Date/Time: Mon, 21 Apr 2025 13:14:37 +0000
unable to download Sierra Chart Installer
View Count: 397
[2023-02-07 13:07:27] |
User76183 - Posts: 69 |
Hello! unable to download Sierra Chart Installer. Once I try to download Sierra from your official website it shows "MD5 for file does not match. File: SierraChart_64.exe HTTP connection ID: 71 to download3 sierrachart.com 443 for request ID:71 Timed out waiting for shutdown.... And then the installation process is stuck. It shows that download is failed and waiting for reconnection |
[2023-02-07 13:43:15] |
Sierra_Chart Engineering - Posts: 19285 |
To understand this we really need to see the entire log. However, for now use the ZIP installer instead: Software Download: Sierra Chart Zip Installer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-07 17:39:54] |
I have also issues with Teton connection, order flow and execution: [17176] Chartbook Sharing Server | Restore Settings | Read from File 'C:\SierraChart\SierraChart2480\Data\ChartbookSharing\ChartbookSharingSettings.config' | 2023-02-07 09:22:10.762 [17176] Chartbook Sharing Server | Restore Settings | Start reading internal server states | 2023-02-07 09:22:10.763 [17176] Chartbook Sharing Server | Restore Settings | Finish reading internal server states. OK | 2023-02-07 09:22:10.764 [17176] Chartbook Sharing Server | Server | Send @RestartServer to All /Start | 2023-02-07 09:22:10.764 Created the DTC Protocol server. | 2023-02-07 09:22:10.764 DTC Protocol Server listening on port 11099. | 2023-02-07 09:22:10.764 Reading Internal Order ID file. | 2023-02-07 09:22:10.764 Reading Trade Orders file. | 2023-02-07 09:22:10.803 Reading Trade Positions file. | 2023-02-07 09:22:10.806 Reading Trade Account Data files. | 2023-02-07 09:22:10.808 UDPListener (1756). Port 22903 | Listening on UDP port 22903. | 2023-02-07 09:22:10.811 Software version: 2480 64-bit | 2023-02-07 09:22:10.811 OpenGL enabled (NVIDIA Corporation/NVIDIA GeForce RTX 3060/PCIe/SSE2) | 2023-02-07 09:22:10.811 Primary Thread ID: 17176 | 2023-02-07 09:22:10.811 Usage end date: 2023-05-27 | 2023-02-07 09:22:10.811 Enabled for: Advanced Features 2. | 2023-02-07 09:22:10.811 Enabled for: Sierra Chart Historical Data Service. | 2023-02-07 09:22:10.811 Enabled for: Denali Real-Time Exchange Data Feed. | 2023-02-07 09:22:10.811 Enabled for: Delayed Denali Exchange Data Feed. | 2023-02-07 09:22:10.811 Enabled for exchange2: CME (Trading Account Required) | 2023-02-07 09:22:10.811 Enabled for exchange2: CBOT (Trading Account Required) | 2023-02-07 09:22:10.811 Enabled for exchange2: COMEX (Trading Account Required) | 2023-02-07 09:22:10.811 Enabled for exchange2: NYMEX (Trading Account Required) | 2023-02-07 09:22:10.811 Enabled for exchange2: fairx_exchange.data | 2023-02-07 09:22:10.811 Allow Support for Sierra Chart Data Feeds is enabled. | 2023-02-07 09:22:10.811 Current selected Data/Trading service: Teton CME Order Routing | 2023-02-07 09:22:10.811 Custom symbol settings values: enabled | 2023-02-07 09:22:10.811 Chart Update Interval: 500 | 2023-02-07 09:22:10.811 Intraday Data Storage Time Unit: 0 | 2023-02-07 09:22:10.811 Time Zone: -08:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2023-02-07 09:22:10.811 2023-02-07 17:22:10 Local computer time in UTC | 2023-02-07 09:22:10.811 2023-02-07 09:22:10 Local computer time in SC Time Zone | 2023-02-07 09:22:10.811 2023-02-07 17:22:10 Server time in UTC | 2023-02-07 09:22:10.811 Local computer UTC time and Server UTC time difference: 0 seconds. | 2023-02-07 09:22:10.811 Program path: C:\SierraChart\SierraChart2480\ | 2023-02-07 09:22:10.811 Data Files path: C:\SierraChart\SierraChart2480\Data\ | 2023-02-07 09:22:10.811 OS Version Number: 10.0 | 2023-02-07 09:22:10.811 Locale Setting: C | 2023-02-07 09:22:10.811 DLLs: sst_syx_64.dll, TicinoMathV2.0.dll, TicinoMathV2.0_64.dll, TicinoMathV3.0.dll, TicinoMathV3.0_2151.dll, TicinoMathV3.0_2151_64.dll, TicinoMathV3.0_64.dll, TicinoSuite_64.dll, UserContributedStudies_64.dll | 2023-02-07 09:22:10.812 Allowed protected custom studies: SST_Syx, TicinoMathV2.0.DLL, TicinoMathV3.0.DLL, TicinoSuite, zyp_app | 2023-02-07 09:22:10.812 Crash reporter started: true | 2023-02-07 09:22:10.812 Created the DTC Protocol historical data server. | 2023-02-07 09:22:10.820 HD Server Manager | Listening on port 11098. | 2023-02-07 09:22:10.821 Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. | 2023-02-07 09:22:10.821 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:22:10.835 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-02-07 09:22:11.098 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-02-07 09:22:11.098 Received 5 login tokens. | 2023-02-07 09:22:11.609 Symbol settings MD5 received. Request ID: 1. | 2023-02-07 09:22:13.060 Symbol settings are up-to-date for sc_futures_direct.dtc.trading. | 2023-02-07 09:22:13.060 Files to Open on Startup | File does not exist: C:\SierraChart\SierraChart2480\Data\TYP_DOMs_ES_NQ_2022_v2443.Cht | 2023-02-07 09:22:16.068 Teton CME Order Routing | Firm: Dorman | 2023-02-07 09:22:18.068 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-02-07 09:22:18.068 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-02-07 09:22:18.071 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-02-07 09:22:18.071 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2023-02-07 09:22:18.071 Teton CME Order Routing | Network connection to server complete. | 2023-02-07 09:22:18.314 Teton CME Order Routing | Starting socket receive thread. | 2023-02-07 09:22:18.314 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-02-07 09:22:18.314 Created process C:\SierraChart\SierraChart2480\SierraChartInstance_2\SierraChart_64.exe. Current folder: C:\SierraChart\SierraChart2480\SierraChartInstance_2 | 2023-02-07 09:22:20.485 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-02-07 09:22:20.789 Teton CME Order Routing | Sending logon request message. | 2023-02-07 09:22:20.789 Teton CME Order Routing | Received logon response. | 2023-02-07 09:22:22.071 Teton CME Order Routing | Server Name: SC DTC Server. Build=44641. | 2023-02-07 09:22:22.071 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-02-07 09:22:22.071 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2023-02-07 09:22:22.071 Teton CME Order Routing | Trading is supported. | 2023-02-07 09:22:22.071 Teton CME Order Routing | Order cancel and replace is supported. | 2023-02-07 09:22:22.071 Teton CME Order Routing | OCO Orders supported. | 2023-02-07 09:22:22.071 Teton CME Order Routing | Bracket Orders supported. | 2023-02-07 09:22:22.071 Teton CME Order Routing | Connected to server complete. | 2023-02-07 09:22:22.071 Triggering next historical data download in queue. | 2023-02-07 09:22:22.072 Triggering next historical data download in queue. | 2023-02-07 09:22:22.072 Triggering next historical data download in queue. | 2023-02-07 09:22:22.072 Triggering next historical data download in queue. | 2023-02-07 09:22:22.072 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:22:22.072 Mapping ESM20_FUT_CME to ESM20. Service code: cme | 2023-02-07 09:22:22.072 Using symbol data fast lookup vector | 2023-02-07 09:22:22.072 Denali Data Feed | Starting real-time market data updates for: ESM20_FUT_CME (ESM20). ID: 1 Service code: cme | 2023-02-07 09:22:22.072 Denali Data Feed | Connecting to the server ds21.sierracharts.com. Port 10048 | 2023-02-07 09:22:22.072 Denali Data Feed | Requesting security definition data for: ESM20_FUT_CME (ESM20). ID: 1 | 2023-02-07 09:22:22.073 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:22:22.073 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:22:22.073 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:22:22.073 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:22:22.073 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:22:22.073 Subscribing to symbol for symbol alert. ESU20_FUT_CME | 2023-02-07 09:22:22.073 Mapping ESU20_FUT_CME to ESU20. Service code: cme | 2023-02-07 09:22:22.073 Denali Data Feed | Starting real-time market data updates for: ESU20_FUT_CME (ESU20). ID: 2 Service code: cme | 2023-02-07 09:22:22.073 Denali Data Feed | Requesting security definition data for: ESU20_FUT_CME (ESU20). ID: 2 | 2023-02-07 09:22:22.073 Subscribing to symbol for symbol alert. GCG21_FUT_CME | 2023-02-07 09:22:22.073 Mapping GCG21_FUT_CME to GCG21. Service code: comex | 2023-02-07 09:22:22.073 Denali Data Feed | Starting real-time market data updates for: GCG21_FUT_CME (GCG21). ID: 3 Service code: comex | 2023-02-07 09:22:22.073 Denali Data Feed | Requesting security definition data for: GCG21_FUT_CME (GCG21). ID: 3 | 2023-02-07 09:22:22.073 Subscribing to symbol for symbol alert. 6EH21_FUT_CME | 2023-02-07 09:22:22.073 Mapping 6EH21_FUT_CME to 6EH21. Service code: cme | 2023-02-07 09:22:22.073 Denali Data Feed | Starting real-time market data updates for: 6EH21_FUT_CME (6EH21). ID: 4 Service code: cme | 2023-02-07 09:22:22.073 Denali Data Feed | Requesting security definition data for: 6EH21_FUT_CME (6EH21). ID: 4 | 2023-02-07 09:22:22.073 Subscribing to symbol for symbol alert. ESH21_FUT_CME | 2023-02-07 09:22:22.073 Mapping ESH21_FUT_CME to ESH21. Service code: cme | 2023-02-07 09:22:22.073 Denali Data Feed | Starting real-time market data updates for: ESH21_FUT_CME (ESH21). ID: 5 Service code: cme | 2023-02-07 09:22:22.073 Denali Data Feed | Requesting security definition data for: ESH21_FUT_CME (ESH21). ID: 5 | 2023-02-07 09:22:22.073 Subscribing to symbol for symbol alert. ESH21_FUT_CME | 2023-02-07 09:22:22.073 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2023-02-07 09:22:22.073 No download requests in the queue to start downloads for. | 2023-02-07 09:22:22.073 No download requests in the queue to start downloads for. | 2023-02-07 09:22:22.074 No download requests in the queue to start downloads for. | 2023-02-07 09:22:22.074 No download requests in the queue to start downloads for. | 2023-02-07 09:22:22.074 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2023-02-07 15:03:49.033833 | 2023-02-07 09:22:22.074 DTC Client socket (3) | Creating socket. | 2023-02-07 09:22:22.078 DTC Client socket (3) | New receive buffer size: 5242880 | 2023-02-07 09:22:22.078 DTC Client socket (3) | Connecting to IP: 216.1.90.129. | 2023-02-07 09:22:22.078 Denali Data Feed | Network connection to server complete. | 2023-02-07 09:22:22.313 Denali Data Feed | Starting socket receive thread. | 2023-02-07 09:22:22.313 Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-07 09:22:22.314 Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-02-07 09:22:22.567 Denali Data Feed | Sending logon request message. | 2023-02-07 09:22:22.567 Denali Data Feed | Received logon response. | 2023-02-07 09:22:22.803 Denali Data Feed | Server Name: RealTime Server. | 2023-02-07 09:22:22.803 Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-02-07 09:22:22.803 Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. | 2023-02-07 09:22:22.803 Denali Data Feed | Waiting for socket receive thread to end | 2023-02-07 09:22:22.803 DTC Client socket (3) | CloseSocket call. | 2023-02-07 09:22:22.803 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:22:22.803 Denali Data Feed | Disconnected from the server. | 2023-02-07 09:22:22.803 Denali Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-02-07 09:22:22.803 DTC Client socket (3) | Socket gracefully closed by remote side. | 2023-02-07 09:22:23.029 DTC Client socket (3) | Closed. | 2023-02-07 09:22:23.029 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESM20_FUT_CME | 2023-02-07 09:22:23.874 Teton CME Order Routing | Received security definition for symbol ESM20_FUT_CME | 2023-02-07 09:22:23.874 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESU20_FUT_CME | 2023-02-07 09:22:23.874 Teton CME Order Routing | Received security definition for symbol ESU20_FUT_CME | 2023-02-07 09:22:23.874 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: GCG21_FUT_CME | 2023-02-07 09:22:23.874 Teton CME Order Routing | Received security definition for symbol GCG21_FUT_CME | 2023-02-07 09:22:23.874 Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 443 | 2023-02-07 09:22:24.817 DTC Client socket (2) | Creating socket. | 2023-02-07 09:22:24.820 DTC Client socket (2) | New receive buffer size: 5242880 | 2023-02-07 09:22:24.820 DTC Client socket (2) | Connecting to IP: 142.215.18.148. | 2023-02-07 09:22:24.820 Denali Data Feed | Network connection to server complete. | 2023-02-07 09:22:25.070 Denali Data Feed | Starting socket receive thread. | 2023-02-07 09:22:25.070 Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-07 09:22:25.071 Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-02-07 09:22:25.339 Denali Data Feed | Sending logon request message. | 2023-02-07 09:22:25.339 Denali Data Feed | Received logon response. | 2023-02-07 09:22:26.334 Denali Data Feed | Server Name: SC Realtime Server. | 2023-02-07 09:22:26.334 Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-02-07 09:22:26.334 Denali Data Feed | Successfully connected. | 2023-02-07 09:22:26.334 Denali Data Feed | Trading is not supported. | 2023-02-07 09:22:26.334 Denali Data Feed | Restarting real-time data updates for symbol: 6EH21_FUT_CME -> 6EH21 | 2023-02-07 09:22:26.334 Denali Data Feed | Restarting real-time data updates for symbol: ESH21_FUT_CME -> ESH21 | 2023-02-07 09:22:26.334 Denali Data Feed | Restarting real-time data updates for symbol: ESM20_FUT_CME -> ESM20 | 2023-02-07 09:22:26.334 Denali Data Feed | Restarting real-time data updates for symbol: ESU20_FUT_CME -> ESU20 | 2023-02-07 09:22:26.334 Denali Data Feed | Restarting real-time data updates for symbol: GCG21_FUT_CME -> GCG21 | 2023-02-07 09:22:26.334 Denali Data Feed | Real-time data for symbol 6EH21_FUT_CME is currently unavailable. | 2023-02-07 09:22:26.663 Denali Data Feed | Received security definition for symbol 6EH21_FUT_CME | 2023-02-07 09:22:26.663 Denali Data Feed | Real-time data for symbol ESH21_FUT_CME is currently unavailable. | 2023-02-07 09:22:26.663 Denali Data Feed | Received security definition for symbol ESH21_FUT_CME | 2023-02-07 09:22:26.663 Denali Data Feed | Real-time data for symbol ESM20_FUT_CME is currently unavailable. | 2023-02-07 09:22:26.663 Denali Data Feed | Received security definition for symbol ESM20_FUT_CME | 2023-02-07 09:22:26.663 Denali Data Feed | Real-time data for symbol ESU20_FUT_CME is currently unavailable. | 2023-02-07 09:22:26.663 Denali Data Feed | Received security definition for symbol ESU20_FUT_CME | 2023-02-07 09:22:26.663 Denali Data Feed | Real-time data for symbol GCG21_FUT_CME is currently unavailable. | 2023-02-07 09:22:26.663 Denali Data Feed | Received security definition for symbol GCG21_FUT_CME | 2023-02-07 09:22:26.663 DTC Protocol server | Incoming connection from 127.0.0.1. | 2023-02-07 09:22:34.970 DTC client #1. 127.0.0.1 (3) | Creating socket. | 2023-02-07 09:22:34.971 DTC client #1. 127.0.0.1 (3) | New receive buffer size: 262144 | 2023-02-07 09:22:34.971 DTC client #1. 127.0.0.1 (3) | Allocated send buffers: 32 of 131072 bytes. | 2023-02-07 09:22:34.972 DTC client #1. 127.0.0.1 | Set DTC encoding to Binary VLS | 2023-02-07 09:22:34.972 DTC client #1. 127.0.0.1 | Requested heartbeat interval: 20 | 2023-02-07 09:22:34.973 DTC client #1. Sierra Chart. 127.0.0.1 | Received logon request. | 2023-02-07 09:22:34.973 DTC client #1. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: resetmsc. Result text: Connected to SC DTC Protocol server. Service=sc_futures_direct.dtc.trading|SymbolSettings=sc_futures_direct.dtc.trading | 2023-02-07 09:22:34.973 NQH23_FUT_CME 1 Min #15 | Reloading chart. | 2023-02-07 09:22:46.651 NQH23_FUT_CME [CV] #14 | Reloading chart. | 2023-02-07 09:22:46.671 NQH23_FUT_CME [CV] #14 | Performing continuous chart historical Daily data download for symbol NQH23_FUT_CME starting at last date in file. | 2023-02-07 09:22:46.676 Starting DelayedDownloadMonitoringTimer | 2023-02-07 09:22:46.676 Starting HDTimeoutTimer | 2023-02-07 09:22:46.676 Added historical Daily data request for NQH23_FUT_CME to the queue. | 2023-02-07 09:22:46.676 Triggering next historical data download in queue. | 2023-02-07 09:22:46.676 NQH23_FUT_CME [CV] #14 | Waiting for historical downloads to complete with the IDs: 1, | 2023-02-07 09:22:46.679 UBH23_FUT_CME [CV] #10 | Reloading chart. | 2023-02-07 09:22:46.936 UBH23_FUT_CME [CV] #10 | Performing continuous chart historical Daily data download for symbol UBH23_FUT_CME starting at last date in file. | 2023-02-07 09:22:46.940 Added historical Daily data request for UBH23_FUT_CME to the queue. | 2023-02-07 09:22:46.940 UBH23_FUT_CME [CV] #10 | Waiting for historical downloads to complete with the IDs: 2, | 2023-02-07 09:22:46.944 ESH23_FUT_CME [CV] #17 | Reloading chart. | 2023-02-07 09:22:47.098 ESH23_FUT_CME [CV] #17 | Performing continuous chart historical Daily data download for symbol ESH23_FUT_CME starting at last date in file. | 2023-02-07 09:22:47.103 Added historical Daily data request for ESH23_FUT_CME to the queue. | 2023-02-07 09:22:47.103 ESH23_FUT_CME [CV] #17 | Waiting for historical downloads to complete with the IDs: 3, | 2023-02-07 09:22:47.107 YMH23_FUT_CME [CV] #1 | Reloading chart. | 2023-02-07 09:22:47.141 YMH23_FUT_CME [CV] #1 | Performing continuous chart historical Daily data download for symbol YMH23_FUT_CME starting at last date in file. | 2023-02-07 09:22:47.145 Added historical Daily data request for YMH23_FUT_CME to the queue. | 2023-02-07 09:22:47.145 YMH23_FUT_CME [CV] #1 | Waiting for historical downloads to complete with the IDs: 4, | 2023-02-07 09:22:47.149 RTYH23_FUT_CME [CV] #4 | Reloading chart. | 2023-02-07 09:22:47.177 RTYH23_FUT_CME [CV] #4 | Performing continuous chart historical Daily data download for symbol RTYH23_FUT_CME starting at last date in file. | 2023-02-07 09:22:47.181 Added historical Daily data request for RTYH23_FUT_CME to the queue. | 2023-02-07 09:22:47.181 RTYH23_FUT_CME [CV] #4 | Waiting for historical downloads to complete with the IDs: 5, | 2023-02-07 09:22:47.185 ESH23_FUT_CME 30 Sec #7 | Reloading chart. | 2023-02-07 09:22:47.287 ESH23_FUT_CME 30 Sec #13 | Reloading chart. | 2023-02-07 09:22:47.304 NQH23_FUT_CME 30 Sec #16 | Reloading chart. | 2023-02-07 09:22:47.319 NQH23_FUT_CME 30 Sec #18 | Reloading chart. | 2023-02-07 09:22:47.332 6EH23_FUT_CME [CV] #2 | Reloading chart. | 2023-02-07 09:22:47.353 6EH23_FUT_CME [CV] #2 | Performing continuous chart historical Daily data download for symbol 6EH23_FUT_CME starting at last date in file. | 2023-02-07 09:22:47.357 Added historical Daily data request for 6EH23_FUT_CME to the queue. | 2023-02-07 09:22:47.357 6EH23_FUT_CME [CV] #2 | Waiting for historical downloads to complete with the IDs: 6, | 2023-02-07 09:22:47.361 CLH23_FUT_CME [CV] #3 | Reloading chart. | 2023-02-07 09:22:47.380 Starting DelayedDownloadMonitoringTimer | 2023-02-07 09:22:47.386 Starting HDTimeoutTimer | 2023-02-07 09:22:47.386 Added historical Intraday data request for CLH23_FUT_CME to the queue. | 2023-02-07 09:22:47.386 Triggering next historical data download in queue. | 2023-02-07 09:22:47.386 CLH23_FUT_CME [CV] #3 | Performing continuous chart historical Daily data download for symbol CLH23_FUT_CME starting at last date in file. | 2023-02-07 09:22:47.391 Added historical Daily data request for CLH23_FUT_CME to the queue. | 2023-02-07 09:22:47.391 CLH23_FUT_CME [CV] #3 | Waiting for historical downloads to complete with the IDs: 7, 8, | 2023-02-07 09:22:47.394 GCJ23_FUT_CME [CV] #12 | Reloading chart. | 2023-02-07 09:22:47.422 Added historical Intraday data request for GCJ23_FUT_CME to the queue. | 2023-02-07 09:22:47.427 GCJ23_FUT_CME [CV] #12 | Performing continuous chart historical Daily data download for symbol GCJ23_FUT_CME starting at last date in file. | 2023-02-07 09:22:47.430 Added historical Daily data request for GCJ23_FUT_CME to the queue. | 2023-02-07 09:22:47.430 GCJ23_FUT_CME [CV] #12 | Waiting for historical downloads to complete with the IDs: 9, 10, | 2023-02-07 09:22:47.436 Loading DLL: C:\SierraChart\SierraChart2480\Data\sst_syx.dll (sst_syx_64.dll). Handle: 66000000 | 2023-02-07 09:22:47.446 ESH23_FUT_CME Daily #20 | Reloading chart. | 2023-02-07 09:22:47.462 NQH23_FUT_CME Daily #21 | Reloading chart. | 2023-02-07 09:22:47.479 YMH23_FUT_CME Daily #22 | Reloading chart. | 2023-02-07 09:22:47.496 CLG23_FUT_CME Daily #23 | Reloading chart. | 2023-02-07 09:22:47.513 GCG23_FUT_CME Daily #24 | Reloading chart. | 2023-02-07 09:22:47.532 ZBH23_FUT_CME [CV] #26 | Reloading chart. | 2023-02-07 09:22:47.558 Added historical Intraday data request for ZBH23_FUT_CME to the queue. | 2023-02-07 09:22:47.558 ZBH23_FUT_CME [CV] #26 | Performing continuous chart historical Daily data download for symbol ZBH23_FUT_CME starting at last date in file. | 2023-02-07 09:22:47.562 Added historical Daily data request for ZBH23_FUT_CME to the queue. | 2023-02-07 09:22:47.562 ZBH23_FUT_CME [CV] #26 | Waiting for historical downloads to complete with the IDs: 11, 12, | 2023-02-07 09:22:47.566 ZNH23_FUT_CME [CV] #27 | Reloading chart. | 2023-02-07 09:22:47.731 Added historical Intraday data request for ZNH23_FUT_CME to the queue. | 2023-02-07 09:22:47.732 ZNH23_FUT_CME [CV] #27 | Performing continuous chart historical Daily data download for symbol ZNH23_FUT_CME starting at last date in file. | 2023-02-07 09:22:47.736 Added historical Daily data request for ZNH23_FUT_CME to the queue. | 2023-02-07 09:22:47.736 ZNH23_FUT_CME [CV] #27 | Waiting for historical downloads to complete with the IDs: 13, 14, | 2023-02-07 09:22:47.740 ZFH23_FUT_CME [CV] #28 | Reloading chart. | 2023-02-07 09:22:47.772 ZFH23_FUT_CME [CV] #28 | Performing continuous chart historical Daily data download for symbol ZFH23_FUT_CME starting at last date in file. | 2023-02-07 09:22:47.776 Added historical Daily data request for ZFH23_FUT_CME to the queue. | 2023-02-07 09:22:47.776 ZFH23_FUT_CME [CV] #28 | Waiting for historical downloads to complete with the IDs: 15, | 2023-02-07 09:22:47.781 TNH23_FUT_CME [CV] #29 | Reloading chart. | 2023-02-07 09:22:47.813 Added historical Intraday data request for TNH23_FUT_CME to the queue. | 2023-02-07 09:22:47.813 TNH23_FUT_CME [CV] #29 | Performing continuous chart historical Daily data download for symbol TNH23_FUT_CME starting at last date in file. | 2023-02-07 09:22:47.817 Added historical Daily data request for TNH23_FUT_CME to the queue. | 2023-02-07 09:22:47.817 TNH23_FUT_CME [CV] #29 | Waiting for historical downloads to complete with the IDs: 16, 17, | 2023-02-07 09:22:47.821 Loading DLL: C:\SierraChart\SierraChart2480\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ffa6f8f0000 | 2023-02-07 09:22:47.829 NQH23_FUT_CME 1 Min #5 | Reloading chart. | 2023-02-07 09:22:47.840 Mapping NQH23_FUT_CME to NQH23. Service code: cme | 2023-02-07 09:22:48.025 HD Request # 1 | Downloading Historical Daily chart data for NQH23_FUT_CME. Starting date: 2023-02-02. Service: sc_futures_direct.dtc.trading | 2023-02-07 09:22:48.026 ESH23_FUT_CME 30 Sec #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChart2480\Data\ESH23_FUT_CME.scid | 2023-02-07 09:22:48.027 ESH23_FUT_CME 30 Sec #13 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChart2480\Data\ESH23_FUT_CME.scid | 2023-02-07 09:22:48.028 NQH23_FUT_CME 30 Sec #16 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChart2480\Data\NQH23_FUT_CME.scid | 2023-02-07 09:22:48.028 NQH23_FUT_CME 30 Sec #18 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChart2480\Data\NQH23_FUT_CME.scid | 2023-02-07 09:22:48.028 Mapping CLH23_FUT_CME to CLH23. Service code: nymex | 2023-02-07 09:22:48.028 HD Request # 2 | Downloading Intraday chart data for CLH23_FUT_CME to the file CLH23_FUT_CME.scid. Service: nymex | 2023-02-07 09:22:48.028 HD Request # 2 | Download start date-time: 2023-01-02 16:00:00.000000. File last date-time: 2023-02-07 09:16:32.445002 | 2023-02-07 09:22:48.029 HD Request # 2 | Disabling Intraday chart updating for symbol. | 2023-02-07 09:22:48.029 HD Request # 2 | Using server: ds26.sierracharts.com port 10150 | 2023-02-07 09:22:48.029 Socket (5) | Creating socket. | 2023-02-07 09:22:48.032 Socket (5) | New receive buffer size: 5242880 | 2023-02-07 09:22:48.032 Socket (5) | Connecting to IP: 142.215.17.188. | 2023-02-07 09:22:48.032 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6EH21_FUT_CME | 2023-02-07 09:22:48.252 Teton CME Order Routing | Received security definition for symbol 6EH21_FUT_CME | 2023-02-07 09:22:48.252 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH21_FUT_CME | 2023-02-07 09:22:48.252 Teton CME Order Routing | Received security definition for symbol ESH21_FUT_CME | 2023-02-07 09:22:48.252 Updated verified funded futures trading account ending date to: 2023-03-09 17:22:48 | 2023-02-07 09:22:48.252 Mapping 6EH23_FUT_CME to 6EH23. Service code: cme | 2023-02-07 09:22:48.296 Denali Data Feed | Starting real-time market data updates for: 6EH23_FUT_CME (6EH23). ID: 8 Service code: cme | 2023-02-07 09:22:48.296 Denali Data Feed | Requesting security definition data for: 6EH23_FUT_CME (6EH23). ID: 8 | 2023-02-07 09:22:48.296 Requesting market depth updates for: 6EH23_FUT_CME if supported. | 2023-02-07 09:22:48.296 Teton CME Order Routing | Connecting to the server ds28-2.sierracharts.com. Port 10060 | 2023-02-07 09:22:48.297 DTC Client socket (6) | Creating socket. | 2023-02-07 09:22:48.297 DTC Client socket (6) | New receive buffer size: 5242880 | 2023-02-07 09:22:48.297 DTC Client socket (6) | Connecting to IP: 142.215.18.148. | 2023-02-07 09:22:48.297 Denali Data Feed | Starting real-time market data updates for: CLH23_FUT_CME (CLH23). ID: 7 Service code: nymex | 2023-02-07 09:22:48.297 Denali Data Feed | Requesting security definition data for: CLH23_FUT_CME (CLH23). ID: 7 | 2023-02-07 09:22:48.298 Requesting market depth updates for: CLH23_FUT_CME if supported. | 2023-02-07 09:22:48.298 Mapping ESH23_FUT_CME to ESH23. Service code: cme | 2023-02-07 09:22:48.298 Denali Data Feed | Starting real-time market data updates for: ESH23_FUT_CME (ESH23). ID: 9 Service code: cme | 2023-02-07 09:22:48.298 Denali Data Feed | Requesting security definition data for: ESH23_FUT_CME (ESH23). ID: 9 | 2023-02-07 09:22:48.298 Requesting market depth updates for: ESH23_FUT_CME if supported. | 2023-02-07 09:22:48.298 Mapping GCJ23_FUT_CME to GCJ23. Service code: comex | 2023-02-07 09:22:48.298 Denali Data Feed | Starting real-time market data updates for: GCJ23_FUT_CME (GCJ23). ID: 10 Service code: comex | 2023-02-07 09:22:48.298 Denali Data Feed | Requesting security definition data for: GCJ23_FUT_CME (GCJ23). ID: 10 | 2023-02-07 09:22:48.298 Requesting market depth updates for: GCJ23_FUT_CME if supported. | 2023-02-07 09:22:48.298 Denali Data Feed | Starting real-time market data updates for: NQH23_FUT_CME (NQH23). ID: 6 Service code: cme | 2023-02-07 09:22:48.298 Denali Data Feed | Requesting security definition data for: NQH23_FUT_CME (NQH23). ID: 6 | 2023-02-07 09:22:48.298 Requesting market depth updates for: NQH23_FUT_CME if supported. | 2023-02-07 09:22:48.298 Mapping RTYH23_FUT_CME to RTYH23. Service code: cme | 2023-02-07 09:22:48.298 Denali Data Feed | Starting real-time market data updates for: RTYH23_FUT_CME (RTYH23). ID: 11 Service code: cme | 2023-02-07 09:22:48.298 Denali Data Feed | Requesting security definition data for: RTYH23_FUT_CME (RTYH23). ID: 11 | 2023-02-07 09:22:48.298 Requesting market depth updates for: RTYH23_FUT_CME if supported. | 2023-02-07 09:22:48.298 Mapping TNH23_FUT_CME to TNH23. Service code: cbot | 2023-02-07 09:22:48.298 Denali Data Feed | Starting real-time market data updates for: TNH23_FUT_CME (TNH23). ID: 12 Service code: cbot | 2023-02-07 09:22:48.298 Denali Data Feed | Requesting security definition data for: TNH23_FUT_CME (TNH23). ID: 12 | 2023-02-07 09:22:48.298 Requesting market depth updates for: TNH23_FUT_CME if supported. | 2023-02-07 09:22:48.298 Mapping UBH23_FUT_CME to UBH23. Service code: cbot | 2023-02-07 09:22:48.298 Denali Data Feed | Starting real-time market data updates for: UBH23_FUT_CME (UBH23). ID: 13 Service code: cbot | 2023-02-07 09:22:48.298 Denali Data Feed | Requesting security definition data for: UBH23_FUT_CME (UBH23). ID: 13 | 2023-02-07 09:22:48.298 Requesting market depth updates for: UBH23_FUT_CME if supported. | 2023-02-07 09:22:48.298 Mapping YMH23_FUT_CME to YMH23. Service code: cbot | 2023-02-07 09:22:48.298 Denali Data Feed | Starting real-time market data updates for: YMH23_FUT_CME (YMH23). ID: 14 Service code: cbot | 2023-02-07 09:22:48.298 Denali Data Feed | Requesting security definition data for: YMH23_FUT_CME (YMH23). ID: 14 | 2023-02-07 09:22:48.298 Requesting market depth updates for: YMH23_FUT_CME if supported. | 2023-02-07 09:22:48.298 Mapping ZBH23_FUT_CME to ZBH23. Service code: cbot | 2023-02-07 09:22:48.298 Denali Data Feed | Starting real-time market data updates for: ZBH23_FUT_CME (ZBH23). ID: 15 Service code: cbot | 2023-02-07 09:22:48.298 Denali Data Feed | Requesting security definition data for: ZBH23_FUT_CME (ZBH23). ID: 15 | 2023-02-07 09:22:48.298 Requesting market depth updates for: ZBH23_FUT_CME if supported. | 2023-02-07 09:22:48.298 Mapping ZFH23_FUT_CME to ZFH23. Service code: cbot | 2023-02-07 09:22:48.298 Denali Data Feed | Starting real-time market data updates for: ZFH23_FUT_CME (ZFH23). ID: 16 Service code: cbot | 2023-02-07 09:22:48.299 Denali Data Feed | Requesting security definition data for: ZFH23_FUT_CME (ZFH23). ID: 16 | 2023-02-07 09:22:48.299 Requesting market depth updates for: ZFH23_FUT_CME if supported. | 2023-02-07 09:22:48.299 Mapping ZNH23_FUT_CME to ZNH23. Service code: cbot | 2023-02-07 09:22:48.299 Denali Data Feed | Starting real-time market data updates for: ZNH23_FUT_CME (ZNH23). ID: 17 Service code: cbot | 2023-02-07 09:22:48.299 Denali Data Feed | Requesting security definition data for: ZNH23_FUT_CME (ZNH23). ID: 17 | 2023-02-07 09:22:48.299 Requesting market depth updates for: ZNH23_FUT_CME if supported. | 2023-02-07 09:22:48.299 Added historical Daily data request for CLG23_FUT_CME to the queue. | 2023-02-07 09:22:48.497 Triggering next historical data download in queue. | 2023-02-07 09:22:48.497 Mapping CLG23_FUT_CME to CLG23. Service code: nymex | 2023-02-07 09:22:48.497 Denali Data Feed | Starting real-time market data updates for: CLG23_FUT_CME (CLG23). ID: 18 Service code: nymex | 2023-02-07 09:22:48.497 Denali Data Feed | Requesting security definition data for: CLG23_FUT_CME (CLG23). ID: 18 | 2023-02-07 09:22:48.497 HD Request # 2 | Setting DTC encoding to Binary VLS | 2023-02-07 09:22:48.505 HD Request # 2 | Sending historical data logon request message. | 2023-02-07 09:22:48.505 Added historical Daily data request for GCG23_FUT_CME to the queue. | 2023-02-07 09:22:48.532 Triggering next historical data download in queue. | 2023-02-07 09:22:48.532 Mapping GCG23_FUT_CME to GCG23. Service code: comex | 2023-02-07 09:22:48.532 Denali Data Feed | Starting real-time market data updates for: GCG23_FUT_CME (GCG23). ID: 19 Service code: comex | 2023-02-07 09:22:48.532 Denali Data Feed | Requesting security definition data for: GCG23_FUT_CME (GCG23). ID: 19 | 2023-02-07 09:22:48.532 Teton CME Order Routing | Network connection to server complete. | 2023-02-07 09:22:48.550 Teton CME Order Routing | Starting socket receive thread. | 2023-02-07 09:22:48.550 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-07 09:22:48.550 Added historical Intraday data request for NQH23_FUT_CME to the queue. | 2023-02-07 09:22:48.648 Intraday data recording state for symbol NQH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:22:48.648 Triggering next historical data download in queue. | 2023-02-07 09:22:48.648 Added historical Intraday data request for ESH23_FUT_CME to the queue. | 2023-02-07 09:22:48.782 Intraday data recording state for symbol ESH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:22:48.782 Triggering next historical data download in queue. | 2023-02-07 09:22:48.782 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-02-07 09:22:48.809 Teton CME Order Routing | Sending logon request message. | 2023-02-07 09:22:48.809 HD Request # 1 | Requesting historical Daily data for NQH23 starting at 2023-02-01. SC External HD service. | 2023-02-07 09:22:49.161 HD Request # 2 | Requesting Intraday data. Start date-time: 2023-01-02 16:00:00. Record interval: 0. Symbol: CLH23 | 2023-02-07 09:22:49.256 HD Request # 2 | Decompressing data. | 2023-02-07 09:22:49.509 Denali Data Feed | Clearing market depth for 6EH23_FUT_CME | 2023-02-07 09:22:49.584 Denali Data Feed | Received security definition for symbol 6EH23_FUT_CME | 2023-02-07 09:22:49.584 Denali Data Feed | Clearing market depth for CLH23_FUT_CME | 2023-02-07 09:22:49.585 Denali Data Feed | Received security definition for symbol CLH23_FUT_CME | 2023-02-07 09:22:49.585 Denali Data Feed | Clearing market depth for ESH23_FUT_CME | 2023-02-07 09:22:49.585 Denali Data Feed | Received security definition for symbol ESH23_FUT_CME | 2023-02-07 09:22:49.585 Denali Data Feed | Clearing market depth for GCJ23_FUT_CME | 2023-02-07 09:22:49.585 Denali Data Feed | Received security definition for symbol GCJ23_FUT_CME | 2023-02-07 09:22:49.585 Denali Data Feed | Clearing market depth for NQH23_FUT_CME | 2023-02-07 09:22:49.585 Denali Data Feed | Received security definition for symbol NQH23_FUT_CME | 2023-02-07 09:22:49.585 Denali Data Feed | Clearing market depth for RTYH23_FUT_CME | 2023-02-07 09:22:49.585 Denali Data Feed | Received security definition for symbol RTYH23_FUT_CME | 2023-02-07 09:22:49.585 Denali Data Feed | Clearing market depth for TNH23_FUT_CME | 2023-02-07 09:22:49.585 Denali Data Feed | Received security definition for symbol TNH23_FUT_CME | 2023-02-07 09:22:49.585 Denali Data Feed | Clearing market depth for UBH23_FUT_CME | 2023-02-07 09:22:49.586 Denali Data Feed | Received security definition for symbol UBH23_FUT_CME | 2023-02-07 09:22:49.586 Denali Data Feed | Clearing market depth for YMH23_FUT_CME | 2023-02-07 09:22:49.586 Denali Data Feed | Received security definition for symbol YMH23_FUT_CME | 2023-02-07 09:22:49.586 Denali Data Feed | Clearing market depth for ZBH23_FUT_CME | 2023-02-07 09:22:49.586 Denali Data Feed | Received security definition for symbol ZBH23_FUT_CME | 2023-02-07 09:22:49.586 Denali Data Feed | Clearing market depth for ZFH23_FUT_CME | 2023-02-07 09:22:49.586 Denali Data Feed | Received security definition for symbol ZFH23_FUT_CME | 2023-02-07 09:22:49.586 Denali Data Feed | Clearing market depth for ZNH23_FUT_CME | 2023-02-07 09:22:49.586 Denali Data Feed | Received security definition for symbol ZNH23_FUT_CME | 2023-02-07 09:22:49.586 Denali Data Feed | Real-time data for symbol CLG23_FUT_CME is currently unavailable. | 2023-02-07 09:22:49.589 Denali Data Feed | Received security definition for symbol CLG23_FUT_CME | 2023-02-07 09:22:49.589 Denali Data Feed | Received security definition for symbol GCG23_FUT_CME | 2023-02-07 09:22:49.589 Teton CME Order Routing | Received logon response. | 2023-02-07 09:22:49.692 Teton CME Order Routing | Server Name: SC Realtime Server. | 2023-02-07 09:22:49.692 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-02-07 09:22:49.692 Teton CME Order Routing | Successfully connected. | 2023-02-07 09:22:49.692 Teton CME Order Routing | Trading is not supported. | 2023-02-07 09:22:49.692 Teton CME Order Routing | Starting market orders updates for: 6EH23. MinimumMarketByOrderQuantity: 0. Service code: cme | 2023-02-07 09:22:49.692 Teton CME Order Routing | Restarting market orders data for symbol: 6EH23_FUT_CME -> 6EH23 | 2023-02-07 09:22:49.692 Teton CME Order Routing | Starting market orders updates for: CLH23. