Date/Time: Mon, 21 Apr 2025 13:05:47 +0000
Rithmic (Leeloo Trading)
View Count: 742
[2023-02-07 18:27:00] |
natemallard - Posts: 2 |
Hello, I have data through Leeloo trading (Rithmic is the provider I believe). Am I able to use that for data on SC? If so, does it matter which package I choose to allow me to use rithmic data? I prefer to see orderflow data (TPO charts, and DOM)
[2023-02-07 22:22:53] |
John - SC Support - Posts: 39362 |
In order to connect to your Rithmic account and get the data from Rithmic, you need to be on one of the Integrated packages. Further, since you state you need TPO charts that means that you need to use the Integrated Advanced package (Package 11). You will find the information on the packages here: Description of Service Packages and Pricing: Packages If you have not already done so, you will need to follow the instructions at the following link to connect your Sierra Chart to your Rithmic account, once you have changed to Package 11: Rithmic Trading Platform Service: Setup Instructions Note that if you change to Package 11 at any time before your trial is done, the remaining trial time will be added to the paid package time (i.e. you do not lose the trial time). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-08 12:44:28] |
Thanks for the reply! I got rithmic set up and I believe I am connected. However, I am not seeing data actually come through on the screen. I have attached screenshots to show the issues I’m having.
![]() ![]() Attachment Deleted. |
[2023-02-08 16:12:15] |
You need to change your symbols to what is used by Rithmic. To do this, open your Chartbooks and select Edit >> Translate Symbols to Current Service.
[2023-02-08 16:45:24] |
Sierra_Chart Engineering - Posts: 19285 |
Here is the relevant documentation: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
