Date/Time: Tue, 22 Apr 2025 02:27:39 +0000
Changes to graphics settings - global
View Count: 377
[2023-02-25 20:41:59] |
OriolCasas - Posts: 189 |
Hello, I am trying to make changes to graphics settings - global and the changes don't appear on my charts, how is it possible? Thank you |
[2023-02-27 15:14:59] |
This would mean that your charts are setup for chart specific graphics. Select Chart >> Graphics Settings >> Chart and see if the option at the top for Use Global Graphics Settings Instead of These Settings is disabled. If it is, then the chart graphics are defined by the settings in this window. If it is enabled, then we would need to know and we would dig into this further. Refer to the following for more information: Graphics Settings: Using Different Color and Graphics Settings for Specific Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-27 15:24:53] |
Use Global Graphics Settings Instead of These Settings is enabled and it was before the message. I guess what is happening is quite strange. Thank you |
[2023-02-27 18:23:01] |
What items in the Graphics Settings are you changing (give us 1 or 2 of them)
