Date/Time: Mon, 25 Nov 2024 05:42:11 +0000
Trade Order Error
View Count: 950
[2023-02-08 06:59:15]
User890348 - Posts: 3
I keep getting this error when trying to place orders through the DOM, Teton CME order routing (order rejected). Info: Trade Order Error - Symbol not allowed for trading for account.
I have tried contacting the clearing house and they told me to go from step 5 in this: https://www.sierrachart.com/index.php?page=doc/SierraChartDirectOrderRoutingService.php#SetupInstructions, which I believe I have done, and it seems to be connecting correctly, but I get the order error every time I post one.
[2023-02-08 07:09:58]
User697966 - Posts: 6
I have a similar problem that appeared this morning but on the EUREX exchange using the Sierra Chart trading evaluator.
Trading Evaluator (Order reject). Info: Trade Order Error - Symbol not found in margin data. Margin requirement not known for symbol. Margin calculation <= 0. Invalid. Text: Parent order. Tag: SimpleBracket.twconfig. Internal Order ID: 11855. Service Order ID: 4301139. Symbol: FGBLH23. Account: cserni | 2023-02-08 08:08:15.845 *
[2023-02-08 16:01:23]
Sierra_Chart Engineering - Posts: 17169
We need to know the exact symbol being traded.
Tell us the exact symbol. We do not know what the symbol is.
Regarding post #2 We will have a look at that today. There is some problem involving EUREX margin data.
Date Time Of Last Edit: 2023-02-08 16:02:07
[2023-02-08 16:26:12]
I think it regards every symbol, but the ones I have tried so far are: 10YG23_FUT_CME, 30YG23_FUT_CME. I just tried now and got the "Internal Order ID: 74. Service Order ID: 575968", does this help?
[2023-02-08 17:30:37]
Find out from your broker if they have allowed trading in 10Y and 30Y futures for your account.
Date Time Of Last Edit: 2023-02-08 17:34:06
[2023-02-08 19:58:50]
Everything is set they say.
[2024-03-27 14:56:30]
User443178 - Posts: 16
I am seeing the same thing this morning for WTI crude mini's, while the ES mini's are fine. MCLK24_FUT_CME
2024-03-27 10:50:24.830 | Teton CME Order Routing (Order reject). Info: Trade Order Error - Symbol not found in margin data. Margin requirement not known for symbol. Margin calculation <= 0. Invalid. Text: Parent order. Tag: Oil3TrailOffset.twconfig. Internal Order ID: 83187. Service Order ID: 1324806. Symbol: MCLK24_FUT_CME. Account:xxxx *
This was fine yesterday and there is more than enough cash to cover margins.
[2024-03-27 16:04:17]
There was an issue with the information from the CME for the MCL symbol. Your broker has been informed on how to resolve this for you, so if you are still having an issue, then please check with your broker.
[2024-03-28 10:14:51]
User706963 - Posts: 8
I am getting the following: 'Trading Evaluator (Order reject). Info: Trade Order Error- Symbol not found in margin data. Margin requirement not known for symbol. Margin calculation <=0. Invalid.'
As a result I'm stuck in a CLK24 trade - the bracket orders were cancelled when I tried to flatten and now it won't even let me replace the stop manually or exit the position.
[2024-03-28 10:44:05]
Berliner JFK - Posts: 45
I get the same error message but with the simulated futures trading service:
2024-03-28 05:15:00.939 | Trading Evaluator (Order reject). Info: Trade Order Error - Symbol not found in margin data. Margin requirement not known for symbol. Margin calculation <= 0. Invalid.
I also have an open position (simulated futures trading service) and cannot modify it.
[2024-03-28 10:56:11]
User762422 - Posts: 5
I also get the same error message on the simulated futures trading service:
I am currently in a trade and can't flatten or add a stop
2024-03-28 04:49:33.761 | Trading Evaluator (Order reject). Info: Trade Order Error - Symbol not found in margin data. Margin requirement not known for symbol. Margin calculation <= 0. Invalid. Internal Order ID: 5142. Service Order ID: 9235851. Symbol:HGK24
[2024-03-28 13:50:36]
User726633 - Posts: 1
Good morning. I get a similar error on the Simulated Futures Trading Service with MESM24:
2024-03-28 08:46:08.262 | Trading Evaluator - Delayed (Order reject). Info: Trade Order Error - Symbol not found in margin data. Margin requirement not known for symbol. Margin calculation <= 0. Invalid. Text: Parent order. Internal Order ID: 1950. Service Order ID: 2493840. Symbol: MESM24.
When I Request Margin Data for the symbol in Edit Trade Account -> Margin I get another error:
Date Time Of Last Edit: 2024-03-28 13:54:12
[2024-03-28 15:16:22]
This is being looked into.
[2024-03-28 15:28:35]
This has been fixed.
[2024-03-29 01:53:28]
We apologize for this issue. We had a critical update that we need to release in simulation, before live, and we forgot to place the margin files in the folder for the Sierra Chart server process to access.
[2024-03-29 10:39:26]
Thank you very much for this.
Could this issue possibly affect live trading?
I see that there was also the issue with Teton order routing:
Trade Order Error | Post: 377272
order rejected | Post: 377341
opening position problems | Post: 377410
[2024-03-29 14:12:39]
It was not the exact same issue, but there was a related issue with live trading for just the symbol MCL. Brokers were given a work around fairly quickly, but AMP has decided to wait for our final fix on this, so if you are trading with AMP using our Teton Order Routing, you will not be able to trade MCL.
We expect to have the issue resolved today, so everything should be fine for the open on Sunday night.
[2024-03-30 01:57:28]
The problem only affected MCL for live trading because the CME removed that from the span margin file available on their website.
It would not be affecting other symbols.
Date Time Of Last Edit: 2024-03-30 01:57:39
[2024-03-30 20:03:15]
Regarding the Trading Evaluator service, it is possible to disable the margin requirement check. It can be disabled with this account option:
Trade Account and Risk Management: Require Sufficient Margin For New Positions (Margin Settings)
