Date/Time: Mon, 21 Apr 2025 23:30:23 +0000
Spacing in BidAskVolumeBars charts
View Count: 290
[2023-02-16 23:14:01] |
User480109 - Posts: 49 |
I noticed that annoyingly as time moves forward, the spacing between my bidaskvolumebars charts gaps apart for some reason. Is there a way to keep then nice and stacked all the time? Please see attached chart. Thank you!
[2023-02-16 23:45:41] |
You have the Scale set to Automatic. As such, it just depends on the number of levels that are available to be displayed at any given time. When there are fewer levels, the system spreads the data out a bit more, and vice versa. The other option is to use a Constant Range scaling, but then you may find that the data goes off the top or bottom of the screen when you have a lot of information. The Numbers Bars are just tough to scale given how much information there can be and how the information changes. Refer to the following for more on this topic: Numbers Bars: Scaling a Numbers Bars Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