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2023-02-07 09:22:49.692 Teton CME Order Routing | Restarting market orders data for symbol: CLH23_FUT_CME -> CLH23 | 2023-02-07 09:22:49.692 Teton CME Order Routing | Starting market orders updates for: ESH23. MinimumMarketByOrderQuantity: 0. Service code: cme | 2023-02-07 09:22:49.692 Teton CME Order Routing | Restarting market orders data for symbol: ESH23_FUT_CME -> ESH23 | 2023-02-07 09:22:49.692 Teton CME Order Routing | Starting market orders updates for: GCJ23. MinimumMarketByOrderQuantity: 0. Service code: comex | 2023-02-07 09:22:49.692 Teton CME Order Routing | Restarting market orders data for symbol: GCJ23_FUT_CME -> GCJ23 | 2023-02-07 09:22:49.692 Teton CME Order Routing | Starting market orders updates for: NQH23. MinimumMarketByOrderQuantity: 0. Service code: cme | 2023-02-07 09:22:49.692 Teton CME Order Routing | Restarting market orders data for symbol: NQH23_FUT_CME -> NQH23 | 2023-02-07 09:22:49.692 Teton CME Order Routing | Starting market orders updates for: RTYH23. MinimumMarketByOrderQuantity: 0. Service code: cme | 2023-02-07 09:22:49.692 Teton CME Order Routing | Restarting market orders data for symbol: RTYH23_FUT_CME -> RTYH23 | 2023-02-07 09:22:49.692 Teton CME Order Routing | Starting market orders updates for: TNH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:22:49.692 Teton CME Order Routing | Restarting market orders data for symbol: TNH23_FUT_CME -> TNH23 | 2023-02-07 09:22:49.692 Teton CME Order Routing | Starting market orders updates for: UBH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:22:49.692 Teton CME Order Routing | Restarting market orders data for symbol: UBH23_FUT_CME -> UBH23 | 2023-02-07 09:22:49.692 Teton CME Order Routing | Starting market orders updates for: YMH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:22:49.692 Teton CME Order Routing | Restarting market orders data for symbol: YMH23_FUT_CME -> YMH23 | 2023-02-07 09:22:49.692 Teton CME Order Routing | Starting market orders updates for: ZBH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:22:49.692 Teton CME Order Routing | Restarting market orders data for symbol: ZBH23_FUT_CME -> ZBH23 | 2023-02-07 09:22:49.692 Teton CME Order Routing | Starting market orders updates for: ZFH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:22:49.692 Teton CME Order Routing | Restarting market orders data for symbol: ZFH23_FUT_CME -> ZFH23 | 2023-02-07 09:22:49.692 Teton CME Order Routing | Starting market orders updates for: ZNH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:22:49.692 Teton CME Order Routing | Restarting market orders data for symbol: ZNH23_FUT_CME -> ZNH23 | 2023-02-07 09:22:49.692 HD Request # 2 | Receiving Intraday data for CLH23_FUT_CME starting at 2023-01-02 16:00:14.351000 | 2023-02-07 09:22:50.005 HD Request # 2 | Truncating file to starting date-time of 2023-01-02 16:00:14.351. | 2023-02-07 09:22:50.005 HD Request # 1 | Receiving historical Daily data for NQH23_FUT_CME starting at 2023-02-02. | 2023-02-07 09:22:50.034 HD Request # 1 | Writing historical Daily data to the file NQH23_FUT_CME.dly. | 2023-02-07 09:22:50.034 HD Request # 1 | Bytes received: 250 | 2023-02-07 09:22:50.035 HD Request # 1 | Received 4 Daily data records from 2023-02-02 00:00:00 to 2023-02-06 00:00:00 (5.0 days) and wrote 3 records for NQH23_FUT_CME | 2023-02-07 09:22:50.035 HD Request # 1 | Completion time: 2s. | 2023-02-07 09:22:50.035 HD Request # 1 | Daily data download complete for NQH23_FUT_CME. Unique request ID: 1 | 2023-02-07 09:22:50.035 Removing historical data download ID 1. | 2023-02-07 09:22:50.035 Triggering next historical data download in queue. | 2023-02-07 09:22:50.035 HD Request # 3 | Downloading Historical Daily chart data for UBH23_FUT_CME. Starting date: 2023-02-02. Service: sc_futures_direct.dtc.trading | 2023-02-07 09:22:50.035 Teton CME Order Routing | Market Orders data has been rejected for symbol: 6EH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:22:50.050 Teton CME Order Routing | Market Orders data has been rejected for symbol: CLH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:22:50.050 Teton CME Order Routing | Market Orders data has been rejected for symbol: ESH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:22:50.050 Teton CME Order Routing | Market Orders data has been rejected for symbol: GCJ23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:22:50.050 Teton CME Order Routing | Market Orders data has been rejected for symbol: NQH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:22:50.050 Teton CME Order Routing | Market Orders data has been rejected for symbol: RTYH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:22:50.050 Teton CME Order Routing | Market Orders data has been rejected for symbol: TNH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:22:50.050 Teton CME Order Routing | Market Orders data has been rejected for symbol: UBH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:22:50.050 Teton CME Order Routing | Market Orders data has been rejected for symbol: YMH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:22:50.050 Teton CME Order Routing | Market Orders data has been rejected for symbol: ZBH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:22:50.050 Teton CME Order Routing | Market Orders data has been rejected for symbol: ZFH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:22:50.050 Teton CME Order Routing | Market Orders data has been rejected for symbol: ZNH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:22:50.050 NQH23_FUT_CME [CV] #14 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-07 09:22:50.052 NQH23_FUT_CME [CV] #14 | Reloading chart. | 2023-02-07 09:22:50.052 NQH23_FUT_CME [CV] #14 | StartDateTimeForLoadingOrderFills: 2023-02-06 15:00:00 | 2023-02-07 09:22:50.069 NQH23_FUT_CME [CV] #14 | Reloading chart. | 2023-02-07 09:22:50.248 NQH23_FUT_CME [CV] #14 | StartDateTimeForLoadingOrderFills: 2023-02-06 15:00:00 | 2023-02-07 09:22:50.268 HD Request # 2 | Timestamp of first Intraday data file record written: 2023-01-02 16:00:14.351000. | 2023-02-07 09:22:50.459 NQH23_FUT_CME[M] Daily #21 | Reloading chart. | 2023-02-07 09:22:50.474 Chart #21 has tagged chart #14 for full recalculation. Chartbook: Modified.Cht | 2023-02-07 09:22:50.477 NQH23_FUT_CME [CV][M] #14 | Performing a full recalculation because it has been tagged. Chartbook: Modified.Cht | 2023-02-07 09:22:50.489 Chart #21 has tagged chart #14 for full recalculation. Chartbook: Modified.Cht | 2023-02-07 09:22:50.974 NQH23_FUT_CME [CV][M] #14 | Performing a full recalculation because it has been tagged. Chartbook: Modified.Cht | 2023-02-07 09:22:50.990 HD Request # 3 | Requesting historical Daily data for UDH23 starting at 2023-02-01. SC External HD service. | 2023-02-07 09:22:51.182 HD Request # 3 | Receiving historical Daily data for UBH23_FUT_CME starting at 2023-02-02. | 2023-02-07 09:22:51.973 HD Request # 3 | Writing historical Daily data to the file UBH23_FUT_CME.dly. | 2023-02-07 09:22:51.973 HD Request # 3 | Bytes received: 268 | 2023-02-07 09:22:51.973 HD Request # 3 | Received 4 Daily data records from 2023-02-02 00:00:00 to 2023-02-06 00:00:00 (5.0 days) and wrote 3 records for UBH23_FUT_CME | 2023-02-07 09:22:51.973 HD Request # 3 | Completion time: 1s. | 2023-02-07 09:22:51.973 HD Request # 3 | Daily data download complete for UBH23_FUT_CME. Unique request ID: 2 | 2023-02-07 09:22:51.973 Removing historical data download ID 2. | 2023-02-07 09:22:51.973 Triggering next historical data download in queue. | 2023-02-07 09:22:51.973 HD Request # 4 | Downloading Historical Daily chart data for ESH23_FUT_CME. Starting date: 2023-02-02. Service: sc_futures_direct.dtc.trading | 2023-02-07 09:22:51.974 UBH23_FUT_CME [CV] #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-07 09:22:51.992 UBH23_FUT_CME [CV] #10 | Reloading chart. | 2023-02-07 09:22:51.993 UBH23_FUT_CME [CV] #10 | StartDateTimeForLoadingOrderFills: 2023-02-06 17:00:00 | 2023-02-07 09:22:52.003 UBH23_FUT_CME [CV] #10 | Reloading chart. | 2023-02-07 09:22:52.233 UBH23_FUT_CME [CV] #10 | StartDateTimeForLoadingOrderFills: 2023-02-06 17:00:00 | 2023-02-07 09:22:52.247 Added historical Intraday data request for UBH23_FUT_CME to the queue. | 2023-02-07 09:22:52.293 Intraday data recording state for symbol UBH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:22:52.293 Triggering next historical data download in queue. | 2023-02-07 09:22:52.293 HD Request # 4 | Requesting historical Daily data for ESH23 starting at 2023-02-01. SC External HD service. | 2023-02-07 09:22:53.116 HD Request # 4 | Receiving historical Daily data for ESH23_FUT_CME starting at 2023-02-02. | 2023-02-07 09:22:53.814 HD Request # 4 | Writing historical Daily data to the file ESH23_FUT_CME.dly. | 2023-02-07 09:22:53.814 HD Request # 4 | Bytes received: 242 | 2023-02-07 09:22:53.815 HD Request # 4 | Received 4 Daily data records from 2023-02-02 00:00:00 to 2023-02-06 00:00:00 (5.0 days) and wrote 3 records for ESH23_FUT_CME | 2023-02-07 09:22:53.815 HD Request # 4 | Completion time: 2s. | 2023-02-07 09:22:53.815 HD Request # 4 | Daily data download complete for ESH23_FUT_CME. Unique request ID: 3 | 2023-02-07 09:22:53.815 Removing historical data download ID 3. | 2023-02-07 09:22:53.815 Triggering next historical data download in queue. | 2023-02-07 09:22:53.815 HD Request # 5 | Downloading Historical Daily chart data for YMH23_FUT_CME. Starting date: 2023-02-02. Service: sc_futures_direct.dtc.trading | 2023-02-07 09:22:53.816 ESH23_FUT_CME [CV] #17 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-07 09:22:53.865 ESH23_FUT_CME [CV] #17 | Reloading chart. | 2023-02-07 09:22:53.865 ESH23_FUT_CME [CV] #17 | StartDateTimeForLoadingOrderFills: 2023-02-06 15:00:00 | 2023-02-07 09:22:53.893 ESH23_FUT_CME [CV] #17 | Reloading chart. | 2023-02-07 09:22:53.942 ESH23_FUT_CME[M] Daily #20 | Reloading chart. | 2023-02-07 09:22:53.966 Chart #20 has tagged chart #17 for full recalculation. Chartbook: Modified.Cht | 2023-02-07 09:22:53.969 ESH23_FUT_CME [CV] #17 | StartDateTimeForLoadingOrderFills: 2023-02-06 15:00:00 | 2023-02-07 09:22:53.973 Chart #20 has tagged chart #17 for full recalculation. Chartbook: Modified.Cht | 2023-02-07 09:22:54.458 ESH23_FUT_CME [CV][M] #17 | Performing a full recalculation because it has been tagged. Chartbook: Modified.Cht | 2023-02-07 09:22:54.458 HD Request # 5 | Requesting historical Daily data for YMH23 starting at 2023-02-01. SC External HD service. | 2023-02-07 09:22:54.945 HD Request # 5 | Receiving historical Daily data for YMH23_FUT_CME starting at 2023-02-02. | 2023-02-07 09:22:55.645 HD Request # 5 | Writing historical Daily data to the file YMH23_FUT_CME.dly. | 2023-02-07 09:22:55.645 HD Request # 5 | Bytes received: 216 | 2023-02-07 09:22:55.646 HD Request # 5 | Received 4 Daily data records from 2023-02-02 00:00:00 to 2023-02-06 00:00:00 (5.0 days) and wrote 3 records for YMH23_FUT_CME | 2023-02-07 09:22:55.646 HD Request # 5 | Completion time: 2s. | 2023-02-07 09:22:55.646 HD Request # 5 | Daily data download complete for YMH23_FUT_CME. Unique request ID: 4 | 2023-02-07 09:22:55.646 Removing historical data download ID 4. | 2023-02-07 09:22:55.646 Triggering next historical data download in queue. | 2023-02-07 09:22:55.646 HD Request # 6 | Downloading Historical Daily chart data for RTYH23_FUT_CME. Starting date: 2023-02-02. Service: sc_futures_direct.dtc.trading | 2023-02-07 09:22:55.646 YMH23_FUT_CME [CV] #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-07 09:22:55.678 YMH23_FUT_CME [CV] #1 | Reloading chart. | 2023-02-07 09:22:55.678 YMH23_FUT_CME [CV] #1 | StartDateTimeForLoadingOrderFills: 2023-02-06 15:00:00 | 2023-02-07 09:22:55.695 YMH23_FUT_CME [CV] #1 | Reloading chart. | 2023-02-07 09:22:55.732 YMH23_FUT_CME [CV] #1 | StartDateTimeForLoadingOrderFills: 2023-02-06 15:00:00 | 2023-02-07 09:22:55.744 Added historical Intraday data request for YMH23_FUT_CME to the queue. | 2023-02-07 09:22:55.781 Intraday data recording state for symbol YMH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:22:55.781 Triggering next historical data download in queue. | 2023-02-07 09:22:55.781 YMH23_FUT_CME[M] Daily #22 | Reloading chart. | 2023-02-07 09:22:55.990 Chart #22 has tagged chart #1 for full recalculation. Chartbook: Modified.Cht | 2023-02-07 09:22:55.993 YMH23_FUT_CME [CV][M] #1 | Performing a full recalculation because it has been tagged. Chartbook: Modified.Cht | 2023-02-07 09:22:56.037 Chart #22 has tagged chart #1 for full recalculation. Chartbook: Modified.Cht | 2023-02-07 09:22:56.499 YMH23_FUT_CME [CV][M] #1 | Performing a full recalculation because it has been tagged. Chartbook: Modified.Cht | 2023-02-07 09:22:56.499 HD Request # 6 | Requesting historical Daily data for QRH23 starting at 2023-02-01. SC External HD service. | 2023-02-07 09:22:56.776 HD Request # 6 | Receiving historical Daily data for RTYH23_FUT_CME starting at 2023-02-02. | 2023-02-07 09:22:57.552 HD Request # 6 | Writing historical Daily data to the file RTYH23_FUT_CME.dly. | 2023-02-07 09:22:57.552 HD Request # 6 | Bytes received: 232 | 2023-02-07 09:22:57.553 HD Request # 6 | Received 4 Daily data records from 2023-02-02 00:00:00 to 2023-02-06 00:00:00 (5.0 days) and wrote 3 records for RTYH23_FUT_CME | 2023-02-07 09:22:57.553 HD Request # 6 | Completion time: 2s. | 2023-02-07 09:22:57.553 HD Request # 6 | Daily data download complete for RTYH23_FUT_CME. Unique request ID: 5 | 2023-02-07 09:22:57.553 Removing historical data download ID 5. | 2023-02-07 09:22:57.553 Triggering next historical data download in queue. | 2023-02-07 09:22:57.554 HD Request # 7 | Downloading Historical Daily chart data for 6EH23_FUT_CME. Starting date: 2023-02-02. Service: sc_futures_direct.dtc.trading | 2023-02-07 09:22:57.554 RTYH23_FUT_CME [CV] #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-07 09:22:57.647 RTYH23_FUT_CME [CV] #4 | Reloading chart. | 2023-02-07 09:22:57.647 RTYH23_FUT_CME [CV] #4 | StartDateTimeForLoadingOrderFills: 2023-02-06 15:00:00 | 2023-02-07 09:22:57.674 RTYH23_FUT_CME [CV] #4 | Reloading chart. | 2023-02-07 09:22:57.808 RTYH23_FUT_CME [CV] #4 | StartDateTimeForLoadingOrderFills: 2023-02-06 15:00:00 | 2023-02-07 09:22:57.827 Added historical Intraday data request for RTYH23_FUT_CME to the queue. | 2023-02-07 09:22:57.864 Intraday data recording state for symbol RTYH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:22:57.864 Triggering next historical data download in queue. | 2023-02-07 09:22:57.864 HD Request # 7 | Requesting historical Daily data for E6H23 starting at 2023-02-01. SC External HD service. | 2023-02-07 09:22:58.686 HD Request # 7 | Receiving historical Daily data for 6EH23_FUT_CME starting at 2023-02-02. | 2023-02-07 09:22:59.474 HD Request # 7 | Writing historical Daily data to the file 6EH23_FUT_CME.dly. | 2023-02-07 09:22:59.475 HD Request # 7 | Bytes received: 246 | 2023-02-07 09:22:59.478 HD Request # 7 | Received 4 Daily data records from 2023-02-02 00:00:00 to 2023-02-06 00:00:00 (5.0 days) and wrote 3 records for 6EH23_FUT_CME | 2023-02-07 09:22:59.478 HD Request # 7 | Completion time: 2s. | 2023-02-07 09:22:59.478 HD Request # 7 | Daily data download complete for 6EH23_FUT_CME. Unique request ID: 6 | 2023-02-07 09:22:59.478 Removing historical data download ID 6. | 2023-02-07 09:22:59.478 Triggering next historical data download in queue. | 2023-02-07 09:22:59.478 HD Request # 8 | Downloading Historical Daily chart data for CLH23_FUT_CME. Starting date: 2023-02-02. Service: sc_futures_direct.dtc.trading | 2023-02-07 09:22:59.478 6EH23_FUT_CME [CV] #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-07 09:22:59.521 6EH23_FUT_CME [CV] #2 | Reloading chart. | 2023-02-07 09:22:59.521 6EH23_FUT_CME [CV] #2 | StartDateTimeForLoadingOrderFills: 2023-02-06 15:00:00 | 2023-02-07 09:22:59.552 6EH23_FUT_CME [CV] #2 | Reloading chart. | 2023-02-07 09:22:59.582 6EH23_FUT_CME [CV] #2 | StartDateTimeForLoadingOrderFills: 2023-02-06 15:00:00 | 2023-02-07 09:22:59.606 Added historical Intraday data request for 6EH23_FUT_CME to the queue. | 2023-02-07 09:22:59.643 Intraday data recording state for symbol 6EH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:22:59.643 Triggering next historical data download in queue. | 2023-02-07 09:22:59.643 HD Request # 8 | Requesting historical Daily data for CLH23 starting at 2023-02-01. SC External HD service. | 2023-02-07 09:23:00.601 HD Request # 8 | Receiving historical Daily data for CLH23_FUT_CME starting at 2023-02-02. | 2023-02-07 09:23:01.286 HD Request # 8 | Writing historical Daily data to the file CLH23_FUT_CME.dly. | 2023-02-07 09:23:01.286 HD Request # 8 | Bytes received: 216 | 2023-02-07 09:23:01.293 HD Request # 8 | Received 4 Daily data records from 2023-02-02 00:00:00 to 2023-02-06 00:00:00 (5.0 days) and wrote 3 records for CLH23_FUT_CME | 2023-02-07 09:23:01.293 HD Request # 8 | Completion time: 2s. | 2023-02-07 09:23:01.293 HD Request # 8 | Daily data download complete for CLH23_FUT_CME. Unique request ID: 8 | 2023-02-07 09:23:01.293 Removing historical data download ID 8. | 2023-02-07 09:23:01.293 Triggering next historical data download in queue. | 2023-02-07 09:23:01.293 HD Request # 9 | Downloading Historical Daily chart data for GCJ23_FUT_CME. Starting date: 2023-02-02. Service: sc_futures_direct.dtc.trading | 2023-02-07 09:23:01.294 HD Request # 9 | Requesting historical Daily data for GCJ23 starting at 2023-02-01. SC External HD service. | 2023-02-07 09:23:02.396 HD Request # 9 | Receiving historical Daily data for GCJ23_FUT_CME starting at 2023-02-02. | 2023-02-07 09:23:03.191 HD Request # 9 | Writing historical Daily data to the file GCJ23_FUT_CME.dly. | 2023-02-07 09:23:03.192 HD Request # 9 | Bytes received: 230 | 2023-02-07 09:23:03.193 HD Request # 9 | Received 4 Daily data records from 2023-02-02 00:00:00 to 2023-02-06 00:00:00 (5.0 days) and wrote 3 records for GCJ23_FUT_CME | 2023-02-07 09:23:03.193 HD Request # 9 | Completion time: 2s. | 2023-02-07 09:23:03.193 HD Request # 9 | Daily data download complete for GCJ23_FUT_CME. Unique request ID: 10 | 2023-02-07 09:23:03.193 Removing historical data download ID 10. | 2023-02-07 09:23:03.193 Triggering next historical data download in queue. | 2023-02-07 09:23:03.193 HD Request # 10 | Downloading Historical Daily chart data for ZBH23_FUT_CME. Starting date: 2023-02-02. Service: sc_futures_direct.dtc.trading | 2023-02-07 09:23:03.193 HD Request # 10 | Requesting historical Daily data for ZBH23 starting at 2023-02-01. SC External HD service. | 2023-02-07 09:23:04.419 HD Request # 10 | Receiving historical Daily data for ZBH23_FUT_CME starting at 2023-02-02. | 2023-02-07 09:23:05.209 HD Request # 10 | Writing historical Daily data to the file ZBH23_FUT_CME.dly. | 2023-02-07 09:23:05.210 HD Request # 10 | Bytes received: 269 | 2023-02-07 09:23:05.210 HD Request # 10 | Received 4 Daily data records from 2023-02-02 00:00:00 to 2023-02-06 00:00:00 (5.0 days) and wrote 3 records for ZBH23_FUT_CME | 2023-02-07 09:23:05.210 HD Request # 10 | Completion time: 2s. | 2023-02-07 09:23:05.210 HD Request # 10 | Daily data download complete for ZBH23_FUT_CME. Unique request ID: 12 | 2023-02-07 09:23:05.210 Removing historical data download ID 12. | 2023-02-07 09:23:05.210 Triggering next historical data download in queue. | 2023-02-07 09:23:05.210 HD Request # 11 | Downloading Historical Daily chart data for ZNH23_FUT_CME. Starting date: 2023-02-02. Service: sc_futures_direct.dtc.trading | 2023-02-07 09:23:05.211 HD Request # 11 | Requesting historical Daily data for ZNH23 starting at 2023-02-01. SC External HD service. | 2023-02-07 09:23:06.343 Socket (5) | CloseSocket call. | 2023-02-07 09:23:06.984 Socket (5) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:23:06.984 Historical data download thread signaled to stop. | 2023-02-07 09:23:06.984 HD Request # 2 | Received 3493181 Intraday data records from 2023-01-02 16:00:14.351000 to 2023-02-07 09:23:03.903006 (35.7 days) and wrote 3493181 records for CLH23_FUT_CME | 2023-02-07 09:23:06.984 HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:23:03.903006 | 2023-02-07 09:23:06.988 Added 9 Time and Sales records to Intraday data file for CLH23_FUT_CME after download. | 2023-02-07 09:23:06.988 HD Request # 2 | Completion time: 18s. | 2023-02-07 09:23:06.988 HD Request # 2 | Intraday data download complete for CLH23_FUT_CME. Unique request ID: 7 | 2023-02-07 09:23:06.988 Removing historical data download ID 7. | 2023-02-07 09:23:06.988 Real-time Intraday chart data file updates started for CLH23_FUT_CME | 2023-02-07 09:23:06.988 Intraday chart data file opened for CLH23_FUT_CME | 2023-02-07 09:23:06.988 HD Request # 2 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:23:06.988 CLH23_FUT_CME [CV] #3 | Flagging to reload Intraday data on download completion. | 2023-02-07 09:23:06.991 Triggering next historical data download in queue. | 2023-02-07 09:23:06.991 HD Request # 12 | Downloading Intraday chart data for GCJ23_FUT_CME to the file GCJ23_FUT_CME.scid. Service: comex | 2023-02-07 09:23:06.991 HD Request # 12 | Download start date-time: 2023-01-12 16:00:00.000000. File last date-time: 2023-02-07 09:16:36.501002 | 2023-02-07 09:23:06.991 HD Request # 12 | Disabling Intraday chart updating for symbol. | 2023-02-07 09:23:06.991 HD Request # 12 | Using server: ds28.sierracharts.com port 10149 | 2023-02-07 09:23:06.992 Socket (4) | Creating socket. | 2023-02-07 09:23:06.995 Socket (4) | New receive buffer size: 5242880 | 2023-02-07 09:23:06.995 Socket (4) | Connecting to IP: 142.215.18.147. | 2023-02-07 09:23:06.995 CLH23_FUT_CME [CV] #3 | Reloading chart. | 2023-02-07 09:23:07.035 CLH23_FUT_CME [CV] #3 | Waiting for historical downloads to complete with the IDs: 18, | 2023-02-07 09:23:07.039 HD Request # 11 | Receiving historical Daily data for ZNH23_FUT_CME starting at 2023-02-02. | 2023-02-07 09:23:07.048 HD Request # 11 | Writing historical Daily data to the file ZNH23_FUT_CME.dly. | 2023-02-07 09:23:07.048 HD Request # 11 | Bytes received: 281 | 2023-02-07 09:23:07.048 HD Request # 11 | Received 4 Daily data records from 2023-02-02 00:00:00 to 2023-02-06 00:00:00 (5.0 days) and wrote 3 records for ZNH23_FUT_CME | 2023-02-07 09:23:07.048 HD Request # 11 | Completion time: 2s. | 2023-02-07 09:23:07.048 HD Request # 11 | Daily data download complete for ZNH23_FUT_CME. Unique request ID: 14 | 2023-02-07 09:23:07.048 Removing historical data download ID 14. | 2023-02-07 09:23:07.048 Triggering next historical data download in queue. | 2023-02-07 09:23:07.048 HD Request # 13 | Downloading Historical Daily chart data for ZFH23_FUT_CME. Starting date: 2023-02-02. Service: sc_futures_direct.dtc.trading | 2023-02-07 09:23:07.049 Socket (5) | Socket gracefully closed by remote side. | 2023-02-07 09:23:07.203 Socket (5) | Closed. | 2023-02-07 09:23:07.203 HD Request # 12 | Setting DTC encoding to Binary VLS | 2023-02-07 09:23:07.450 HD Request # 12 | Sending historical data logon request message. | 2023-02-07 09:23:07.450 HD Request # 13 | Requesting historical Daily data for ZFH23 starting at 2023-02-01. SC External HD service. | 2023-02-07 09:23:08.182 HD Request # 12 | Requesting Intraday data. Start date-time: 2023-01-12 16:00:00. Record interval: 0. Symbol: GCJ23 | 2023-02-07 09:23:08.211 HD Request # 12 | Decompressing data. | 2023-02-07 09:23:08.451 HD Request # 13 | Receiving historical Daily data for ZFH23_FUT_CME starting at 2023-02-02. | 2023-02-07 09:23:08.960 HD Request # 13 | Writing historical Daily data to the file ZFH23_FUT_CME.dly. | 2023-02-07 09:23:08.961 HD Request # 13 | Bytes received: 302 | 2023-02-07 09:23:08.961 HD Request # 13 | Received 4 Daily data records from 2023-02-02 00:00:00 to 2023-02-06 00:00:00 (5.0 days) and wrote 3 records for ZFH23_FUT_CME | 2023-02-07 09:23:08.961 HD Request # 13 | Completion time: 1s. | 2023-02-07 09:23:08.961 HD Request # 13 | Daily data download complete for ZFH23_FUT_CME. Unique request ID: 15 | 2023-02-07 09:23:08.961 Removing historical data download ID 15. | 2023-02-07 09:23:08.961 Triggering next historical data download in queue. | 2023-02-07 09:23:08.961 HD Request # 14 | Downloading Historical Daily chart data for TNH23_FUT_CME. Starting date: 2023-02-02. Service: sc_futures_direct.dtc.trading | 2023-02-07 09:23:08.962 ZFH23_FUT_CME [CV] #28 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-07 09:23:08.991 ZFH23_FUT_CME [CV] #28 | Reloading chart. | 2023-02-07 09:23:08.992 ZFH23_FUT_CME [CV] #28 | StartDateTimeForLoadingOrderFills: 2023-02-06 17:00:00 | 2023-02-07 09:23:09.011 ZFH23_FUT_CME [CV] #28 | Reloading chart. | 2023-02-07 09:23:09.170 ZFH23_FUT_CME [CV] #28 | StartDateTimeForLoadingOrderFills: 2023-02-06 17:00:00 | 2023-02-07 09:23:09.183 Added historical Intraday data request for ZFH23_FUT_CME to the queue. | 2023-02-07 09:23:09.232 Intraday data recording state for symbol ZFH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:23:09.232 Triggering next historical data download in queue. | 2023-02-07 09:23:09.232 HD Request # 12 | Receiving Intraday data for GCJ23_FUT_CME starting at 2023-01-12 16:00:02.347000 | 2023-02-07 09:23:09.434 HD Request # 12 | Truncating file to starting date-time of 2023-01-12 16:00:02.347. | 2023-02-07 09:23:09.434 HD Request # 14 | Requesting historical Daily data for TNH23 starting at 2023-02-01. SC External HD service. | 2023-02-07 09:23:10.094 HD Request # 14 | Receiving historical Daily data for TNH23_FUT_CME starting at 2023-02-02. | 2023-02-07 09:23:10.783 HD Request # 14 | Writing historical Daily data to the file TNH23_FUT_CME.dly. | 2023-02-07 09:23:10.783 HD Request # 14 | Bytes received: 286 | 2023-02-07 09:23:10.783 HD Request # 14 | Received 4 Daily data records from 2023-02-02 00:00:00 to 2023-02-06 00:00:00 (5.0 days) and wrote 3 records for TNH23_FUT_CME | 2023-02-07 09:23:10.783 HD Request # 14 | Completion time: 2s. | 2023-02-07 09:23:10.783 HD Request # 14 | Daily data download complete for TNH23_FUT_CME. Unique request ID: 17 | 2023-02-07 09:23:10.783 Removing historical data download ID 17. | 2023-02-07 09:23:10.783 Triggering next historical data download in queue. | 2023-02-07 09:23:10.783 HD Request # 15 | Downloading Historical Daily chart data for CLG23_FUT_CME. Starting date: 2023-01-18. Service: sc_futures_direct.dtc.trading | 2023-02-07 09:23:10.784 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\CLH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:23:11.380 HD Request # 15 | Requesting historical Daily data for CLG23 starting at 2023-01-17. SC External HD service. | 2023-02-07 09:23:11.915 HD Request # 12 | Timestamp of first Intraday data file record written: 2023-01-12 16:00:02.347000. | 2023-02-07 09:23:12.306 HD Request # 15 | Receiving historical Daily data for CLG23_FUT_CME starting at 2023-01-18. | 2023-02-07 09:23:12.626 HD Request # 15 | Writing historical Daily data to the file CLG23_FUT_CME.dly. | 2023-02-07 09:23:12.626 HD Request # 15 | Bytes received: 207 | 2023-02-07 09:23:12.629 HD Request # 15 | Received 4 Daily data records from 2023-01-18 00:00:00 to 2023-01-20 00:00:00 (3.0 days) and wrote 3 records for CLG23_FUT_CME | 2023-02-07 09:23:12.629 HD Request # 15 | Completion time: 2s. | 2023-02-07 09:23:12.629 HD Request # 15 | Daily data download complete for CLG23_FUT_CME. Unique request ID: 18 | 2023-02-07 09:23:12.629 Removing historical data download ID 18. | 2023-02-07 09:23:12.629 Triggering next historical data download in queue. | 2023-02-07 09:23:12.629 HD Request # 16 | Downloading Historical Daily chart data for GCG23_FUT_CME. Starting date: 2023-02-02. Service: sc_futures_direct.dtc.trading | 2023-02-07 09:23:12.630 CLH23_FUT_CME [CV] #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-07 09:23:12.641 CLH23_FUT_CME [CV] #3 | Reloading chart. | 2023-02-07 09:23:12.644 CLH23_FUT_CME [CV] #3 | Reloading chart. | 2023-02-07 09:23:12.716 CLH23_FUT_CME [CV] #3 | StartDateTimeForLoadingOrderFills: 2023-02-06 11:30:00 | 2023-02-07 09:23:12.728 CLG23_FUT_CME[M] Daily #23 | Reloading chart. | 2023-02-07 09:23:13.103 Chart #23 has tagged chart #3 for full recalculation. Chartbook: Modified.Cht | 2023-02-07 09:23:13.112 CLH23_FUT_CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Modified.Cht | 2023-02-07 09:23:13.163 HD Request # 16 | Requesting historical Daily data for GCG23 starting at 2023-02-01. SC External HD service. | 2023-02-07 09:23:13.762 HD Request # 16 | Receiving historical Daily data for GCG23_FUT_CME starting at 2023-02-02. | 2023-02-07 09:23:14.472 HD Request # 16 | Writing historical Daily data to the file GCG23_FUT_CME.dly. | 2023-02-07 09:23:14.472 HD Request # 16 | Bytes received: 209 | 2023-02-07 09:23:14.473 HD Request # 16 | Received 4 Daily data records from 2023-02-02 00:00:00 to 2023-02-06 00:00:00 (5.0 days) and wrote 3 records for GCG23_FUT_CME | 2023-02-07 09:23:14.473 HD Request # 16 | Completion time: 2s. | 2023-02-07 09:23:14.474 HD Request # 16 | Daily data download complete for GCG23_FUT_CME. Unique request ID: 19 | 2023-02-07 09:23:14.474 Removing historical data download ID 19. | 2023-02-07 09:23:14.474 Triggering next historical data download in queue. | 2023-02-07 09:23:14.474 No download requests in the queue to start downloads for. | 2023-02-07 09:23:14.474 GCG23_FUT_CME[M] Daily #24 | Reloading chart. | 2023-02-07 09:23:14.601 Socket (4) | CloseSocket call. | 2023-02-07 09:23:33.806 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:23:33.806 Historical data download thread signaled to stop. | 2023-02-07 09:23:33.809 HD Request # 12 | Received 1284698 Intraday data records from 2023-01-12 16:00:02.347000 to 2023-02-07 09:23:20.460000 (25.7 days) and wrote 1284698 records for GCJ23_FUT_CME | 2023-02-07 09:23:33.809 HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:23:20.460000 | 2023-02-07 09:23:33.812 Added 2 Time and Sales records to Intraday data file for GCJ23_FUT_CME after download. | 2023-02-07 09:23:33.812 HD Request # 12 | Completion time: 27s. | 2023-02-07 09:23:33.812 HD Request # 12 | Intraday data download complete for GCJ23_FUT_CME. Unique request ID: 9 | 2023-02-07 09:23:33.812 Removing historical data download ID 9. | 2023-02-07 09:23:33.812 Real-time Intraday chart data file updates started for GCJ23_FUT_CME | 2023-02-07 09:23:33.812 Intraday chart data file opened for GCJ23_FUT_CME | 2023-02-07 09:23:33.812 HD Request # 12 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:23:33.812 GCJ23_FUT_CME [CV] #12 | Flagging to reload Intraday data on download completion. | 2023-02-07 09:23:33.814 Triggering next historical data download in queue. | 2023-02-07 09:23:33.814 HD Request # 17 | Downloading Intraday chart data for ZBH23_FUT_CME to the file ZBH23_FUT_CME.scid. Service: cbot | 2023-02-07 09:23:33.814 HD Request # 17 | Download start date-time: 2022-11-14 16:00:00.000000. File last date-time: 2023-02-07 09:16:36.297000 | 2023-02-07 09:23:33.814 HD Request # 17 | Disabling Intraday chart updating for symbol. | 2023-02-07 09:23:33.814 HD Request # 17 | Using server: ds23.sierracharts.com port 10150 | 2023-02-07 09:23:33.814 Socket (5) | Creating socket. | 2023-02-07 09:23:33.818 Socket (5) | New receive buffer size: 5242880 | 2023-02-07 09:23:33.818 Socket (5) | Connecting to IP: 142.215.17.190. | 2023-02-07 09:23:33.818 GCJ23_FUT_CME [CV] #12 | Reloading chart. | 2023-02-07 09:23:33.819 GCJ23_FUT_CME [CV] #12 | StartDateTimeForLoadingOrderFills: 2023-02-06 15:00:00 | 2023-02-07 09:23:33.880 Socket (4) | Socket gracefully closed by remote side. | 2023-02-07 09:23:34.035 Socket (4) | Closed. | 2023-02-07 09:23:34.035 HD Request # 17 | Setting DTC encoding to Binary VLS | 2023-02-07 09:23:34.375 HD Request # 17 | Sending historical data logon request message. | 2023-02-07 09:23:34.375 HD Request # 17 | Requesting Intraday data. Start date-time: 2022-11-14 16:00:00. Record interval: 0. Symbol: ZBH23 | 2023-02-07 09:23:35.159 HD Request # 17 | Decompressing data. | 2023-02-07 09:23:35.449 HD Request # 17 | Receiving Intraday data for ZBH23_FUT_CME starting at 2022-11-14 16:24:48.644000 | 2023-02-07 09:23:36.280 HD Request # 17 | Truncating file to starting date-time of 2022-11-14 16:24:48.644. | 2023-02-07 09:23:36.280 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\GCJ23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:23:36.648 HD Request # 17 | Timestamp of first Intraday data file record written: 2022-11-14 16:24:48.644000. | 2023-02-07 09:23:36.804 Teton CME Order Routing | There has been no activity on the network socket for 45s. Will reconnect. | 2023-02-07 09:23:38.097 Connection to the external service has been lost. | 2023-02-07 09:23:38.097 Teton CME Order Routing | Waiting for socket receive thread to end | 2023-02-07 09:23:38.235 DTC Client socket (1) | CloseSocket call. | 2023-02-07 09:23:38.235 DTC Client socket (1) | Max send buffers used during socket life: 5 | 2023-02-07 09:23:38.235 DTC Client socket (1) | Max send buffer size during socket life: 690 | 2023-02-07 09:23:38.235 Teton CME Order Routing | Disconnected. | 2023-02-07 09:23:38.235 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-07 09:23:38.235 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:23:38.235 Teton CME Order Routing | Firm: Dorman | 2023-02-07 09:23:40.275 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-02-07 09:23:40.275 DTC Client socket (4) | Creating socket. Using TLS 1.2. | 2023-02-07 09:23:40.275 DTC Client socket (4) | New receive buffer size: 5242880 | 2023-02-07 09:23:40.275 DTC Client socket (4) | Connecting to IP: 208.185.224.129. | 2023-02-07 09:23:40.275 Teton CME Order Routing | Network connection to server complete. | 2023-02-07 09:23:40.527 Teton CME Order Routing | Starting socket receive thread. | 2023-02-07 09:23:40.527 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-02-07 09:23:40.527 Teton CME Order Routing | Did not receive Encoding Response from server. Disconnecting. | 2023-02-07 09:24:00.561 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-07 09:24:00.561 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-07 09:24:00.561 Teton CME Order Routing | Waiting for socket receive thread to end | 2023-02-07 09:24:00.567 DTC Client socket (4) | CloseSocket call. | 2023-02-07 09:24:00.567 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:24:00.567 Teton CME Order Routing | Disconnected. | 2023-02-07 09:24:00.567 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-07 09:24:00.567 Teton CME Order Routing | Firm: Dorman | 2023-02-07 09:24:02.581 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-02-07 09:24:02.581 DTC Client socket (7) | Creating socket. Using TLS 1.2. | 2023-02-07 09:24:02.581 DTC Client socket (7) | New receive buffer size: 5242880 | 2023-02-07 09:24:02.581 DTC Client socket (7) | Connecting to IP: 208.185.224.129. | 2023-02-07 09:24:02.581 Teton CME Order Routing | Network connection to server complete. | 2023-02-07 09:24:02.817 Teton CME Order Routing | Starting socket receive thread. | 2023-02-07 09:24:02.817 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-02-07 09:24:02.817 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-02-07 09:24:04.662 Teton CME Order Routing | Sending logon request message. | 2023-02-07 09:24:04.662 Teton CME Order Routing | Received logon response. | 2023-02-07 09:24:05.360 Teton CME Order Routing | Server Name: SC DTC Server. Build=44641. | 2023-02-07 09:24:05.360 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-02-07 09:24:05.360 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2023-02-07 09:24:05.360 Teton CME Order Routing | Trading is supported. | 2023-02-07 09:24:05.360 Teton CME Order Routing | Order cancel and replace is supported. | 2023-02-07 09:24:05.360 Teton CME Order Routing | OCO Orders supported. | 2023-02-07 09:24:05.360 Teton CME Order Routing | Bracket Orders supported. | 2023-02-07 09:24:05.360 Teton CME Order Routing | Connected to server complete. | 2023-02-07 09:24:05.360 Teton CME Order Routing | Waiting for socket receive thread to end | 2023-02-07 09:24:05.360 DTC Client socket (6) | CloseSocket call. | 2023-02-07 09:24:05.360 DTC Client socket (6) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:24:05.360 Teton CME Order Routing | Disconnected from the server. | 2023-02-07 09:24:05.360 Denali Data Feed | Waiting for socket receive thread to end | 2023-02-07 09:24:05.362 DTC Client socket (2) | CloseSocket call. | 2023-02-07 09:24:05.362 DTC Client socket (2) | Max send buffers used during socket life: 4 | 2023-02-07 09:24:05.362 DTC Client socket (2) | Max send buffer size during socket life: 1377 | 2023-02-07 09:24:05.362 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:24:05.362 Denali Data Feed | Disconnected from the server. | 2023-02-07 09:24:05.362 Triggering next historical data download in queue. | 2023-02-07 09:24:05.362 Triggering next historical data download in queue. | 2023-02-07 09:24:05.362 Triggering next historical data download in queue. | 2023-02-07 09:24:05.362 Triggering next historical data download in queue. | 2023-02-07 09:24:05.362 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:24:05.362 Mapping ESM20_FUT_CME to ESM20. Service code: cme | 2023-02-07 09:24:05.362 Using symbol data fast lookup vector | 2023-02-07 09:24:05.362 Denali Data Feed | Starting real-time market data updates for: ESM20_FUT_CME (ESM20). ID: 1 Service code: cme | 2023-02-07 09:24:05.362 Denali Data Feed | Connecting to the server ds23.sierracharts.com. Port 443 | 2023-02-07 09:24:05.362 Denali Data Feed | Requesting security definition data for: ESM20_FUT_CME (ESM20). ID: 1 | 2023-02-07 09:24:05.362 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:24:05.362 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:24:05.362 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:24:05.362 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:24:05.362 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:24:05.362 Subscribing to symbol for symbol alert. ESU20_FUT_CME | 2023-02-07 09:24:05.362 Mapping ESU20_FUT_CME to ESU20. Service code: cme | 2023-02-07 09:24:05.362 Denali Data Feed | Starting real-time market data updates for: ESU20_FUT_CME (ESU20). ID: 2 Service code: cme | 2023-02-07 09:24:05.362 Denali Data Feed | Requesting security definition data for: ESU20_FUT_CME (ESU20). ID: 2 | 2023-02-07 09:24:05.362 Subscribing to symbol for symbol alert. GCG21_FUT_CME | 2023-02-07 09:24:05.362 Mapping GCG21_FUT_CME to GCG21. Service code: comex | 2023-02-07 09:24:05.362 Denali Data Feed | Starting real-time market data updates for: GCG21_FUT_CME (GCG21). ID: 3 Service code: comex | 2023-02-07 09:24:05.363 Denali Data Feed | Requesting security definition data for: GCG21_FUT_CME (GCG21). ID: 3 | 2023-02-07 09:24:05.363 Subscribing to symbol for symbol alert. 