Date/Time: Mon, 21 Apr 2025 23:27:29 +0000
Customizations for Dom Charts
View Count: 367
[2023-02-16 11:32:02] |
TOMIbell@2007 - Posts: 5 |
I Customized My Dom Charts But the Changes didnt save for every Dom Chart Why.
[2023-02-16 17:39:51] |
We need more information on what exactly you did, as we do not have enough information to give a clear answer.
[2023-02-16 17:45:50] |
Well I was trying to customize my Dom charts in the free trials, But the moment I closed the app everything disappeared, and none of the customizations even reflected n Dom charts of other symbols. Thank You.
Date Time Of Last Edit: 2023-02-16 17:46:28
[2023-02-16 22:18:55] |
We think what you did was not save the Trading DOM. Therefore, when you opened the Chartbook again, the Trading DOM was not automatically there, so you would have opened a new Trading DOM, which does exactly that - opens a brand new Trading DOM. It does not open the Trading DOM that you had setup previously. You need to make sure the Trading DOM is open when you save your Chartbook, this way when you open the Chartbook the Trading DOM will come back. The Trading DOM is a Chart-like object, so this is how it works. This is different from items like the Time and Sales or Market Depth windows. For more information, refer to the following: Chart Trading and the Chart DOM: Saving Trade DOM Configuration For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-17 09:07:25] |
Thank you.
