Date/Time: Tue, 04 Nov 2025 16:32:29 +0000
question about Graphics Settings
View Count: 707
[2023-02-28 19:32:18]
Tony - Posts: 640
I tried set some of the values in "Graphics Settings - Chart" different than "Graphics Settings - Global", it works great, until I noticed every time I check and uncheck "Use Global Graphics Settings Instead of These Settings", some of the values I set in "Graphics Settings - Chart" (i.e. Chart Scale Border) will be changed to the corresponding Global Graphics value by itself and I had to change it back to the value I wanted.
In my case, I need change the value of sc.UseGlobalChartColors in ACSIL from time to time, it doesn't work all the time, unless for those values that can be accessed by ACSIL, like sc.ChartBackgroundColor
I am wondering if "Graphics Settings - Chart" and "Graphics Settings - Global" can be treated as 2 different sets and independent?
Thanks a lot!
Date Time Of Last Edit: 2023-02-28 19:39:26
[2023-03-03 18:41:04]
Sierra_Chart Engineering - Posts: 21306
We will look into this.
[2023-03-04 09:19:10]
This issue is not reproducible and does not make technical sense as to why it would occur.
You must be changing this color in ACSIL:
sc.ScaleBorderColor
If so, this will lead to the problem but we will implement a solution to that in the next release.
[2023-03-05 05:48:27]
Tony - Posts: 640
Thanks for the reply.
I did some further investigations, first I thought it was Linux issue, switch to Windows, it was the same, then I removed custom study (only one) from chart book and restart Sierra Chart, and then issue was gone.
So, it was caused by my study, not sure what it is yet, I will try to find it out.
I didn't realize there is a sc.ScaleBorderColor variable, I got around my issue by doing this:
if (sc.CharacterEventCode==113) { // "q"
  sc.HideStudy = !sc.HideStudy;
  sc.UseGlobalChartColors = sc.HideStudy ? 0 : 1;
  sc.ChartBackgroundColor = sc.HideStudy ? RGB(105,105,105) : RGB(255,245,211);
sc.ScaleBorderColor = sc.HideStudy ? RGB(105,105,105) : RGB(255,245,211);
It seems working fine, hope it is safe for me to do that.
Thanks a lot!
[2023-03-07 17:24:23]
Also to let you know, ACSIL is going to have new functions to get and set all the different color and graphics properties for a chart.
This will be out next week.