6EH21_FUT_CME | 2023-02-07 09:24:05.363 Mapping 6EH21_FUT_CME to 6EH21. Service code: cme | 2023-02-07 09:24:05.363 Denali Data Feed | Starting real-time market data updates for: 6EH21_FUT_CME (6EH21). ID: 4 Service code: cme | 2023-02-07 09:24:05.363 Denali Data Feed | Requesting security definition data for: 6EH21_FUT_CME (6EH21). ID: 4 | 2023-02-07 09:24:05.363 Subscribing to symbol for symbol alert. ESH21_FUT_CME | 2023-02-07 09:24:05.363 Mapping ESH21_FUT_CME to ESH21. Service code: cme | 2023-02-07 09:24:05.363 Denali Data Feed | Starting real-time market data updates for: ESH21_FUT_CME (ESH21). ID: 5 Service code: cme | 2023-02-07 09:24:05.363 Denali Data Feed | Requesting security definition data for: ESH21_FUT_CME (ESH21). ID: 5 | 2023-02-07 09:24:05.363 DTC Client socket (8) | Creating socket. | 2023-02-07 09:24:05.363 Subscribing to symbol for symbol alert. ESH21_FUT_CME | 2023-02-07 09:24:05.363 Updated verified funded futures trading account ending date to: 2023-03-09 17:24:05 | 2023-02-07 09:24:05.363 DTC Client socket (8) | New receive buffer size: 5242880 | 2023-02-07 09:24:05.363 DTC Client socket (8) | Connecting to IP: 142.215.17.190. | 2023-02-07 09:24:05.363 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2023-02-07 09:24:05.439 DTC Client socket (8) | CloseSocket call. | 2023-02-07 09:24:05.439 Denali Data Feed | Disconnected from the server. | 2023-02-07 09:24:05.440 Denali Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-02-07 09:24:05.440 No download requests in the queue to start downloads for. | 2023-02-07 09:24:05.440 No download requests in the queue to start downloads for. | 2023-02-07 09:24:05.440 No download requests in the queue to start downloads for. | 2023-02-07 09:24:05.440 DTC Client socket (8) | Closed. | 2023-02-07 09:24:05.440 Mapping 6EH23_FUT_CME to 6EH23. Service code: cme | 2023-02-07 09:24:05.440 Denali Data Feed | Starting real-time market data updates for: 6EH23_FUT_CME (6EH23). ID: 6 Service code: cme | 2023-02-07 09:24:05.440 Denali Data Feed | Requesting security definition data for: 6EH23_FUT_CME (6EH23). ID: 6 | 2023-02-07 09:24:05.440 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2023-02-07 15:03:49.033833 | 2023-02-07 09:24:05.445 Mapping RTYH23_FUT_CME to RTYH23. Service code: cme | 2023-02-07 09:24:05.445 Denali Data Feed | Starting real-time market data updates for: RTYH23_FUT_CME (RTYH23). ID: 7 Service code: cme | 2023-02-07 09:24:05.445 Denali Data Feed | Requesting security definition data for: RTYH23_FUT_CME (RTYH23). ID: 7 | 2023-02-07 09:24:05.445 Mapping YMH23_FUT_CME to YMH23. Service code: cbot | 2023-02-07 09:24:05.448 Denali Data Feed | Starting real-time market data updates for: YMH23_FUT_CME (YMH23). ID: 8 Service code: cbot | 2023-02-07 09:24:05.448 Denali Data Feed | Requesting security definition data for: YMH23_FUT_CME (YMH23). ID: 8 | 2023-02-07 09:24:05.448 Mapping CLH23_FUT_CME to CLH23. Service code: nymex | 2023-02-07 09:24:05.454 Denali Data Feed | Starting real-time market data updates for: CLH23_FUT_CME (CLH23). ID: 9 Service code: nymex | 2023-02-07 09:24:05.454 Denali Data Feed | Requesting security definition data for: CLH23_FUT_CME (CLH23). ID: 9 | 2023-02-07 09:24:05.454 Added historical Intraday data request for CLH23_FUT_CME to the queue. | 2023-02-07 09:24:05.454 Intraday data recording state for symbol CLH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:24:05.454 Triggering next historical data download in queue. | 2023-02-07 09:24:05.454 Mapping GCJ23_FUT_CME to GCJ23. Service code: comex | 2023-02-07 09:24:05.490 Denali Data Feed | Starting real-time market data updates for: GCJ23_FUT_CME (GCJ23). ID: 10 Service code: comex | 2023-02-07 09:24:05.490 Denali Data Feed | Requesting security definition data for: GCJ23_FUT_CME (GCJ23). ID: 10 | 2023-02-07 09:24:05.490 Added historical Intraday data request for GCJ23_FUT_CME to the queue. | 2023-02-07 09:24:05.490 Intraday data recording state for symbol GCJ23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:24:05.490 Triggering next historical data download in queue. | 2023-02-07 09:24:05.490 Mapping ZFH23_FUT_CME to ZFH23. Service code: cbot | 2023-02-07 09:24:05.506 Denali Data Feed | Starting real-time market data updates for: ZFH23_FUT_CME (ZFH23). ID: 11 Service code: cbot | 2023-02-07 09:24:05.506 Denali Data Feed | Requesting security definition data for: ZFH23_FUT_CME (ZFH23). ID: 11 | 2023-02-07 09:24:05.506 Mapping ESH23_FUT_CME to ESH23. Service code: cme | 2023-02-07 09:24:05.508 Denali Data Feed | Starting real-time market data updates for: ESH23_FUT_CME (ESH23). ID: 12 Service code: cme | 2023-02-07 09:24:05.508 Denali Data Feed | Requesting security definition data for: ESH23_FUT_CME (ESH23). ID: 12 | 2023-02-07 09:24:05.508 Mapping UBH23_FUT_CME to UBH23. Service code: cbot | 2023-02-07 09:24:05.516 Denali Data Feed | Starting real-time market data updates for: UBH23_FUT_CME (UBH23). ID: 13 Service code: cbot | 2023-02-07 09:24:05.516 Denali Data Feed | Requesting security definition data for: UBH23_FUT_CME (UBH23). ID: 13 | 2023-02-07 09:24:05.516 Mapping NQH23_FUT_CME to NQH23. Service code: cme | 2023-02-07 09:24:05.518 Denali Data Feed | Starting real-time market data updates for: NQH23_FUT_CME (NQH23). ID: 14 Service code: cme | 2023-02-07 09:24:05.518 Denali Data Feed | Requesting security definition data for: NQH23_FUT_CME (NQH23). ID: 14 | 2023-02-07 09:24:05.518 DTC Client socket (6) | Socket gracefully closed by remote side. | 2023-02-07 09:24:05.607 DTC Client socket (6) | Closed. | 2023-02-07 09:24:05.607 Mapping GCG23_FUT_CME to GCG23. Service code: comex | 2023-02-07 09:24:05.687 Denali Data Feed | Starting real-time market data updates for: GCG23_FUT_CME (GCG23). ID: 15 Service code: comex | 2023-02-07 09:24:05.687 Denali Data Feed | Requesting security definition data for: GCG23_FUT_CME (GCG23). ID: 15 | 2023-02-07 09:24:05.687 Mapping CLG23_FUT_CME to CLG23. Service code: nymex | 2023-02-07 09:24:05.688 Denali Data Feed | Starting real-time market data updates for: CLG23_FUT_CME (CLG23). ID: 16 Service code: nymex | 2023-02-07 09:24:05.688 Denali Data Feed | Requesting security definition data for: CLG23_FUT_CME (CLG23). ID: 16 | 2023-02-07 09:24:05.688 Denali Data Feed | Connecting to the server ds13.sierracharts.com. Port 10048 | 2023-02-07 09:24:07.427 DTC Client socket (6) | Creating socket. | 2023-02-07 09:24:07.440 DTC Client socket (6) | New receive buffer size: 5242880 | 2023-02-07 09:24:07.440 DTC Client socket (6) | Connecting to IP: 162.251.232.244. | 2023-02-07 09:24:07.440 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESM20_FUT_CME | 2023-02-07 09:24:08.918 Teton CME Order Routing | Received security definition for symbol ESM20_FUT_CME | 2023-02-07 09:24:08.918 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESU20_FUT_CME | 2023-02-07 09:24:08.918 Teton CME Order Routing | Received security definition for symbol ESU20_FUT_CME | 2023-02-07 09:24:08.918 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: GCG21_FUT_CME | 2023-02-07 09:24:08.918 Teton CME Order Routing | Received security definition for symbol GCG21_FUT_CME | 2023-02-07 09:24:08.918 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6EH21_FUT_CME | 2023-02-07 09:24:08.918 Teton CME Order Routing | Received security definition for symbol 6EH21_FUT_CME | 2023-02-07 09:24:08.918 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH21_FUT_CME | 2023-02-07 09:24:08.918 Teton CME Order Routing | Received security definition for symbol ESH21_FUT_CME | 2023-02-07 09:24:08.918 Requesting market depth updates for: 6EH23_FUT_CME if supported. | 2023-02-07 09:24:10.348 Separate subscription for market depth updates not supported. 6EH23_FUT_CME | 2023-02-07 09:24:10.348 Requesting market depth updates for: CLH23_FUT_CME if supported. | 2023-02-07 09:24:10.348 Separate subscription for market depth updates not supported. CLH23_FUT_CME | 2023-02-07 09:24:10.348 Requesting market depth updates for: ESH23_FUT_CME if supported. | 2023-02-07 09:24:10.348 Separate subscription for market depth updates not supported. ESH23_FUT_CME | 2023-02-07 09:24:10.348 Requesting market depth updates for: GCJ23_FUT_CME if supported. | 2023-02-07 09:24:10.348 Separate subscription for market depth updates not supported. GCJ23_FUT_CME | 2023-02-07 09:24:10.348 Requesting market depth updates for: NQH23_FUT_CME if supported. | 2023-02-07 09:24:10.348 Separate subscription for market depth updates not supported. NQH23_FUT_CME | 2023-02-07 09:24:10.348 Requesting market depth updates for: RTYH23_FUT_CME if supported. | 2023-02-07 09:24:10.348 Separate subscription for market depth updates not supported. RTYH23_FUT_CME | 2023-02-07 09:24:10.348 Mapping TNH23_FUT_CME to TNH23. Service code: cbot | 2023-02-07 09:24:10.348 Denali Data Feed | Starting real-time market data updates for: TNH23_FUT_CME (TNH23). ID: 17 Service code: cbot | 2023-02-07 09:24:10.348 Denali Data Feed | Requesting security definition data for: TNH23_FUT_CME (TNH23). ID: 17 | 2023-02-07 09:24:10.348 Requesting market depth updates for: TNH23_FUT_CME if supported. | 2023-02-07 09:24:10.348 Separate subscription for market depth updates not supported. TNH23_FUT_CME | 2023-02-07 09:24:10.348 Requesting market depth updates for: UBH23_FUT_CME if supported. | 2023-02-07 09:24:10.348 Separate subscription for market depth updates not supported. UBH23_FUT_CME | 2023-02-07 09:24:10.348 Requesting market depth updates for: YMH23_FUT_CME if supported. | 2023-02-07 09:24:10.348 Separate subscription for market depth updates not supported. YMH23_FUT_CME | 2023-02-07 09:24:10.348 Mapping ZBH23_FUT_CME to ZBH23. Service code: cbot | 2023-02-07 09:24:10.348 Denali Data Feed | Starting real-time market data updates for: ZBH23_FUT_CME (ZBH23). ID: 18 Service code: cbot | 2023-02-07 09:24:10.348 Denali Data Feed | Requesting security definition data for: ZBH23_FUT_CME (ZBH23). ID: 18 | 2023-02-07 09:24:10.348 Requesting market depth updates for: ZBH23_FUT_CME if supported. | 2023-02-07 09:24:10.348 Separate subscription for market depth updates not supported. ZBH23_FUT_CME | 2023-02-07 09:24:10.348 Requesting market depth updates for: ZFH23_FUT_CME if supported. | 2023-02-07 09:24:10.348 Separate subscription for market depth updates not supported. ZFH23_FUT_CME | 2023-02-07 09:24:10.348 Mapping ZNH23_FUT_CME to ZNH23. Service code: cbot | 2023-02-07 09:24:10.348 Denali Data Feed | Starting real-time market data updates for: ZNH23_FUT_CME (ZNH23). ID: 19 Service code: cbot | 2023-02-07 09:24:10.348 Denali Data Feed | Requesting security definition data for: ZNH23_FUT_CME (ZNH23). ID: 19 | 2023-02-07 09:24:10.348 Requesting market depth updates for: ZNH23_FUT_CME if supported. | 2023-02-07 09:24:10.348 Separate subscription for market depth updates not supported. ZNH23_FUT_CME | 2023-02-07 09:24:10.348 Socket (5) | CloseSocket call. | 2023-02-07 09:24:24.730 Historical data download thread signaled to stop. | 2023-02-07 09:24:24.730 Socket (5) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:24:24.730 HD Request # 17 | Received 5981359 Intraday data records from 2022-11-14 16:24:48.644000 to 2023-02-07 09:24:20.176001 (84.7 days) and wrote 5981359 records for ZBH23_FUT_CME | 2023-02-07 09:24:24.731 HD Request # 17 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:24:20.176001 | 2023-02-07 09:24:24.734 HD Request # 17 | Completion time: 51s. | 2023-02-07 09:24:24.734 HD Request # 17 | Intraday data download complete for ZBH23_FUT_CME. Unique request ID: 11 | 2023-02-07 09:24:24.734 Removing historical data download ID 11. | 2023-02-07 09:24:24.734 Real-time Intraday chart data file updates started for ZBH23_FUT_CME | 2023-02-07 09:24:24.734 Intraday chart data file opened for ZBH23_FUT_CME | 2023-02-07 09:24:24.734 HD Request # 17 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:24:24.734 ZBH23_FUT_CME [CV] #26 | Flagging to reload Intraday data on download completion. | 2023-02-07 09:24:24.734 Triggering next historical data download in queue. | 2023-02-07 09:24:24.734 Delaying start of download for ZNH23_FUT_CME. | 2023-02-07 09:24:24.734 ZBH23_FUT_CME [CV] #26 | Reloading chart. | 2023-02-07 09:24:24.736 ZBH23_FUT_CME [CV] #26 | StartDateTimeForLoadingOrderFills: 2023-02-06 17:00:00 | 2023-02-07 09:24:24.754 Socket (5) | Socket gracefully closed by remote side. | 2023-02-07 09:24:24.986 Socket (5) | Closed. | 2023-02-07 09:24:24.987 DTC Client socket (6) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2023-02-07 09:24:28.463 * DTC Client socket (6) | CloseSocket call. | 2023-02-07 09:24:28.463 DTC Client socket (6) | Closed. | 2023-02-07 09:24:28.463 DTC Client socket (0) | CloseSocket call. | 2023-02-07 09:24:28.463 Denali Data Feed | Disconnected from the server. | 2023-02-07 09:24:28.463 Denali Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-02-07 09:24:28.463 Denali Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10048 | 2023-02-07 09:24:30.458 DTC Client socket (5) | Creating socket. | 2023-02-07 09:24:30.462 DTC Client socket (5) | New receive buffer size: 5242880 | 2023-02-07 09:24:30.462 DTC Client socket (5) | Connecting to IP: 142.215.17.187. | 2023-02-07 09:24:30.462 Denali Data Feed | Network connection to server complete. | 2023-02-07 09:24:30.697 Denali Data Feed | Starting socket receive thread. | 2023-02-07 09:24:30.697 Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-07 09:24:30.697 Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-02-07 09:24:30.964 Denali Data Feed | Sending logon request message. | 2023-02-07 09:24:30.964 Denali Data Feed | Received logon response. | 2023-02-07 09:24:31.932 Denali Data Feed | Server Name: SC Realtime Server. | 2023-02-07 09:24:31.932 Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-02-07 09:24:31.932 Denali Data Feed | Successfully connected. | 2023-02-07 09:24:31.932 Denali Data Feed | Trading is not supported. | 2023-02-07 09:24:31.932 Denali Data Feed | Restarting real-time data updates for symbol: 6EH21_FUT_CME -> 6EH21 | 2023-02-07 09:24:31.933 Teton CME Order Routing | Connecting to the server ds23-2.sierracharts.com. Port 10060 | 2023-02-07 09:24:31.935 DTC Client socket (6) | Creating socket. | 2023-02-07 09:24:31.935 DTC Client socket (6) | New receive buffer size: 5242880 | 2023-02-07 09:24:31.935 DTC Client socket (6) | Connecting to IP: 142.215.17.187. | 2023-02-07 09:24:31.935 Denali Data Feed | Restarting real-time data updates for symbol: 6EH23_FUT_CME -> 6EH23. Market Depth data restarted. | 2023-02-07 09:24:31.936 Denali Data Feed | Restarting real-time data updates for symbol: CLG23_FUT_CME -> CLG23 | 2023-02-07 09:24:31.936 Denali Data Feed | Restarting real-time data updates for symbol: CLH23_FUT_CME -> CLH23. Market Depth data restarted. | 2023-02-07 09:24:31.936 Denali Data Feed | Restarting real-time data updates for symbol: ESH21_FUT_CME -> ESH21 | 2023-02-07 09:24:31.936 Denali Data Feed | Restarting real-time data updates for symbol: ESH23_FUT_CME -> ESH23. Market Depth data restarted. | 2023-02-07 09:24:31.936 Denali Data Feed | Restarting real-time data updates for symbol: ESM20_FUT_CME -> ESM20 | 2023-02-07 09:24:31.936 Denali Data Feed | Restarting real-time data updates for symbol: ESU20_FUT_CME -> ESU20 | 2023-02-07 09:24:31.936 Denali Data Feed | Restarting real-time data updates for symbol: GCG21_FUT_CME -> GCG21 | 2023-02-07 09:24:31.936 Denali Data Feed | Restarting real-time data updates for symbol: GCG23_FUT_CME -> GCG23 | 2023-02-07 09:24:31.936 Denali Data Feed | Restarting real-time data updates for symbol: GCJ23_FUT_CME -> GCJ23. Market Depth data restarted. | 2023-02-07 09:24:31.936 Denali Data Feed | Restarting real-time data updates for symbol: NQH23_FUT_CME -> NQH23. Market Depth data restarted. | 2023-02-07 09:24:31.936 Denali Data Feed | Restarting real-time data updates for symbol: RTYH23_FUT_CME -> RTYH23. Market Depth data restarted. | 2023-02-07 09:24:31.936 Denali Data Feed | Restarting real-time data updates for symbol: TNH23_FUT_CME -> TNH23. Market Depth data restarted. | 2023-02-07 09:24:31.936 Denali Data Feed | Restarting real-time data updates for symbol: UBH23_FUT_CME -> UBH23. Market Depth data restarted. | 2023-02-07 09:24:31.936 Denali Data Feed | Restarting real-time data updates for symbol: YMH23_FUT_CME -> YMH23. Market Depth data restarted. | 2023-02-07 09:24:31.936 Added historical Intraday data request for ZBH23_FUT_CME to the queue. | 2023-02-07 09:24:31.936 Intraday data recording state for symbol ZBH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:24:31.936 Triggering next historical data download in queue. | 2023-02-07 09:24:31.936 Denali Data Feed | Restarting real-time data updates for symbol: ZBH23_FUT_CME -> ZBH23. Market Depth data restarted. | 2023-02-07 09:24:31.936 Denali Data Feed | Restarting real-time data updates for symbol: ZFH23_FUT_CME -> ZFH23. Market Depth data restarted. | 2023-02-07 09:24:31.936 Denali Data Feed | Restarting real-time data updates for symbol: ZNH23_FUT_CME -> ZNH23. Market Depth data restarted. | 2023-02-07 09:24:31.936 Teton CME Order Routing | Network connection to server complete. | 2023-02-07 09:24:32.201 Teton CME Order Routing | Starting socket receive thread. | 2023-02-07 09:24:32.201 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-07 09:24:32.201 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-02-07 09:24:32.473 Teton CME Order Routing | Sending logon request message. | 2023-02-07 09:24:32.473 Denali Data Feed | Clearing market depth for 6EH23_FUT_CME | 2023-02-07 09:24:33.208 Denali Data Feed | Real-time data for symbol 6EH21_FUT_CME is currently unavailable. | 2023-02-07 09:24:33.208 Denali Data Feed | Received security definition for symbol 6EH21_FUT_CME | 2023-02-07 09:24:33.208 Denali Data Feed | Received security definition for symbol 6EH23_FUT_CME | 2023-02-07 09:24:33.208 Denali Data Feed | Clearing market depth for CLH23_FUT_CME | 2023-02-07 09:24:33.208 Denali Data Feed | Real-time data for symbol CLG23_FUT_CME is currently unavailable. | 2023-02-07 09:24:33.208 Denali Data Feed | Received security definition for symbol CLG23_FUT_CME | 2023-02-07 09:24:33.208 Denali Data Feed | Received security definition for symbol CLH23_FUT_CME | 2023-02-07 09:24:33.208 Denali Data Feed | Clearing market depth for ESH23_FUT_CME | 2023-02-07 09:24:33.208 Denali Data Feed | Real-time data for symbol ESH21_FUT_CME is currently unavailable. | 2023-02-07 09:24:33.208 Denali Data Feed | Received security definition for symbol ESH21_FUT_CME | 2023-02-07 09:24:33.209 Denali Data Feed | Received security definition for symbol ESH23_FUT_CME | 2023-02-07 09:24:33.209 Denali Data Feed | Clearing market depth for GCJ23_FUT_CME | 2023-02-07 09:24:33.209 Denali Data Feed | Clearing market depth for NQH23_FUT_CME | 2023-02-07 09:24:33.209 Denali Data Feed | Clearing market depth for RTYH23_FUT_CME | 2023-02-07 09:24:33.209 Denali Data Feed | Clearing market depth for TNH23_FUT_CME | 2023-02-07 09:24:33.209 Denali Data Feed | Clearing market depth for UBH23_FUT_CME | 2023-02-07 09:24:33.209 Denali Data Feed | Clearing market depth for YMH23_FUT_CME | 2023-02-07 09:24:33.210 Denali Data Feed | Clearing market depth for ZBH23_FUT_CME | 2023-02-07 09:24:33.210 Denali Data Feed | Clearing market depth for ZFH23_FUT_CME | 2023-02-07 09:24:33.210 Denali Data Feed | Clearing market depth for ZNH23_FUT_CME | 2023-02-07 09:24:33.210 Denali Data Feed | Real-time data for symbol ESM20_FUT_CME is currently unavailable. | 2023-02-07 09:24:33.212 Denali Data Feed | Received security definition for symbol ESM20_FUT_CME | 2023-02-07 09:24:33.212 Denali Data Feed | Real-time data for symbol ESU20_FUT_CME is currently unavailable. | 2023-02-07 09:24:33.212 Denali Data Feed | Received security definition for symbol ESU20_FUT_CME | 2023-02-07 09:24:33.212 Denali Data Feed | Real-time data for symbol GCG21_FUT_CME is currently unavailable. | 2023-02-07 09:24:33.212 Denali Data Feed | Received security definition for symbol GCG21_FUT_CME | 2023-02-07 09:24:33.212 Denali Data Feed | Received security definition for symbol GCG23_FUT_CME | 2023-02-07 09:24:33.212 Denali Data Feed | Received security definition for symbol GCJ23_FUT_CME | 2023-02-07 09:24:33.212 Denali Data Feed | Received security definition for symbol NQH23_FUT_CME | 2023-02-07 09:24:33.213 Denali Data Feed | Received security definition for symbol RTYH23_FUT_CME | 2023-02-07 09:24:33.213 Denali Data Feed | Received security definition for symbol TNH23_FUT_CME | 2023-02-07 09:24:33.213 Denali Data Feed | Received security definition for symbol UBH23_FUT_CME | 2023-02-07 09:24:33.213 Denali Data Feed | Received security definition for symbol YMH23_FUT_CME | 2023-02-07 09:24:33.213 Denali Data Feed | Received security definition for symbol ZBH23_FUT_CME | 2023-02-07 09:24:33.213 Denali Data Feed | Received security definition for symbol ZFH23_FUT_CME | 2023-02-07 09:24:33.213 Denali Data Feed | Received security definition for symbol ZNH23_FUT_CME | 2023-02-07 09:24:33.213 Teton CME Order Routing | Received logon response. | 2023-02-07 09:24:33.350 Teton CME Order Routing | Server Name: SC Realtime Server. | 2023-02-07 09:24:33.350 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-02-07 09:24:33.350 Teton CME Order Routing | Successfully connected. | 2023-02-07 09:24:33.350 Teton CME Order Routing | Trading is not supported. | 2023-02-07 09:24:33.350 Teton CME Order Routing | Starting market orders updates for: 6EH23. MinimumMarketByOrderQuantity: 0. Service code: cme | 2023-02-07 09:24:33.350 Teton CME Order Routing | Restarting market orders data for symbol: 6EH23_FUT_CME -> 6EH23 | 2023-02-07 09:24:33.350 Teton CME Order Routing | Starting market orders updates for: CLH23. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2023-02-07 09:24:33.350 Teton CME Order Routing | Restarting market orders data for symbol: CLH23_FUT_CME -> CLH23 | 2023-02-07 09:24:33.350 Teton CME Order Routing | Starting market orders updates for: ESH23. MinimumMarketByOrderQuantity: 0. Service code: cme | 2023-02-07 09:24:33.350 Teton CME Order Routing | Restarting market orders data for symbol: ESH23_FUT_CME -> ESH23 | 2023-02-07 09:24:33.350 Teton CME Order Routing | Starting market orders updates for: GCJ23. MinimumMarketByOrderQuantity: 0. Service code: comex | 2023-02-07 09:24:33.350 Teton CME Order Routing | Restarting market orders data for symbol: GCJ23_FUT_CME -> GCJ23 | 2023-02-07 09:24:33.350 Teton CME Order Routing | Starting market orders updates for: NQH23. MinimumMarketByOrderQuantity: 0. Service code: cme | 2023-02-07 09:24:33.350 Teton CME Order Routing | Restarting market orders data for symbol: NQH23_FUT_CME -> NQH23 | 2023-02-07 09:24:33.350 Teton CME Order Routing | Starting market orders updates for: RTYH23. MinimumMarketByOrderQuantity: 0. Service code: cme | 2023-02-07 09:24:33.350 Teton CME Order Routing | Restarting market orders data for symbol: RTYH23_FUT_CME -> RTYH23 | 2023-02-07 09:24:33.350 Teton CME Order Routing | Starting market orders updates for: TNH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:24:33.350 Teton CME Order Routing | Restarting market orders data for symbol: TNH23_FUT_CME -> TNH23 | 2023-02-07 09:24:33.350 Teton CME Order Routing | Starting market orders updates for: UBH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:24:33.350 Teton CME Order Routing | Restarting market orders data for symbol: UBH23_FUT_CME -> UBH23 | 2023-02-07 09:24:33.350 Teton CME Order Routing | Starting market orders updates for: YMH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:24:33.350 Teton CME Order Routing | Restarting market orders data for symbol: YMH23_FUT_CME -> YMH23 | 2023-02-07 09:24:33.350 Teton CME Order Routing | Starting market orders updates for: ZBH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:24:33.350 Teton CME Order Routing | Restarting market orders data for symbol: ZBH23_FUT_CME -> ZBH23 | 2023-02-07 09:24:33.350 Teton CME Order Routing | Starting market orders updates for: ZFH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:24:33.350 Teton CME Order Routing | Restarting market orders data for symbol: ZFH23_FUT_CME -> ZFH23 | 2023-02-07 09:24:33.350 Teton CME Order Routing | Starting market orders updates for: ZNH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:24:33.350 Teton CME Order Routing | Restarting market orders data for symbol: ZNH23_FUT_CME -> ZNH23 | 2023-02-07 09:24:33.350 Teton CME Order Routing | Market Orders data has been rejected for symbol: 6EH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:24:33.715 Teton CME Order Routing | Market Orders data has been rejected for symbol: CLH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:24:33.715 Teton CME Order Routing | Market Orders data has been rejected for symbol: ESH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:24:33.715 Teton CME Order Routing | Market Orders data has been rejected for symbol: GCJ23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:24:33.715 Teton CME Order Routing | Market Orders data has been rejected for symbol: NQH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:24:33.715 Teton CME Order Routing | Market Orders data has been rejected for symbol: RTYH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:24:33.715 Teton CME Order Routing | Market Orders data has been rejected for symbol: TNH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:24:33.715 Teton CME Order Routing | Market Orders data has been rejected for symbol: UBH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:24:33.715 Teton CME Order Routing | Market Orders data has been rejected for symbol: YMH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:24:33.715 Teton CME Order Routing | Market Orders data has been rejected for symbol: ZBH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:24:33.715 Teton CME Order Routing | Market Orders data has been rejected for symbol: ZFH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:24:33.715 Teton CME Order Routing | Market Orders data has been rejected for symbol: ZNH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:24:33.715 Updated verified funded futures trading account ending date to: 2023-03-09 17:24:36 | 2023-02-07 09:24:36.325 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6EH23_FUT_CME | 2023-02-07 09:24:36.325 Teton CME Order Routing | Received security definition for symbol 6EH23_FUT_CME | 2023-02-07 09:24:36.325 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: RTYH23_FUT_CME | 2023-02-07 09:24:36.325 Teton CME Order Routing | Received security definition for symbol RTYH23_FUT_CME | 2023-02-07 09:24:36.325 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: YMH23_FUT_CME | 2023-02-07 09:24:36.325 Teton CME Order Routing | Received security definition for symbol YMH23_FUT_CME | 2023-02-07 09:24:36.325 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: CLH23_FUT_CME | 2023-02-07 09:24:36.325 Teton CME Order Routing | Received security definition for symbol CLH23_FUT_CME | 2023-02-07 09:24:36.325 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: GCJ23_FUT_CME | 2023-02-07 09:24:36.325 Teton CME Order Routing | Received security definition for symbol GCJ23_FUT_CME | 2023-02-07 09:24:36.325 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZFH23_FUT_CME | 2023-02-07 09:24:36.325 Teton CME Order Routing | Received security definition for symbol ZFH23_FUT_CME | 2023-02-07 09:24:36.325 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH23_FUT_CME | 2023-02-07 09:24:36.325 Teton CME Order Routing | Received security definition for symbol ESH23_FUT_CME | 2023-02-07 09:24:36.325 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: UBH23_FUT_CME | 2023-02-07 09:24:36.325 Teton CME Order Routing | Received security definition for symbol UBH23_FUT_CME | 2023-02-07 09:24:36.325 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQH23_FUT_CME | 2023-02-07 09:24:36.325 Teton CME Order Routing | Received security definition for symbol NQH23_FUT_CME | 2023-02-07 09:24:36.325 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: GCG23_FUT_CME | 2023-02-07 09:24:37.945 Teton CME Order Routing | Received security definition for symbol GCG23_FUT_CME | 2023-02-07 09:24:37.945 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: CLG23_FUT_CME | 2023-02-07 09:24:37.945 Teton CME Order Routing | Received security definition for symbol CLG23_FUT_CME | 2023-02-07 09:24:37.945 HD Request # 18 | Downloading Intraday chart data for ZNH23_FUT_CME to the file ZNH23_FUT_CME.scid. Service: cbot | 2023-02-07 09:24:38.442 HD Request # 18 | Download start date-time: 2022-11-14 16:00:00.000000. File last date-time: 2023-02-07 09:16:21.172004 | 2023-02-07 09:24:38.443 HD Request # 18 | Disabling Intraday chart updating for symbol. | 2023-02-07 09:24:38.443 HD Request # 18 | Using server: ds26.sierracharts.com port 10149 | 2023-02-07 09:24:38.443 Socket (8) | Creating socket. | 2023-02-07 09:24:38.443 Socket (8) | New receive buffer size: 5242880 | 2023-02-07 09:24:38.443 Socket (8) | Connecting to IP: 142.215.17.188. | 2023-02-07 09:24:38.443 HD Request # 18 | Setting DTC encoding to Binary VLS | 2023-02-07 09:24:38.867 HD Request # 18 | Sending historical data logon request message. | 2023-02-07 09:24:38.867 HD Request # 18 | Requesting Intraday data. Start date-time: 2022-11-14 16:00:00. Record interval: 0. Symbol: ZNH23 | 2023-02-07 09:24:39.587 HD Request # 18 | Decompressing data. | 2023-02-07 09:24:39.805 HD Request # 18 | Receiving Intraday data for ZNH23_FUT_CME starting at 2022-11-14 16:20:06.153000 | 2023-02-07 09:24:40.245 HD Request # 18 | Truncating file to starting date-time of 2022-11-14 16:20:06.153. | 2023-02-07 09:24:40.245 HD Request # 18 | Timestamp of first Intraday data file record written: 2022-11-14 16:20:06.153000. | 2023-02-07 09:24:40.461 Teton CME Order Routing | There has been no activity on the network socket for 45s. Will reconnect. | 2023-02-07 09:25:22.580 Connection to the external service has been lost. | 2023-02-07 09:25:22.580 Teton CME Order Routing | Waiting for socket receive thread to end | 2023-02-07 09:25:22.661 DTC Client socket (7) | CloseSocket call. | 2023-02-07 09:25:22.661 DTC Client socket (7) | Max send buffers used during socket life: 6 | 2023-02-07 09:25:22.661 DTC Client socket (7) | Max send buffer size during socket life: 799 | 2023-02-07 09:25:22.661 DTC Client socket (7) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:25:22.661 Teton CME Order Routing | Disconnected. | 2023-02-07 09:25:22.661 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-07 09:25:22.661 Teton CME Order Routing | Firm: Dorman | 2023-02-07 09:25:24.642 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-02-07 09:25:24.642 DTC Client socket (9) | Creating socket. Using TLS 1.2. | 2023-02-07 09:25:24.642 DTC Client socket (9) | New receive buffer size: 5242880 | 2023-02-07 09:25:24.643 DTC Client socket (9) | Connecting to IP: 208.185.224.129. | 2023-02-07 09:25:24.643 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-02-07 09:25:38.491 DTC Client socket (1) | Closed. | 2023-02-07 09:25:38.491 DTC Client socket (9) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2023-02-07 09:25:45.700 * DTC Client socket (9) | CloseSocket call. | 2023-02-07 09:25:45.704 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-07 09:25:45.704 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-07 09:25:45.704 DTC Client socket (9) | Closed. | 2023-02-07 09:25:45.704 DTC Client socket (0) | CloseSocket call. | 2023-02-07 09:25:45.741 Teton CME Order Routing | Disconnected. | 2023-02-07 09:25:45.741 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-07 09:25:45.741 Teton CME Order Routing | Firm: Dorman | 2023-02-07 09:25:47.755 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-02-07 09:25:47.755 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-02-07 09:25:47.756 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-02-07 09:25:47.756 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2023-02-07 09:25:47.756 Socket (8) | CloseSocket call. | 2023-02-07 09:25:56.895 Socket (8) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:25:56.895 Historical data download thread signaled to stop. | 2023-02-07 09:25:56.911 HD Request # 18 | Received 12940490 Intraday data records from 2022-11-14 16:20:06.153000 to 2023-02-07 09:25:54.980002 (84.7 days) and wrote 12940490 records for ZNH23_FUT_CME | 2023-02-07 09:25:56.912 HD Request # 18 | Completion time: 1m 18s. | 2023-02-07 09:25:56.912 HD Request # 18 | Intraday data download complete for ZNH23_FUT_CME. Unique request ID: 13 | 2023-02-07 09:25:56.912 Removing historical data download ID 13. | 2023-02-07 09:25:56.912 Real-time Intraday chart data file updates started for ZNH23_FUT_CME | 2023-02-07 09:25:56.912 Intraday chart data file opened for ZNH23_FUT_CME | 2023-02-07 09:25:56.912 HD Request # 18 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:25:56.912 ZNH23_FUT_CME [CV] #27 | Flagging to reload Intraday data on download completion. | 2023-02-07 09:25:56.914 Triggering next historical data download in queue. | 2023-02-07 09:25:56.914 HD Request # 19 | Downloading Intraday chart data for TNH23_FUT_CME to the file TNH23_FUT_CME.scid. Service: cbot | 2023-02-07 09:25:56.914 HD Request # 19 | Download start date-time: 2022-11-14 16:00:00.000000. File last date-time: 2023-02-07 09:16:36.716002 | 2023-02-07 09:25:56.914 HD Request # 19 | Disabling Intraday chart updating for symbol. | 2023-02-07 09:25:56.914 HD Request # 19 | Using server: ds28.sierracharts.com port 10150 | 2023-02-07 09:25:56.914 Socket (9) | Creating socket. | 2023-02-07 09:25:56.914 Socket (9) | New receive buffer size: 5242880 | 2023-02-07 09:25:56.915 Socket (9) | Connecting to IP: 142.215.18.147. | 2023-02-07 09:25:56.915 ZNH23_FUT_CME [CV] #27 | Reloading chart. | 2023-02-07 09:25:56.934 ZNH23_FUT_CME [CV] #27 | StartDateTimeForLoadingOrderFills: 2023-02-06 17:00:00 | 2023-02-07 09:25:56.965 Teton CME Order Routing | Network connection to server complete. | 2023-02-07 09:25:57.005 Teton CME Order Routing | Starting socket receive thread. | 2023-02-07 09:25:57.005 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-02-07 09:25:57.005 Socket (8) | Socket gracefully closed by remote side. | 2023-02-07 09:25:57.132 Socket (8) | Closed. | 2023-02-07 09:25:57.132 HD Request # 19 | Setting DTC encoding to Binary VLS | 2023-02-07 09:25:57.396 HD Request # 19 | Sending historical data logon request message. | 2023-02-07 09:25:57.396 HD Request # 19 | Requesting Intraday data. Start date-time: 2022-11-14 16:00:00. Record interval: 0. Symbol: TNH23 | 2023-02-07 09:25:58.147 HD Request # 19 | Decompressing data. | 2023-02-07 09:25:58.380 HD Request # 19 | Receiving Intraday data for TNH23_FUT_CME starting at 2022-11-14 18:16:53.158000 | 2023-02-07 09:25:59.090 HD Request # 19 | Truncating file to starting date-time of 2022-11-14 18:16:53.158. | 2023-02-07 09:25:59.090 HD Request # 19 | Timestamp of first Intraday data file record written: 2022-11-14 18:16:53.158000. | 2023-02-07 09:25:59.798 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-02-07 09:26:00.635 Teton CME Order Routing | Sending logon request message. | 2023-02-07 09:26:00.635 Teton CME Order Routing | Received logon response. | 2023-02-07 09:26:01.348 Teton CME Order Routing | Server Name: SC DTC Server. Build=44641. | 2023-02-07 09:26:01.348 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-02-07 09:26:01.348 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2023-02-07 09:26:01.348 Teton CME Order Routing | Trading is supported. | 2023-02-07 09:26:01.348 Teton CME Order Routing | Order cancel and replace is supported. | 2023-02-07 09:26:01.348 Teton CME Order Routing | OCO Orders supported. | 2023-02-07 09:26:01.348 Teton CME Order Routing | Bracket Orders supported. | 2023-02-07 09:26:01.348 Teton CME Order Routing | Connected to server complete. | 2023-02-07 09:26:01.348 Teton CME Order Routing | Waiting for socket receive thread to end | 2023-02-07 09:26:01.348 DTC Client socket (6) | CloseSocket call. | 2023-02-07 09:26:01.348 DTC Client socket (6) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:26:01.348 Teton CME Order Routing | Disconnected from the server. | 2023-02-07 09:26:01.348 Denali Data Feed | Waiting for socket receive thread to end | 2023-02-07 09:26:01.348 DTC Client socket (5) | CloseSocket call. | 2023-02-07 09:26:01.349 DTC Client socket (5) | Max send buffers used during socket life: 4 | 2023-02-07 09:26:01.349 DTC Client socket (5) | Max send buffer size during socket life: 1793 | 2023-02-07 09:26:01.349 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:26:01.349 Denali Data Feed | Disconnected from the server. | 2023-02-07 09:26:01.349 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\ZNH23_FUT_CME.scid. Thread ID: 17176 | 2023-02-07 09:26:01.349 Triggering next historical data download in queue. | 2023-02-07 09:26:01.349 Triggering next historical data download in queue. | 2023-02-07 09:26:01.349 Triggering next historical data download in queue. | 2023-02-07 09:26:01.349 Triggering next historical data download in queue. | 2023-02-07 09:26:01.349 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:26:01.349 Mapping ESM20_FUT_CME to ESM20. Service code: cme | 2023-02-07 09:26:01.349 Using symbol data fast lookup vector | 2023-02-07 09:26:01.349 Denali Data Feed | Starting real-time market data updates for: ESM20_FUT_CME (ESM20). ID: 1 Service code: cme | 2023-02-07 09:26:01.349 Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 10048 | 2023-02-07 09:26:01.349 Denali Data Feed | Requesting security definition data for: ESM20_FUT_CME (ESM20). ID: 1 | 2023-02-07 09:26:01.349 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:26:01.349 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:26:01.349 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:26:01.349 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:26:01.349 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:26:01.349 Subscribing to symbol for symbol alert. ESU20_FUT_CME | 2023-02-07 09:26:01.349 Mapping ESU20_FUT_CME to ESU20. Service code: cme | 2023-02-07 09:26:01.349 Denali Data Feed | Starting real-time market data updates for: ESU20_FUT_CME (ESU20). ID: 2 Service code: cme | 2023-02-07 09:26:01.349 Denali Data Feed | Requesting security definition data for: ESU20_FUT_CME (ESU20). ID: 2 | 2023-02-07 09:26:01.349 Subscribing to symbol for symbol alert. GCG21_FUT_CME | 2023-02-07 09:26:01.349 Mapping GCG21_FUT_CME to GCG21. Service code: comex | 2023-02-07 09:26:01.349 Denali Data Feed | Starting real-time market data updates for: GCG21_FUT_CME (GCG21). ID: 3 Service code: comex | 2023-02-07 09:26:01.349 Denali Data Feed | Requesting security definition data for: GCG21_FUT_CME (GCG21). ID: 3 | 2023-02-07 09:26:01.349 Subscribing to symbol for symbol alert. 