Date/Time: Tue, 22 Apr 2025 07:40:09 +0000
Symbol of Dax cash DE40 in denali feeds
View Count: 852
[2023-03-05 21:25:44] |
jubakerdel - Posts: 13 |
Hello , I am at IB as a broker, but I subscribed to denali feeds, I would like to know how to find the dax cash symbol (de40). thanks, |
[2023-03-06 01:15:00] |
Sierra_Chart Engineering - Posts: 19297 |
Sierra Chart does not provide this data but you can get it from Interactive Brokers if they have the data by using the right symbol: Interactive Brokers Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-06 02:04:16] |
User584084 - Posts: 283 |
I use DAX-IND-EUREX in SC for the DE40 Index.
Date Time Of Last Edit: 2023-03-06 02:09:13
[2023-03-06 09:51:33] |
Hello, After taking into account your recommendations, when I try to open the graph of AX-IND-EUREX in SC for the DE40 Index, I get the following error ? Can this error be corrected by the SC team, or do I have to contact IB to solve it ? Thanks's |
[2023-03-06 11:01:22] |
You need to request trading/market data permissions for the German exchanges from IB. Usually takes 1 to 2 days once you request permissions. Easiest way to do this would be to contact IB support. If you want real time data for the DAX40 Index, you will need to subscribe to the German ETFs and Indexes data feed. It is 1.25 Euros per month. https://www.sierrachart.com/image.php?Image=167810160542.png Date Time Of Last Edit: 2023-03-06 11:21:44
[2023-03-06 11:01:46] |
Contact Interactive Brokers about that error message.
