Date/Time: Tue, 22 Apr 2025 07:22:13 +0000
Rithmic conecction
View Count: 353
[2023-03-01 19:05:36]
User686013 - Posts: 1
Hi, I am trying to connect to SC with Rithmic data feed. I have some funded accoutns (Apex) and see much value on using SC for trading. I have downloaded latest version and followd instructions given in the SC site. But in the Data/trade Service Settings I get the following
"Rithmic Direct - DTC (Not enabled on package)" what does this mean and how can I get it to setup?
Appreciate the help!
Date Time Of Last Edit: 2023-03-02 00:11:43
[2023-03-02 15:14:12]
John - SC Support - Posts: 39395
The account you posted from was expired (you do not have any Usage Time). This would be why you received that notice.
We see that you did not use all the time from your trial therefore we have setup your account to be on Package 12 for 15 days. This will allow you to connect to Rithmic, which you would not be able to do on a trial. When the 15 days are over, you will then have to activate a paid package in order to continue to use the system.
Follow the instructions at the following link to connect to Rithmic:
Rithmic Trading Platform Service: Setup Instructions
