:36:19
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 12:36:19
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 12:36:19
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 12:36:19
SC Forex Data (FXCM): Connecting to the server ds3.sierracharts.com. Port 443 | 2014-06-17 12:36:24
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 12:36:35
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 12:36:35
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 12:36:35
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 12:36:35
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 12:36:35
SC Forex Data (FXCM): Connecting to the server ds4.sierracharts.com. Port 443 | 2014-06-17 12:36:41
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 12:36:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 12:36:48
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 12:36:48
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 12:36:48
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 12:36:48
SC Forex Data (FXCM): Connecting to the server ds5.sierracharts.com. Port 443 | 2014-06-17 12:36:53
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 12:36:53
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 12:36:53
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 12:36:53
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 12:36:53
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 12:36:53
SC Forex Data (FXCM): Connecting to the server ds3.sierracharts.com. Port 443 | 2014-06-17 12:36:58
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 12:36:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 12:36:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 12:36:58
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 12:36:58
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 12:36:58
SC Forex Data (FXCM): Connecting to the server ds4.sierracharts.com. Port 443 | 2014-06-17 12:37:03
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 12:37:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 12:37:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 12:37:03
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 12:37:03
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 12:37:03
SC Forex Data (FXCM): Connecting to the server ds5.sierracharts.com. Port 443 | 2014-06-17 12:37:08
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 12:37:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 12:37:08
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 12:37:08
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 12:37:08
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 12:37:08
SC Forex Data (FXCM): Connecting to the server ds3.sierracharts.com. Port 443 | 2014-06-17 12:37:13
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 12:37:13
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 12:37:13
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 12:37:13
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 12:37:13
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 12:37:13
SC Forex Data (FXCM): Connecting to the server ds4.sierracharts.com. Port 443 | 2014-06-17 12:37:18
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 12:37:19
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 12:37:19
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 12:37:19
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 12:37:19
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 12:37:19
SC Forex Data (FXCM): Connecting to the server ds5.sierracharts.com. Port 443 | 2014-06-17 12:37:24
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 12:37:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 12:37:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 12:37:24
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 12:37:24
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 12:37:24
SC Forex Data (FXCM): Connecting to the server ds3.sierracharts.com. Port 443 | 2014-06-17 12:37:29
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 12:37:29
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 12:37:29
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 12:37:29
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 12:37:29
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 12:37:29
SC Forex Data (FXCM): Connecting to the server ds4.sierracharts.com. Port 443 | 2014-06-17 12:37:34
Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-06-17 12:37:34
The network socket is connected. | 2014-06-17 12:37:34
SC Forex Data (FXCM): Connected to server. | 2014-06-17 12:37:34
SC Forex Data (FXCM): Sending logon request message. | 2014-06-17 12:37:34
SC Forex Data (FXCM) Server Info - Server Name: . Server Version: . Provider Name: . | 2014-06-17 12:37:34
SC Forex Data (FXCM) - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-06-17 12:37:34
SC Forex Data (FXCM) - Successfully connected. | 2014-06-17 12:37:34
Socket closed. Windows error code 10053: Une connexion établie a été abandonnée par un logiciel de votre ordinateur hôte. | 2014-06-17 13:01:56
Socket has been shutdown and closed. | 2014-06-17 13:01:56
Connection to the external service has been lost. | 2014-06-17 13:01:56
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 13:01:56
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 13:01:56
SC Forex Data (FXCM): Connecting to the server ds5.sierracharts.com. Port 443 | 2014-06-17 13:02:01
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 13:02:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 13:02:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 13:02:01
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 13:02:01
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 13:02:01
SC Forex Data (FXCM): Connecting to the server ds3.sierracharts.com. Port 443 | 2014-06-17 13:02:06
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 13:02:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 13:02:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 13:02:07
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 13:02:07
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 13:02:07
SC Forex Data (FXCM): Connecting to the server ds4.sierracharts.com. Port 443 | 2014-06-17 13:02:12
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 13:02:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 13:02:12
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 13:02:12
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 13:02:12
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 13:02:12
SC Forex Data (FXCM): Connecting to the server ds5.sierracharts.com. Port 443 | 2014-06-17 13:02:17
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 13:02:17
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 13:02:17
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 13:02:17
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 13:02:17
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 13:02:17
SC Forex Data (FXCM): Connecting to the server ds3.sierracharts.com. Port 443 | 2014-06-17 13:02:22
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 13:02:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 13:02:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 13:02:22
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 13:02:22
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 13:02:22
SC Forex Data (FXCM): Connecting to the server ds4.sierracharts.com. Port 443 | 2014-06-17 13:02:27
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 13:02:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 13:02:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 13:02:27
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 13:02:27
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 13:02:27
SC Forex Data (FXCM): Connecting to the server ds5.sierracharts.com. Port 443 | 2014-06-17 13:02:32
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 13:02:32
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 13:02:32
