Date/Time: Sun, 28 Apr 2024 11:11:50 +0000
TPO > Letters/Blocks in Own Column "ALL" < request
View Count: 1848
[2013-05-01 11:59:46] |
Rainer - Posts: 108 |
additional Parameter request. When select "Letters/Blocks in Own Column" (on a MP-TPO) can you please add option "Letters/Blocks in Own Column ALL", in order not having to click on every day if wanting to see an expanded overview over a few weeks; see attached screenshot. This will expand All MP-TPOs (in the Chart). (note: have been working with Market Profile for 13yrs, and one can really see a different 'dimension' when the days range are expanded) |
[2013-05-03 05:05:04] |
We will see about this. It will not be for a while.
[2013-05-05 14:04:50] |
jsoviero - Posts: 84 |
Yes in a similar request to this, please add an option to split out all Globex sessions from the RTH sessions. Thank you in advance.
[2013-05-05 21:21:05] |
This is already supported and we answered you on this previously. See: How to split a TPO into RTH and Globes sessions? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