6EH21_FUT_CME | 2023-02-07 09:26:01.349 Mapping 6EH21_FUT_CME to 6EH21. Service code: cme | 2023-02-07 09:26:01.349 Denali Data Feed | Starting real-time market data updates for: 6EH21_FUT_CME (6EH21). ID: 4 Service code: cme | 2023-02-07 09:26:01.349 DTC Client socket (8) | Creating socket. | 2023-02-07 09:26:01.349 Denali Data Feed | Requesting security definition data for: 6EH21_FUT_CME (6EH21). ID: 4 | 2023-02-07 09:26:01.349 Subscribing to symbol for symbol alert. ESH21_FUT_CME | 2023-02-07 09:26:01.349 DTC Client socket (8) | New receive buffer size: 5242880 | 2023-02-07 09:26:01.349 Mapping ESH21_FUT_CME to ESH21. Service code: cme | 2023-02-07 09:26:01.349 DTC Client socket (8) | Connecting to IP: 142.215.17.188. | 2023-02-07 09:26:01.349 Denali Data Feed | Starting real-time market data updates for: ESH21_FUT_CME (ESH21). ID: 5 Service code: cme | 2023-02-07 09:26:01.349 Denali Data Feed | Requesting security definition data for: ESH21_FUT_CME (ESH21). ID: 5 | 2023-02-07 09:26:01.349 Subscribing to symbol for symbol alert. ESH21_FUT_CME | 2023-02-07 09:26:01.349 Updated verified funded futures trading account ending date to: 2023-03-09 17:26:01 | 2023-02-07 09:26:01.350 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2023-02-07 09:26:01.414 DTC Client socket (8) | CloseSocket call. | 2023-02-07 09:26:01.414 Denali Data Feed | Disconnected from the server. | 2023-02-07 09:26:01.414 Denali Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-02-07 09:26:01.414 No download requests in the queue to start downloads for. | 2023-02-07 09:26:01.414 No download requests in the queue to start downloads for. | 2023-02-07 09:26:01.414 DTC Client socket (8) | Closed. | 2023-02-07 09:26:01.414 No download requests in the queue to start downloads for. | 2023-02-07 09:26:01.414 Mapping ZNH23_FUT_CME to ZNH23. Service code: cbot | 2023-02-07 09:26:01.427 Denali Data Feed | Starting real-time market data updates for: ZNH23_FUT_CME (ZNH23). ID: 6 Service code: cbot | 2023-02-07 09:26:01.427 Denali Data Feed | Requesting security definition data for: ZNH23_FUT_CME (ZNH23). ID: 6 | 2023-02-07 09:26:01.427 Added historical Intraday data request for ZNH23_FUT_CME to the queue. | 2023-02-07 09:26:01.427 Intraday data recording state for symbol ZNH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:26:01.427 Triggering next historical data download in queue. | 2023-02-07 09:26:01.427 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2023-02-07 15:03:49.033833 | 2023-02-07 09:26:01.430 Mapping ZBH23_FUT_CME to ZBH23. Service code: cbot | 2023-02-07 09:26:01.430 Denali Data Feed | Starting real-time market data updates for: ZBH23_FUT_CME (ZBH23). ID: 7 Service code: cbot | 2023-02-07 09:26:01.430 Denali Data Feed | Requesting security definition data for: ZBH23_FUT_CME (ZBH23). ID: 7 | 2023-02-07 09:26:01.430 Mapping ZFH23_FUT_CME to ZFH23. Service code: cbot | 2023-02-07 09:26:01.432 Denali Data Feed | Starting real-time market data updates for: ZFH23_FUT_CME (ZFH23). ID: 8 Service code: cbot | 2023-02-07 09:26:01.432 Denali Data Feed | Requesting security definition data for: ZFH23_FUT_CME (ZFH23). ID: 8 | 2023-02-07 09:26:01.432 Mapping ESH23_FUT_CME to ESH23. Service code: cme | 2023-02-07 09:26:01.433 Denali Data Feed | Starting real-time market data updates for: ESH23_FUT_CME (ESH23). ID: 9 Service code: cme | 2023-02-07 09:26:01.433 Denali Data Feed | Requesting security definition data for: ESH23_FUT_CME (ESH23). ID: 9 | 2023-02-07 09:26:01.433 Mapping UBH23_FUT_CME to UBH23. Service code: cbot | 2023-02-07 09:26:01.438 Denali Data Feed | Starting real-time market data updates for: UBH23_FUT_CME (UBH23). ID: 10 Service code: cbot | 2023-02-07 09:26:01.438 Denali Data Feed | Requesting security definition data for: UBH23_FUT_CME (UBH23). ID: 10 | 2023-02-07 09:26:01.438 Mapping NQH23_FUT_CME to NQH23. Service code: cme | 2023-02-07 09:26:01.440 Denali Data Feed | Starting real-time market data updates for: NQH23_FUT_CME (NQH23). ID: 11 Service code: cme | 2023-02-07 09:26:01.440 Denali Data Feed | Requesting security definition data for: NQH23_FUT_CME (NQH23). ID: 11 | 2023-02-07 09:26:01.440 Mapping 6EH23_FUT_CME to 6EH23. Service code: cme | 2023-02-07 09:26:01.446 Denali Data Feed | Starting real-time market data updates for: 6EH23_FUT_CME (6EH23). ID: 12 Service code: cme | 2023-02-07 09:26:01.446 Denali Data Feed | Requesting security definition data for: 6EH23_FUT_CME (6EH23). ID: 12 | 2023-02-07 09:26:01.446 Mapping RTYH23_FUT_CME to RTYH23. Service code: cme | 2023-02-07 09:26:01.448 Denali Data Feed | Starting real-time market data updates for: RTYH23_FUT_CME (RTYH23). ID: 13 Service code: cme | 2023-02-07 09:26:01.449 Denali Data Feed | Requesting security definition data for: RTYH23_FUT_CME (RTYH23). ID: 13 | 2023-02-07 09:26:01.449 Mapping YMH23_FUT_CME to YMH23. Service code: cbot | 2023-02-07 09:26:01.451 Denali Data Feed | Starting real-time market data updates for: YMH23_FUT_CME (YMH23). ID: 14 Service code: cbot | 2023-02-07 09:26:01.451 Denali Data Feed | Requesting security definition data for: YMH23_FUT_CME (YMH23). ID: 14 | 2023-02-07 09:26:01.451 Mapping CLH23_FUT_CME to CLH23. Service code: nymex | 2023-02-07 09:26:01.456 Denali Data Feed | Starting real-time market data updates for: CLH23_FUT_CME (CLH23). ID: 15 Service code: nymex | 2023-02-07 09:26:01.456 Denali Data Feed | Requesting security definition data for: CLH23_FUT_CME (CLH23). ID: 15 | 2023-02-07 09:26:01.456 Mapping GCJ23_FUT_CME to GCJ23. Service code: comex | 2023-02-07 09:26:01.492 Denali Data Feed | Starting real-time market data updates for: GCJ23_FUT_CME (GCJ23). ID: 16 Service code: comex | 2023-02-07 09:26:01.492 Denali Data Feed | Requesting security definition data for: GCJ23_FUT_CME (GCJ23). ID: 16 | 2023-02-07 09:26:01.492 Mapping GCG23_FUT_CME to GCG23. Service code: comex | 2023-02-07 09:26:01.513 Denali Data Feed | Starting real-time market data updates for: GCG23_FUT_CME (GCG23). ID: 17 Service code: comex | 2023-02-07 09:26:01.513 Denali Data Feed | Requesting security definition data for: GCG23_FUT_CME (GCG23). ID: 17 | 2023-02-07 09:26:01.513 Mapping CLG23_FUT_CME to CLG23. Service code: nymex | 2023-02-07 09:26:01.514 Denali Data Feed | Starting real-time market data updates for: CLG23_FUT_CME (CLG23). ID: 18 Service code: nymex | 2023-02-07 09:26:01.514 Denali Data Feed | Requesting security definition data for: CLG23_FUT_CME (CLG23). ID: 18 | 2023-02-07 09:26:01.514 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESM20_FUT_CME | 2023-02-07 09:26:01.584 Teton CME Order Routing | Received security definition for symbol ESM20_FUT_CME | 2023-02-07 09:26:01.584 DTC Client socket (6) | Socket gracefully closed by remote side. | 2023-02-07 09:26:01.589 DTC Client socket (6) | Closed. | 2023-02-07 09:26:01.589 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESU20_FUT_CME | 2023-02-07 09:26:03.359 Teton CME Order Routing | Received security definition for symbol ESU20_FUT_CME | 2023-02-07 09:26:03.359 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: GCG21_FUT_CME | 2023-02-07 09:26:03.359 Teton CME Order Routing | Received security definition for symbol GCG21_FUT_CME | 2023-02-07 09:26:03.359 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6EH21_FUT_CME | 2023-02-07 09:26:03.359 Teton CME Order Routing | Received security definition for symbol 6EH21_FUT_CME | 2023-02-07 09:26:03.359 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH21_FUT_CME | 2023-02-07 09:26:03.359 Teton CME Order Routing | Received security definition for symbol ESH21_FUT_CME | 2023-02-07 09:26:03.359 Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048 | 2023-02-07 09:26:03.411 DTC Client socket (6) | Creating socket. | 2023-02-07 09:26:03.411 DTC Client socket (6) | New receive buffer size: 5242880 | 2023-02-07 09:26:03.411 DTC Client socket (6) | Connecting to IP: 142.215.18.148. | 2023-02-07 09:26:03.411 DTC Client socket (4) | Timed out waiting for shutdown. Performing an immediate socket close. | 2023-02-07 09:26:03.568 DTC Client socket (4) | Closed. | 2023-02-07 09:26:03.568 Denali Data Feed | Network connection to server complete. | 2023-02-07 09:26:03.653 Denali Data Feed | Starting socket receive thread. | 2023-02-07 09:26:03.653 Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-07 09:26:03.653 Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-02-07 09:26:03.921 Denali Data Feed | Sending logon request message. | 2023-02-07 09:26:03.921 Denali Data Feed | Received logon response. | 2023-02-07 09:26:04.911 Denali Data Feed | Server Name: SC Realtime Server. | 2023-02-07 09:26:04.911 Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-02-07 09:26:04.911 Denali Data Feed | Successfully connected. | 2023-02-07 09:26:04.911 Denali Data Feed | Trading is not supported. | 2023-02-07 09:26:04.911 Denali Data Feed | Restarting real-time data updates for symbol: 6EH21_FUT_CME -> 6EH21 | 2023-02-07 09:26:04.911 Denali Data Feed | Restarting real-time data updates for symbol: 6EH23_FUT_CME -> 6EH23 | 2023-02-07 09:26:04.911 Denali Data Feed | Restarting real-time data updates for symbol: CLG23_FUT_CME -> CLG23 | 2023-02-07 09:26:04.911 Denali Data Feed | Restarting real-time data updates for symbol: CLH23_FUT_CME -> CLH23 | 2023-02-07 09:26:04.911 Denali Data Feed | Restarting real-time data updates for symbol: ESH21_FUT_CME -> ESH21 | 2023-02-07 09:26:04.911 Denali Data Feed | Restarting real-time data updates for symbol: ESH23_FUT_CME -> ESH23 | 2023-02-07 09:26:04.911 Denali Data Feed | Restarting real-time data updates for symbol: ESM20_FUT_CME -> ESM20 | 2023-02-07 09:26:04.911 Denali Data Feed | Restarting real-time data updates for symbol: ESU20_FUT_CME -> ESU20 | 2023-02-07 09:26:04.911 Denali Data Feed | Restarting real-time data updates for symbol: GCG21_FUT_CME -> GCG21 | 2023-02-07 09:26:04.911 Denali Data Feed | Restarting real-time data updates for symbol: GCG23_FUT_CME -> GCG23 | 2023-02-07 09:26:04.911 Denali Data Feed | Restarting real-time data updates for symbol: GCJ23_FUT_CME -> GCJ23 | 2023-02-07 09:26:04.911 Denali Data Feed | Restarting real-time data updates for symbol: NQH23_FUT_CME -> NQH23 | 2023-02-07 09:26:04.911 Denali Data Feed | Restarting real-time data updates for symbol: RTYH23_FUT_CME -> RTYH23 | 2023-02-07 09:26:04.911 Denali Data Feed | Restarting real-time data updates for symbol: UBH23_FUT_CME -> UBH23 | 2023-02-07 09:26:04.911 Denali Data Feed | Restarting real-time data updates for symbol: YMH23_FUT_CME -> YMH23 | 2023-02-07 09:26:04.911 Denali Data Feed | Restarting real-time data updates for symbol: ZBH23_FUT_CME -> ZBH23 | 2023-02-07 09:26:04.911 Denali Data Feed | Restarting real-time data updates for symbol: ZFH23_FUT_CME -> ZFH23 | 2023-02-07 09:26:04.911 Denali Data Feed | Restarting real-time data updates for symbol: ZNH23_FUT_CME -> ZNH23 | 2023-02-07 09:26:04.911 Denali Data Feed | Real-time data for symbol 6EH21_FUT_CME is currently unavailable. | 2023-02-07 09:26:05.499 Denali Data Feed | Received security definition for symbol 6EH21_FUT_CME | 2023-02-07 09:26:05.499 Denali Data Feed | Received security definition for symbol 6EH23_FUT_CME | 2023-02-07 09:26:05.499 Denali Data Feed | Real-time data for symbol CLG23_FUT_CME is currently unavailable. | 2023-02-07 09:26:05.499 Denali Data Feed | Received security definition for symbol CLG23_FUT_CME | 2023-02-07 09:26:05.499 Denali Data Feed | Received security definition for symbol CLH23_FUT_CME | 2023-02-07 09:26:05.499 Denali Data Feed | Real-time data for symbol ESH21_FUT_CME is currently unavailable. | 2023-02-07 09:26:05.499 Denali Data Feed | Received security definition for symbol ESH21_FUT_CME | 2023-02-07 09:26:05.499 Denali Data Feed | Received security definition for symbol ESH23_FUT_CME | 2023-02-07 09:26:05.499 Denali Data Feed | Real-time data for symbol ESM20_FUT_CME is currently unavailable. | 2023-02-07 09:26:05.499 Denali Data Feed | Received security definition for symbol ESM20_FUT_CME | 2023-02-07 09:26:05.499 Denali Data Feed | Real-time data for symbol ESU20_FUT_CME is currently unavailable. | 2023-02-07 09:26:05.499 Denali Data Feed | Received security definition for symbol ESU20_FUT_CME | 2023-02-07 09:26:05.499 Denali Data Feed | Real-time data for symbol GCG21_FUT_CME is currently unavailable. | 2023-02-07 09:26:05.499 Denali Data Feed | Received security definition for symbol GCG21_FUT_CME | 2023-02-07 09:26:05.499 Denali Data Feed | Received security definition for symbol GCG23_FUT_CME | 2023-02-07 09:26:05.499 Denali Data Feed | Received security definition for symbol GCJ23_FUT_CME | 2023-02-07 09:26:05.500 Denali Data Feed | Received security definition for symbol NQH23_FUT_CME | 2023-02-07 09:26:05.501 Denali Data Feed | Received security definition for symbol RTYH23_FUT_CME | 2023-02-07 09:26:05.501 Denali Data Feed | Received security definition for symbol UBH23_FUT_CME | 2023-02-07 09:26:05.501 Denali Data Feed | Received security definition for symbol YMH23_FUT_CME | 2023-02-07 09:26:05.501 Denali Data Feed | Received security definition for symbol ZBH23_FUT_CME | 2023-02-07 09:26:05.501 Denali Data Feed | Received security definition for symbol ZFH23_FUT_CME | 2023-02-07 09:26:05.501 Denali Data Feed | Received security definition for symbol ZNH23_FUT_CME | 2023-02-07 09:26:05.501 Requesting market depth updates for: 6EH23_FUT_CME if supported. | 2023-02-07 09:26:06.379 Teton CME Order Routing | Connecting to the server ds28-2.sierracharts.com. Port 10060 | 2023-02-07 09:26:06.380 DTC Client socket (8) | Creating socket. | 2023-02-07 09:26:06.381 DTC Client socket (8) | New receive buffer size: 5242880 | 2023-02-07 09:26:06.381 DTC Client socket (8) | Connecting to IP: 142.215.18.148. | 2023-02-07 09:26:06.381 Requesting market depth updates for: CLH23_FUT_CME if supported. | 2023-02-07 09:26:06.381 Requesting market depth updates for: ESH23_FUT_CME if supported. | 2023-02-07 09:26:06.381 Requesting market depth updates for: GCJ23_FUT_CME if supported. | 2023-02-07 09:26:06.381 Requesting market depth updates for: NQH23_FUT_CME if supported. | 2023-02-07 09:26:06.381 Requesting market depth updates for: RTYH23_FUT_CME if supported. | 2023-02-07 09:26:06.381 Mapping TNH23_FUT_CME to TNH23. Service code: cbot | 2023-02-07 09:26:06.381 Denali Data Feed | Starting real-time market data updates for: TNH23_FUT_CME (TNH23). ID: 19 Service code: cbot | 2023-02-07 09:26:06.381 Denali Data Feed | Requesting security definition data for: TNH23_FUT_CME (TNH23). ID: 19 | 2023-02-07 09:26:06.381 Requesting market depth updates for: TNH23_FUT_CME if supported. | 2023-02-07 09:26:06.381 Requesting market depth updates for: UBH23_FUT_CME if supported. | 2023-02-07 09:26:06.381 Requesting market depth updates for: YMH23_FUT_CME if supported. | 2023-02-07 09:26:06.381 Requesting market depth updates for: ZBH23_FUT_CME if supported. | 2023-02-07 09:26:06.381 Requesting market depth updates for: ZFH23_FUT_CME if supported. | 2023-02-07 09:26:06.381 Requesting market depth updates for: ZNH23_FUT_CME if supported. | 2023-02-07 09:26:06.381 Teton CME Order Routing | Network connection to server complete. | 2023-02-07 09:26:06.614 Teton CME Order Routing | Starting socket receive thread. | 2023-02-07 09:26:06.614 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-07 09:26:06.614 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-02-07 09:26:06.876 Teton CME Order Routing | Sending logon request message. | 2023-02-07 09:26:06.876 Denali Data Feed | Clearing market depth for 6EH23_FUT_CME | 2023-02-07 09:26:07.396 Denali Data Feed | Clearing market depth for CLH23_FUT_CME | 2023-02-07 09:26:07.396 Denali Data Feed | Clearing market depth for ESH23_FUT_CME | 2023-02-07 09:26:07.397 Denali Data Feed | Clearing market depth for GCJ23_FUT_CME | 2023-02-07 09:26:07.397 Denali Data Feed | Clearing market depth for NQH23_FUT_CME | 2023-02-07 09:26:07.397 Denali Data Feed | Clearing market depth for RTYH23_FUT_CME | 2023-02-07 09:26:07.397 Denali Data Feed | Clearing market depth for TNH23_FUT_CME | 2023-02-07 09:26:07.397 Denali Data Feed | Received security definition for symbol TNH23_FUT_CME | 2023-02-07 09:26:07.397 Denali Data Feed | Clearing market depth for UBH23_FUT_CME | 2023-02-07 09:26:07.397 Denali Data Feed | Clearing market depth for YMH23_FUT_CME | 2023-02-07 09:26:07.398 Denali Data Feed | Clearing market depth for ZBH23_FUT_CME | 2023-02-07 09:26:07.398 Denali Data Feed | Clearing market depth for ZFH23_FUT_CME | 2023-02-07 09:26:07.398 Denali Data Feed | Clearing market depth for ZNH23_FUT_CME | 2023-02-07 09:26:07.398 Teton CME Order Routing | Received logon response. | 2023-02-07 09:26:07.726 Teton CME Order Routing | Server Name: SC Realtime Server. | 2023-02-07 09:26:07.726 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-02-07 09:26:07.726 Teton CME Order Routing | Successfully connected. | 2023-02-07 09:26:07.726 Teton CME Order Routing | Trading is not supported. | 2023-02-07 09:26:07.726 Teton CME Order Routing | Starting market orders updates for: 6EH23. MinimumMarketByOrderQuantity: 0. Service code: cme | 2023-02-07 09:26:07.726 Teton CME Order Routing | Restarting market orders data for symbol: 6EH23_FUT_CME -> 6EH23 | 2023-02-07 09:26:07.726 Teton CME Order Routing | Starting market orders updates for: CLH23. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2023-02-07 09:26:07.726 Teton CME Order Routing | Restarting market orders data for symbol: CLH23_FUT_CME -> CLH23 | 2023-02-07 09:26:07.726 Teton CME Order Routing | Starting market orders updates for: ESH23. MinimumMarketByOrderQuantity: 0. Service code: cme | 2023-02-07 09:26:07.726 Teton CME Order Routing | Restarting market orders data for symbol: ESH23_FUT_CME -> ESH23 | 2023-02-07 09:26:07.726 Teton CME Order Routing | Starting market orders updates for: GCJ23. MinimumMarketByOrderQuantity: 0. Service code: comex | 2023-02-07 09:26:07.726 Teton CME Order Routing | Restarting market orders data for symbol: GCJ23_FUT_CME -> GCJ23 | 2023-02-07 09:26:07.726 Teton CME Order Routing | Starting market orders updates for: NQH23. MinimumMarketByOrderQuantity: 0. Service code: cme | 2023-02-07 09:26:07.726 Teton CME Order Routing | Restarting market orders data for symbol: NQH23_FUT_CME -> NQH23 | 2023-02-07 09:26:07.726 Teton CME Order Routing | Starting market orders updates for: RTYH23. MinimumMarketByOrderQuantity: 0. Service code: cme | 2023-02-07 09:26:07.726 Teton CME Order Routing | Restarting market orders data for symbol: RTYH23_FUT_CME -> RTYH23 | 2023-02-07 09:26:07.726 Teton CME Order Routing | Starting market orders updates for: TNH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:26:07.726 Teton CME Order Routing | Restarting market orders data for symbol: TNH23_FUT_CME -> TNH23 | 2023-02-07 09:26:07.726 Teton CME Order Routing | Starting market orders updates for: UBH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:26:07.726 Teton CME Order Routing | Restarting market orders data for symbol: UBH23_FUT_CME -> UBH23 | 2023-02-07 09:26:07.726 Teton CME Order Routing | Starting market orders updates for: YMH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:26:07.726 Teton CME Order Routing | Restarting market orders data for symbol: YMH23_FUT_CME -> YMH23 | 2023-02-07 09:26:07.726 Teton CME Order Routing | Starting market orders updates for: ZBH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:26:07.726 Teton CME Order Routing | Restarting market orders data for symbol: ZBH23_FUT_CME -> ZBH23 | 2023-02-07 09:26:07.726 Teton CME Order Routing | Starting market orders updates for: ZFH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:26:07.726 Teton CME Order Routing | Restarting market orders data for symbol: ZFH23_FUT_CME -> ZFH23 | 2023-02-07 09:26:07.726 Teton CME Order Routing | Starting market orders updates for: ZNH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:26:07.726 Teton CME Order Routing | Restarting market orders data for symbol: ZNH23_FUT_CME -> ZNH23 | 2023-02-07 09:26:07.726 Teton CME Order Routing | Market Orders data has been rejected for symbol: 6EH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:26:08.062 Teton CME Order Routing | Market Orders data has been rejected for symbol: CLH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:26:08.062 Teton CME Order Routing | Market Orders data has been rejected for symbol: ESH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:26:08.062 Teton CME Order Routing | Market Orders data has been rejected for symbol: GCJ23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:26:08.062 Teton CME Order Routing | Market Orders data has been rejected for symbol: NQH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:26:08.062 Teton CME Order Routing | Market Orders data has been rejected for symbol: RTYH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:26:08.062 Teton CME Order Routing | Market Orders data has been rejected for symbol: TNH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:26:08.062 Teton CME Order Routing | Market Orders data has been rejected for symbol: UBH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:26:08.062 Teton CME Order Routing | Market Orders data has been rejected for symbol: YMH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:26:08.062 Teton CME Order Routing | Market Orders data has been rejected for symbol: ZBH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:26:08.062 Teton CME Order Routing | Market Orders data has been rejected for symbol: ZFH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:26:08.062 Teton CME Order Routing | Market Orders data has been rejected for symbol: ZNH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:26:08.062 Updated verified funded futures trading account ending date to: 2023-03-09 17:26:12 | 2023-02-07 09:26:12.070 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZNH23_FUT_CME | 2023-02-07 09:26:12.070 Teton CME Order Routing | Received security definition for symbol ZNH23_FUT_CME | 2023-02-07 09:26:12.070 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZBH23_FUT_CME | 2023-02-07 09:26:12.070 Teton CME Order Routing | Received security definition for symbol ZBH23_FUT_CME | 2023-02-07 09:26:12.070 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZFH23_FUT_CME | 2023-02-07 09:26:12.070 Teton CME Order Routing | Received security definition for symbol ZFH23_FUT_CME | 2023-02-07 09:26:12.070 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH23_FUT_CME | 2023-02-07 09:26:12.070 Teton CME Order Routing | Received security definition for symbol ESH23_FUT_CME | 2023-02-07 09:26:12.070 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: UBH23_FUT_CME | 2023-02-07 09:26:12.070 Teton CME Order Routing | Received security definition for symbol UBH23_FUT_CME | 2023-02-07 09:26:12.070 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQH23_FUT_CME | 2023-02-07 09:26:12.070 Teton CME Order Routing | Received security definition for symbol NQH23_FUT_CME | 2023-02-07 09:26:12.070 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6EH23_FUT_CME | 2023-02-07 09:26:12.070 Teton CME Order Routing | Received security definition for symbol 6EH23_FUT_CME | 2023-02-07 09:26:12.070 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: RTYH23_FUT_CME | 2023-02-07 09:26:12.070 Teton CME Order Routing | Received security definition for symbol RTYH23_FUT_CME | 2023-02-07 09:26:12.070 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: YMH23_FUT_CME | 2023-02-07 09:26:12.070 Teton CME Order Routing | Received security definition for symbol YMH23_FUT_CME | 2023-02-07 09:26:12.070 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: CLH23_FUT_CME | 2023-02-07 09:26:12.070 Teton CME Order Routing | Received security definition for symbol CLH23_FUT_CME | 2023-02-07 09:26:12.070 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: GCJ23_FUT_CME | 2023-02-07 09:26:12.070 Teton CME Order Routing | Received security definition for symbol GCJ23_FUT_CME | 2023-02-07 09:26:12.070 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: GCG23_FUT_CME | 2023-02-07 09:26:14.063 Teton CME Order Routing | Received security definition for symbol GCG23_FUT_CME | 2023-02-07 09:26:14.063 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: CLG23_FUT_CME | 2023-02-07 09:26:14.063 Teton CME Order Routing | Received security definition for symbol CLG23_FUT_CME | 2023-02-07 09:26:14.063 Teton CME Order Routing | Received final trade activity snapshot. Count=175. TradeAccount=44435 | 2023-02-07 09:26:14.063 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: TNH23_FUT_CME | 2023-02-07 09:26:14.063 Teton CME Order Routing | Received security definition for symbol TNH23_FUT_CME | 2023-02-07 09:26:14.063 NQH23_FUT_CME [CV][M] #14 | StartDateTimeForLoadingOrderFills: 2023-02-06 15:00:00 | 2023-02-07 09:26:14.324 DTC Client socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2023-02-07 09:26:33.577 DTC Client socket (2) | Closed. | 2023-02-07 09:26:33.577 DTC Client socket (4) | Deleting network socket now after delay. | 2023-02-07 09:26:33.577 Socket (9) | CloseSocket call. | 2023-02-07 09:26:42.172 Socket (9) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:26:42.172 Historical data download thread signaled to stop. | 2023-02-07 09:26:42.173 HD Request # 19 | Received 4913826 Intraday data records from 2022-11-14 18:16:53.158000 to 2023-02-07 09:26:39.864000 (84.6 days) and wrote 4913826 records for TNH23_FUT_CME | 2023-02-07 09:26:42.173 HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:26:39.864000 | 2023-02-07 09:26:42.176 HD Request # 19 | Completion time: 46s. | 2023-02-07 09:26:42.176 HD Request # 19 | Intraday data download complete for TNH23_FUT_CME. Unique request ID: 16 | 2023-02-07 09:26:42.176 Removing historical data download ID 16. | 2023-02-07 09:26:42.176 Real-time Intraday chart data file updates started for TNH23_FUT_CME | 2023-02-07 09:26:42.176 Intraday chart data file opened for TNH23_FUT_CME | 2023-02-07 09:26:42.176 HD Request # 19 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:26:42.176 TNH23_FUT_CME [CV] #29 | Flagging to reload Intraday data on download completion. | 2023-02-07 09:26:42.176 Triggering next historical data download in queue. | 2023-02-07 09:26:42.176 HD Request # 20 | Downloading Intraday chart data for NQH23_FUT_CME to the file NQH23_FUT_CME.scid. Service: cme | 2023-02-07 09:26:42.176 HD Request # 20 | Download start date-time: 2023-02-07 09:16:36.000000. File last date-time: 2023-02-07 09:16:36.494000 | 2023-02-07 09:26:42.176 HD Request # 20 | Using server: ds23.sierracharts.com port 10149 | 2023-02-07 09:26:42.176 Socket (4) | Creating socket. | 2023-02-07 09:26:42.176 Socket (4) | New receive buffer size: 5242880 | 2023-02-07 09:26:42.176 Socket (4) | Connecting to IP: 142.215.17.190. | 2023-02-07 09:26:42.176 TNH23_FUT_CME [CV] #29 | Reloading chart. | 2023-02-07 09:26:42.194 TNH23_FUT_CME [CV] #29 | StartDateTimeForLoadingOrderFills: 2023-02-06 17:00:00 | 2023-02-07 09:26:42.212 Socket (9) | Socket gracefully closed by remote side. | 2023-02-07 09:26:42.386 Socket (9) | Closed. | 2023-02-07 09:26:42.386 HD Request # 20 | Setting DTC encoding to Binary VLS | 2023-02-07 09:26:42.614 HD Request # 20 | Sending historical data logon request message. | 2023-02-07 09:26:42.614 HD Request # 20 | Requesting Intraday data. Start date-time: 2023-02-07 09:16:36. Record interval: 0. Symbol: NQH23 | 2023-02-07 09:26:43.364 HD Request # 20 | Decompressing data. | 2023-02-07 09:26:43.589 HD Request # 20 | Receiving Intraday data for NQH23_FUT_CME starting at 2023-02-07 09:16:36.292000 | 2023-02-07 09:26:44.268 Socket (4) | CloseSocket call. | 2023-02-07 09:26:44.269 Historical data download thread signaled to stop. | 2023-02-07 09:26:44.269 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:26:44.269 HD Request # 20 | Timestamp of first Intraday data file record written: 2023-02-07 09:16:37.354000. | 2023-02-07 09:26:44.269 HD Request # 20 | Received 7087 Intraday data records from 2023-02-07 09:16:36.292000 to 2023-02-07 09:26:43.173000 (10.1 minutes) and wrote 7080 records for NQH23_FUT_CME | 2023-02-07 09:26:44.270 HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:26:43.173000 | 2023-02-07 09:26:44.273 Added 3 Time and Sales records to Intraday data file for NQH23_FUT_CME after download. | 2023-02-07 09:26:44.273 HD Request # 20 | Completion time: 2s. | 2023-02-07 09:26:44.273 HD Request # 20 | Intraday data download complete for NQH23_FUT_CME. Unique request ID: 20 | 2023-02-07 09:26:44.273 Removing historical data download ID 20. | 2023-02-07 09:26:44.273 Real-time Intraday chart data file updates started for NQH23_FUT_CME | 2023-02-07 09:26:44.273 Intraday chart data file opened for NQH23_FUT_CME | 2023-02-07 09:26:44.273 HD Request # 20 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:26:44.273 Triggering next historical data download in queue. | 2023-02-07 09:26:44.273 HD Request # 21 | Downloading Intraday chart data for ESH23_FUT_CME to the file ESH23_FUT_CME.scid. Service: cme | 2023-02-07 09:26:44.273 HD Request # 21 | Download start date-time: 2023-02-07 09:16:36.000000. File last date-time: 2023-02-07 09:16:36.609000 | 2023-02-07 09:26:44.273 HD Request # 21 | Using server: ds26.sierracharts.com port 10150 | 2023-02-07 09:26:44.273 Socket (9) | Creating socket. | 2023-02-07 09:26:44.273 Socket (9) | New receive buffer size: 5242880 | 2023-02-07 09:26:44.273 Socket (9) | Connecting to IP: 142.215.17.188. | 2023-02-07 09:26:44.273 Socket (4) | Socket gracefully closed by remote side. | 2023-02-07 09:26:44.487 Socket (4) | Closed. | 2023-02-07 09:26:44.487 HD Request # 21 | Setting DTC encoding to Binary VLS | 2023-02-07 09:26:44.702 HD Request # 21 | Sending historical data logon request message. | 2023-02-07 09:26:44.702 HD Request # 21 | Requesting Intraday data. Start date-time: 2023-02-07 09:16:36. Record interval: 0. Symbol: ESH23 | 2023-02-07 09:26:45.433 HD Request # 21 | Decompressing data. | 2023-02-07 09:26:45.646 HD Request # 21 | Receiving Intraday data for ESH23_FUT_CME starting at 2023-02-07 09:16:36.384000 | 2023-02-07 09:26:45.865 Socket (9) | CloseSocket call. | 2023-02-07 09:26:46.075 Socket (9) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:26:46.076 Historical data download thread signaled to stop. | 2023-02-07 09:26:46.076 HD Request # 21 | Timestamp of first Intraday data file record written: 2023-02-07 09:16:38.212000. | 2023-02-07 09:26:46.076 HD Request # 21 | Received 13709 Intraday data records from 2023-02-07 09:16:36.384000 to 2023-02-07 09:26:43.164006 (10.1 minutes) and wrote 13668 records for ESH23_FUT_CME | 2023-02-07 09:26:46.076 HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:26:43.164006 | 2023-02-07 09:26:46.080 Added 15 Time and Sales records to Intraday data file for ESH23_FUT_CME after download. | 2023-02-07 09:26:46.080 HD Request # 21 | Completion time: 2s. | 2023-02-07 09:26:46.080 HD Request # 21 | Intraday data download complete for ESH23_FUT_CME. Unique request ID: 21 | 2023-02-07 09:26:46.080 Removing historical data download ID 21. | 2023-02-07 09:26:46.080 Real-time Intraday chart data file updates started for ESH23_FUT_CME | 2023-02-07 09:26:46.080 Intraday chart data file opened for ESH23_FUT_CME | 2023-02-07 09:26:46.080 HD Request # 21 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:26:46.080 Triggering next historical data download in queue. | 2023-02-07 09:26:46.080 HD Request # 22 | Downloading Intraday chart data for UBH23_FUT_CME to the file UBH23_FUT_CME.scid. Service: cbot | 2023-02-07 09:26:46.080 HD Request # 22 | Download start date-time: 2023-02-07 09:16:36.000000. File last date-time: 2023-02-07 09:16:36.366005 | 2023-02-07 09:26:46.080 HD Request # 22 | Using server: ds28.sierracharts.com port 10149 | 2023-02-07 09:26:46.080 Socket (4) | Creating socket. | 2023-02-07 09:26:46.080 Socket (4) | New receive buffer size: 5242880 | 2023-02-07 09:26:46.081 Socket (4) | Connecting to IP: 142.215.18.147. | 2023-02-07 09:26:46.081 Socket (9) | Socket gracefully closed by remote side. | 2023-02-07 09:26:46.285 Socket (9) | Closed. | 2023-02-07 09:26:46.285 HD Request # 22 | Setting DTC encoding to Binary VLS | 2023-02-07 09:26:46.524 HD Request # 22 | Sending historical data logon request message. | 2023-02-07 09:26:46.524 HD Request # 22 | Requesting Intraday data. Start date-time: 2023-02-07 09:16:36. Record interval: 0. Symbol: UBH23 | 2023-02-07 09:26:47.282 HD Request # 22 | Decompressing data. | 2023-02-07 09:26:47.507 HD Request # 22 | Receiving Intraday data for UBH23_FUT_CME starting at 2023-02-07 09:16:36.291000 | 2023-02-07 09:26:47.508 Socket (4) | CloseSocket call. | 2023-02-07 09:26:47.509 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:26:47.509 Historical data download thread signaled to stop. | 2023-02-07 09:26:47.509 HD Request # 22 | Timestamp of first Intraday data file record written: 2023-02-07 09:16:40.467000. | 2023-02-07 09:26:47.509 HD Request # 22 | Received 726 Intraday data records from 2023-02-07 09:16:36.291000 to 2023-02-07 09:26:45.372000 (10.2 minutes) and wrote 705 records for UBH23_FUT_CME | 2023-02-07 09:26:47.509 HD Request # 22 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:26:45.372000 | 2023-02-07 09:26:47.511 HD Request # 22 | Completion time: 1s. | 2023-02-07 09:26:47.511 HD Request # 22 | Intraday data download complete for UBH23_FUT_CME. Unique request ID: 22 | 2023-02-07 09:26:47.511 Removing historical data download ID 22. | 2023-02-07 09:26:47.511 Real-time Intraday chart data file updates started for UBH23_FUT_CME | 2023-02-07 09:26:47.511 Intraday chart data file opened for UBH23_FUT_CME | 2023-02-07 09:26:47.511 HD Request # 22 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:26:47.511 Triggering next historical data download in queue. | 2023-02-07 09:26:47.511 HD Request # 23 | Downloading Intraday chart data for YMH23_FUT_CME to the file YMH23_FUT_CME.scid. Service: cbot | 2023-02-07 09:26:47.511 HD Request # 23 | Download start date-time: 2023-02-07 09:16:36.000000. File last date-time: 2023-02-07 09:16:36.617000 | 2023-02-07 09:26:47.512 HD Request # 23 | Using server: ds23.sierracharts.com port 10150 | 2023-02-07 09:26:47.512 Socket (9) | Creating socket. | 2023-02-07 09:26:47.512 Socket (9) | New receive buffer size: 5242880 | 2023-02-07 09:26:47.512 Socket (9) | Connecting to IP: 142.215.17.190. | 2023-02-07 09:26:47.512 Socket (4) | Socket gracefully closed by remote side. | 2023-02-07 09:26:47.736 Socket (4) | Closed. | 2023-02-07 09:26:47.736 HD Request # 23 | Setting DTC encoding to Binary VLS | 2023-02-07 09:26:47.992 HD Request # 23 | Sending historical data logon request message. | 2023-02-07 09:26:47.992 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\ESH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:26:48.317 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\NQH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:26:48.317 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\TNH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:26:48.317 HD Request # 23 | Requesting Intraday data. Start date-time: 2023-02-07 09:16:36. Record interval: 0. Symbol: YMH23 | 2023-02-07 09:26:48.747 HD Request # 23 | Decompressing data. | 2023-02-07 09:26:48.983 HD Request # 23 | Receiving Intraday data for YMH23_FUT_CME starting at 2023-02-07 09:16:36.386000 | 2023-02-07 09:26:49.221 Socket (9) | CloseSocket call. | 2023-02-07 09:26:49.222 Socket (9) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:26:49.222 Historical data download thread signaled to stop. | 2023-02-07 09:26:49.252 HD Request # 23 | Timestamp of first Intraday data file record written: 2023-02-07 09:16:38.216000. | 2023-02-07 09:26:49.252 HD Request # 23 | Received 1722 Intraday data records from 2023-02-07 09:16:36.386000 to 2023-02-07 09:26:48.664001 (10.2 minutes) and wrote 1720 records for YMH23_FUT_CME | 2023-02-07 09:26:49.252 HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:26:48.664001 | 2023-02-07 09:26:49.255 HD Request # 23 | Completion time: 2s. | 2023-02-07 09:26:49.255 HD Request # 23 | Intraday data download complete for YMH23_FUT_CME. Unique request ID: 23 | 2023-02-07 09:26:49.255 Removing historical data download ID 23. | 2023-02-07 09:26:49.255 Real-time Intraday chart data file updates started for YMH23_FUT_CME | 2023-02-07 09:26:49.255 Intraday chart data file opened for YMH23_FUT_CME | 2023-02-07 09:26:49.255 HD Request # 23 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:26:49.255 Triggering next historical data download in queue. | 2023-02-07 09:26:49.255 HD Request # 24 | Downloading Intraday chart data for RTYH23_FUT_CME to the file RTYH23_FUT_CME.scid. Service: cme | 2023-02-07 09:26:49.255 HD Request # 24 | Download start date-time: 2023-02-07 09:16:36.000000. File last date-time: 2023-02-07 09:16:36.593000 | 2023-02-07 09:26:49.255 HD Request # 24 | Using server: ds26.sierracharts.com port 10149 | 2023-02-07 09:26:49.255 Socket (4) | Creating socket. | 2023-02-07 09:26:49.255 Socket (4) | New receive buffer size: 5242880 | 2023-02-07 09:26:49.255 Socket (4) | Connecting to IP: 142.215.17.188. | 2023-02-07 09:26:49.255 Socket (9) | Socket gracefully closed by remote side. | 2023-02-07 09:26:49.455 Socket (9) | Closed. | 2023-02-07 09:26:49.455 HD Request # 24 | Setting DTC encoding to Binary VLS | 2023-02-07 09:26:49.746 HD Request # 24 | Sending historical data logon request message. | 2023-02-07 09:26:49.746 HD Request # 24 | Requesting Intraday data. Start date-time: 2023-02-07 09:16:36. Record interval: 0. Symbol: RTYH23 | 2023-02-07 09:26:50.500 HD Request # 24 | Decompressing data. | 2023-02-07 09:26:50.740 HD Request # 24 | Receiving Intraday data for RTYH23_FUT_CME starting at 2023-02-07 09:16:36.294000 | 2023-02-07 09:26:50.743 Socket (4) | CloseSocket call. | 2023-02-07 09:26:50.743 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:26:50.743 Historical data download thread signaled to stop. | 2023-02-07 09:26:50.748 HD Request # 24 | Timestamp of first Intraday data file record written: 2023-02-07 09:16:38.212000. | 2023-02-07 09:26:50.748 HD Request # 24 | Received 1621 Intraday data records from 2023-02-07 09:16:36.294000 to 2023-02-07 09:26:45.583003 (10.2 minutes) and wrote 1616 records for RTYH23_FUT_CME | 2023-02-07 09:26:50.748 HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:26:45.583003 | 2023-02-07 09:26:50.751 Added 8 Time and Sales records to