Date/Time: Tue, 22 Apr 2025 10:32:34 +0000
problem downloading data in more than one instance
View Count: 282
[2023-03-06 15:46:03]
User111577 - Posts: 5
I have 2 accounts with 3 differents companies (Dorman, Apex Funding and Elite Funding), 2 of them use Rithmic data. I installed copies of Sierra Chart on 3 different computers. I followed all the setup instructions,
I can run all instances of Sierra, but only the instance that I connect first gets real time data. The other instances just sits there. For example, I start both instances. I connect the Dorman instance and it runs fine. Now I connect the Apex or Elite instance. It downloads Historical Data, then just sits there.
If I start Apex first, the 2 others downloads historical data, then just sits there.
They are accessing completely different brokerages, data feeds, etc. They are on separate computers. What I need to do?
Any help appreciated. Thanks
[2023-03-06 15:46:53]
Sierra_Chart Engineering - Posts: 19305
The Connections section here explains all of this in detail and what to do:
Denali Exchange Data Feed: Connections
