Date/Time: Mon, 21 Apr 2025 18:19:39 +0000
alarms
View Count: 351
[2023-02-10 19:09:09] |
User473031 - Posts: 56 |
I'm trying to set an alarm is triggered when price go above or below bollinger band, a sound and pop message (if that is possible) Are you able to help me with this? I've gone through the documentation but I'm still not able to be successful. thanks Michael |
[2023-02-10 22:22:37] |
John - SC Support - Posts: 39381 |
You would set an "Alert" on the Bollinger Band study (there is a tab for Alerts on the Settings window for the study). Since you just want to be alerted when price crosses the Bollinger Band, the alert entry would look like the following: =CROSSOVER(C, ID1.SG1) Where C is the Close (last or current price) and ID1.SG1 is the ID of the Bollinger Bands Study and SG (Subgraph) 1 of the Bollinger Bands study (Top Band). Then select an Alert Sound on that Alerts tab and any other settings as you need them. The information for setting up Alerts is at the following link: Study/Chart Alerts And Scanning The general instructions for setting up an Alert sound is at the following link: General Settings Window: Configuring Alert Number Instructions Note that all the information for the Alert Sound Settings are just above this section. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-11 05:14:55] |
Ok thank you, Now what if I have data in region 2 with a Bollinger band. Is C applied to the region that it is in? So for example, advance decline data in region 2 and I have it with an Bollinger band. Same approach? |
[2023-02-13 15:01:51] |
It does not matter the region. There are certain variables that are setup for the Main Price Graph, so 'C' is always referring to the Close (Last) of the Main Price Graph (the main bars in Region 1). Refer to the following: Study/Chart Alerts And Scanning: Available Main Price Graph Identifiers/Variables For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
