Date/Time: Mon, 21 Apr 2025 23:30:19 +0000
Unable to cancel Pending Open Order
View Count: 762
[2023-02-21 19:59:55] |
User374327 - Posts: 3 |
Order cancellation failed | Reject text: The order was in a state that prohibited a cancel request. Internal Order ID: 21936. Service Order ID: 649605165. Symbol: F.US.MESH23. Account: xxx | 2023-02-21 14:42:11.474 * Order cancellation failed | Reject text: The order was in a state that prohibited a cancel request. Internal Order ID: 21960. Service Order ID: 649430000. Symbol: F.US.MESH23. Account: xxx | 2023-02-21 14:46:36.855 * Order cancellation failed | Reject text: The order was in a state that prohibited a cancel request. Internal Order ID: 21936. Service Order ID: 649605165. Symbol: F.US.MESH23. Account: xxx| 2023-02-21 14:47:53.769 * |
[2023-02-21 20:16:04] |
Cold ES - Posts: 1 |
I am getting the same thing today. Based on the number of posts about this issue it is wide spread. I bet it has something to do with Teton Order Routing. My pending orders were submitted at 2:37pm ET. I think Teton went down around that time
[2023-02-21 20:22:03] |
Gary Number 2 - Posts: 133 |
AMP just emailed saying that CQG has order routing issues as well. Yes, likely widespread since I use CQG routing with AMP.
[2023-02-21 20:23:45] |
mattvk - Posts: 34 |
Same issue here. I'm with AMP using CQG order routing, and was able to flatten my position by logging on to the CQG web dashboard directly. This is a major f-up. Open orders are still showing as "pending cancel"
Date Time Of Last Edit: 2023-02-21 20:25:52
[2023-02-21 20:43:42] |
Message from AMP trade desk chat 3:43 pm EST: The order routing system is experiencing technical problems. Please restart your platform.
Pending orders are stuck "in transit" We are working with CQG and will provide update shortly. All customers will be notified when the system is functioning normally. |
[2023-02-21 20:47:01] |
User753428 - Posts: 173 |
CQG had a similar but worse order routing issue around a year or two ago but back then, you couldn't even flatten your position (and neither could your broker). the issue wasn't resolved for over 12 hours and i was stuck in a long position that i had entered during the cash session. as fate might have it, the market tanked overnight and i sustained a pretty heavy loss. the good news is that AMP was generous enough to refund my loss on that position but the bad news is AMP still refuses to offer the Teton Order routing service as an alternative. i'm glad to hear this time around, people are at least able to close out their positions. |
[2023-02-21 22:25:21] |
This is a CQG issue, so there is nothing we can do to alleviate the immediate issue. You will need to check with your broker for updates.
[2023-02-21 22:56:21] |
Sierra_Chart Engineering - Posts: 19290 |
I am getting the same thing today. Based on the number of posts about this issue it is wide spread. I bet it has something to do with Teton Order Routing. My pending orders were submitted at 2:37pm ET. I think Teton went down around that time You are not using Teton order routing! You are using CQG.This has nothing to do with Teton order routing. To solve the problem you do need to use Teton order routing: Sierra Chart Teton Futures Order Routing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-02-22 06:52:06