Intraday data file for RTYH23_FUT_CME after download. | 2023-02-07 09:26:50.751 HD Request # 24 | Completion time: 1s. | 2023-02-07 09:26:50.751 HD Request # 24 | Intraday data download complete for RTYH23_FUT_CME. Unique request ID: 24 | 2023-02-07 09:26:50.751 Removing historical data download ID 24. | 2023-02-07 09:26:50.751 Real-time Intraday chart data file updates started for RTYH23_FUT_CME | 2023-02-07 09:26:50.751 Intraday chart data file opened for RTYH23_FUT_CME | 2023-02-07 09:26:50.751 HD Request # 24 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:26:50.751 Triggering next historical data download in queue. | 2023-02-07 09:26:50.751 HD Request # 25 | Downloading Intraday chart data for 6EH23_FUT_CME to the file 6EH23_FUT_CME.scid. Service: cme | 2023-02-07 09:26:50.751 HD Request # 25 | Download start date-time: 2023-02-07 09:16:36.000000. File last date-time: 2023-02-07 09:16:36.548001 | 2023-02-07 09:26:50.751 HD Request # 25 | Using server: ds28.sierracharts.com port 10150 | 2023-02-07 09:26:50.751 Socket (9) | Creating socket. | 2023-02-07 09:26:50.751 Socket (9) | New receive buffer size: 5242880 | 2023-02-07 09:26:50.751 Socket (9) | Connecting to IP: 142.215.18.147. | 2023-02-07 09:26:50.751 Socket (4) | Socket gracefully closed by remote side. | 2023-02-07 09:26:50.983 Socket (4) | Closed. | 2023-02-07 09:26:50.983 HD Request # 25 | Setting DTC encoding to Binary VLS | 2023-02-07 09:26:51.214 HD Request # 25 | Sending historical data logon request message. | 2023-02-07 09:26:51.214 HD Request # 25 | Requesting Intraday data. Start date-time: 2023-02-07 09:16:36. Record interval: 0. Symbol: 6EH23 | 2023-02-07 09:26:51.967 HD Request # 25 | Decompressing data. | 2023-02-07 09:26:52.202 HD Request # 25 | Receiving Intraday data for 6EH23_FUT_CME starting at 2023-02-07 09:16:36.547000 | 2023-02-07 09:26:52.204 Socket (9) | CloseSocket call. | 2023-02-07 09:26:52.204 Socket (9) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:26:52.204 Historical data download thread signaled to stop. | 2023-02-07 09:26:52.207 HD Request # 25 | Timestamp of first Intraday data file record written: 2023-02-07 09:16:38.951000. | 2023-02-07 09:26:52.207 HD Request # 25 | Received 809 Intraday data records from 2023-02-07 09:16:36.547000 to 2023-02-07 09:26:42.087003 (10.1 minutes) and wrote 804 records for 6EH23_FUT_CME | 2023-02-07 09:26:52.207 HD Request # 25 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:26:42.087003 | 2023-02-07 09:26:52.210 HD Request # 25 | Completion time: 2s. | 2023-02-07 09:26:52.210 HD Request # 25 | Intraday data download complete for 6EH23_FUT_CME. Unique request ID: 25 | 2023-02-07 09:26:52.210 Removing historical data download ID 25. | 2023-02-07 09:26:52.210 Real-time Intraday chart data file updates started for 6EH23_FUT_CME | 2023-02-07 09:26:52.210 Intraday chart data file opened for 6EH23_FUT_CME | 2023-02-07 09:26:52.210 HD Request # 25 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:26:52.210 Triggering next historical data download in queue. | 2023-02-07 09:26:52.210 HD Request # 26 | Downloading Intraday chart data for ZFH23_FUT_CME to the file ZFH23_FUT_CME.scid. Service: cbot | 2023-02-07 09:26:52.210 HD Request # 26 | Download start date-time: 2023-02-07 09:16:36.000000. File last date-time: 2023-02-07 09:16:36.438005 | 2023-02-07 09:26:52.210 HD Request # 26 | Using server: ds23.sierracharts.com port 10149 | 2023-02-07 09:26:52.210 Socket (4) | Creating socket. | 2023-02-07 09:26:52.210 Socket (4) | New receive buffer size: 5242880 | 2023-02-07 09:26:52.210 Socket (4) | Connecting to IP: 142.215.17.190. | 2023-02-07 09:26:52.210 Socket (9) | Socket gracefully closed by remote side. | 2023-02-07 09:26:52.433 Socket (9) | Closed. | 2023-02-07 09:26:52.433 HD Request # 26 | Setting DTC encoding to Binary VLS | 2023-02-07 09:26:52.651 HD Request # 26 | Sending historical data logon request message. | 2023-02-07 09:26:52.651 HD Request # 26 | Requesting Intraday data. Start date-time: 2023-02-07 09:16:36. Record interval: 0. Symbol: ZFH23 | 2023-02-07 09:26:52.863 HD Request # 26 | Decompressing data. | 2023-02-07 09:26:53.074 HD Request # 26 | Receiving Intraday data for ZFH23_FUT_CME starting at 2023-02-07 09:16:36.300000 | 2023-02-07 09:26:53.287 Socket (4) | CloseSocket call. | 2023-02-07 09:26:53.288 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:26:53.288 Historical data download thread signaled to stop. | 2023-02-07 09:26:53.296 HD Request # 26 | Timestamp of first Intraday data file record written: 2023-02-07 09:16:38.800000. | 2023-02-07 09:26:53.297 HD Request # 26 | Received 2417 Intraday data records from 2023-02-07 09:16:36.300000 to 2023-02-07 09:26:50.770000 (10.2 minutes) and wrote 2369 records for ZFH23_FUT_CME | 2023-02-07 09:26:53.297 HD Request # 26 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:26:50.770000 | 2023-02-07 09:26:53.299 HD Request # 26 | Completion time: 1s. | 2023-02-07 09:26:53.299 HD Request # 26 | Intraday data download complete for ZFH23_FUT_CME. Unique request ID: 26 | 2023-02-07 09:26:53.299 Removing historical data download ID 26. | 2023-02-07 09:26:53.299 Real-time Intraday chart data file updates started for ZFH23_FUT_CME | 2023-02-07 09:26:53.299 Intraday chart data file opened for ZFH23_FUT_CME | 2023-02-07 09:26:53.299 HD Request # 26 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:26:53.299 Triggering next historical data download in queue. | 2023-02-07 09:26:53.299 HD Request # 27 | Downloading Intraday chart data for CLH23_FUT_CME to the file CLH23_FUT_CME.scid. Service: nymex | 2023-02-07 09:26:53.299 HD Request # 27 | Download start date-time: 2023-02-07 09:24:01.000000. File last date-time: 2023-02-07 09:24:01.024000 | 2023-02-07 09:26:53.299 HD Request # 27 | Using server: ds26.sierracharts.com port 10150 | 2023-02-07 09:26:53.299 Socket (9) | Creating socket. | 2023-02-07 09:26:53.299 Socket (9) | New receive buffer size: 5242880 | 2023-02-07 09:26:53.299 Socket (9) | Connecting to IP: 142.215.17.188. | 2023-02-07 09:26:53.299 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\RTYH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:26:53.356 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\YMH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:26:53.356 Socket (4) | Socket gracefully closed by remote side. | 2023-02-07 09:26:53.497 Socket (4) | Closed. | 2023-02-07 09:26:53.497 HD Request # 27 | Setting DTC encoding to Binary VLS | 2023-02-07 09:26:53.734 HD Request # 27 | Sending historical data logon request message. | 2023-02-07 09:26:53.734 HD Request # 27 | Requesting Intraday data. Start date-time: 2023-02-07 09:24:01. Record interval: 0. Symbol: CLH23 | 2023-02-07 09:26:53.951 HD Request # 27 | Decompressing data. | 2023-02-07 09:26:54.168 HD Request # 27 | Receiving Intraday data for CLH23_FUT_CME starting at 2023-02-07 09:24:01.014000 | 2023-02-07 09:26:54.169 Socket (9) | CloseSocket call. | 2023-02-07 09:26:54.169 Socket (9) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:26:54.169 Historical data download thread signaled to stop. | 2023-02-07 09:26:54.185 HD Request # 27 | Timestamp of first Intraday data file record written: 2023-02-07 09:24:01.774000. | 2023-02-07 09:26:54.185 HD Request # 27 | Received 867 Intraday data records from 2023-02-07 09:24:01.014000 to 2023-02-07 09:26:51.759000 (2.8 minutes) and wrote 863 records for CLH23_FUT_CME | 2023-02-07 09:26:54.185 HD Request # 27 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:26:51.759000 | 2023-02-07 09:26:54.188 HD Request # 27 | Completion time: 1s. | 2023-02-07 09:26:54.188 HD Request # 27 | Intraday data download complete for CLH23_FUT_CME. Unique request ID: 27 | 2023-02-07 09:26:54.188 Removing historical data download ID 27. | 2023-02-07 09:26:54.188 Real-time Intraday chart data file updates started for CLH23_FUT_CME | 2023-02-07 09:26:54.188 Intraday chart data file opened for CLH23_FUT_CME | 2023-02-07 09:26:54.188 HD Request # 27 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:26:54.188 Triggering next historical data download in queue. | 2023-02-07 09:26:54.188 HD Request # 28 | Downloading Intraday chart data for GCJ23_FUT_CME to the file GCJ23_FUT_CME.scid. Service: comex | 2023-02-07 09:26:54.188 HD Request # 28 | Download start date-time: 2023-02-07 09:24:00.000000. File last date-time: 2023-02-07 09:24:00.919000 | 2023-02-07 09:26:54.188 HD Request # 28 | Using server: ds28.sierracharts.com port 10149 | 2023-02-07 09:26:54.188 Socket (4) | Creating socket. | 2023-02-07 09:26:54.188 Socket (4) | New receive buffer size: 5242880 | 2023-02-07 09:26:54.188 Socket (4) | Connecting to IP: 142.215.18.147. | 2023-02-07 09:26:54.188 Socket (9) | Socket gracefully closed by remote side. | 2023-02-07 09:26:54.385 Socket (9) | Closed. | 2023-02-07 09:26:54.385 HD Request # 28 | Setting DTC encoding to Binary VLS | 2023-02-07 09:26:54.660 HD Request # 28 | Sending historical data logon request message. | 2023-02-07 09:26:54.660 HD Request # 28 | Requesting Intraday data. Start date-time: 2023-02-07 09:24:00. Record interval: 0. Symbol: GCJ23 | 2023-02-07 09:26:54.900 HD Request # 28 | Decompressing data. | 2023-02-07 09:26:55.141 HD Request # 28 | Receiving Intraday data for GCJ23_FUT_CME starting at 2023-02-07 09:24:00.918000 | 2023-02-07 09:26:55.141 Socket (4) | CloseSocket call. | 2023-02-07 09:26:55.142 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:26:55.142 Historical data download thread signaled to stop. | 2023-02-07 09:26:55.142 HD Request # 28 | Timestamp of first Intraday data file record written: 2023-02-07 09:24:08.407000. | 2023-02-07 09:26:55.142 HD Request # 28 | Received 210 Intraday data records from 2023-02-07 09:24:00.918000 to 2023-02-07 09:26:51.093000 (2.8 minutes) and wrote 208 records for GCJ23_FUT_CME | 2023-02-07 09:26:55.142 HD Request # 28 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:26:51.093000 | 2023-02-07 09:26:55.146 Added 5 Time and Sales records to Intraday data file for GCJ23_FUT_CME after download. | 2023-02-07 09:26:55.146 HD Request # 28 | Completion time: 1s. | 2023-02-07 09:26:55.146 HD Request # 28 | Intraday data download complete for GCJ23_FUT_CME. Unique request ID: 28 | 2023-02-07 09:26:55.146 Removing historical data download ID 28. | 2023-02-07 09:26:55.146 Real-time Intraday chart data file updates started for GCJ23_FUT_CME | 2023-02-07 09:26:55.146 Intraday chart data file opened for GCJ23_FUT_CME | 2023-02-07 09:26:55.146 HD Request # 28 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:26:55.146 Triggering next historical data download in queue. | 2023-02-07 09:26:55.146 HD Request # 29 | Downloading Intraday chart data for ZBH23_FUT_CME to the file ZBH23_FUT_CME.scid. Service: cbot | 2023-02-07 09:26:55.146 HD Request # 29 | Download start date-time: 2023-02-07 09:24:20.000000. File last date-time: 2023-02-07 09:24:20.176001 | 2023-02-07 09:26:55.146 HD Request # 29 | Using server: ds23.sierracharts.com port 10150 | 2023-02-07 09:26:55.146 Socket (9) | Creating socket. | 2023-02-07 09:26:55.146 Socket (9) | New receive buffer size: 5242880 | 2023-02-07 09:26:55.146 Socket (9) | Connecting to IP: 142.215.17.190. | 2023-02-07 09:26:55.146 Socket (4) | Socket gracefully closed by remote side. | 2023-02-07 09:26:55.379 Socket (4) | Closed. | 2023-02-07 09:26:55.379 HD Request # 29 | Setting DTC encoding to Binary VLS | 2023-02-07 09:26:55.681 HD Request # 29 | Sending historical data logon request message. | 2023-02-07 09:26:55.681 HD Request # 29 | Requesting Intraday data. Start date-time: 2023-02-07 09:24:20. Record interval: 0. Symbol: ZBH23 | 2023-02-07 09:26:55.943 HD Request # 29 | Decompressing data. | 2023-02-07 09:26:56.204 HD Request # 29 | Receiving Intraday data for ZBH23_FUT_CME starting at 2023-02-07 09:24:20.172000 | 2023-02-07 09:26:56.204 Socket (9) | CloseSocket call. | 2023-02-07 09:26:56.204 Socket (9) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:26:56.204 Historical data download thread signaled to stop. | 2023-02-07 09:26:56.210 HD Request # 29 | Timestamp of first Intraday data file record written: 2023-02-07 09:24:35.985000. | 2023-02-07 09:26:56.210 HD Request # 29 | Received 152 Intraday data records from 2023-02-07 09:24:20.172000 to 2023-02-07 09:26:47.896000 (2.5 minutes) and wrote 135 records for ZBH23_FUT_CME | 2023-02-07 09:26:56.210 HD Request # 29 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:26:47.896000 | 2023-02-07 09:26:56.213 Added 1 Time and Sales records to Intraday data file for ZBH23_FUT_CME after download. | 2023-02-07 09:26:56.213 HD Request # 29 | Completion time: 1s. | 2023-02-07 09:26:56.213 HD Request # 29 | Intraday data download complete for ZBH23_FUT_CME. Unique request ID: 29 | 2023-02-07 09:26:56.213 Removing historical data download ID 29. | 2023-02-07 09:26:56.213 Real-time Intraday chart data file updates started for ZBH23_FUT_CME | 2023-02-07 09:26:56.213 Intraday chart data file opened for ZBH23_FUT_CME | 2023-02-07 09:26:56.213 HD Request # 29 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:26:56.213 Triggering next historical data download in queue. | 2023-02-07 09:26:56.213 HD Request # 30 | Downloading Intraday chart data for ZNH23_FUT_CME to the file ZNH23_FUT_CME.scid. Service: cbot | 2023-02-07 09:26:56.213 HD Request # 30 | Download start date-time: 2023-02-07 09:26:00.000000. File last date-time: 2023-02-07 09:26:00.130000 | 2023-02-07 09:26:56.213 HD Request # 30 | Using server: ds26.sierracharts.com port 10149 | 2023-02-07 09:26:56.213 Socket (4) | Creating socket. | 2023-02-07 09:26:56.213 Socket (4) | New receive buffer size: 5242880 | 2023-02-07 09:26:56.213 Socket (4) | Connecting to IP: 142.215.17.188. | 2023-02-07 09:26:56.213 Socket (9) | Socket gracefully closed by remote side. | 2023-02-07 09:26:56.473 Socket (9) | Closed. | 2023-02-07 09:26:56.473 HD Request # 30 | Setting DTC encoding to Binary VLS | 2023-02-07 09:26:56.653 HD Request # 30 | Sending historical data logon request message. | 2023-02-07 09:26:56.653 HD Request # 30 | Requesting Intraday data. Start date-time: 2023-02-07 09:26:00. Record interval: 0. Symbol: ZNH23 | 2023-02-07 09:26:56.870 HD Request # 30 | Decompressing data. | 2023-02-07 09:26:57.084 HD Request # 30 | Receiving Intraday data for ZNH23_FUT_CME starting at 2023-02-07 09:26:00.006000 | 2023-02-07 09:26:57.084 Socket (4) | CloseSocket call. | 2023-02-07 09:26:57.084 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:26:57.085 Historical data download thread signaled to stop. | 2023-02-07 09:26:57.097 HD Request # 30 | Timestamp of first Intraday data file record written: 2023-02-07 09:26:07.024000. | 2023-02-07 09:26:57.097 HD Request # 30 | Received 241 Intraday data records from 2023-02-07 09:26:00.006000 to 2023-02-07 09:26:53.753000 (53.7 seconds) and wrote 236 records for ZNH23_FUT_CME | 2023-02-07 09:26:57.097 HD Request # 30 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:26:53.753000 | 2023-02-07 09:26:57.099 HD Request # 30 | Completion time: 1s. | 2023-02-07 09:26:57.099 HD Request # 30 | Intraday data download complete for ZNH23_FUT_CME. Unique request ID: 30 | 2023-02-07 09:26:57.099 Removing historical data download ID 30. | 2023-02-07 09:26:57.099 Real-time Intraday chart data file updates started for ZNH23_FUT_CME | 2023-02-07 09:26:57.099 Intraday chart data file opened for ZNH23_FUT_CME | 2023-02-07 09:26:57.099 HD Request # 30 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:26:57.099 Triggering next historical data download in queue. | 2023-02-07 09:26:57.099 No download requests in the queue to start downloads for. | 2023-02-07 09:26:57.099 Socket (4) | Socket gracefully closed by remote side. | 2023-02-07 09:26:57.298 Socket (4) | Closed. | 2023-02-07 09:26:57.298 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\ZBH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:26:58.422 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\ZFH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:26:58.423 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\UBH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:26:58.423 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\6EH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:26:58.423 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\CLH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:26:58.423 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\GCJ23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:26:58.423 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\ZNH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:27:03.458 DTC Client socket (2) | Deleting network socket now after delay. | 2023-02-07 09:27:03.583 DTC Client socket (7) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2023-02-07 09:27:22.899 * DTC Client socket (7) | Socket gracefully closed by remote side. | 2023-02-07 09:27:22.899 DTC Client socket (7) | Closed. | 2023-02-07 09:27:22.899 File >> Disconnect selected. | 2023-02-07 09:27:32.660 Teton CME Order Routing | Waiting for socket receive thread to end | 2023-02-07 09:27:32.732 DTC Client socket (1) | CloseSocket call. | 2023-02-07 09:27:32.732 DTC Client socket (1) | Max send buffers used during socket life: 5 | 2023-02-07 09:27:32.732 DTC Client socket (1) | Max send buffer size during socket life: 782 | 2023-02-07 09:27:32.732 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:27:32.732 Teton CME Order Routing | Waiting for socket receive thread to end | 2023-02-07 09:27:32.732 DTC Client socket (8) | CloseSocket call. | 2023-02-07 09:27:32.732 DTC Client socket (8) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:27:32.732 Teton CME Order Routing | Disconnected from the server. | 2023-02-07 09:27:32.733 Denali Data Feed | Waiting for socket receive thread to end | 2023-02-07 09:27:32.737 DTC Client socket (6) | CloseSocket call. | 2023-02-07 09:27:32.738 Denali Data Feed | Disconnected from the server. | 2023-02-07 09:27:32.738 Teton CME Order Routing | Disconnected. | 2023-02-07 09:27:32.738 DTC Client socket (6) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:27:32.738 DTC Client socket (8) | Socket gracefully closed by remote side. | 2023-02-07 09:27:32.949 DTC Client socket (8) | Closed. | 2023-02-07 09:27:32.949 Teton CME Order Routing | Firm: Dorman | 2023-02-07 09:27:35.217 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-02-07 09:27:35.217 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-02-07 09:27:35.217 DTC Client socket (2) | New receive buffer size: 5242880 | 2023-02-07 09:27:35.217 DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2023-02-07 09:27:35.217 Teton CME Order Routing | Network connection to server complete. | 2023-02-07 09:27:35.476 Teton CME Order Routing | Starting socket receive thread. | 2023-02-07 09:27:35.476 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-02-07 09:27:35.476 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-02-07 09:27:51.424 Teton CME Order Routing | Sending logon request message. | 2023-02-07 09:27:51.424 DTC Client socket (5) | Timed out waiting for shutdown. Performing an immediate socket close. | 2023-02-07 09:28:03.599 DTC Client socket (5) | Closed. | 2023-02-07 09:28:03.599 DTC Client socket (5) | Deleting network socket now after delay. | 2023-02-07 09:28:33.614 Service connection timed out. Will disconnect and retry. | 2023-02-07 09:28:35.208 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-07 09:28:35.208 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-07 09:28:35.208 Teton CME Order Routing | Waiting for socket receive thread to end | 2023-02-07 09:28:35.223 DTC Client socket (2) | CloseSocket call. | 2023-02-07 09:28:35.224 Teton CME Order Routing | Disconnected. | 2023-02-07 09:28:35.224 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-07 09:28:35.224 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:28:35.224 Teton CME Order Routing | Firm: Dorman | 2023-02-07 09:28:37.228 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-02-07 09:28:37.228 DTC Client socket (4) | Creating socket. Using TLS 1.2. | 2023-02-07 09:28:37.228 DTC Client socket (4) | New receive buffer size: 5242880 | 2023-02-07 09:28:37.228 DTC Client socket (4) | Connecting to IP: 208.185.224.129. | 2023-02-07 09:28:37.229 Teton CME Order Routing | Network connection to server complete. | 2023-02-07 09:28:37.478 Teton CME Order Routing | Starting socket receive thread. | 2023-02-07 09:28:37.478 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-02-07 09:28:37.479 File >> Disconnect selected. | 2023-02-07 09:28:38.385 Teton CME Order Routing | Waiting for socket receive thread to end | 2023-02-07 09:28:38.385 DTC Client socket (4) | CloseSocket call. | 2023-02-07 09:28:38.385 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:28:38.385 Teton CME Order Routing | Disconnected. | 2023-02-07 09:28:38.385 Teton CME Order Routing | Firm: Dorman | 2023-02-07 09:28:41.160 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-02-07 09:28:41.160 DTC Client socket (5) | Creating socket. Using TLS 1.2. | 2023-02-07 09:28:41.161 DTC Client socket (5) | New receive buffer size: 5242880 | 2023-02-07 09:28:41.161 DTC Client socket (5) | Connecting to IP: 208.185.224.129. | 2023-02-07 09:28:41.161 Teton CME Order Routing | Network connection to server complete. | 2023-02-07 09:28:41.417 Teton CME Order Routing | Starting socket receive thread. | 2023-02-07 09:28:41.417 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-02-07 09:28:41.417 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-02-07 09:28:42.792 Teton CME Order Routing | Sending logon request message. | 2023-02-07 09:28:42.792 Teton CME Order Routing | Received logon response. | 2023-02-07 09:28:43.036 Teton CME Order Routing | Server Name: SC DTC Server. Build=44641. | 2023-02-07 09:28:43.036 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-02-07 09:28:43.036 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2023-02-07 09:28:43.036 Teton CME Order Routing | Trading is supported. | 2023-02-07 09:28:43.036 Teton CME Order Routing | Order cancel and replace is supported. | 2023-02-07 09:28:43.036 Teton CME Order Routing | OCO Orders supported. | 2023-02-07 09:28:43.036 Teton CME Order Routing | Bracket Orders supported. | 2023-02-07 09:28:43.036 Teton CME Order Routing | Connected to server complete. | 2023-02-07 09:28:43.036 Triggering next historical data download in queue. | 2023-02-07 09:28:43.036 Triggering next historical data download in queue. | 2023-02-07 09:28:43.036 Triggering next historical data download in queue. | 2023-02-07 09:28:43.036 Triggering next historical data download in queue. | 2023-02-07 09:28:43.036 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:28:43.036 Mapping ESM20_FUT_CME to ESM20. Service code: cme | 2023-02-07 09:28:43.036 Using symbol data fast lookup vector | 2023-02-07 09:28:43.036 Denali Data Feed | Starting real-time market data updates for: ESM20_FUT_CME (ESM20). ID: 1 Service code: cme | 2023-02-07 09:28:43.036 Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443 | 2023-02-07 09:28:43.036 Denali Data Feed | Requesting security definition data for: ESM20_FUT_CME (ESM20). ID: 1 | 2023-02-07 09:28:43.036 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:28:43.036 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:28:43.036 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:28:43.036 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:28:43.036 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:28:43.036 Subscribing to symbol for symbol alert. ESU20_FUT_CME | 2023-02-07 09:28:43.036 Mapping ESU20_FUT_CME to ESU20. Service code: cme | 2023-02-07 09:28:43.036 Denali Data Feed | Starting real-time market data updates for: ESU20_FUT_CME (ESU20). ID: 2 Service code: cme | 2023-02-07 09:28:43.036 Denali Data Feed | Requesting security definition data for: ESU20_FUT_CME (ESU20). ID: 2 | 2023-02-07 09:28:43.036 Subscribing to symbol for symbol alert. GCG21_FUT_CME | 2023-02-07 09:28:43.036 Mapping GCG21_FUT_CME to GCG21. Service code: comex | 2023-02-07 09:28:43.036 Denali Data Feed | Starting real-time market data updates for: GCG21_FUT_CME (GCG21). ID: 3 Service code: comex | 2023-02-07 09:28:43.036 Denali Data Feed | Requesting security definition data for: GCG21_FUT_CME (GCG21). ID: 3 | 2023-02-07 09:28:43.036 Subscribing to symbol for symbol alert. 6EH21_FUT_CME | 2023-02-07 09:28:43.036 Mapping 6EH21_FUT_CME to 6EH21. Service code: cme | 2023-02-07 09:28:43.036 Denali Data Feed | Starting real-time market data updates for: 6EH21_FUT_CME (6EH21). ID: 4 Service code: cme | 2023-02-07 09:28:43.036 Denali Data Feed | Requesting security definition data for: 6EH21_FUT_CME (6EH21). ID: 4 | 2023-02-07 09:28:43.036 Subscribing to symbol for symbol alert. ESH21_FUT_CME | 2023-02-07 09:28:43.036 Mapping ESH21_FUT_CME to ESH21. Service code: cme | 2023-02-07 09:28:43.036 Denali Data Feed | Starting real-time market data updates for: ESH21_FUT_CME (ESH21). ID: 5 Service code: cme | 2023-02-07 09:28:43.036 Denali Data Feed | Requesting security definition data for: ESH21_FUT_CME (ESH21). ID: 5 | 2023-02-07 09:28:43.036 Subscribing to symbol for symbol alert. ESH21_FUT_CME | 2023-02-07 09:28:43.036 Updated verified funded futures trading account ending date to: 2023-03-09 17:28:43 | 2023-02-07 09:28:43.037 DTC Client socket (7) | Creating socket. | 2023-02-07 09:28:43.037 DTC Client socket (7) | New receive buffer size: 5242880 | 2023-02-07 09:28:43.037 DTC Client socket (7) | Connecting to IP: 142.215.18.147. | 2023-02-07 09:28:43.037 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2023-02-07 09:28:43.109 No download requests in the queue to start downloads for. | 2023-02-07 09:28:43.109 No download requests in the queue to start downloads for. | 2023-02-07 09:28:43.109 No download requests in the queue to start downloads for. | 2023-02-07 09:28:43.109 No download requests in the queue to start downloads for. | 2023-02-07 09:28:43.109 Mapping 6EH23_FUT_CME to 6EH23. Service code: cme | 2023-02-07 09:28:43.109 Denali Data Feed | Starting real-time market data updates for: 6EH23_FUT_CME (6EH23). ID: 6 Service code: cme | 2023-02-07 09:28:43.109 Denali Data Feed | Requesting security definition data for: 6EH23_FUT_CME (6EH23). ID: 6 | 2023-02-07 09:28:43.109 Added historical Intraday data request for 6EH23_FUT_CME to the queue. | 2023-02-07 09:28:43.109 Intraday data recording state for symbol 6EH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:28:43.109 Triggering next historical data download in queue. | 2023-02-07 09:28:43.109 Delaying start of download for 6EH23_FUT_CME. | 2023-02-07 09:28:43.112 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2023-02-07 15:03:49.033833 | 2023-02-07 09:28:43.112 Mapping RTYH23_FUT_CME to RTYH23. Service code: cme | 2023-02-07 09:28:43.112 Denali Data Feed | Starting real-time market data updates for: RTYH23_FUT_CME (RTYH23). ID: 7 Service code: cme | 2023-02-07 09:28:43.112 Denali Data Feed | Requesting security definition data for: RTYH23_FUT_CME (RTYH23). ID: 7 | 2023-02-07 09:28:43.113 Added historical Intraday data request for RTYH23_FUT_CME to the queue. | 2023-02-07 09:28:43.113 Intraday data recording state for symbol RTYH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:28:43.113 Triggering next historical data download in queue. | 2023-02-07 09:28:43.113 Mapping YMH23_FUT_CME to YMH23. Service code: cbot | 2023-02-07 09:28:43.115 Denali Data Feed | Starting real-time market data updates for: YMH23_FUT_CME (YMH23). ID: 8 Service code: cbot | 2023-02-07 09:28:43.115 Denali Data Feed | Requesting security definition data for: YMH23_FUT_CME (YMH23). ID: 8 | 2023-02-07 09:28:43.115 Added historical Intraday data request for YMH23_FUT_CME to the queue. | 2023-02-07 09:28:43.116 Intraday data recording state for symbol YMH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:28:43.116 Triggering next historical data download in queue. | 2023-02-07 09:28:43.116 Mapping ZNH23_FUT_CME to ZNH23. Service code: cbot | 2023-02-07 09:28:43.123 Denali Data Feed | Starting real-time market data updates for: ZNH23_FUT_CME (ZNH23). ID: 9 Service code: cbot | 2023-02-07 09:28:43.123 Denali Data Feed | Requesting security definition data for: ZNH23_FUT_CME (ZNH23). ID: 9 | 2023-02-07 09:28:43.123 Added historical Intraday data request for ZNH23_FUT_CME to the queue. | 2023-02-07 09:28:43.123 Intraday data recording state for symbol ZNH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:28:43.123 Triggering next historical data download in queue. | 2023-02-07 09:28:43.123 Mapping CLH23_FUT_CME to CLH23. Service code: nymex | 2023-02-07 09:28:43.125 Denali Data Feed | Starting real-time market data updates for: CLH23_FUT_CME (CLH23). ID: 10 Service code: nymex | 2023-02-07 09:28:43.125 Denali Data Feed | Requesting security definition data for: CLH23_FUT_CME (CLH23). ID: 10 | 2023-02-07 09:28:43.125 Added historical Intraday data request for CLH23_FUT_CME to the queue. | 2023-02-07 09:28:43.126 Intraday data recording state for symbol CLH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:28:43.126 Triggering next historical data download in queue. | 2023-02-07 09:28:43.126 Mapping TNH23_FUT_CME to TNH23. Service code: cbot | 2023-02-07 09:28:43.160 Denali Data Feed | Starting real-time market data updates for: TNH23_FUT_CME (TNH23). ID: 11 Service code: cbot | 2023-02-07 09:28:43.160 Denali Data Feed | Requesting security definition data for: TNH23_FUT_CME (TNH23). ID: 11 | 2023-02-07 09:28:43.160 Added historical Intraday data request for TNH23_FUT_CME to the queue. | 2023-02-07 09:28:43.160 Intraday data recording state for symbol TNH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:28:43.160 Triggering next historical data download in queue. | 2023-02-07 09:28:43.160 Mapping GCJ23_FUT_CME to GCJ23. Service code: comex | 2023-02-07 09:28:43.162 Denali Data Feed | Starting real-time market data updates for: GCJ23_FUT_CME (GCJ23). ID: 12 Service code: comex | 2023-02-07 09:28:43.162 Denali Data Feed | Requesting security definition data for: GCJ23_FUT_CME (GCJ23). ID: 12 | 2023-02-07 09:28:43.162 Added historical Intraday data request for GCJ23_FUT_CME to the queue. | 2023-02-07 09:28:43.162 Intraday data recording state for symbol GCJ23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:28:43.162 Triggering next historical data download in queue. | 2023-02-07 09:28:43.162 Mapping ZBH23_FUT_CME to ZBH23. Service code: cbot | 2023-02-07 09:28:43.177 Denali Data Feed | Starting real-time market data updates for: ZBH23_FUT_CME (ZBH23). ID: 13 Service code: cbot | 2023-02-07 09:28:43.177 Denali Data Feed | Requesting security definition data for: ZBH23_FUT_CME (ZBH23). ID: 13 | 2023-02-07 09:28:43.177 Added historical Intraday data request for ZBH23_FUT_CME to the queue. | 2023-02-07 09:28:43.177 Intraday data recording state for symbol ZBH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:28:43.177 Triggering next historical data download in queue. | 2023-02-07 09:28:43.177 Mapping ZFH23_FUT_CME to ZFH23. Service code: cbot | 2023-02-07 09:28:43.179 Denali Data Feed | Starting real-time market data updates for: ZFH23_FUT_CME (ZFH23). ID: 14 Service code: cbot | 2023-02-07 09:28:43.179 Denali Data Feed | Requesting security definition data for: ZFH23_FUT_CME (ZFH23). ID: 14 | 2023-02-07 09:28:43.179 Added historical Intraday data request for ZFH23_FUT_CME to the queue. | 2023-02-07 09:28:43.179 Intraday data recording state for symbol ZFH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:28:43.179 Triggering next historical data download in queue. | 2023-02-07 09:28:43.179 Mapping ESH23_FUT_CME to ESH23. Service code: cme | 2023-02-07 09:28:43.181 Denali Data Feed | Starting real-time market data updates for: ESH23_FUT_CME (ESH23). ID: 15 Service code: cme | 2023-02-07 09:28:43.181 Denali Data Feed | Requesting security definition data for: ESH23_FUT_CME (ESH23). ID: 15 | 2023-02-07 09:28:43.181 Added historical Intraday data request for ESH23_FUT_CME to the queue. | 2023-02-07 09:28:43.181 Intraday data recording state for symbol ESH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:28:43.181 Triggering next historical data download in queue. | 2023-02-07 09:28:43.181 Mapping UBH23_FUT_CME to UBH23. Service code: cbot | 2023-02-07 09:28:43.186 Denali Data Feed | Starting real-time market data updates for: UBH23_FUT_CME (UBH23). ID: 16 Service code: cbot | 2023-02-07 09:28:43.186 Denali Data Feed | Requesting security definition data for: UBH23_FUT_CME (UBH23). ID: 16 | 2023-02-07 09:28:43.186 Added historical Intraday data request for UBH23_FUT_CME to the queue. | 2023-02-07 09:28:43.186 Intraday data recording state for symbol UBH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:28:43.186 Triggering next historical data download in queue. | 2023-02-07 09:28:43.186 Mapping NQH23_FUT_CME to NQH23. Service code: cme | 2023-02-07 09:28:43.187 Denali Data Feed | Starting real-time market data updates for: NQH23_FUT_CME (NQH23). ID: 17 Service code: cme | 2023-02-07 09:28:43.187 Denali Data Feed | Requesting security definition data for: NQH23_FUT_CME (NQH23). ID: 17 | 2023-02-07 09:28:43.187 Added historical Intraday data request for NQH23_FUT_CME to the queue. | 2023-02-07 09:28:43.187 Intraday data recording state for symbol NQH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:28:43.187 Triggering next historical data download in queue. | 2023-02-07 09:28:43.187 Mapping GCG23_FUT_CME to GCG23. Service code: comex | 2023-02-07 09:28:43.215 Denali Data Feed | Starting real-time market data updates for: GCG23_FUT_CME (GCG23). ID: 18 Service code: comex | 2023-02-07 09:28:43.215 Denali Data Feed | Requesting security definition data for: GCG23_FUT_CME (GCG23). ID: 18 | 2023-02-07 09:28:43.215 Mapping CLG23_FUT_CME to CLG23. Service code: nymex | 2023-02-07 09:28:43.216 Denali Data Feed | Starting real-time market data updates for: CLG23_FUT_CME (CLG23). ID: 19 Service code: nymex | 2023-02-07 09:28:43.216 Denali Data Feed | Requesting security definition data for: CLG23_FUT_CME (CLG23). ID: 19 | 2023-02-07 09:28:43.216 Denali Data Feed | Network connection to server complete. | 2023-02-07 09:28:43.289 Denali Data Feed | Starting socket receive thread. | 2023-02-07 09:28:43.289 Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-07 09:28:43.290 Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-02-07 09:28:43.568 Denali Data Feed | Sending logon request message. | 2023-02-07 09:28:43.568 Denali Data Feed | Received logon response. | 2023-02-07 09:28:44.580 Denali Data Feed | Server Name: SC Realtime Server. | 2023-02-07 09:28:44.580 Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-02-07 09:28:44.580 Denali Data Feed | Successfully connected. | 2023-02-07 09:28:44.580 Denali Data Feed | Trading is not supported. | 2023-02-07 09:28:44.580 Denali Data Feed | Restarting real-time data updates for symbol: 6EH21_FUT_CME -> 6EH21 | 2023-02-07 09:28:44.580 Denali Data Feed | Restarting real-time data updates for symbol: 6EH23_FUT_CME -> 6EH23 | 2023-02-07 09:28:44.580 Denali Data Feed | Restarting real-time data updates for symbol: CLG23_FUT_CME -> CLG23 | 2023-02-07 09:28:44.580 Denali Data Feed | Restarting real-time data updates for symbol: CLH23_FUT_CME -> CLH23 | 2023-02-07 09:28:44.580 Denali Data Feed | Restarting real-time data updates for symbol: ESH21_FUT_CME -> ESH21 | 2023-02-07 09:28:44.580 Denali Data Feed | Restarting real-time data updates for symbol: ESH23_FUT_CME -> ESH23 | 2023-02-07 09:28:44.580 Denali Data Feed | Restarting real-time data updates for symbol: ESM20_FUT_CME -> ESM20 | 2023-02-07 09:28:44.580 Denali Data Feed | Restarting real-time data updates for symbol: ESU20_FUT_CME -> ESU20 | 2023-02-07 09:28:44.580 Denali Data Feed | Restarting real-time data updates for symbol: GCG21_FUT_CME -> GCG21 | 2023-02-07 09:28:44.580 Denali Data Feed | Restarting real-time data updates for symbol: GCG23_FUT_CME -> GCG23 | 2023-02-07 09:28:44.580 Denali Data Feed | Restarting real-time data updates for symbol: GCJ23_FUT_CME -> GCJ23 | 2023-02-07 09:28:44.580 Denali Data Feed | Restarting real-time data updates for symbol: NQH23_FUT_CME -> NQH23 | 2023-02-07 09:28:44.580 Denali Data Feed | Restarting real-time data updates for symbol: RTYH23_FUT_CME -> RTYH23 | 2023-02-07 09:28:44.580 Denali Data Feed | Restarting real-time data updates for symbol: TNH23_FUT_CME -> TNH23 | 2023-02-07 09:28:44.580 Denali Data Feed | Restarting real-time data updates for symbol: UBH23_FUT_CME -> UBH23 | 2023-02-07 09:28:44.580 Denali Data Feed | Restarting real-time data updates for symbol: YMH23_FUT_CME -> YMH23 | 2023-02-07 09:28:44.580 Denali Data Feed | Restarting real-time data updates for symbol: ZBH23_FUT_CME -> ZBH23 | 2023-02-07 09:28:44.580 Denali Data Feed | Restarting real-time data updates for symbol: ZFH23_FUT_CME -> ZFH23 | 2023-02-07 09:28:44.580 Denali Data Feed | Restarting real-time data updates for symbol: ZNH23_FUT_CME -> ZNH23 | 2023-02-07 09:28:44.580 Denali Data Feed | Real-time data for symbol 6EH21_FUT_CME is currently unavailable. | 2023-02-07 09:28:44.936 Denali Data Feed | Received security definition for symbol 6EH21_FUT_CME | 2023-02-07 09:28:44.936 Denali Data Feed | Received security definition for symbol 6EH23_FUT_CME | 2023-02-07 09:28:44.936 Denali Data Feed | Real-time data for symbol CLG23_FUT_CME is currently unavailable. | 2023-02-07 09:28:44.936 Denali Data Feed | Received security definition for symbol CLG23_FUT_CME | 2023-02-07 09:28:44.936 Denali Data Feed | Received security definition for symbol CLH23_FUT_CME | 2023-02-07 09:28:44.936 Denali Data Feed | Real-time data for symbol ESH21_FUT_CME is currently unavailable. | 2023-02-07 09:28:44.936 Denali Data Feed | Received security definition for symbol ESH21_FUT_CME | 2023-02-07 09:28:44.936 Denali Data Feed | Received security definition for symbol ESH23_FUT_CME | 2023-02-07 09:28:44.936 Denali Data Feed | Real-time data for symbol ESM20_FUT_CME is currently unavailable. | 2023-02-07 09:28:44.936 Denali Data Feed | Received security definition for symbol ESM20_FUT_CME | 2023-02-07 09:28:44.936 Denali Data Feed | Real-time data for symbol ESU20_FUT_CME is currently unavailable. | 2023-02-07 09:28:44.936 Denali Data Feed | Received security definition for symbol ESU20_FUT_CME | 2023-02-07 09:28:44.936 Denali Data Feed | Real-time data for symbol GCG21_FUT_CME is currently unavailable. | 2023-02-07 09:28:44.936 Denali Data Feed | Received security definition for symbol GCG21_FUT_CME | 2023-02-07 09:28:44.936 Denali Data Feed | Received security definition for symbol GCG23_FUT_CME | 2023-02-07 09:28:44.936 Denali Data Feed | Received security definition for symbol GCJ23_FUT_CME | 2023-02-07 09:28:44.936 Denali Data Feed | Received security definition for symbol NQH23_FUT_CME | 2023-02-07 09:28:44.936 Denali Data Feed | Received security definition for symbol RTYH23_FUT_CME | 2023-02-07 09:28:44.936 Denali Data Feed | Received security definition for symbol TNH23_FUT_CME | 2023-02-07 09:28:44.936 Denali Data Feed | Received security definition for symbol UBH23_FUT_CME | 2023-02-07 09:28:44.936 Denali Data Feed | Received security definition for symbol YMH23_FUT_CME | 2023-02-07 09:28:44.936 Denali Data Feed | Received security definition for symbol ZBH23_FUT_CME | 2023-02-07 09:28:44.936 Denali Data Feed | Received security definition for symbol ZFH23_FUT_CME | 2023-02-07 09:28:44.936 Denali Data Feed | Received security definition for symbol ZNH23_FUT_CME | 2023-02-07 09:28:44.936 Requesting market depth updates for: 6EH23_FUT_CME if supported. | 2023-02-07 09:28:48.031 Teton CME Order Routing | Connecting to the server ds28.sierracharts.com. Port 10060 | 2023-02-07 09:28:48.033 DTC Client socket (8) | Creating socket. | 2023-02-07 09:28:48.034 DTC Client socket (8) | New receive buffer size: 5242880 | 2023-02-07 09:28:48.034 DTC Client socket (8) | Connecting to IP: 142.215.18.147. | 2023-02-07 09:28:48.034 Requesting market depth updates for: CLH23_FUT_CME if supported. | 2023-02-07 09:28:48.034 Requesting market depth updates for: ESH23_FUT_CME if supported. | 2023-02-07 09:28:48.034 Requesting market depth updates for: GCJ23_FUT_CME if supported. | 2023-02-07 09:28:48.034 Requesting market depth updates for: NQH23_FUT_CME if supported. | 2023-02-07 09:28:48.034 Requesting market depth updates for: RTYH23_FUT_CME if supported. | 2023-02-07 09:28:48.034 Requesting market depth updates for: TNH23_FUT_CME if supported. | 2023-02-07 09:28:48.034 Requesting market depth updates for: UBH23_FUT_CME if supported. | 2023-02-07 09:28:48.034 Requesting market depth updates for: YMH23_FUT_CME if supported. | 2023-02-07 09:28:48.034 Requesting market depth updates for: ZBH23_FUT_CME if supported. | 2023-02-07 09:28:48.034 Requesting market depth updates for: ZFH23_FUT_CME if supported. | 2023-02-07 09:28:48.034 Requesting market depth updates for: ZNH23_FUT_CME if supported. | 2023-02-07 09:28:48.034 Teton CME Order Routing | Network connection to server complete. | 2023-02-07 09:28:48.270 Teton CME Order Routing | Starting socket receive thread. | 2023-02-07 09:28:48.270 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-07 09:28:48.270 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-02-07 09:28:48.521 Teton CME Order Routing | Sending logon request message. | 2023-02-07 09:28:48.521 Denali Data Feed | Clearing market depth for 6EH23_FUT_CME | 2023-02-07 09:28:48.852 Denali Data Feed | Clearing market depth for CLH23_FUT_CME | 2023-02-07 09:28:48.852 Denali Data Feed | Clearing market depth for ESH23_FUT_CME | 2023-02-07 09:28:48.852 Denali Data Feed | Clearing market depth for GCJ23_FUT_CME | 2023-02-07 09:28:48.852 Denali Data Feed | Clearing market depth for NQH23_FUT_CME | 2023-02-07 09:28:48.852 Denali Data Feed | Clearing market depth for RTYH23_FUT_CME | 2023-02-07 09:28:48.852 Denali Data Feed | Clearing market depth for TNH23_FUT_CME | 2023-02-07 09:28:48.852 Denali Data Feed | Clearing market depth for UBH23_FUT_CME | 2023-02-07 09:28:48.852 Denali Data Feed | Clearing market depth for YMH23_FUT_CME | 2023-02-07 09:28:48.852 Denali Data Feed | Clearing market depth for ZBH23_FUT_CME | 2023-02-07 09:28:48.852 Denali Data Feed | Clearing market depth for ZFH23_FUT_CME | 2023-02-07 09:28:48.853 Denali Data Feed | Clearing market depth for ZNH23_FUT_CME | 2023-02-07 09:28:48.853 Teton CME Order Routing | Received logon response. | 2023-02-07 09:28:49.374 Teton CME Order Routing | Server Name: SC Realtime Server. | 2023-02-07 09:28:49.374 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-02-07 09:28:49.374 Teton CME Order Routing | Successfully connected. | 2023-02-07 09:28:49.374 Teton CME Order Routing | Trading is not supported. | 2023-02-07 09:28:49.374 Teton CME Order Routing | Starting market orders updates for: 6EH23. MinimumMarketByOrderQuantity: 0. Service code: cme | 2023-02-07 09:28:49.374 Teton CME Order Routing | Restarting market orders data for symbol: 6EH23_FUT_CME -> 6EH23 | 2023-02-07 09:28:49.374 Teton CME Order Routing | Starting market orders updates for: CLH23. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2023-02-07 09:28:49.374 Teton CME Order Routing | Restarting market orders data for symbol: CLH23_FUT_CME -> CLH23 | 2023-02-07 09:28:49.374 Teton CME Order Routing | Starting market orders updates for: ESH23. MinimumMarketByOrderQuantity: 0. Service code: cme | 2023-02-07 09:28:49.374 Teton CME Order Routing | Restarting market orders data for symbol: ESH23_FUT_CME -> ESH23 | 2023-02-07 09:28:49.374 Teton CME Order Routing | Starting market orders updates for: GCJ23. MinimumMarketByOrderQuantity: 0. Service code: comex | 2023-02-07 09:28:49.374 Teton CME Order Routing | Restarting market orders data for symbol: GCJ23_FUT_CME -> GCJ23 | 2023-02-07 09:28:49.374 Teton CME Order Routing | Starting market orders updates for: NQH23. MinimumMarketByOrderQuantity: 0. Service code: cme | 2023-02-07 09:28:49.374 Teton CME Order Routing | Restarting market orders data for symbol: NQH23_FUT_CME -> NQH23 | 2023-02-07 09:28:49.374 Teton CME Order Routing | Starting market orders updates for: RTYH23. MinimumMarketByOrderQuantity: 0. Service code: cme | 2023-02-07 09:28:49.374 Teton CME Order Routing | Restarting market orders data for symbol: RTYH23_FUT_CME -> RTYH23 | 2023-02-07 09:28:49.374 Teton CME Order Routing | Starting market orders updates for: TNH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:28:49.374 Teton CME Order Routing | Restarting market orders data for symbol: TNH23_FUT_CME -> TNH23 | 2023-02-07 09:28:49.374 Teton CME Order Routing | Starting market orders updates for: UBH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:28:49.374 Teton CME Order Routing | Restarting market orders data for symbol: UBH23_FUT_CME -> UBH23 | 2023-02-07 09:28:49.374 Teton CME Order Routing | Starting market orders updates for: YMH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:28:49.374 Teton CME Order Routing | Restarting market orders data for symbol: YMH23_FUT_CME -> YMH23 | 2023-02-07 09:28:49.374 Teton CME Order Routing | Starting market orders updates for: ZBH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:28:49.374 Teton CME Order Routing | Restarting market orders data for symbol: ZBH23_FUT_CME -> ZBH23 | 2023-02-07 09:28:49.374 Teton CME Order Routing | Starting market orders updates for: ZFH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:28:49.374 Teton CME Order Routing | Restarting market orders data for symbol: ZFH23_FUT_CME -> ZFH23 | 2023-02-07 09:28:49.374 Teton CME Order Routing | Starting market orders updates for: ZNH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:28:49.374 Teton CME Order Routing | Restarting market orders data for symbol: ZNH23_FUT_CME -> ZNH23 | 2023-02-07 09:28:49.374 Teton CME Order Routing | Market Orders data has been rejected for symbol: 6EH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:28:49.759 Teton CME Order Routing | Market Orders data has been rejected for symbol: CLH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:28:49.759 Teton CME Order Routing | Market Orders data has been rejected for symbol: ESH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:28:49.759 Teton CME Order Routing | Market Orders data has been rejected for symbol: GCJ23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:28:49.759 Teton CME Order Routing | Market Orders data has been rejected for symbol: NQH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:28:49.759 Teton CME Order Routing | Market Orders data has been rejected for symbol: RTYH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:28:49.759 Teton CME Order Routing | Market Orders data has been rejected for symbol: TNH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:28:49.759 Teton CME Order Routing | Market Orders data has been rejected for symbol: UBH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:28:49.759 Teton CME Order Routing | Market Orders data has been rejected for symbol: YMH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:28:49.759 Teton CME Order Routing | Market Orders data has been rejected for symbol: ZBH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:28:49.759 Teton CME Order Routing | Market Orders data has been rejected for symbol: ZFH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:28:49.759 Teton CME Order Routing | Market Orders data has been rejected for symbol: ZNH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:28:49.759 HD Request # 31 | Downloading Intraday chart data for 6EH23_FUT_CME to the file 6EH23_FUT_CME.scid. Service: cme | 2023-02-07 09:28:49.775 HD Request # 31 | Download start date-time: 2023-02-07 09:27:29.000000. File last date-time: 2023-02-07 09:27:29.029002 | 2023-02-07 09:28:49.775 HD Request # 31 | Using server: ds28.sierracharts.com port 10150 | 2023-02-07 09:28:49.775 Socket (9) | Creating socket. | 2023-02-07 09:28:49.775 Socket (9) | New receive buffer size: 5242880 | 2023-02-07 09:28:49.775 Socket (9) | Connecting to IP: 142.215.18.147. | 2023-02-07 09:28:49.775 HD Request # 31 | Setting DTC encoding to Binary VLS | 2023-02-07 09:28:50.281 HD Request # 31 | Sending historical data logon request message. | 2023-02-07 09:28:50.281 HD Request # 31 | Requesting Intraday data. Start date-time: 2023-02-07 09:27:29. Record interval: 0. Symbol: 6EH23 | 2023-02-07 09:28:51.052 HD Request # 31 | Decompressing data. | 2023-02-07 09:28:51.305 HD Request # 31 | Receiving Intraday data for 6EH23_FUT_CME starting at 2023-02-07 09:27:29.029000 | 2023-02-07 09:28:51.305 Socket (9) | CloseSocket call. | 2023-02-07 09:28:51.306 Socket (9) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:28:51.306 Historical data download thread signaled to stop. | 2023-02-07 09:28:51.306 HD Request # 31 | Timestamp of first Intraday data file record written: 2023-02-07 09:27:36.269000. | 2023-02-07 09:28:51.306 HD Request # 31 | Received 141 Intraday data records from 2023-02-07 09:27:29.029000 to 2023-02-07 09:28:47.606000 (78.6 seconds) and wrote 138 records for 6EH23_FUT_CME | 2023-02-07 09:28:51.306 HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:28:47.606000 | 2023-02-07 09:28:51.310 HD Request # 31 | Completion time: 2s. | 2023-02-07 09:28:51.310 HD Request # 31 | Intraday data download complete for 6EH23_FUT_CME. Unique request ID: 31 | 2023-02-07 09:28:51.310 Removing historical data download ID 31. | 2023-02-07 09:28:51.310 Real-time Intraday chart data file updates started for 6EH23_FUT_CME | 2023-02-07 09:28:51.310 Intraday chart data file opened for 6EH23_FUT_CME | 2023-02-07 09:28:51.310 HD Request # 31 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:28:51.310 Triggering next historical data download in queue. | 2023-02-07 09:28:51.310 HD Request # 32 | Downloading Intraday chart data for RTYH23_FUT_CME to the file RTYH23_FUT_CME.scid. Service: cme | 2023-02-07 09:28:51.310 HD Request # 32 | Download start date-time: 2023-02-07 09:27:33.000000. File last date-time: 2023-02-07 09:27:33.128000 | 2023-02-07 09:28:51.310 HD Request # 32 | Using server: ds23.sierracharts.com port 10149 | 2023-02-07 09:28:51.310 Socket (10) | Creating socket. | 2023-02-07 09:28:51.310 Socket (10) | New receive buffer size: 5242880 | 2023-02-07 09:28:51.310 Socket (10) | Connecting to IP: 142.215.17.190. | 2023-02-07 09:28:51.310 Socket (9) | Socket gracefully closed by remote side. | 2023-02-07 09:28:51.562 Socket (9) | Closed. | 2023-02-07 09:28:51.562 HD Request # 32 | Setting DTC encoding to Binary VLS | 2023-02-07 09:28:51.813 HD Request # 32 | Sending historical data logon request message. | 2023-02-07 09:28:51.813 HD Request # 32 | Requesting Intraday data. Start date-time: 2023-02-07 09:27:33. Record interval: 0. Symbol: RTYH23 | 2023-02-07 09:28:52.568 HD Request # 32 | Decompressing data. | 2023-02-07 09:28:52.807 HD Request # 32 | Receiving Intraday data for RTYH23_FUT_CME starting at 2023-02-07 09:27:33.128000 | 2023-02-07 09:28:52.808 Socket (10) | CloseSocket call. | 2023-02-07 09:28:52.808 Socket (10) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:28:52.808 Historical data download thread signaled to stop. | 2023-02-07 09:28:52.808 HD Request # 32 | Timestamp of first Intraday data file record written: 2023-02-07 09:27:33.484000. | 2023-02-07 09:28:52.809 HD Request # 32 | Received 191 Intraday data records from 2023-02-07 09:27:33.128000 to 2023-02-07 09:28:51.869000 (78.7 seconds) and wrote 190 records for RTYH23_FUT_CME | 2023-02-07 09:28:52.809 HD Request # 32 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:28:51.869000 | 2023-02-07 09:28:52.811 HD Request # 32 | Completion time: 1s. | 2023-02-07 09:28:52.811 HD Request # 32 | Intraday data download complete for RTYH23_FUT_CME. Unique request ID: 32 | 2023-02-07 09:28:52.811 Removing historical data download ID 32. | 2023-02-07 09:28:52.811 Real-time Intraday chart data file updates started for RTYH23_FUT_CME | 2023-02-07 09:28:52.811 Intraday chart data file opened for RTYH23_FUT_CME | 2023-02-07 09:28:52.811 HD Request # 32 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:28:52.811 Triggering next historical data download in queue. | 2023-02-07 09:28:52.811 HD Request # 33 | Downloading Intraday chart data for YMH23_FUT_CME to the file YMH23_FUT_CME.scid. Service: cbot | 2023-02-07 09:28:52.811 HD Request # 33 | Download start date-time: 2023-02-07 09:27:32.000000. File last date-time: 2023-02-07 09:27:32.660000 | 2023-02-07 09:28:52.812 HD Request # 33 | Using server: ds26.sierracharts.com port 10150 | 2023-02-07 09:28:52.812 Socket (9) | Creating socket. | 2023-02-07 09:28:52.812 Socket (9) | New receive buffer size: 5242880 | 2023-02-07 09:28:52.812 Socket (9) | Connecting to IP: 142.215.17.188. | 2023-02-07 09:28:52.812 Socket (10) | Socket gracefully closed by remote side. | 2023-02-07 09:28:53.046 Socket (10) | Closed. | 2023-02-07 09:28:53.046 HD Request # 33 | Setting DTC encoding to Binary VLS | 2023-02-07 09:28:53.265 HD Request # 33 | Sending historical data logon request message. | 2023-02-07 09:28:53.265 HD Request # 33 | Requesting Intraday data. Start date-time: 2023-02-07 09:27:32. Record interval: 0. Symbol: YMH23 | 2023-02-07 09:28:54.011 HD Request # 33 | Decompressing data. | 2023-02-07 09:28:54.243 HD Request # 33 | Receiving Intraday data for YMH23_FUT_CME starting at 2023-02-07 09:27:32.111000 | 2023-02-07 09:28:54.243 Socket (9) | CloseSocket call. | 2023-02-07 09:28:54.244 Socket (9) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:28:54.244 Historical data download thread signaled to stop. | 2023-02-07 09:28:54.244 HD Request # 33 | Timestamp of first Intraday data file record written: 2023-02-07 09:27:35.326000. | 2023-02-07 09:28:54.244 HD Request # 33 | Received 220 Intraday data records from 2023-02-07 09:27:32.111000 to 2023-02-07 09:28:50.687000 (78.6 seconds) and wrote 218 records for YMH23_FUT_CME | 2023-02-07 09:28:54.244 HD Request # 33 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:28:50.687000 | 2023-02-07 09:28:54.247 Added 2 Time and Sales records to Intraday data file for YMH23_FUT_CME after download. | 2023-02-07 09:28:54.247 HD Request # 33 | Completion time: 2s. | 2023-02-07 09:28:54.247 HD Request # 33 | Intraday data download complete for YMH23_FUT_CME. Unique request ID: 33 | 2023-02-07 09:28:54.247 Removing historical data download ID 33. | 2023-02-07 09:28:54.247 Real-time Intraday chart data file updates started for YMH23_FUT_CME | 2023-02-07 09:28:54.247 Intraday chart data file opened for YMH23_FUT_CME | 2023-02-07 09:28:54.247 HD Request # 33 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:28:54.247 Triggering next historical data download in queue. | 2023-02-07 09:28:54.247 HD Request # 34 | Downloading Intraday chart data for ZNH23_FUT_CME to the file ZNH23_FUT_CME.scid. Service: cbot | 2023-02-07 09:28:54.247 HD Request # 34 | Download start date-time: 2023-02-07 09:27:30.000000. File last date-time: 2023-02-07 09:27:30.005000 | 2023-02-07 09:28:54.247 HD Request # 34 | Using server: ds28.sierracharts.com port 10149 | 2023-02-07 09:28:54.247 Socket (10) | Creating socket. | 2023-02-07 09:28:54.247 Socket (10) | New receive buffer size: 5242880 | 2023-02-07 09:28:54.247 Socket (10) | Connecting to IP: 142.215.18.147. | 2023-02-07 09:28:54.247 Socket (9) | Socket gracefully closed by remote side. | 2023-02-07 09:28:54.476 Socket (9) | Closed. | 2023-02-07 09:28:54.476 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\6EH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:28:54.515 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\RTYH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:28:54.515 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\YMH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:28:54.516 HD Request # 34 | Setting DTC encoding to Binary VLS | 2023-02-07 09:28:54.701 HD Request # 34 | Sending historical data logon request message. | 2023-02-07 09:28:54.701 HD Request # 34 | Requesting Intraday data. Start date-time: 2023-02-07 09:27:30. Record interval: 0. Symbol: ZNH23 | 2023-02-07 09:28:55.453 HD Request # 34 | Decompressing data. | 2023-02-07 09:28:55.678 HD Request # 34 | Receiving Intraday data for ZNH23_FUT_CME starting at 2023-02-07 09:27:30.005000 | 2023-02-07 09:28:55.679 Socket (10) | CloseSocket call. | 2023-02-07 09:28:55.679 Socket (10) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:28:55.679 Historical data download thread signaled to stop. | 2023-02-07 09:28:55.679 HD Request # 34 | Timestamp of first Intraday data file record written: 2023-02-07 09:27:33.821000. | 2023-02-07 09:28:55.679 HD Request # 34 | Received 522 Intraday data records from 2023-02-07 09:27:30.005000 to 2023-02-07 09:28:54.026000 (84.0 seconds) and wrote 521 records for ZNH23_FUT_CME | 2023-02-07 09:28:55.679 HD Request # 34 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:28:54.026000 | 2023-02-07 09:28:55.683 HD Request # 34 | Completion time: 1s. | 2023-02-07 09:28:55.683 HD Request # 34 | Intraday data download complete for ZNH23_FUT_CME. Unique request ID: 34 | 2023-02-07 09:28:55.683 Removing historical data download ID 34. | 2023-02-07 09:28:55.683 Real-time Intraday chart data file updates started for ZNH23_FUT_CME | 2023-02-07 09:28:55.683 Intraday chart data file opened for ZNH23_FUT_CME | 2023-02-07 09:28:55.683 HD Request # 34 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:28:55.683 Triggering next historical data download in queue. | 2023-02-07 09:28:55.683 HD Request # 35 | Downloading Intraday chart data for CLH23_FUT_CME to the file CLH23_FUT_CME.scid. Service: nymex | 2023-02-07 09:28:55.683 HD Request # 35 | Download start date-time: 2023-02-07 09:27:33.000000. File last date-time: 2023-02-07 09:27:33.007001 | 2023-02-07 09:28:55.684 HD Request # 35 | Using server: ds23.sierracharts.com port 10150 | 2023-02-07 09:28:55.684 Socket (9) | Creating socket. | 2023-02-07 09:28:55.684 Socket (9) | New receive buffer size: 5242880 | 2023-02-07 09:28:55.684 Socket (9) | Connecting to IP: 142.215.17.190. | 2023-02-07 09:28:55.684 Socket (10) | Socket gracefully closed by remote side. | 2023-02-07 09:28:55.914 Socket (10) | Closed. | 2023-02-07 09:28:55.914 HD Request # 35 | Setting DTC encoding to Binary VLS | 2023-02-07 09:28:56.168 HD Request # 35 | Sending historical data logon request message. | 2023-02-07 09:28:56.168 HD Request # 35 | Requesting Intraday data. Start date-time: 2023-02-07 09:27:33. Record interval: 0. Symbol: CLH23 | 2023-02-07 09:28:56.942 HD Request # 35 | Decompressing data. | 2023-02-07 09:28:57.181 HD Request # 35 | Receiving Intraday data for CLH23_FUT_CME starting at 2023-02-07 09:27:33.007000 | 2023-02-07 09:28:57.182 Socket (9) | CloseSocket call. | 2023-02-07 09:28:57.182 Socket (9) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:28:57.182 Historical data download thread signaled to stop. | 2023-02-07 09:28:57.215 HD Request # 35 | Timestamp of first Intraday data file record written: 2023-02-07 09:27:34.670000. | 2023-02-07 09:28:57.215 HD Request # 35 | Received 267 Intraday data records from 2023-02-07 09:27:33.007000 to 2023-02-07 09:28:55.584000 (82.6 seconds) and wrote 265 records for CLH23_FUT_CME | 2023-02-07 09:28:57.215 HD Request # 35 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:28:55.584000 | 2023-02-07 09:28:57.218 Added 1 Time and Sales records to Intraday data file for CLH23_FUT_CME after download. | 2023-02-07 09:28:57.218 HD Request # 35 | Completion time: 2s. | 2023-02-07 09:28:57.218 HD Request # 35 | Intraday data download complete for CLH23_FUT_CME. Unique request ID: 35 | 2023-02-07 09:28:57.218 Removing historical data download ID 35. | 2023-02-07 09:28:57.218 Real-time Intraday chart data file updates started for CLH23_FUT_CME | 2023-02-07 09:28:57.218 Intraday chart data file opened for CLH23_FUT_CME | 2023-02-07 09:28:57.218 HD Request # 35 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:28:57.218 Triggering next historical data download in queue. | 2023-02-07 09:28:57.218 HD Request # 36 | Downloading Intraday chart data for TNH23_FUT_CME to the file TNH23_FUT_CME.scid. Service: cbot | 2023-02-07 09:28:57.218 HD Request # 36 | Download start date-time: 2023-02-07 09:27:23.000000. File last date-time: 2023-02-07 09:27:23.230001 | 2023-02-07 09:28:57.218 HD Request # 36 | Using server: ds26.sierracharts.com port 10149 | 2023-02-07 09:28:57.218 Socket (10) | Creating socket. | 2023-02-07 09:28:57.218 Socket (10) | New receive buffer size: 5242880 | 2023-02-07 09:28:57.218 Socket (10) | Connecting to IP: 142.215.17.188. | 2023-02-07 09:28:57.218 Socket (9) | Socket gracefully closed by remote side. | 2023-02-07 09:28:57.420 Socket (9) | Closed. | 2023-02-07 09:28:57.420 HD Request # 36 | Setting DTC encoding to Binary VLS | 2023-02-07 09:28:57.720 HD Request # 36 | Sending historical data logon request message. | 2023-02-07 09:28:57.720 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESM20_FUT_CME | 2023-02-07 09:28:57.948 Teton CME Order Routing | Received security definition for symbol ESM20_FUT_CME | 2023-02-07 09:28:57.948 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESU20_FUT_CME | 2023-02-07 09:28:57.948 Teton CME Order Routing | Received security definition for symbol ESU20_FUT_CME | 2023-02-07 09:28:57.948 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: GCG21_FUT_CME | 2023-02-07 09:28:57.948 Teton CME Order Routing | Received security definition for symbol GCG21_FUT_CME | 2023-02-07 09:28:57.948 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6EH21_FUT_CME | 2023-02-07 09:28:57.948 Teton CME Order Routing | Received security definition for symbol 6EH21_FUT_CME | 2023-02-07 09:28:57.948 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH21_FUT_CME | 2023-02-07 09:28:57.948 Teton CME Order Routing | Received security definition for symbol ESH21_FUT_CME | 2023-02-07 09:28:57.948 HD Request # 36 | Requesting Intraday data. Start date-time: 2023-02-07 09:27:23. Record interval: 0. Symbol: TNH23 | 2023-02-07 09:28:58.484 HD Request # 36 | Decompressing data. | 2023-02-07 09:28:58.732 HD Request # 36 | Receiving Intraday data for TNH23_FUT_CME starting at 2023-02-07 09:27:23.230000 | 2023-02-07 09:28:58.732 Socket (10) | CloseSocket call. | 2023-02-07 09:28:58.732 Socket (10) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:28:58.732 Historical data download thread signaled to stop. | 2023-02-07 09:28:58.737 HD Request # 36 | Timestamp of first Intraday data file record written: 2023-02-07 09:27:58.177000. | 2023-02-07 09:28:58.737 HD Request # 36 | Received 131 Intraday data records from 2023-02-07 09:27:23.230000 to 2023-02-07 09:28:40.714001 (77.5 seconds) and wrote 129 records for TNH23_FUT_CME | 2023-02-07 09:28:58.737 HD Request # 36 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:28:40.714001 | 2023-02-07 09:28:58.740 HD Request # 36 | Completion time: 1s. | 2023-02-07 09:28:58.740 HD Request # 36 | Intraday data download complete for TNH23_FUT_CME. Unique request ID: 36 | 2023-02-07 09:28:58.740 Removing historical data download ID 36. | 2023-02-07 09:28:58.740 Real-time Intraday chart data file updates started for TNH23_FUT_CME | 2023-02-07 09:28:58.740 Intraday chart data file opened for TNH23_FUT_CME | 2023-02-07 09:28:58.740 HD Request # 36 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:28:58.740 Triggering next historical data download in queue. | 2023-02-07 09:28:58.740 HD Request # 37 | Downloading Intraday chart data for GCJ23_FUT_CME to the file GCJ23_FUT_CME.scid. Service: comex | 2023-02-07 09:28:58.740 HD Request # 37 | Download start date-time: 2023-02-07 09:27:33.000000. File last date-time: 2023-02-07 09:27:33.058000 | 2023-02-07 09:28:58.740 HD Request # 37 | Using server: ds28.sierracharts.com port 10150 | 2023-02-07 09:28:58.740 Socket (9) | Creating socket. | 2023-02-07 09:28:58.740 Socket (9) | New receive buffer size: 5242880 | 2023-02-07 09:28:58.740 Socket (9) | Connecting to IP: 142.215.18.147. | 2023-02-07 09:28:58.740 Socket (10) | Socket gracefully closed by remote side. | 2023-02-07 09:28:58.977 Socket (10) | Closed. | 2023-02-07 09:28:58.978 HD Request # 37 | Setting DTC encoding to Binary VLS | 2023-02-07 09:28:59.231 HD Request # 37 | Sending historical data logon request message. | 2023-02-07 09:28:59.231 HD Request # 37 | Requesting Intraday data. Start date-time: 2023-02-07 09:27:33. Record interval: 0. Symbol: GCJ23 | 2023-02-07 09:28:59.481 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\ZNH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:28:59.567 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\CLH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:28:59.567 HD Request # 37 | Decompressing data. | 2023-02-07 09:28:59.727 HD Request # 37 | Receiving Intraday data for GCJ23_FUT_CME starting at 2023-02-07 09:27:33.058000 | 2023-02-07 09:28:59.727 Socket (9) | CloseSocket call. | 2023-02-07 09:28:59.727 Socket (9) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:28:59.727 Historical data download thread signaled to stop. | 2023-02-07 09:28:59.749 HD Request # 37 | Timestamp of first Intraday data file record written: 2023-02-07 09:27:35.240000. | 2023-02-07 09:28:59.749 HD Request # 37 | Received 88 Intraday data records from 2023-02-07 09:27:33.058000 to 2023-02-07 09:28:48.854000 (75.8 seconds) and wrote 87 records for GCJ23_FUT_CME | 2023-02-07 09:28:59.749 HD Request # 37 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:28:48.854000 | 2023-02-07 09:28:59.752 Added 2 Time and Sales records to Intraday data file for GCJ23_FUT_CME after download. | 2023-02-07 09:28:59.752 HD Request # 37 | Completion time: 1s. | 2023-02-07 09:28:59.752 HD Request # 37 | Intraday data download complete for GCJ23_FUT_CME. Unique request ID: 37 | 2023-02-07 09:28:59.752 Removing historical data download ID 37. | 2023-02-07 09:28:59.752 Real-time Intraday chart data file updates started for GCJ23_FUT_CME | 2023-02-07 09:28:59.752 Intraday chart data file opened for GCJ23_FUT_CME | 2023-02-07 09:28:59.752 HD Request # 37 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:28:59.752 Triggering next historical data download in queue. | 2023-02-07 09:28:59.752 HD Request # 38 | Downloading Intraday chart data for ZBH23_FUT_CME to the file ZBH23_FUT_CME.scid. Service: cbot | 2023-02-07 09:28:59.752 HD Request # 38 | Download start date-time: 2023-02-07 09:27:32.000000. File last date-time: 2023-02-07 09:27:32.775000 | 2023-02-07 09:28:59.752 HD Request # 38 | Using server: ds23.sierracharts.com port 10149 | 2023-02-07 09:28:59.752 Socket (10) | Creating socket. | 2023-02-07 09:28:59.752 Socket (10) | New receive buffer size: 5242880 | 2023-02-07 09:28:59.752 Socket (10) | Connecting to IP: 142.215.17.190. | 2023-02-07 09:28:59.753 Socket (9) | Socket gracefully closed by remote side. | 2023-02-07 09:28:59.978 Socket (9) | Closed. | 2023-02-07 09:28:59.978 HD Request # 38 | Setting DTC encoding to Binary VLS | 2023-02-07 09:29:00.238 HD Request # 38 | Sending historical data logon request message. | 2023-02-07 09:29:00.238 HD Request # 38 | Requesting Intraday data. Start date-time: 2023-02-07 09:27:32. Record interval: 0. Symbol: ZBH23 | 2023-02-07 09:29:00.478 HD Request # 38 | Decompressing data. | 2023-02-07 09:29:00.720 HD Request # 38 | Receiving Intraday data for ZBH23_FUT_CME starting at 2023-02-07 09:27:32.775000 | 2023-02-07 09:29:00.721 Socket (10) | CloseSocket call. | 2023-02-07 09:29:00.721 Socket (10) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:29:00.721 Historical data download thread signaled to stop. | 2023-02-07 09:29:00.749 HD Request # 38 | Timestamp of first Intraday data file record written: 2023-02-07 09:27:37.030000. | 2023-02-07 09:29:00.749 HD Request # 38 | Received 281 Intraday data records from 2023-02-07 09:27:32.775000 to 2023-02-07 09:28:53.520000 (80.7 seconds) and wrote 280 records for ZBH23_FUT_CME | 2023-02-07 09:29:00.749 HD Request # 38 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:28:53.520000 | 2023-02-07 09:29:00.752 HD Request # 38 | Completion time: 1s. | 2023-02-07 09:29:00.752 HD Request # 38 | Intraday data download complete for ZBH23_FUT_CME. Unique request ID: 38 | 2023-02-07 09:29:00.752 Removing historical data download ID 38. | 2023-02-07 09:29:00.752 Real-time Intraday chart data file updates started for ZBH23_FUT_CME | 2023-02-07 09:29:00.752 Intraday chart data file opened for ZBH23_FUT_CME | 2023-02-07 09:29:00.752 HD Request # 38 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:29:00.752 Triggering next historical data download in queue. | 2023-02-07 09:29:00.752 HD Request # 39 | Downloading Intraday chart data for ZFH23_FUT_CME to the file ZFH23_FUT_CME.scid. Service: cbot | 2023-02-07 09:29:00.752 HD Request # 39 | Download start date-time: 2023-02-07 09:27:32.000000. File last date-time: 2023-02-07 09:27:32.419000 | 2023-02-07 09:29:00.752 HD Request # 39 | Using server: ds26.sierracharts.com port 10150 | 2023-02-07 09:29:00.752 Socket (9) | Creating socket. | 2023-02-07 09:29:00.752 Socket (9) | New receive buffer size: 5242880 | 2023-02-07 09:29:00.752 Socket (9) | Connecting to IP: 142.215.17.188. | 2023-02-07 09:29:00.752 Socket (10) | Socket gracefully closed by remote side. | 2023-02-07 09:29:00.969 Socket (10) | Closed. | 2023-02-07 09:29:00.969 HD Request # 39 | Setting DTC encoding to Binary VLS | 2023-02-07 09:29:01.232 HD Request # 39 | Sending historical data logon request message. | 2023-02-07 09:29:01.232 HD Request # 39 | Requesting Intraday data. Start date-time: 2023-02-07 09:27:32. Record interval: 0. Symbol: ZFH23 | 2023-02-07 09:29:01.466 HD Request # 39 | Decompressing data. | 2023-02-07 09:29:01.706 HD Request # 39 | Receiving Intraday data for ZFH23_FUT_CME starting at 2023-02-07 09:27:32.419000 | 2023-02-07 09:29:01.706 Socket (9) | CloseSocket call. | 2023-02-07 09:29:01.707 Socket (9) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:29:01.707 Historical data download thread signaled to stop. | 2023-02-07 09:29:01.708 HD Request # 39 | Timestamp of first Intraday data file record written: 2023-02-07 09:27:33.572000. | 2023-02-07 09:29:01.708 HD Request # 39 | Received 483 Intraday data records from 2023-02-07 09:27:32.419000 to 2023-02-07 09:28:42.548000 (70.1 seconds) and wrote 482 records for ZFH23_FUT_CME | 2023-02-07 09:29:01.708 HD Request # 39 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:28:42.548000 | 2023-02-07 09:29:01.711 Added 1 Time and Sales records to Intraday data file for ZFH23_FUT_CME after download. | 2023-02-07 09:29:01.711 HD Request # 39 | Completion time: 1s. | 2023-02-07 09:29:01.711 HD Request # 39 | Intraday data download complete for ZFH23_FUT_CME. Unique request ID: 39 | 2023-02-07 09:29:01.711 Removing historical data download ID 39. | 2023-02-07 09:29:01.711 Real-time Intraday chart data file updates started for ZFH23_FUT_CME | 2023-02-07 09:29:01.711 Intraday chart data file opened for ZFH23_FUT_CME | 2023-02-07 09:29:01.711 HD Request # 39 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:29:01.711 Triggering next historical data download in queue. | 2023-02-07 09:29:01.711 HD Request # 40 | Downloading Intraday chart data for ESH23_FUT_CME to the file ESH23_FUT_CME.scid. Service: cme | 2023-02-07 09:29:01.711 HD Request # 40 | Download start date-time: 2023-02-07 09:27:33.000000. File last date-time: 2023-02-07 09:27:33.128004 | 2023-02-07 09:29:01.711 HD Request # 40 | Using server: ds28.sierracharts.com port 10149 | 2023-02-07 09:29:01.711 Socket (10) | Creating socket. | 2023-02-07 09:29:01.711 Socket (10) | New receive buffer size: 5242880 | 2023-02-07 09:29:01.711 Socket (10) | Connecting to IP: 142.215.18.147. | 2023-02-07 09:29:01.711 Socket (9) | Socket gracefully closed by remote side. | 2023-02-07 09:29:01.942 Socket (9) | Closed. | 2023-02-07 09:29:01.942 HD Request # 40 | Setting DTC encoding to Binary VLS | 2023-02-07 09:29:02.186 HD Request # 40 | Sending historical data logon request message. | 2023-02-07 09:29:02.186 HD Request # 40 | Requesting Intraday data. Start date-time: 2023-02-07 09:27:33. Record interval: 0. Symbol: ESH23 | 2023-02-07 09:29:02.424 HD Request # 40 | Decompressing data. | 2023-02-07 09:29:02.656 HD Request # 40 | Receiving Intraday data for ESH23_FUT_CME starting at 2023-02-07 09:27:33.128000 | 2023-02-07 09:29:02.887 Socket (10) | CloseSocket call. | 2023-02-07 09:29:02.888 Socket (10) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:29:02.888 Historical data download thread signaled to stop. | 2023-02-07 09:29:02.914 HD Request # 40 | Timestamp of first Intraday data file record written: 2023-02-07 09:27:33.484000. | 2023-02-07 09:29:02.914 HD Request # 40 | Received 1764 Intraday data records from 2023-02-07 09:27:33.128000 to 2023-02-07 09:29:00.018001 (86.9 seconds) and wrote 1759 records for ESH23_FUT_CME | 2023-02-07 09:29:02.914 HD Request # 40 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:29:00.018001 | 2023-02-07 09:29:02.918 Added 44 Time and Sales records to Intraday data file for ESH23_FUT_CME after download. | 2023-02-07 09:29:02.918 HD Request # 40 | Completion time: 1s. | 2023-02-07 09:29:02.918 HD Request # 40 | Intraday data download complete for ESH23_FUT_CME. Unique request ID: 40 | 2023-02-07 09:29:02.918 Removing historical data download ID 40. | 2023-02-07 09:29:02.918 Real-time Intraday chart data file updates started for ESH23_FUT_CME | 2023-02-07 09:29:02.918 Intraday chart data file opened for ESH23_FUT_CME | 2023-02-07 09:29:02.918 HD Request # 40 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:29:02.918 Triggering next historical data download in queue. | 2023-02-07 09:29:02.918 HD Request # 41 | Downloading Intraday chart data for UBH23_FUT_CME to the file UBH23_FUT_CME.scid. Service: cbot | 2023-02-07 09:29:02.918 HD Request # 41 | Download start date-time: 2023-02-07 09:27:19.000000. File last date-time: 2023-02-07 09:27:19.758000 | 2023-02-07 09:29:02.918 HD Request # 41 | Using server: ds23.sierracharts.com port 10150 | 2023-02-07 09:29:02.918 Socket (9) | Creating socket. | 2023-02-07 09:29:02.918 Socket (9) | New receive buffer size: 5242880 | 2023-02-07 09:29:02.918 Socket (9) | Connecting to IP: 142.215.17.190. | 2023-02-07 09:29:02.918 Socket (10) | Socket gracefully closed by remote side. | 2023-02-07 09:29:03.114 Socket (10) | Closed. | 2023-02-07 09:29:03.114 HD Request # 41 | Setting DTC encoding to Binary VLS | 2023-02-07 09:29:03.382 HD Request # 41 | Sending historical data logon request message. | 2023-02-07 09:29:03.382 HD Request # 41 | Requesting Intraday data. Start date-time: 2023-02-07 09:27:19. Record interval: 0. Symbol: UBH23 | 2023-02-07 09:29:03.617 HD Request # 41 | Decompressing data. | 2023-02-07 09:29:03.850 HD Request # 41 | Receiving Intraday data for UBH23_FUT_CME starting at 2023-02-07 09:27:19.038000 | 2023-02-07 09:29:03.851 Socket (9) | CloseSocket call. | 2023-02-07 09:29:03.851 Socket (9) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:29:03.851 Historical data download thread signaled to stop. | 2023-02-07 09:29:03.860 HD Request # 41 | Timestamp of first Intraday data file record written: 2023-02-07 09:27:36.237000. | 2023-02-07 09:29:03.860 HD Request # 41 | Received 150 Intraday data records from 2023-02-07 09:27:19.038000 to 2023-02-07 09:28:59.793000 (100.8 seconds) and wrote 140 records for UBH23_FUT_CME | 2023-02-07 09:29:03.860 HD Request # 41 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:28:59.793000 | 2023-02-07 09:29:03.863 HD Request # 41 | Completion time: 1s. | 2023-02-07 09:29:03.863 HD Request # 41 | Intraday data download complete for UBH23_FUT_CME. Unique request ID: 41 | 2023-02-07 09:29:03.863 Removing historical data download ID 41. | 2023-02-07 09:29:03.863 Real-time Intraday chart data file updates started for UBH23_FUT_CME | 2023-02-07 09:29:03.863 Intraday chart data file opened for UBH23_FUT_CME | 2023-02-07 