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 13:02:32
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 13:02:32
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 13:02:32
SC Forex Data (FXCM): Connecting to the server ds3.sierracharts.com. Port 443 | 2014-06-17 13:02:37
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 13:02:38
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 13:02:38
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 13:02:38
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 13:02:38
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 13:02:38
SC Forex Data (FXCM): Connecting to the server ds4.sierracharts.com. Port 443 | 2014-06-17 13:02:43
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 13:02:43
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 13:02:43
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 13:02:43
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 13:02:43
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 13:02:43
SC Forex Data (FXCM): Connecting to the server ds5.sierracharts.com. Port 443 | 2014-06-17 13:02:48
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 13:02:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 13:02:48
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 13:02:48
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 13:02:48
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 13:02:48
SC Forex Data (FXCM): Connecting to the server ds3.sierracharts.com. Port 443 | 2014-06-17 13:02:53
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 13:02:53
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 13:02:53
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 13:02:53
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 13:02:53
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 13:02:53
SC Forex Data (FXCM): Connecting to the server ds4.sierracharts.com. Port 443 | 2014-06-17 13:02:58
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 13:02:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 13:02:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 13:02:58
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 13:02:58
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 13:02:58
SC Forex Data (FXCM): Connecting to the server ds5.sierracharts.com. Port 443 | 2014-06-17 13:03:03
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 13:03:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 13:03:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 13:03:03
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 13:03:03
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 13:03:03
SC Forex Data (FXCM): Connecting to the server ds3.sierracharts.com. Port 443 | 2014-06-17 13:03:08
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 13:03:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 13:03:08
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 13:03:08
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 13:03:08
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 13:03:08
SC Forex Data (FXCM): Connecting to the server ds4.sierracharts.com. Port 443 | 2014-06-17 13:03:13
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 13:03:14
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 13:03:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 13:03:14
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 13:03:14
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 13:03:14
SC Forex Data (FXCM): Connecting to the server ds5.sierracharts.com. Port 443 | 2014-06-17 13:03:19
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 13:03:19
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 13:03:19
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 13:03:19
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 13:03:19
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 13:03:19
SC Forex Data (FXCM): Connecting to the server ds3.sierracharts.com. Port 443 | 2014-06-17 13:03:24
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 13:03:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 13:03:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 13:03:24
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 13:03:24
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 13:03:24
SC Forex Data (FXCM): Connecting to the server ds4.sierracharts.com. Port 443 | 2014-06-17 13:03:29
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 13:03:29
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 13:03:29
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 13:03:29
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 13:03:29
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 13:03:29
SC Forex Data (FXCM): Connecting to the server ds5.sierracharts.com. Port 443 | 2014-06-17 13:03:34
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 13:03:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 13:03:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 13:03:34
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 13:03:34
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 13:03:34
SC Forex Data (FXCM): Connecting to the server ds3.sierracharts.com. Port 443 | 2014-06-17 13:03:39
Socket error on address resolution: Windows error code 11001: Hôte inconnu. | 2014-06-17 13:03:39
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-17 13:03:39
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-17 13:03:39
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 13:03:39
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-17 13:03:39
SC Forex Data (FXCM): Connecting to the server ds4.sierracharts.com. Port 443 | 2014-06-17 13:03:44
Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-06-17 13:03:44
The network socket is connected. | 2014-06-17 13:03:48
SC Forex Data (FXCM): Connected to server. | 2014-06-17 13:03:48
SC Forex Data (FXCM): Sending logon request message. | 2014-06-17 13:03:48
SC Forex Data (FXCM) Server Info - Server Name: . Server Version: . Provider Name: . | 2014-06-17 13:03:48
SC Forex Data (FXCM) - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-06-17 13:03:48
SC Forex Data (FXCM) - Successfully connected. | 2014-06-17 13:03:48
Current selected Data/Trading service: TransAct | 2014-06-17 13:41:17
Checking for new symbol settings for ta | 2014-06-17 13:41:17
Socket has been shutdown and closed. | 2014-06-17 13:41:17
SC Forex Data (FXCM): Disconnected from the server. | 2014-06-17 13:41:17
TransAct - Starting server: C:\A-SierraChart-old\Transact\TransactToSierraBridge.exe | 2014-06-17 13:41:17
Requesting symbol settings for ta. Overwrite = on. | 2014-06-17 13:41:18
Symbol settings received. | 2014-06-17 13:41:18
Processed received symbol settings | 2014-06-17 13:41:18
TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-17 13:41:19
The network socket is connected. | 2014-06-17 13:41:19
TransAct: Connected to server. | 2014-06-17 13:41:19
DTC Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2014-06-17 13:41:19
DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-06-17 13:41:19
TransAct: Sending logon request message. | 2014-06-17 13:41:19
TransAct: Market data feed reported to be lost. | 2014-06-17 13:41:21
Transact Futures Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2014-06-17 13:41:21
Transact Futures - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-06-17 13:41:21
Transact Futures - Connection error: Unknown Error Code: 60. | 2014-06-17 13:41:21
Socket has been shutdown and closed. | 2014-06-17 13:41:21
Transact Futures: Disconnected from the server. | 2014-06-17 13:41:21
[2014-06-17 17:13:54]
A more important problem is this:
To solve this, enable this option:
Global Settings >> General Settings >> Always Use Data Folder within Main Folder.
After enabling this, restart Sierra Chart.
For the connection problem to TransAct you are getting these messages:
Contact TransAct support here about this:
http://www.transactfutures.com/ContactUs.htm
Date Time Of Last Edit: 2014-06-17 17:14:33
