Date/Time: Tue, 22 Apr 2025 07:54:29 +0000
10min delay on live feeds
View Count: 400
[2023-02-24 15:13:24] |
Christos Boundikas - Posts: 5 |
I have gone through and made all the connections as explained in the articles but we are still getting data that is 10min old.. How can we check this and get live data? |
[2023-02-24 15:49:19] |
You need to go through the Setup for the Denali Exchange Data Feed and eventually activate and pay for, the exchanges for which you want the real-time data. You will find the instructions for the CME Group data on the Denali Exchange Data Feed at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* If you need data for EUREX, CFE, or NASDAQ TotalView, then those instructions are just below the above set of instructions. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-27 16:22:08] |
This was done already for at least 30 days as SC already debited my balance.
[2023-02-27 16:23:05] |
Can you not peer into my account and see all this, seems you are troubleshooting, can save all our time by you have admin panel so we get to the root issue.
[2023-02-27 18:26:44] |
We have looked at the setup of your account. You have not done the setup for the Denali Exchange Data Feed, as you have not filled out the data agreements or activated any exchanges - ever. You also have never been charged for any exchange fees. Package 12 (or any of the Integrated packages) do not automatically give you real-time data - they just give you the ability to get the real-time data, as opposed to the Base packages, which do not. You still need to go through the instructions at the following link and activate and pay for the exchanges for which you want real-time data: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-28 14:02:30] |
Can you please tell me what I have been charged for for the last 2 months since this was not real time data? My balance is half of what I sent in.
[2023-02-28 17:44:49] |
Your account has been charged for the Usage Time of Package 12 for one month ($56.00) two times (two months). You can view the transactions for your account by selecting the link for View Transaction Log and Payments Receipts on the Main Control Panel for your account on our website. You can also get their directly through the following link: https://www.sierrachart.com/UserControlPanel.php?page=TransactionLog You will see that you have not been charged for any exchange fees. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-01 12:56:01] |
Okay I have submitted all the CME as per attached screen shot. I still dont have live data.
[2023-03-01 21:10:07] |
Everything on your account looks good. If you are still having issues then follow these instructions to get us your Message Log: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