09:29:03.863 HD Request # 41 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:29:03.863 Triggering next historical data download in queue. | 2023-02-07 09:29:03.863 HD Request # 42 | Downloading Intraday chart data for NQH23_FUT_CME to the file NQH23_FUT_CME.scid. Service: cme | 2023-02-07 09:29:03.863 HD Request # 42 | Download start date-time: 2023-02-07 09:27:33.000000. File last date-time: 2023-02-07 09:27:33.103000 | 2023-02-07 09:29:03.863 HD Request # 42 | Using server: ds26.sierracharts.com port 10149 | 2023-02-07 09:29:03.863 Socket (10) | Creating socket. | 2023-02-07 09:29:03.863 Socket (10) | New receive buffer size: 5242880 | 2023-02-07 09:29:03.863 Socket (10) | Connecting to IP: 142.215.17.188. | 2023-02-07 09:29:03.863 Socket (9) | Socket gracefully closed by remote side. | 2023-02-07 09:29:04.091 Socket (9) | Closed. | 2023-02-07 09:29:04.091 HD Request # 42 | Setting DTC encoding to Binary VLS | 2023-02-07 09:29:04.347 HD Request # 42 | Sending historical data logon request message. | 2023-02-07 09:29:04.347 HD Request # 42 | Requesting Intraday data. Start date-time: 2023-02-07 09:27:33. Record interval: 0. Symbol: NQH23 | 2023-02-07 09:29:04.585 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\GCJ23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:29:04.598 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\ZFH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:29:04.598 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\ESH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:29:04.598 HD Request # 42 | Decompressing data. | 2023-02-07 09:29:04.828 HD Request # 42 | Receiving Intraday data for NQH23_FUT_CME starting at 2023-02-07 09:27:33.103000 | 2023-02-07 09:29:04.829 Socket (10) | CloseSocket call. | 2023-02-07 09:29:04.829 Socket (10) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:29:04.829 Historical data download thread signaled to stop. | 2023-02-07 09:29:04.836 HD Request # 42 | Timestamp of first Intraday data file record written: 2023-02-07 09:27:34.121000. | 2023-02-07 09:29:04.836 HD Request # 42 | Received 726 Intraday data records from 2023-02-07 09:27:33.103000 to 2023-02-07 09:29:04.738000 (91.6 seconds) and wrote 725 records for NQH23_FUT_CME | 2023-02-07 09:29:04.836 HD Request # 42 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:29:04.738000 | 2023-02-07 09:29:04.839 HD Request # 42 | Completion time: 1s. | 2023-02-07 09:29:04.839 HD Request # 42 | Intraday data download complete for NQH23_FUT_CME. Unique request ID: 42 | 2023-02-07 09:29:04.839 Removing historical data download ID 42. | 2023-02-07 09:29:04.839 Real-time Intraday chart data file updates started for NQH23_FUT_CME | 2023-02-07 09:29:04.839 Intraday chart data file opened for NQH23_FUT_CME | 2023-02-07 09:29:04.839 HD Request # 42 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:29:04.839 Triggering next historical data download in queue. | 2023-02-07 09:29:04.839 No download requests in the queue to start downloads for. | 2023-02-07 09:29:04.839 Socket (10) | Socket gracefully closed by remote side. | 2023-02-07 09:29:05.078 Socket (10) | Closed. | 2023-02-07 09:29:05.078 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\TNH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:29:09.645 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\ZBH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:29:09.645 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\UBH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:29:09.646 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\NQH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:29:09.646 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2023-02-07 09:29:32.970 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-02-07 09:29:32.970 DTC Client socket (1) | Closed. | 2023-02-07 09:29:32.970 DTC Client socket (6) | Timed out waiting for shutdown. Performing an immediate socket close. | 2023-02-07 09:29:33.631 DTC Client socket (6) | Closed. | 2023-02-07 09:29:33.631 Teton CME Order Routing | There has been no activity on the network socket for 1m 4s. Will reconnect. | 2023-02-07 09:30:01.165 Connection to the external service has been lost. | 2023-02-07 09:30:01.165 Teton CME Order Routing | Waiting for socket receive thread to end | 2023-02-07 09:30:01.229 DTC Client socket (5) | CloseSocket call. | 2023-02-07 09:30:01.230 DTC Client socket (5) | Max send buffers used during socket life: 5 | 2023-02-07 09:30:01.230 DTC Client socket (5) | Max send buffer size during socket life: 816 | 2023-02-07 09:30:01.230 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:30:01.230 Teton CME Order Routing | Disconnected. | 2023-02-07 09:30:01.230 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-07 09:30:01.230 Teton CME Order Routing | Firm: Dorman | 2023-02-07 09:30:03.216 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-02-07 09:30:03.216 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-02-07 09:30:03.217 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-02-07 09:30:03.217 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2023-02-07 09:30:03.217 DTC Client socket (6) | Deleting network socket now after delay. | 2023-02-07 09:30:03.645 Teton CME Order Routing | Network connection to server complete. | 2023-02-07 09:30:06.463 Teton CME Order Routing | Starting socket receive thread. | 2023-02-07 09:30:06.463 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-02-07 09:30:06.463 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-02-07 09:30:07.780 Teton CME Order Routing | Sending logon request message. | 2023-02-07 09:30:07.780 Teton CME Order Routing | Received logon response. | 2023-02-07 09:30:08.486 Teton CME Order Routing | Server Name: SC DTC Server. Build=44641. | 2023-02-07 09:30:08.486 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-02-07 09:30:08.486 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2023-02-07 09:30:08.486 Teton CME Order Routing | Trading is supported. | 2023-02-07 09:30:08.486 Teton CME Order Routing | Order cancel and replace is supported. | 2023-02-07 09:30:08.486 Teton CME Order Routing | OCO Orders supported. | 2023-02-07 09:30:08.486 Teton CME Order Routing | Bracket Orders supported. | 2023-02-07 09:30:08.486 Teton CME Order Routing | Connected to server complete. | 2023-02-07 09:30:08.486 Triggering next historical data download in queue. | 2023-02-07 09:30:08.486 Triggering next historical data download in queue. | 2023-02-07 09:30:08.486 Triggering next historical data download in queue. | 2023-02-07 09:30:08.486 Triggering next historical data download in queue. | 2023-02-07 09:30:08.486 Updated verified funded futures trading account ending date to: 2023-03-09 17:30:08 | 2023-02-07 09:30:08.486 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2023-02-07 09:30:08.561 No download requests in the queue to start downloads for. | 2023-02-07 09:30:08.561 No download requests in the queue to start downloads for. | 2023-02-07 09:30:08.561 No download requests in the queue to start downloads for. | 2023-02-07 09:30:08.561 No download requests in the queue to start downloads for. | 2023-02-07 09:30:08.561 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2023-02-07 15:03:49.033833 | 2023-02-07 09:30:08.568 Updated verified funded futures trading account ending date to: 2023-03-09 17:30:08 | 2023-02-07 09:30:08.801 DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2023-02-07 09:30:35.487 * DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-02-07 09:30:35.487 DTC Client socket (2) | Closed. | 2023-02-07 09:30:35.487 Teton CME Order Routing | Received final trade activity snapshot. Count=86. TradeAccount=44435 | 2023-02-07 09:30:50.593 NQH23_FUT_CME [CV][M] #14 | StartDateTimeForLoadingOrderFills: 2023-02-06 15:00:00 | 2023-02-07 09:30:50.662 DTC Client socket (4) | Timed out waiting for shutdown. Performing an immediate socket close. | 2023-02-07 09:31:03.661 DTC Client socket (4) | Closed. | 2023-02-07 09:31:03.661 DTC Client socket (4) | Deleting network socket now after delay. | 2023-02-07 09:31:33.676 Teton CME Order Routing | There has been no activity on the network socket for 57s. Will reconnect. | 2023-02-07 09:32:03.216 Connection to the external service has been lost. | 2023-02-07 09:32:03.216 Teton CME Order Routing | Waiting for socket receive thread to end | 2023-02-07 09:32:03.278 DTC Client socket (1) | CloseSocket call. | 2023-02-07 09:32:03.278 DTC Client socket (1) | Max send buffers used during socket life: 3 | 2023-02-07 09:32:03.278 DTC Client socket (1) | Max send buffer size during socket life: 329 | 2023-02-07 09:32:03.278 Teton CME Order Routing | Disconnected. | 2023-02-07 09:32:03.279 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-07 09:32:03.279 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:32:03.279 DTC Client socket (5) | Timed out waiting for shutdown. Performing an immediate socket close. | 2023-02-07 09:32:03.679 DTC Client socket (5) | Closed. | 2023-02-07 09:32:03.679 Teton CME Order Routing | Firm: Dorman | 2023-02-07 09:32:05.311 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-02-07 09:32:05.311 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-02-07 09:32:05.311 DTC Client socket (2) | New receive buffer size: 5242880 | 2023-02-07 09:32:05.312 DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2023-02-07 09:32:05.312 Teton CME Order Routing | Network connection to server complete. | 2023-02-07 09:32:08.551 Teton CME Order Routing | Starting socket receive thread. | 2023-02-07 09:32:08.551 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-02-07 09:32:08.551 Teton CME Order Routing | Did not receive Encoding Response from server. Disconnecting. | 2023-02-07 09:32:28.624 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-07 09:32:28.624 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-07 09:32:28.624 Teton CME Order Routing | Waiting for socket receive thread to end | 2023-02-07 09:32:28.661 DTC Client socket (2) | CloseSocket call. | 2023-02-07 09:32:28.661 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:32:28.661 Teton CME Order Routing | Disconnected. | 2023-02-07 09:32:28.662 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-07 09:32:28.662 Teton CME Order Routing | Firm: Dorman | 2023-02-07 09:32:30.683 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-02-07 09:32:30.683 DTC Client socket (4) | Creating socket. Using TLS 1.2. | 2023-02-07 09:32:30.684 DTC Client socket (4) | New receive buffer size: 5242880 | 2023-02-07 09:32:30.684 DTC Client socket (4) | Connecting to IP: 208.185.224.129. | 2023-02-07 09:32:30.684 Teton CME Order Routing | Network connection to server complete. | 2023-02-07 09:32:30.923 Teton CME Order Routing | Starting socket receive thread. | 2023-02-07 09:32:30.923 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-02-07 09:32:30.923 DTC Client socket (5) | Deleting network socket now after delay. | 2023-02-07 09:32:33.689 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-02-07 09:32:34.190 Teton CME Order Routing | Sending logon request message. | 2023-02-07 09:32:34.190 Teton CME Order Routing | Received logon response. | 2023-02-07 09:32:34.901 Teton CME Order Routing | Server Name: SC DTC Server. Build=44641. | 2023-02-07 09:32:34.901 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-02-07 09:32:34.901 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2023-02-07 09:32:34.901 Teton CME Order Routing | Trading is supported. | 2023-02-07 09:32:34.901 Teton CME Order Routing | Order cancel and replace is supported. | 2023-02-07 09:32:34.901 Teton CME Order Routing | OCO Orders supported. | 2023-02-07 09:32:34.901 Teton CME Order Routing | Bracket Orders supported. | 2023-02-07 09:32:34.901 Teton CME Order Routing | Connected to server complete. | 2023-02-07 09:32:34.901 Teton CME Order Routing | Waiting for socket receive thread to end | 2023-02-07 09:32:34.901 DTC Client socket (8) | CloseSocket call. | 2023-02-07 09:32:34.901 DTC Client socket (8) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:32:34.901 Teton CME Order Routing | Disconnected from the server. | 2023-02-07 09:32:34.901 Denali Data Feed | Waiting for socket receive thread to end | 2023-02-07 09:32:34.901 DTC Client socket (7) | CloseSocket call. | 2023-02-07 09:32:34.902 DTC Client socket (7) | Max send buffers used during socket life: 3 | 2023-02-07 09:32:34.902 DTC Client socket (7) | Max send buffer size during socket life: 1326 | 2023-02-07 09:32:34.902 Denali Data Feed | Disconnected from the server. | 2023-02-07 09:32:34.902 DTC Client socket (7) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:32:34.902 Triggering next historical data download in queue. | 2023-02-07 09:32:34.902 Triggering next historical data download in queue. | 2023-02-07 09:32:34.902 Triggering next historical data download in queue. | 2023-02-07 09:32:34.902 Triggering next historical data download in queue. | 2023-02-07 09:32:34.902 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:32:34.902 Mapping ESM20_FUT_CME to ESM20. Service code: cme | 2023-02-07 09:32:34.902 Using symbol data fast lookup vector | 2023-02-07 09:32:34.902 Denali Data Feed | Starting real-time market data updates for: ESM20_FUT_CME (ESM20). ID: 1 Service code: cme | 2023-02-07 09:32:34.902 Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443 | 2023-02-07 09:32:34.902 Denali Data Feed | Requesting security definition data for: ESM20_FUT_CME (ESM20). ID: 1 | 2023-02-07 09:32:34.902 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:32:34.902 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:32:34.902 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:32:34.902 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:32:34.902 Subscribing to symbol for symbol alert. ESM20_FUT_CME | 2023-02-07 09:32:34.902 Subscribing to symbol for symbol alert. ESU20_FUT_CME | 2023-02-07 09:32:34.902 Mapping ESU20_FUT_CME to ESU20. Service code: cme | 2023-02-07 09:32:34.902 Denali Data Feed | Starting real-time market data updates for: ESU20_FUT_CME (ESU20). ID: 2 Service code: cme | 2023-02-07 09:32:34.902 Denali Data Feed | Requesting security definition data for: ESU20_FUT_CME (ESU20). ID: 2 | 2023-02-07 09:32:34.902 Subscribing to symbol for symbol alert. GCG21_FUT_CME | 2023-02-07 09:32:34.902 Mapping GCG21_FUT_CME to GCG21. Service code: comex | 2023-02-07 09:32:34.902 Denali Data Feed | Starting real-time market data updates for: GCG21_FUT_CME (GCG21). ID: 3 Service code: comex | 2023-02-07 09:32:34.902 Denali Data Feed | Requesting security definition data for: GCG21_FUT_CME (GCG21). ID: 3 | 2023-02-07 09:32:34.902 Subscribing to symbol for symbol alert. 6EH21_FUT_CME | 2023-02-07 09:32:34.902 Mapping 6EH21_FUT_CME to 6EH21. Service code: cme | 2023-02-07 09:32:34.902 Denali Data Feed | Starting real-time market data updates for: 6EH21_FUT_CME (6EH21). ID: 4 Service code: cme | 2023-02-07 09:32:34.902 Denali Data Feed | Requesting security definition data for: 6EH21_FUT_CME (6EH21). ID: 4 | 2023-02-07 09:32:34.902 Subscribing to symbol for symbol alert. ESH21_FUT_CME | 2023-02-07 09:32:34.902 Mapping ESH21_FUT_CME to ESH21. Service code: cme | 2023-02-07 09:32:34.902 Denali Data Feed | Starting real-time market data updates for: ESH21_FUT_CME (ESH21). ID: 5 Service code: cme | 2023-02-07 09:32:34.902 Denali Data Feed | Requesting security definition data for: ESH21_FUT_CME (ESH21). ID: 5 | 2023-02-07 09:32:34.902 Subscribing to symbol for symbol alert. ESH21_FUT_CME | 2023-02-07 09:32:34.902 Updated verified funded futures trading account ending date to: 2023-03-09 17:32:34 | 2023-02-07 09:32:34.902 DTC Client socket (5) | Creating socket. | 2023-02-07 09:32:34.902 DTC Client socket (5) | New receive buffer size: 5242880 | 2023-02-07 09:32:34.902 DTC Client socket (5) | Connecting to IP: 142.215.18.147. | 2023-02-07 09:32:34.902 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2023-02-07 09:32:34.968 DTC Client socket (5) | CloseSocket call. | 2023-02-07 09:32:34.968 Denali Data Feed | Disconnected from the server. | 2023-02-07 09:32:34.968 Denali Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-02-07 09:32:34.968 No download requests in the queue to start downloads for. | 2023-02-07 09:32:34.968 No download requests in the queue to start downloads for. | 2023-02-07 09:32:34.968 No download requests in the queue to start downloads for. | 2023-02-07 09:32:34.968 No download requests in the queue to start downloads for. | 2023-02-07 09:32:34.968 DTC Client socket (5) | Closed. | 2023-02-07 09:32:34.968 Mapping ZBH23_FUT_CME to ZBH23. Service code: cbot | 2023-02-07 09:32:34.968 Denali Data Feed | Starting real-time market data updates for: ZBH23_FUT_CME (ZBH23). ID: 6 Service code: cbot | 2023-02-07 09:32:34.968 Denali Data Feed | Requesting security definition data for: ZBH23_FUT_CME (ZBH23). ID: 6 | 2023-02-07 09:32:34.968 Added historical Intraday data request for ZBH23_FUT_CME to the queue. | 2023-02-07 09:32:34.968 Intraday data recording state for symbol ZBH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:32:34.968 Triggering next historical data download in queue. | 2023-02-07 09:32:34.968 Delaying start of download for ZBH23_FUT_CME. | 2023-02-07 09:32:34.971 Mapping ZFH23_FUT_CME to ZFH23. Service code: cbot | 2023-02-07 09:32:34.971 Denali Data Feed | Starting real-time market data updates for: ZFH23_FUT_CME (ZFH23). ID: 7 Service code: cbot | 2023-02-07 09:32:34.971 Denali Data Feed | Requesting security definition data for: ZFH23_FUT_CME (ZFH23). ID: 7 | 2023-02-07 09:32:34.971 Added historical Intraday data request for ZFH23_FUT_CME to the queue. | 2023-02-07 09:32:34.971 Intraday data recording state for symbol ZFH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:32:34.971 Triggering next historical data download in queue. | 2023-02-07 09:32:34.971 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2023-02-07 15:03:49.033833 | 2023-02-07 09:32:34.973 Mapping ESH23_FUT_CME to ESH23. Service code: cme | 2023-02-07 09:32:34.973 Denali Data Feed | Starting real-time market data updates for: ESH23_FUT_CME (ESH23). ID: 8 Service code: cme | 2023-02-07 09:32:34.973 Denali Data Feed | Requesting security definition data for: ESH23_FUT_CME (ESH23). ID: 8 | 2023-02-07 09:32:34.973 Added historical Intraday data request for ESH23_FUT_CME to the queue. | 2023-02-07 09:32:34.973 Intraday data recording state for symbol ESH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:32:34.973 Triggering next historical data download in queue. | 2023-02-07 09:32:34.973 Mapping UBH23_FUT_CME to UBH23. Service code: cbot | 2023-02-07 09:32:34.980 Denali Data Feed | Starting real-time market data updates for: UBH23_FUT_CME (UBH23). ID: 9 Service code: cbot | 2023-02-07 09:32:34.980 Denali Data Feed | Requesting security definition data for: UBH23_FUT_CME (UBH23). ID: 9 | 2023-02-07 09:32:34.980 Added historical Intraday data request for UBH23_FUT_CME to the queue. | 2023-02-07 09:32:34.981 Intraday data recording state for symbol UBH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:32:34.981 Triggering next historical data download in queue. | 2023-02-07 09:32:34.981 Mapping NQH23_FUT_CME to NQH23. Service code: cme | 2023-02-07 09:32:34.982 Denali Data Feed | Starting real-time market data updates for: NQH23_FUT_CME (NQH23). ID: 10 Service code: cme | 2023-02-07 09:32:34.982 Denali Data Feed | Requesting security definition data for: NQH23_FUT_CME (NQH23). ID: 10 | 2023-02-07 09:32:34.982 Added historical Intraday data request for NQH23_FUT_CME to the queue. | 2023-02-07 09:32:34.982 Intraday data recording state for symbol NQH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:32:34.982 Triggering next historical data download in queue. | 2023-02-07 09:32:34.982 Mapping 6EH23_FUT_CME to 6EH23. Service code: cme | 2023-02-07 09:32:34.994 Denali Data Feed | Starting real-time market data updates for: 6EH23_FUT_CME (6EH23). ID: 11 Service code: cme | 2023-02-07 09:32:34.994 Denali Data Feed | Requesting security definition data for: 6EH23_FUT_CME (6EH23). ID: 11 | 2023-02-07 09:32:34.994 Added historical Intraday data request for 6EH23_FUT_CME to the queue. | 2023-02-07 09:32:34.994 Intraday data recording state for symbol 6EH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:32:34.994 Triggering next historical data download in queue. | 2023-02-07 09:32:34.994 Mapping RTYH23_FUT_CME to RTYH23. Service code: cme | 2023-02-07 09:32:34.996 Denali Data Feed | Starting real-time market data updates for: RTYH23_FUT_CME (RTYH23). ID: 12 Service code: cme | 2023-02-07 09:32:34.996 Denali Data Feed | Requesting security definition data for: RTYH23_FUT_CME (RTYH23). ID: 12 | 2023-02-07 09:32:34.996 Added historical Intraday data request for RTYH23_FUT_CME to the queue. | 2023-02-07 09:32:34.996 Intraday data recording state for symbol RTYH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:32:34.996 Triggering next historical data download in queue. | 2023-02-07 09:32:34.996 Mapping YMH23_FUT_CME to YMH23. Service code: cbot | 2023-02-07 09:32:34.998 Denali Data Feed | Starting real-time market data updates for: YMH23_FUT_CME (YMH23). ID: 13 Service code: cbot | 2023-02-07 09:32:34.998 Denali Data Feed | Requesting security definition data for: YMH23_FUT_CME (YMH23). ID: 13 | 2023-02-07 09:32:34.998 Added historical Intraday data request for YMH23_FUT_CME to the queue. | 2023-02-07 09:32:34.998 Intraday data recording state for symbol YMH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:32:34.998 Triggering next historical data download in queue. | 2023-02-07 09:32:34.998 Mapping ZNH23_FUT_CME to ZNH23. Service code: cbot | 2023-02-07 09:32:35.004 Denali Data Feed | Starting real-time market data updates for: ZNH23_FUT_CME (ZNH23). ID: 14 Service code: cbot | 2023-02-07 09:32:35.004 Denali Data Feed | Requesting security definition data for: ZNH23_FUT_CME (ZNH23). ID: 14 | 2023-02-07 09:32:35.004 Added historical Intraday data request for ZNH23_FUT_CME to the queue. | 2023-02-07 09:32:35.004 Intraday data recording state for symbol ZNH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:32:35.004 Triggering next historical data download in queue. | 2023-02-07 09:32:35.004 Mapping CLH23_FUT_CME to CLH23. Service code: nymex | 2023-02-07 09:32:35.005 Denali Data Feed | Starting real-time market data updates for: CLH23_FUT_CME (CLH23). ID: 15 Service code: nymex | 2023-02-07 09:32:35.005 Denali Data Feed | Requesting security definition data for: CLH23_FUT_CME (CLH23). ID: 15 | 2023-02-07 09:32:35.005 Added historical Intraday data request for CLH23_FUT_CME to the queue. | 2023-02-07 09:32:35.005 Intraday data recording state for symbol CLH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:32:35.005 Triggering next historical data download in queue. | 2023-02-07 09:32:35.005 Mapping TNH23_FUT_CME to TNH23. Service code: cbot | 2023-02-07 09:32:35.041 Denali Data Feed | Starting real-time market data updates for: TNH23_FUT_CME (TNH23). ID: 16 Service code: cbot | 2023-02-07 09:32:35.041 Denali Data Feed | Requesting security definition data for: TNH23_FUT_CME (TNH23). ID: 16 | 2023-02-07 09:32:35.041 Added historical Intraday data request for TNH23_FUT_CME to the queue. | 2023-02-07 09:32:35.041 Intraday data recording state for symbol TNH23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:32:35.041 Triggering next historical data download in queue. | 2023-02-07 09:32:35.041 Mapping GCJ23_FUT_CME to GCJ23. Service code: comex | 2023-02-07 09:32:35.043 Denali Data Feed | Starting real-time market data updates for: GCJ23_FUT_CME (GCJ23). ID: 17 Service code: comex | 2023-02-07 09:32:35.043 Denali Data Feed | Requesting security definition data for: GCJ23_FUT_CME (GCJ23). ID: 17 | 2023-02-07 09:32:35.043 Added historical Intraday data request for GCJ23_FUT_CME to the queue. | 2023-02-07 09:32:35.043 Intraday data recording state for symbol GCJ23_FUT_CME is set to download 'Pending'. | 2023-02-07 09:32:35.043 Triggering next historical data download in queue. | 2023-02-07 09:32:35.043 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESM20_FUT_CME | 2023-02-07 09:32:35.141 Teton CME Order Routing | Received security definition for symbol ESM20_FUT_CME | 2023-02-07 09:32:35.141 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESU20_FUT_CME | 2023-02-07 09:32:35.141 Teton CME Order Routing | Received security definition for symbol ESU20_FUT_CME | 2023-02-07 09:32:35.141 DTC Client socket (8) | Socket gracefully closed by remote side. | 2023-02-07 09:32:35.154 DTC Client socket (8) | Closed. | 2023-02-07 09:32:35.154 Mapping GCG23_FUT_CME to GCG23. Service code: comex | 2023-02-07 09:32:35.253 Denali Data Feed | Starting real-time market data updates for: GCG23_FUT_CME (GCG23). ID: 18 Service code: comex | 2023-02-07 09:32:35.253 Denali Data Feed | Requesting security definition data for: GCG23_FUT_CME (GCG23). ID: 18 | 2023-02-07 09:32:35.253 Mapping CLG23_FUT_CME to CLG23. Service code: nymex | 2023-02-07 09:32:35.255 Denali Data Feed | Starting real-time market data updates for: CLG23_FUT_CME (CLG23). ID: 19 Service code: nymex | 2023-02-07 09:32:35.255 Denali Data Feed | Requesting security definition data for: CLG23_FUT_CME (CLG23). ID: 19 | 2023-02-07 09:32:35.255 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: GCG21_FUT_CME | 2023-02-07 09:32:36.786 Teton CME Order Routing | Received security definition for symbol GCG21_FUT_CME | 2023-02-07 09:32:36.786 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6EH21_FUT_CME | 2023-02-07 09:32:36.786 Teton CME Order Routing | Received security definition for symbol 6EH21_FUT_CME | 2023-02-07 09:32:36.786 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH21_FUT_CME | 2023-02-07 09:32:36.786 Teton CME Order Routing | Received security definition for symbol ESH21_FUT_CME | 2023-02-07 09:32:36.786 Denali Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 443 | 2023-02-07 09:32:36.959 DTC Client socket (5) | Creating socket. | 2023-02-07 09:32:36.963 DTC Client socket (5) | New receive buffer size: 5242880 | 2023-02-07 09:32:36.963 DTC Client socket (5) | Connecting to IP: 142.215.17.189. | 2023-02-07 09:32:36.963 Denali Data Feed | Network connection to server complete. | 2023-02-07 09:32:37.224 Denali Data Feed | Starting socket receive thread. | 2023-02-07 09:32:37.224 Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-07 09:32:37.224 Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-02-07 09:32:37.517 Denali Data Feed | Sending logon request message. | 2023-02-07 09:32:37.517 Denali Data Feed | Received logon response. | 2023-02-07 09:32:38.508 Denali Data Feed | Server Name: SC Realtime Server. | 2023-02-07 09:32:38.508 Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-02-07 09:32:38.508 Denali Data Feed | Successfully connected. | 2023-02-07 09:32:38.508 Denali Data Feed | Trading is not supported. | 2023-02-07 09:32:38.508 Denali Data Feed | Restarting real-time data updates for symbol: 6EH21_FUT_CME -> 6EH21 | 2023-02-07 09:32:38.508 Denali Data Feed | Restarting real-time data updates for symbol: 6EH23_FUT_CME -> 6EH23 | 2023-02-07 09:32:38.508 Denali Data Feed | Restarting real-time data updates for symbol: CLG23_FUT_CME -> CLG23 | 2023-02-07 09:32:38.508 Denali Data Feed | Restarting real-time data updates for symbol: CLH23_FUT_CME -> CLH23 | 2023-02-07 09:32:38.508 Denali Data Feed | Restarting real-time data updates for symbol: ESH21_FUT_CME -> ESH21 | 2023-02-07 09:32:38.508 Denali Data Feed | Restarting real-time data updates for symbol: ESH23_FUT_CME -> ESH23 | 2023-02-07 09:32:38.508 Denali Data Feed | Restarting real-time data updates for symbol: ESM20_FUT_CME -> ESM20 | 2023-02-07 09:32:38.508 Denali Data Feed | Restarting real-time data updates for symbol: ESU20_FUT_CME -> ESU20 | 2023-02-07 09:32:38.508 Denali Data Feed | Restarting real-time data updates for symbol: GCG21_FUT_CME -> GCG21 | 2023-02-07 09:32:38.508 Denali Data Feed | Restarting real-time data updates for symbol: GCG23_FUT_CME -> GCG23 | 2023-02-07 09:32:38.508 Denali Data Feed | Restarting real-time data updates for symbol: GCJ23_FUT_CME -> GCJ23 | 2023-02-07 09:32:38.508 Denali Data Feed | Restarting real-time data updates for symbol: NQH23_FUT_CME -> NQH23 | 2023-02-07 09:32:38.508 Denali Data Feed | Restarting real-time data updates for symbol: RTYH23_FUT_CME -> RTYH23 | 2023-02-07 09:32:38.508 Denali Data Feed | Restarting real-time data updates for symbol: TNH23_FUT_CME -> TNH23 | 2023-02-07 09:32:38.508 Denali Data Feed | Restarting real-time data updates for symbol: UBH23_FUT_CME -> UBH23 | 2023-02-07 09:32:38.508 Denali Data Feed | Restarting real-time data updates for symbol: YMH23_FUT_CME -> YMH23 | 2023-02-07 09:32:38.508 Denali Data Feed | Restarting real-time data updates for symbol: ZBH23_FUT_CME -> ZBH23 | 2023-02-07 09:32:38.508 Denali Data Feed | Restarting real-time data updates for symbol: ZFH23_FUT_CME -> ZFH23 | 2023-02-07 09:32:38.508 Denali Data Feed | Restarting real-time data updates for symbol: ZNH23_FUT_CME -> ZNH23 | 2023-02-07 09:32:38.508 Denali Data Feed | Real-time data for symbol 6EH21_FUT_CME is currently unavailable. | 2023-02-07 09:32:38.844 Denali Data Feed | Received security definition for symbol 6EH21_FUT_CME | 2023-02-07 09:32:38.844 Denali Data Feed | Received security definition for symbol 6EH23_FUT_CME | 2023-02-07 09:32:38.844 Denali Data Feed | Real-time data for symbol CLG23_FUT_CME is currently unavailable. | 2023-02-07 09:32:38.844 Denali Data Feed | Received security definition for symbol CLG23_FUT_CME | 2023-02-07 09:32:38.844 Denali Data Feed | Received security definition for symbol CLH23_FUT_CME | 2023-02-07 09:32:38.844 Denali Data Feed | Real-time data for symbol ESH21_FUT_CME is currently unavailable. | 2023-02-07 09:32:38.844 Denali Data Feed | Received security definition for symbol ESH21_FUT_CME | 2023-02-07 09:32:38.844 Denali Data Feed | Received security definition for symbol ESH23_FUT_CME | 2023-02-07 09:32:38.844 Denali Data Feed | Real-time data for symbol ESM20_FUT_CME is currently unavailable. | 2023-02-07 09:32:38.844 Denali Data Feed | Received security definition for symbol ESM20_FUT_CME | 2023-02-07 09:32:38.844 Denali Data Feed | Real-time data for symbol ESU20_FUT_CME is currently unavailable. | 2023-02-07 09:32:38.844 Denali Data Feed | Received security definition for symbol ESU20_FUT_CME | 2023-02-07 09:32:38.844 Denali Data Feed | Real-time data for symbol GCG21_FUT_CME is currently unavailable. | 2023-02-07 09:32:38.844 Denali Data Feed | Received security definition for symbol GCG21_FUT_CME | 2023-02-07 09:32:38.844 Denali Data Feed | Received security definition for symbol GCG23_FUT_CME | 2023-02-07 09:32:38.844 Denali Data Feed | Received security definition for symbol GCJ23_FUT_CME | 2023-02-07 09:32:38.844 Denali Data Feed | Received security definition for symbol NQH23_FUT_CME | 2023-02-07 09:32:38.844 Denali Data Feed | Received security definition for symbol RTYH23_FUT_CME | 2023-02-07 09:32:38.844 Denali Data Feed | Received security definition for symbol TNH23_FUT_CME | 2023-02-07 09:32:38.844 Denali Data Feed | Received security definition for symbol UBH23_FUT_CME | 2023-02-07 09:32:38.844 Denali Data Feed | Received security definition for symbol YMH23_FUT_CME | 2023-02-07 09:32:38.844 Denali Data Feed | Received security definition for symbol ZBH23_FUT_CME | 2023-02-07 09:32:38.844 Denali Data Feed | Received security definition for symbol ZFH23_FUT_CME | 2023-02-07 09:32:38.844 Denali Data Feed | Received security definition for symbol ZNH23_FUT_CME | 2023-02-07 09:32:38.844 Updated verified funded futures trading account ending date to: 2023-03-09 17:32:39 | 2023-02-07 09:32:39.514 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZBH23_FUT_CME | 2023-02-07 09:32:39.514 Teton CME Order Routing | Received security definition for symbol ZBH23_FUT_CME | 2023-02-07 09:32:39.514 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZFH23_FUT_CME | 2023-02-07 09:32:39.514 Teton CME Order Routing | Received security definition for symbol ZFH23_FUT_CME | 2023-02-07 09:32:39.514 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH23_FUT_CME | 2023-02-07 09:32:39.514 Teton CME Order Routing | Received security definition for symbol ESH23_FUT_CME | 2023-02-07 09:32:39.514 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: UBH23_FUT_CME | 2023-02-07 09:32:39.514 Teton CME Order Routing | Received security definition for symbol UBH23_FUT_CME | 2023-02-07 09:32:39.514 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQH23_FUT_CME | 2023-02-07 09:32:39.514 Teton CME Order Routing | Received security definition for symbol NQH23_FUT_CME | 2023-02-07 09:32:39.514 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6EH23_FUT_CME | 2023-02-07 09:32:39.514 Teton CME Order Routing | Received security definition for symbol 6EH23_FUT_CME | 2023-02-07 09:32:39.514 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: RTYH23_FUT_CME | 2023-02-07 09:32:39.514 Teton CME Order Routing | Received security definition for symbol RTYH23_FUT_CME | 2023-02-07 09:32:39.514 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: YMH23_FUT_CME | 2023-02-07 09:32:39.514 Teton CME Order Routing | Received security definition for symbol YMH23_FUT_CME | 2023-02-07 09:32:39.514 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZNH23_FUT_CME | 2023-02-07 09:32:39.514 Teton CME Order Routing | Received security definition for symbol ZNH23_FUT_CME | 2023-02-07 09:32:39.514 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: CLH23_FUT_CME | 2023-02-07 09:32:39.514 Teton CME Order Routing | Received security definition for symbol CLH23_FUT_CME | 2023-02-07 09:32:39.514 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: TNH23_FUT_CME | 2023-02-07 09:32:39.514 Teton CME Order Routing | Received security definition for symbol TNH23_FUT_CME | 2023-02-07 09:32:39.514 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: GCJ23_FUT_CME | 2023-02-07 09:32:39.514 Teton CME Order Routing | Received security definition for symbol GCJ23_FUT_CME | 2023-02-07 09:32:39.514 Requesting market depth updates for: 6EH23_FUT_CME if supported. | 2023-02-07 09:32:39.946 Teton CME Order Routing | Connecting to the server ds26-2.sierracharts.com. Port 10060 | 2023-02-07 09:32:39.947 DTC Client socket (6) | Creating socket. | 2023-02-07 09:32:39.947 DTC Client socket (6) | New receive buffer size: 5242880 | 2023-02-07 09:32:39.947 DTC Client socket (6) | Connecting to IP: 142.215.17.189. | 2023-02-07 09:32:39.947 Requesting market depth updates for: CLH23_FUT_CME if supported. | 2023-02-07 09:32:39.948 Requesting market depth updates for: ESH23_FUT_CME if supported. | 2023-02-07 09:32:39.948 Requesting market depth updates for: GCJ23_FUT_CME if supported. | 2023-02-07 09:32:39.948 Requesting market depth updates for: NQH23_FUT_CME if supported. | 2023-02-07 09:32:39.948 Requesting market depth updates for: RTYH23_FUT_CME if supported. | 2023-02-07 09:32:39.948 Requesting market depth updates for: TNH23_FUT_CME if supported. | 2023-02-07 09:32:39.948 Requesting market depth updates for: UBH23_FUT_CME if supported. | 2023-02-07 09:32:39.948 Requesting market depth updates for: YMH23_FUT_CME if supported. | 2023-02-07 09:32:39.948 Requesting market depth updates for: ZBH23_FUT_CME if supported. | 2023-02-07 09:32:39.948 Requesting market depth updates for: ZFH23_FUT_CME if supported. | 2023-02-07 09:32:39.948 Requesting market depth updates for: ZNH23_FUT_CME if supported. | 2023-02-07 09:32:39.948 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: GCG23_FUT_CME | 2023-02-07 09:32:40.002 Teton CME Order Routing | Received security definition for symbol GCG23_FUT_CME | 2023-02-07 09:32:40.002 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: CLG23_FUT_CME | 2023-02-07 09:32:40.002 Teton CME Order Routing | Received security definition for symbol CLG23_FUT_CME | 2023-02-07 09:32:40.002 Teton CME Order Routing | Network connection to server complete. | 2023-02-07 09:32:40.205 Teton CME Order Routing | Starting socket receive thread. | 2023-02-07 09:32:40.205 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-07 09:32:40.205 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-02-07 09:32:40.457 Teton CME Order Routing | Sending logon request message. | 2023-02-07 09:32:40.457 Denali Data Feed | Clearing market depth for 6EH23_FUT_CME | 2023-02-07 09:32:40.699 Denali Data Feed | Clearing market depth for CLH23_FUT_CME | 2023-02-07 09:32:40.700 Denali Data Feed | Clearing market depth for ESH23_FUT_CME | 2023-02-07 09:32:40.700 Denali Data Feed | Clearing market depth for GCJ23_FUT_CME | 2023-02-07 09:32:40.700 Denali Data Feed | Clearing market depth for NQH23_FUT_CME | 2023-02-07 09:32:40.700 Denali Data Feed | Clearing market depth for RTYH23_FUT_CME | 2023-02-07 09:32:40.700 Denali Data Feed | Clearing market depth for TNH23_FUT_CME | 2023-02-07 09:32:40.700 Denali Data Feed | Clearing market depth for UBH23_FUT_CME | 2023-02-07 09:32:40.701 Denali Data Feed | Clearing market depth for YMH23_FUT_CME | 2023-02-07 09:32:40.701 Denali Data Feed | Clearing market depth for ZBH23_FUT_CME | 2023-02-07 09:32:40.701 Denali Data Feed | Clearing market depth for ZFH23_FUT_CME | 2023-02-07 09:32:40.701 Denali Data Feed | Clearing market depth for ZNH23_FUT_CME | 2023-02-07 09:32:40.701 Teton CME Order Routing | Received logon response. | 2023-02-07 09:32:41.311 Teton CME Order Routing | Server Name: SC Realtime Server. | 2023-02-07 09:32:41.311 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-02-07 09:32:41.311 Teton CME Order Routing | Successfully connected. | 2023-02-07 09:32:41.311 Teton CME Order Routing | Trading is not supported. | 2023-02-07 09:32:41.311 Teton CME Order Routing | Starting market orders updates for: 6EH23. MinimumMarketByOrderQuantity: 0. Service code: cme | 2023-02-07 09:32:41.311 Teton CME Order Routing | Restarting market orders data for symbol: 6EH23_FUT_CME -> 6EH23 | 2023-02-07 09:32:41.311 Teton CME Order Routing | Starting market orders updates for: CLH23. