Date/Time: Mon, 21 Apr 2025 17:49:49 +0000
loading error with custom study
View Count: 611
[2023-02-12 16:08:43]
User735389 - Posts: 189
i have a custom study that's been working fine. i have an older computer (windows server 2019, Intel 740qm chip)
i want to run sierra chart on, but it seems to have problems loading the study. i copied the entire sierrachart folder over from the other (working) computer, running the same OS. when i try to add the study, i see an error message something to the effect of
"Error Loading: ...\study.dll. File not found or may be missing SCDLLName."
This immediately made me think of the 64-bit conversion that happened a couple years ago. SC is looking for a file that doesn't exist (study.dll). it should be looking for the "study_64.dll" file. As far as i can tell, the intel 740qm chip is a 64-bit chip, and the OS is 64 bit only. So im a bit baffled as to what's going on here. SC is up-to-date, running the sierrachart_64.exe, verified the study_64.dll file is in the data folder. and if i recall correctly, i was able to run sierra chart previously on this computer, with windows 7/10.
Date Time Of Last Edit: 2023-02-13 01:25:46
[2023-02-13 16:05:11]
John - SC Support - Posts: 39380
We really need to see the exact error message. Please open your Message Log and copy the line of that message and paste it to this thread.
[2023-02-13 20:18:44]
Sierra_Chart Engineering - Posts: 19289
Sierra Chart will automatically do this:
There may be a missing DLL dependency file.
Also do you see the custom studies from that file listed in Analysis >> Studies >> Add Custom Study.