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2023-02-07 09:32:41.311 Teton CME Order Routing | Restarting market orders data for symbol: CLH23_FUT_CME -> CLH23 | 2023-02-07 09:32:41.311 Teton CME Order Routing | Starting market orders updates for: ESH23. MinimumMarketByOrderQuantity: 0. Service code: cme | 2023-02-07 09:32:41.311 Teton CME Order Routing | Restarting market orders data for symbol: ESH23_FUT_CME -> ESH23 | 2023-02-07 09:32:41.311 Teton CME Order Routing | Starting market orders updates for: GCJ23. MinimumMarketByOrderQuantity: 0. Service code: comex | 2023-02-07 09:32:41.311 Teton CME Order Routing | Restarting market orders data for symbol: GCJ23_FUT_CME -> GCJ23 | 2023-02-07 09:32:41.311 Teton CME Order Routing | Starting market orders updates for: NQH23. MinimumMarketByOrderQuantity: 0. Service code: cme | 2023-02-07 09:32:41.311 Teton CME Order Routing | Restarting market orders data for symbol: NQH23_FUT_CME -> NQH23 | 2023-02-07 09:32:41.311 Teton CME Order Routing | Starting market orders updates for: RTYH23. MinimumMarketByOrderQuantity: 0. Service code: cme | 2023-02-07 09:32:41.311 Teton CME Order Routing | Restarting market orders data for symbol: RTYH23_FUT_CME -> RTYH23 | 2023-02-07 09:32:41.311 Teton CME Order Routing | Starting market orders updates for: TNH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:32:41.311 Teton CME Order Routing | Restarting market orders data for symbol: TNH23_FUT_CME -> TNH23 | 2023-02-07 09:32:41.311 Teton CME Order Routing | Starting market orders updates for: UBH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:32:41.311 Teton CME Order Routing | Restarting market orders data for symbol: UBH23_FUT_CME -> UBH23 | 2023-02-07 09:32:41.311 Teton CME Order Routing | Starting market orders updates for: YMH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:32:41.311 Teton CME Order Routing | Restarting market orders data for symbol: YMH23_FUT_CME -> YMH23 | 2023-02-07 09:32:41.311 Teton CME Order Routing | Starting market orders updates for: ZBH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:32:41.311 Teton CME Order Routing | Restarting market orders data for symbol: ZBH23_FUT_CME -> ZBH23 | 2023-02-07 09:32:41.311 Teton CME Order Routing | Starting market orders updates for: ZFH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:32:41.311 Teton CME Order Routing | Restarting market orders data for symbol: ZFH23_FUT_CME -> ZFH23 | 2023-02-07 09:32:41.311 Teton CME Order Routing | Starting market orders updates for: ZNH23. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2023-02-07 09:32:41.311 Teton CME Order Routing | Restarting market orders data for symbol: ZNH23_FUT_CME -> ZNH23 | 2023-02-07 09:32:41.311 Teton CME Order Routing | Market Orders data has been rejected for symbol: 6EH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:32:41.651 Teton CME Order Routing | Market Orders data has been rejected for symbol: CLH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:32:41.651 Teton CME Order Routing | Market Orders data has been rejected for symbol: ESH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:32:41.651 Teton CME Order Routing | Market Orders data has been rejected for symbol: GCJ23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:32:41.651 Teton CME Order Routing | Market Orders data has been rejected for symbol: NQH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:32:41.651 Teton CME Order Routing | Market Orders data has been rejected for symbol: RTYH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:32:41.651 Teton CME Order Routing | Market Orders data has been rejected for symbol: TNH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:32:41.651 Teton CME Order Routing | Market Orders data has been rejected for symbol: UBH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:32:41.651 Teton CME Order Routing | Market Orders data has been rejected for symbol: YMH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:32:41.651 Teton CME Order Routing | Market Orders data has been rejected for symbol: ZBH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:32:41.651 Teton CME Order Routing | Market Orders data has been rejected for symbol: ZFH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:32:41.651 Teton CME Order Routing | Market Orders data has been rejected for symbol: ZNH23_FUT_CME. Market orders request not authorized. | 2023-02-07 09:32:41.651 Teton CME Order Routing | Received final trade activity snapshot. Count=95. TradeAccount=44435 | 2023-02-07 09:32:42.591 HD Request # 43 | Downloading Intraday chart data for ZBH23_FUT_CME to the file ZBH23_FUT_CME.scid. Service: cbot | 2023-02-07 09:32:43.075 HD Request # 43 | Download start date-time: 2023-02-07 09:32:27.000000. File last date-time: 2023-02-07 09:32:27.616000 | 2023-02-07 09:32:43.075 HD Request # 43 | Using server: ds28.sierracharts.com port 10150 | 2023-02-07 09:32:43.075 Socket (8) | Creating socket. | 2023-02-07 09:32:43.075 Socket (8) | New receive buffer size: 5242880 | 2023-02-07 09:32:43.076 Socket (8) | Connecting to IP: 142.215.18.147. | 2023-02-07 09:32:43.076 HD Request # 43 | Setting DTC encoding to Binary VLS | 2023-02-07 09:32:43.555 HD Request # 43 | Sending historical data logon request message. | 2023-02-07 09:32:43.555 HD Request # 43 | Requesting Intraday data. Start date-time: 2023-02-07 09:32:27. Record interval: 0. Symbol: ZBH23 | 2023-02-07 09:32:44.312 HD Request # 43 | Decompressing data. | 2023-02-07 09:32:44.546 HD Request # 43 | Receiving Intraday data for ZBH23_FUT_CME starting at 2023-02-07 09:32:27.595000 | 2023-02-07 09:32:44.546 Socket (8) | CloseSocket call. | 2023-02-07 09:32:44.546 Socket (8) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:32:44.547 Historical data download thread signaled to stop. | 2023-02-07 09:32:44.547 HD Request # 43 | Timestamp of first Intraday data file record written: 2023-02-07 09:32:29.810000. | 2023-02-07 09:32:44.547 HD Request # 43 | Received 100 Intraday data records from 2023-02-07 09:32:27.595000 to 2023-02-07 09:32:38.762001 (11.2 seconds) and wrote 98 records for ZBH23_FUT_CME | 2023-02-07 09:32:44.547 HD Request # 43 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:32:38.762001 | 2023-02-07 09:32:44.551 HD Request # 43 | Completion time: 1s. | 2023-02-07 09:32:44.551 HD Request # 43 | Intraday data download complete for ZBH23_FUT_CME. Unique request ID: 43 | 2023-02-07 09:32:44.551 Removing historical data download ID 43. | 2023-02-07 09:32:44.551 Real-time Intraday chart data file updates started for ZBH23_FUT_CME | 2023-02-07 09:32:44.551 Intraday chart data file opened for ZBH23_FUT_CME | 2023-02-07 09:32:44.551 HD Request # 43 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:32:44.551 Triggering next historical data download in queue. | 2023-02-07 09:32:44.551 HD Request # 44 | Downloading Intraday chart data for ZFH23_FUT_CME to the file ZFH23_FUT_CME.scid. Service: cbot | 2023-02-07 09:32:44.551 HD Request # 44 | Download start date-time: 2023-02-07 09:32:28.000000. File last date-time: 2023-02-07 09:32:28.155000 | 2023-02-07 09:32:44.551 HD Request # 44 | Using server: ds23.sierracharts.com port 10149 | 2023-02-07 09:32:44.551 Socket (9) | Creating socket. | 2023-02-07 09:32:44.551 Socket (9) | New receive buffer size: 5242880 | 2023-02-07 09:32:44.551 Socket (9) | Connecting to IP: 142.215.17.190. | 2023-02-07 09:32:44.551 Socket (8) | Socket gracefully closed by remote side. | 2023-02-07 09:32:44.783 Socket (8) | Closed. | 2023-02-07 09:32:44.783 HD Request # 44 | Setting DTC encoding to Binary VLS | 2023-02-07 09:32:44.999 HD Request # 44 | Sending historical data logon request message. | 2023-02-07 09:32:44.999 HD Request # 44 | Requesting Intraday data. Start date-time: 2023-02-07 09:32:28. Record interval: 0. Symbol: ZFH23 | 2023-02-07 09:32:45.744 HD Request # 44 | Decompressing data. | 2023-02-07 09:32:45.956 HD Request # 44 | Receiving Intraday data for ZFH23_FUT_CME starting at 2023-02-07 09:32:28.155000 | 2023-02-07 09:32:45.958 Socket (9) | CloseSocket call. | 2023-02-07 09:32:45.958 Socket (9) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:32:45.958 Historical data download thread signaled to stop. | 2023-02-07 09:32:45.958 HD Request # 44 | Timestamp of first Intraday data file record written: 2023-02-07 09:32:29.840000. | 2023-02-07 09:32:45.958 HD Request # 44 | Received 266 Intraday data records from 2023-02-07 09:32:28.155000 to 2023-02-07 09:32:43.032000 (14.9 seconds) and wrote 265 records for ZFH23_FUT_CME | 2023-02-07 09:32:45.958 HD Request # 44 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:32:43.032000 | 2023-02-07 09:32:45.962 Added 120 Time and Sales records to Intraday data file for ZFH23_FUT_CME after download. | 2023-02-07 09:32:45.962 HD Request # 44 | Completion time: 1s. | 2023-02-07 09:32:45.962 HD Request # 44 | Intraday data download complete for ZFH23_FUT_CME. Unique request ID: 44 | 2023-02-07 09:32:45.962 Removing historical data download ID 44. | 2023-02-07 09:32:45.962 Real-time Intraday chart data file updates started for ZFH23_FUT_CME | 2023-02-07 09:32:45.962 Intraday chart data file opened for ZFH23_FUT_CME | 2023-02-07 09:32:45.962 HD Request # 44 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:32:45.962 Triggering next historical data download in queue. | 2023-02-07 09:32:45.962 HD Request # 45 | Downloading Intraday chart data for ESH23_FUT_CME to the file ESH23_FUT_CME.scid. Service: cme | 2023-02-07 09:32:45.962 HD Request # 45 | Download start date-time: 2023-02-07 09:32:29.000000. File last date-time: 2023-02-07 09:32:29.124000 | 2023-02-07 09:32:45.962 HD Request # 45 | Using server: ds26.sierracharts.com port 10150 | 2023-02-07 09:32:45.962 Socket (8) | Creating socket. | 2023-02-07 09:32:45.962 Socket (8) | New receive buffer size: 5242880 | 2023-02-07 09:32:45.962 Socket (8) | Connecting to IP: 142.215.17.188. | 2023-02-07 09:32:45.962 Socket (9) | Socket gracefully closed by remote side. | 2023-02-07 09:32:46.169 Socket (9) | Closed. | 2023-02-07 09:32:46.169 HD Request # 45 | Setting DTC encoding to Binary VLS | 2023-02-07 09:32:46.375 HD Request # 45 | Sending historical data logon request message. | 2023-02-07 09:32:46.375 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\ZFH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:32:46.597 HD Request # 45 | Requesting Intraday data. Start date-time: 2023-02-07 09:32:29. Record interval: 0. Symbol: ESH23 | 2023-02-07 09:32:47.110 HD Request # 45 | Decompressing data. | 2023-02-07 09:32:47.316 HD Request # 45 | Receiving Intraday data for ESH23_FUT_CME starting at 2023-02-07 09:32:29.124000 | 2023-02-07 09:32:47.316 Socket (8) | CloseSocket call. | 2023-02-07 09:32:47.316 Socket (8) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:32:47.316 Historical data download thread signaled to stop. | 2023-02-07 09:32:47.319 HD Request # 45 | Timestamp of first Intraday data file record written: 2023-02-07 09:32:29.828000. | 2023-02-07 09:32:47.319 HD Request # 45 | Received 264 Intraday data records from 2023-02-07 09:32:29.124000 to 2023-02-07 09:32:45.782000 (16.7 seconds) and wrote 263 records for ESH23_FUT_CME | 2023-02-07 09:32:47.319 HD Request # 45 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:32:45.782000 | 2023-02-07 09:32:47.322 Added 56 Time and Sales records to Intraday data file for ESH23_FUT_CME after download. | 2023-02-07 09:32:47.322 HD Request # 45 | Completion time: 2s. | 2023-02-07 09:32:47.322 HD Request # 45 | Intraday data download complete for ESH23_FUT_CME. Unique request ID: 45 | 2023-02-07 09:32:47.322 Removing historical data download ID 45. | 2023-02-07 09:32:47.322 Real-time Intraday chart data file updates started for ESH23_FUT_CME | 2023-02-07 09:32:47.322 Intraday chart data file opened for ESH23_FUT_CME | 2023-02-07 09:32:47.322 HD Request # 45 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:32:47.322 Triggering next historical data download in queue. | 2023-02-07 09:32:47.322 HD Request # 46 | Downloading Intraday chart data for UBH23_FUT_CME to the file UBH23_FUT_CME.scid. Service: cbot | 2023-02-07 09:32:47.323 HD Request # 46 | Download start date-time: 2023-02-07 09:32:27.000000. File last date-time: 2023-02-07 09:32:27.666000 | 2023-02-07 09:32:47.323 HD Request # 46 | Using server: ds28.sierracharts.com port 10149 | 2023-02-07 09:32:47.323 Socket (9) | Creating socket. | 2023-02-07 09:32:47.323 Socket (9) | New receive buffer size: 5242880 | 2023-02-07 09:32:47.323 Socket (9) | Connecting to IP: 142.215.18.147. | 2023-02-07 09:32:47.323 Socket (8) | Socket gracefully closed by remote side. | 2023-02-07 09:32:47.524 Socket (8) | Closed. | 2023-02-07 09:32:47.524 HD Request # 46 | Setting DTC encoding to Binary VLS | 2023-02-07 09:32:47.817 HD Request # 46 | Sending historical data logon request message. | 2023-02-07 09:32:47.817 HD Request # 46 | Requesting Intraday data. Start date-time: 2023-02-07 09:32:27. Record interval: 0. Symbol: UBH23 | 2023-02-07 09:32:48.607 HD Request # 46 | Decompressing data. | 2023-02-07 09:32:48.864 HD Request # 46 | Receiving Intraday data for UBH23_FUT_CME starting at 2023-02-07 09:32:27.578000 | 2023-02-07 09:32:48.864 Socket (9) | CloseSocket call. | 2023-02-07 09:32:48.865 Socket (9) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:32:48.865 Historical data download thread signaled to stop. | 2023-02-07 09:32:48.865 HD Request # 46 | Timestamp of first Intraday data file record written: 2023-02-07 09:32:29.612000. | 2023-02-07 09:32:48.865 HD Request # 46 | Received 84 Intraday data records from 2023-02-07 09:32:27.578000 to 2023-02-07 09:32:45.775000 (18.2 seconds) and wrote 81 records for UBH23_FUT_CME | 2023-02-07 09:32:48.865 HD Request # 46 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:32:45.775000 | 2023-02-07 09:32:48.867 HD Request # 46 | Completion time: 1s. | 2023-02-07 09:32:48.867 HD Request # 46 | Intraday data download complete for UBH23_FUT_CME. Unique request ID: 46 | 2023-02-07 09:32:48.867 Removing historical data download ID 46. | 2023-02-07 09:32:48.867 Real-time Intraday chart data file updates started for UBH23_FUT_CME | 2023-02-07 09:32:48.867 Intraday chart data file opened for UBH23_FUT_CME | 2023-02-07 09:32:48.867 HD Request # 46 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:32:48.868 Triggering next historical data download in queue. | 2023-02-07 09:32:48.868 HD Request # 47 | Downloading Intraday chart data for NQH23_FUT_CME to the file NQH23_FUT_CME.scid. Service: cme | 2023-02-07 09:32:48.868 HD Request # 47 | Download start date-time: 2023-02-07 09:32:28.000000. File last date-time: 2023-02-07 09:32:28.829001 | 2023-02-07 09:32:48.868 HD Request # 47 | Using server: ds23.sierracharts.com port 10150 | 2023-02-07 09:32:48.868 Socket (8) | Creating socket. | 2023-02-07 09:32:48.868 Socket (8) | New receive buffer size: 5242880 | 2023-02-07 09:32:48.868 Socket (8) | Connecting to IP: 142.215.17.190. | 2023-02-07 09:32:48.868 Socket (9) | Socket gracefully closed by remote side. | 2023-02-07 09:32:49.111 Socket (9) | Closed. | 2023-02-07 09:32:49.111 HD Request # 47 | Setting DTC encoding to Binary VLS | 2023-02-07 09:32:49.348 HD Request # 47 | Sending historical data logon request message. | 2023-02-07 09:32:49.348 HD Request # 47 | Requesting Intraday data. Start date-time: 2023-02-07 09:32:28. Record interval: 0. Symbol: NQH23 | 2023-02-07 09:32:50.118 HD Request # 47 | Decompressing data. | 2023-02-07 09:32:50.355 HD Request # 47 | Receiving Intraday data for NQH23_FUT_CME starting at 2023-02-07 09:32:28.050000 | 2023-02-07 09:32:50.356 Socket (8) | CloseSocket call. | 2023-02-07 09:32:50.356 Socket (8) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:32:50.356 Historical data download thread signaled to stop. | 2023-02-07 09:32:50.366 HD Request # 47 | Timestamp of first Intraday data file record written: 2023-02-07 09:32:29.203000. | 2023-02-07 09:32:50.367 HD Request # 47 | Received 258 Intraday data records from 2023-02-07 09:32:28.050000 to 2023-02-07 09:32:47.268004 (19.2 seconds) and wrote 248 records for NQH23_FUT_CME | 2023-02-07 09:32:50.367 HD Request # 47 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:32:47.268004 | 2023-02-07 09:32:50.369 Added 20 Time and Sales records to Intraday data file for NQH23_FUT_CME after download. | 2023-02-07 09:32:50.369 HD Request # 47 | Completion time: 2s. | 2023-02-07 09:32:50.369 HD Request # 47 | Intraday data download complete for NQH23_FUT_CME. Unique request ID: 47 | 2023-02-07 09:32:50.369 Removing historical data download ID 47. | 2023-02-07 09:32:50.369 Real-time Intraday chart data file updates started for NQH23_FUT_CME | 2023-02-07 09:32:50.369 Intraday chart data file opened for NQH23_FUT_CME | 2023-02-07 09:32:50.369 HD Request # 47 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:32:50.369 Triggering next historical data download in queue. | 2023-02-07 09:32:50.370 HD Request # 48 | Downloading Intraday chart data for 6EH23_FUT_CME to the file 6EH23_FUT_CME.scid. Service: cme | 2023-02-07 09:32:50.370 HD Request # 48 | Download start date-time: 2023-02-07 09:32:27.000000. File last date-time: 2023-02-07 09:32:27.752000 | 2023-02-07 09:32:50.370 HD Request # 48 | Using server: ds26.sierracharts.com port 10149 | 2023-02-07 09:32:50.370 Socket (9) | Creating socket. | 2023-02-07 09:32:50.370 Socket (9) | New receive buffer size: 5242880 | 2023-02-07 09:32:50.370 Socket (9) | Connecting to IP: 142.215.17.188. | 2023-02-07 09:32:50.370 Socket (8) | Socket gracefully closed by remote side. | 2023-02-07 09:32:50.597 Socket (8) | Closed. | 2023-02-07 09:32:50.597 HD Request # 48 | Setting DTC encoding to Binary VLS | 2023-02-07 09:32:50.895 HD Request # 48 | Sending historical data logon request message. | 2023-02-07 09:32:50.895 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\ESH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:32:51.635 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\NQH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:32:51.636 HD Request # 48 | Requesting Intraday data. Start date-time: 2023-02-07 09:32:27. Record interval: 0. Symbol: 6EH23 | 2023-02-07 09:32:51.663 HD Request # 48 | Decompressing data. | 2023-02-07 09:32:51.918 HD Request # 48 | Receiving Intraday data for 6EH23_FUT_CME starting at 2023-02-07 09:32:27.752000 | 2023-02-07 09:32:51.918 Socket (9) | CloseSocket call. | 2023-02-07 09:32:51.919 Socket (9) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:32:51.919 Historical data download thread signaled to stop. | 2023-02-07 09:32:51.919 HD Request # 48 | Timestamp of first Intraday data file record written: 2023-02-07 09:32:29.329000. | 2023-02-07 09:32:51.919 HD Request # 48 | Received 158 Intraday data records from 2023-02-07 09:32:27.752000 to 2023-02-07 09:32:49.116000 (21.4 seconds) and wrote 157 records for 6EH23_FUT_CME | 2023-02-07 09:32:51.919 HD Request # 48 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:32:49.116000 | 2023-02-07 09:32:51.922 HD Request # 48 | Completion time: 1s. | 2023-02-07 09:32:51.922 HD Request # 48 | Intraday data download complete for 6EH23_FUT_CME. Unique request ID: 48 | 2023-02-07 09:32:51.922 Removing historical data download ID 48. | 2023-02-07 09:32:51.922 Real-time Intraday chart data file updates started for 6EH23_FUT_CME | 2023-02-07 09:32:51.922 Intraday chart data file opened for 6EH23_FUT_CME | 2023-02-07 09:32:51.922 HD Request # 48 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:32:51.922 Triggering next historical data download in queue. | 2023-02-07 09:32:51.922 HD Request # 49 | Downloading Intraday chart data for RTYH23_FUT_CME to the file RTYH23_FUT_CME.scid. Service: cme | 2023-02-07 09:32:51.922 HD Request # 49 | Download start date-time: 2023-02-07 09:32:28.000000. File last date-time: 2023-02-07 09:32:28.829000 | 2023-02-07 09:32:51.922 HD Request # 49 | Using server: ds28.sierracharts.com port 10150 | 2023-02-07 09:32:51.922 Socket (8) | Creating socket. | 2023-02-07 09:32:51.922 Socket (8) | New receive buffer size: 5242880 | 2023-02-07 09:32:51.922 Socket (8) | Connecting to IP: 142.215.18.147. | 2023-02-07 09:32:51.922 Socket (9) | Socket gracefully closed by remote side. | 2023-02-07 09:32:52.172 Socket (9) | Closed. | 2023-02-07 09:32:52.172 HD Request # 49 | Setting DTC encoding to Binary VLS | 2023-02-07 09:32:52.356 HD Request # 49 | Sending historical data logon request message. | 2023-02-07 09:32:52.356 HD Request # 49 | Requesting Intraday data. Start date-time: 2023-02-07 09:32:28. Record interval: 0. Symbol: RTYH23 | 2023-02-07 09:32:52.569 HD Request # 49 | Decompressing data. | 2023-02-07 09:32:52.785 HD Request # 49 | Receiving Intraday data for RTYH23_FUT_CME starting at 2023-02-07 09:32:28.829000 | 2023-02-07 09:32:52.786 Socket (8) | CloseSocket call. | 2023-02-07 09:32:52.786 Socket (8) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:32:52.786 Historical data download thread signaled to stop. | 2023-02-07 09:32:52.803 HD Request # 49 | Timestamp of first Intraday data file record written: 2023-02-07 09:32:30.578000. | 2023-02-07 09:32:52.803 HD Request # 49 | Received 25 Intraday data records from 2023-02-07 09:32:28.829000 to 2023-02-07 09:32:45.598001 (16.8 seconds) and wrote 24 records for RTYH23_FUT_CME | 2023-02-07 09:32:52.803 HD Request # 49 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:32:45.598001 | 2023-02-07 09:32:52.806 Added 5 Time and Sales records to Intraday data file for RTYH23_FUT_CME after download. | 2023-02-07 09:32:52.806 HD Request # 49 | Completion time: 1s. | 2023-02-07 09:32:52.806 HD Request # 49 | Intraday data download complete for RTYH23_FUT_CME. Unique request ID: 49 | 2023-02-07 09:32:52.806 Removing historical data download ID 49. | 2023-02-07 09:32:52.806 Real-time Intraday chart data file updates started for RTYH23_FUT_CME | 2023-02-07 09:32:52.806 Intraday chart data file opened for RTYH23_FUT_CME | 2023-02-07 09:32:52.806 HD Request # 49 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:32:52.806 Triggering next historical data download in queue. | 2023-02-07 09:32:52.806 HD Request # 50 | Downloading Intraday chart data for YMH23_FUT_CME to the file YMH23_FUT_CME.scid. Service: cbot | 2023-02-07 09:32:52.806 HD Request # 50 | Download start date-time: 2023-02-07 09:32:26.000000. File last date-time: 2023-02-07 09:32:26.909000 | 2023-02-07 09:32:52.806 HD Request # 50 | Using server: ds23.sierracharts.com port 10149 | 2023-02-07 09:32:52.806 Socket (9) | Creating socket. | 2023-02-07 09:32:52.806 Socket (9) | New receive buffer size: 5242880 | 2023-02-07 09:32:52.806 Socket (9) | Connecting to IP: 142.215.17.190. | 2023-02-07 09:32:52.806 Socket (8) | Socket gracefully closed by remote side. | 2023-02-07 09:32:52.999 Socket (8) | Closed. | 2023-02-07 09:32:52.999 HD Request # 50 | Setting DTC encoding to Binary VLS | 2023-02-07 09:32:53.243 HD Request # 50 | Sending historical data logon request message. | 2023-02-07 09:32:53.243 HD Request # 50 | Requesting Intraday data. Start date-time: 2023-02-07 09:32:26. Record interval: 0. Symbol: YMH23 | 2023-02-07 09:32:53.456 HD Request # 50 | Decompressing data. | 2023-02-07 09:32:53.670 HD Request # 50 | Receiving Intraday data for YMH23_FUT_CME starting at 2023-02-07 09:32:26.130000 | 2023-02-07 09:32:53.670 Socket (9) | CloseSocket call. | 2023-02-07 09:32:53.671 Socket (9) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:32:53.671 Historical data download thread signaled to stop. | 2023-02-07 09:32:53.695 HD Request # 50 | Timestamp of first Intraday data file record written: 2023-02-07 09:32:29.221000. | 2023-02-07 09:32:53.695 HD Request # 50 | Received 90 Intraday data records from 2023-02-07 09:32:26.130000 to 2023-02-07 09:32:52.761000 (26.6 seconds) and wrote 85 records for YMH23_FUT_CME | 2023-02-07 09:32:53.695 HD Request # 50 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:32:52.761000 | 2023-02-07 09:32:53.698 Added 1 Time and Sales records to Intraday data file for YMH23_FUT_CME after download. | 2023-02-07 09:32:53.698 HD Request # 50 | Completion time: 1s. | 2023-02-07 09:32:53.698 HD Request # 50 | Intraday data download complete for YMH23_FUT_CME. Unique request ID: 50 | 2023-02-07 09:32:53.698 Removing historical data download ID 50. | 2023-02-07 09:32:53.698 Real-time Intraday chart data file updates started for YMH23_FUT_CME | 2023-02-07 09:32:53.698 Intraday chart data file opened for YMH23_FUT_CME | 2023-02-07 09:32:53.698 HD Request # 50 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:32:53.698 Triggering next historical data download in queue. | 2023-02-07 09:32:53.698 HD Request # 51 | Downloading Intraday chart data for ZNH23_FUT_CME to the file ZNH23_FUT_CME.scid. Service: cbot | 2023-02-07 09:32:53.698 HD Request # 51 | Download start date-time: 2023-02-07 09:32:27.000000. File last date-time: 2023-02-07 09:32:27.010000 | 2023-02-07 09:32:53.699 HD Request # 51 | Using server: ds26.sierracharts.com port 10150 | 2023-02-07 09:32:53.699 Socket (8) | Creating socket. | 2023-02-07 09:32:53.699 Socket (8) | New receive buffer size: 5242880 | 2023-02-07 09:32:53.699 Socket (8) | Connecting to IP: 142.215.17.188. | 2023-02-07 09:32:53.699 Socket (9) | Socket gracefully closed by remote side. | 2023-02-07 09:32:53.883 Socket (9) | Closed. | 2023-02-07 09:32:53.883 HD Request # 51 | Setting DTC encoding to Binary VLS | 2023-02-07 09:32:54.148 HD Request # 51 | Sending historical data logon request message. | 2023-02-07 09:32:54.148 HD Request # 51 | Requesting Intraday data. Start date-time: 2023-02-07 09:32:27. Record interval: 0. Symbol: ZNH23 | 2023-02-07 09:32:54.369 HD Request # 51 | Decompressing data. | 2023-02-07 09:32:54.581 HD Request # 51 | Receiving Intraday data for ZNH23_FUT_CME starting at 2023-02-07 09:32:27.010000 | 2023-02-07 09:32:54.581 Socket (8) | CloseSocket call. | 2023-02-07 09:32:54.582 Socket (8) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:32:54.582 Historical data download thread signaled to stop. | 2023-02-07 09:32:54.582 HD Request # 51 | Timestamp of first Intraday data file record written: 2023-02-07 09:32:29.791000. | 2023-02-07 09:32:54.582 HD Request # 51 | Received 479 Intraday data records from 2023-02-07 09:32:27.010000 to 2023-02-07 09:32:52.063000 (25.1 seconds) and wrote 478 records for ZNH23_FUT_CME | 2023-02-07 09:32:54.582 HD Request # 51 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:32:52.063000 | 2023-02-07 09:32:54.585 Added 40 Time and Sales records to Intraday data file for ZNH23_FUT_CME after download. | 2023-02-07 09:32:54.585 HD Request # 51 | Completion time: 1s. | 2023-02-07 09:32:54.585 HD Request # 51 | Intraday data download complete for ZNH23_FUT_CME. Unique request ID: 51 | 2023-02-07 09:32:54.585 Removing historical data download ID 51. | 2023-02-07 09:32:54.585 Real-time Intraday chart data file updates started for ZNH23_FUT_CME | 2023-02-07 09:32:54.585 Intraday chart data file opened for ZNH23_FUT_CME | 2023-02-07 09:32:54.585 HD Request # 51 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:32:54.585 Triggering next historical data download in queue. | 2023-02-07 09:32:54.585 HD Request # 52 | Downloading Intraday chart data for CLH23_FUT_CME to the file CLH23_FUT_CME.scid. Service: nymex | 2023-02-07 09:32:54.585 HD Request # 52 | Download start date-time: 2023-02-07 09:32:28.000000. File last date-time: 2023-02-07 09:32:28.124005 | 2023-02-07 09:32:54.585 HD Request # 52 | Using server: ds28.sierracharts.com port 10149 | 2023-02-07 09:32:54.585 Socket (9) | Creating socket. | 2023-02-07 09:32:54.585 Socket (9) | New receive buffer size: 5242880 | 2023-02-07 09:32:54.585 Socket (9) | Connecting to IP: 142.215.18.147. | 2023-02-07 09:32:54.585 Socket (8) | Socket gracefully closed by remote side. | 2023-02-07 09:32:54.791 Socket (8) | Closed. | 2023-02-07 09:32:54.792 HD Request # 52 | Setting DTC encoding to Binary VLS | 2023-02-07 09:32:55.030 HD Request # 52 | Sending historical data logon request message. | 2023-02-07 09:32:55.030 HD Request # 52 | Requesting Intraday data. Start date-time: 2023-02-07 09:32:28. Record interval: 0. Symbol: CLH23 | 2023-02-07 09:32:55.246 HD Request # 52 | Decompressing data. | 2023-02-07 09:32:55.460 HD Request # 52 | Receiving Intraday data for CLH23_FUT_CME starting at 2023-02-07 09:32:28.124000 | 2023-02-07 09:32:55.460 Socket (9) | CloseSocket call. | 2023-02-07 09:32:55.460 Socket (9) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:32:55.460 Historical data download thread signaled to stop. | 2023-02-07 09:32:55.460 HD Request # 52 | Timestamp of first Intraday data file record written: 2023-02-07 09:32:29.383000. | 2023-02-07 09:32:55.460 HD Request # 52 | Received 71 Intraday data records from 2023-02-07 09:32:28.124000 to 2023-02-07 09:32:52.080000 (24.0 seconds) and wrote 65 records for CLH23_FUT_CME | 2023-02-07 09:32:55.460 HD Request # 52 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:32:52.080000 | 2023-02-07 09:32:55.465 Added 15 Time and Sales records to Intraday data file for CLH23_FUT_CME after download. | 2023-02-07 09:32:55.465 HD Request # 52 | Completion time: 1s. | 2023-02-07 09:32:55.465 HD Request # 52 | Intraday data download complete for CLH23_FUT_CME. Unique request ID: 52 | 2023-02-07 09:32:55.465 Removing historical data download ID 52. | 2023-02-07 09:32:55.465 Real-time Intraday chart data file updates started for CLH23_FUT_CME | 2023-02-07 09:32:55.465 Intraday chart data file opened for CLH23_FUT_CME | 2023-02-07 09:32:55.465 HD Request # 52 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:32:55.465 Triggering next historical data download in queue. | 2023-02-07 09:32:55.465 HD Request # 53 | Downloading Intraday chart data for TNH23_FUT_CME to the file TNH23_FUT_CME.scid. Service: cbot | 2023-02-07 09:32:55.466 HD Request # 53 | Download start date-time: 2023-02-07 09:32:17.000000. File last date-time: 2023-02-07 09:32:17.970000 | 2023-02-07 09:32:55.466 HD Request # 53 | Using server: ds23.sierracharts.com port 10150 | 2023-02-07 09:32:55.466 Socket (8) | Creating socket. | 2023-02-07 09:32:55.466 Socket (8) | New receive buffer size: 5242880 | 2023-02-07 09:32:55.466 Socket (8) | Connecting to IP: 142.215.17.190. | 2023-02-07 09:32:55.466 Socket (9) | Socket gracefully closed by remote side. | 2023-02-07 09:32:55.676 Socket (9) | Closed. | 2023-02-07 09:32:55.676 HD Request # 53 | Setting DTC encoding to Binary VLS | 2023-02-07 09:32:55.917 HD Request # 53 | Sending historical data logon request message. | 2023-02-07 09:32:55.917 HD Request # 53 | Requesting Intraday data. Start date-time: 2023-02-07 09:32:17. Record interval: 0. Symbol: TNH23 | 2023-02-07 09:32:56.135 HD Request # 53 | Decompressing data. | 2023-02-07 09:32:56.353 HD Request # 53 | Receiving Intraday data for TNH23_FUT_CME starting at 2023-02-07 09:32:17.970000 | 2023-02-07 09:32:56.354 Socket (8) | CloseSocket call. | 2023-02-07 09:32:56.354 Socket (8) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:32:56.354 Historical data download thread signaled to stop. | 2023-02-07 09:32:56.355 HD Request # 53 | Timestamp of first Intraday data file record written: 2023-02-07 09:32:31.253000. | 2023-02-07 09:32:56.355 HD Request # 53 | Received 220 Intraday data records from 2023-02-07 09:32:17.970000 to 2023-02-07 09:32:50.923002 (33.0 seconds) and wrote 219 records for TNH23_FUT_CME | 2023-02-07 09:32:56.355 HD Request # 53 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:32:50.923002 | 2023-02-07 09:32:56.358 HD Request # 53 | Completion time: 1s. | 2023-02-07 09:32:56.358 HD Request # 53 | Intraday data download complete for TNH23_FUT_CME. Unique request ID: 53 | 2023-02-07 09:32:56.358 Removing historical data download ID 53. | 2023-02-07 09:32:56.358 Real-time Intraday chart data file updates started for TNH23_FUT_CME | 2023-02-07 09:32:56.358 Intraday chart data file opened for TNH23_FUT_CME | 2023-02-07 09:32:56.358 HD Request # 53 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:32:56.358 Triggering next historical data download in queue. | 2023-02-07 09:32:56.358 HD Request # 54 | Downloading Intraday chart data for GCJ23_FUT_CME to the file GCJ23_FUT_CME.scid. Service: comex | 2023-02-07 09:32:56.358 HD Request # 54 | Download start date-time: 2023-02-07 09:32:24.000000. File last date-time: 2023-02-07 09:32:24.515000 | 2023-02-07 09:32:56.358 HD Request # 54 | Using server: ds26.sierracharts.com port 10149 | 2023-02-07 09:32:56.358 Socket (9) | Creating socket. | 2023-02-07 09:32:56.358 Socket (9) | New receive buffer size: 5242880 | 2023-02-07 09:32:56.358 Socket (9) | Connecting to IP: 142.215.17.188. | 2023-02-07 09:32:56.358 Socket (8) | Socket gracefully closed by remote side. | 2023-02-07 09:32:56.572 Socket (8) | Closed. | 2023-02-07 09:32:56.572 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\UBH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:32:56.686 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\6EH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:32:56.686 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\RTYH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:32:56.686 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\YMH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:32:56.686 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\ZNH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:32:56.686 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\CLH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:32:56.686 HD Request # 54 | Setting DTC encoding to Binary VLS | 2023-02-07 09:32:56.791 HD Request # 54 | Sending historical data logon request message. | 2023-02-07 09:32:56.791 HD Request # 54 | Requesting Intraday data. Start date-time: 2023-02-07 09:32:24. Record interval: 0. Symbol: GCJ23 | 2023-02-07 09:32:57.005 HD Request # 54 | Decompressing data. | 2023-02-07 09:32:57.212 HD Request # 54 | Receiving Intraday data for GCJ23_FUT_CME starting at 2023-02-07 09:32:24.515000 | 2023-02-07 09:32:57.212 Socket (9) | CloseSocket call. | 2023-02-07 09:32:57.212 Socket (9) | Shutdown started. Waiting for graceful close. | 2023-02-07 09:32:57.212 Historical data download thread signaled to stop. | 2023-02-07 09:32:57.213 HD Request # 54 | Timestamp of first Intraday data file record written: 2023-02-07 09:32:31.253000. | 2023-02-07 09:32:57.213 HD Request # 54 | Received 83 Intraday data records from 2023-02-07 09:32:24.515000 to 2023-02-07 09:32:52.000000 (27.5 seconds) and wrote 82 records for GCJ23_FUT_CME | 2023-02-07 09:32:57.213 HD Request # 54 | Add time&sales data | Remembered last file record date-time: 2023-02-07 17:32:52.000000 | 2023-02-07 09:32:57.215 Added 1 Time and Sales records to Intraday data file for GCJ23_FUT_CME after download. | 2023-02-07 09:32:57.215 HD Request # 54 | Completion time: 1s. | 2023-02-07 09:32:57.215 HD Request # 54 | Intraday data download complete for GCJ23_FUT_CME. Unique request ID: 54 | 2023-02-07 09:32:57.215 Removing historical data download ID 54. | 2023-02-07 09:32:57.215 Real-time Intraday chart data file updates started for GCJ23_FUT_CME | 2023-02-07 09:32:57.215 Intraday chart data file opened for GCJ23_FUT_CME | 2023-02-07 09:32:57.215 HD Request # 54 | Enabling Intraday chart updating for symbol. | 2023-02-07 09:32:57.215 Triggering next historical data download in queue. | 2023-02-07 09:32:57.215 No download requests in the queue to start downloads for. | 2023-02-07 09:32:57.215 Socket (9) | Socket gracefully closed by remote side. | 2023-02-07 09:32:57.419 Socket (9) | Closed. | 2023-02-07 09:32:57.419 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\ZBH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:33:01.730 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\GCJ23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:33:01.730 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\TNH23_FUT_CME.scid. Thread ID: 15016 | 2023-02-07 09:33:11.846 DTC Client socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2023-02-07 09:34:03.724 DTC Client socket (1) | Closed. | 2023-02-07 09:34:03.724 DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2023-02-07 09:34:28.904 * DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-02-07 09:34:28.904 DTC Client socket (2) | Closed. | 2023-02-07 09:34:28.904 DTC Client socket (1) | Deleting network socket now after delay. | 2023-02-07 09:34:33.731 |
[2023-02-07 18:50:25] |
John - SC Support - Posts: 39362 |
We do see a few of the following in your log: DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2023-02-07 09:29:32.970 *
DTC Client socket (9) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2023-02-07 09:25:45.700 *
The above indicate a connectivity issue of some kind. Refer to the information here: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem --- As to your software update, that is a separate issue for which we would need the log from the Installer. There is a button at the top that states "Send Log to Suppport". Select that button after you try to do the update and it fails. Then let us know that you sent us the file. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-07 19:04:43] |
User76183 - Posts: 69 |
when I cannot remove my orders I have this: Triggering next historical data download in queue. | 2023-02-07 11:01:30.640 HD Request # 50 | Downloading Intraday chart data for ESH23_FUT_CME to the file ESH23_FUT_CME.scid. Service: cme | 2023-02-07 11:01:30.640 HD Request # 50 | Download start date-time: 2023-02-07 11:01:10.000000. File last date-time: 2023-02-07 11:01:10.373003 | 2023-02-07 11:01:30.640 HD Request # 50 | Using server: ds23.sierracharts.com port 10150 | 2023-02-07 11:01:30.640 Socket (10) | Creating socket. | 2023-02-07 11:01:30.641 Socket (10) | New receive buffer size: 5242880 | 2023-02-07 11:01:30.641 Socket (10) | Connecting to IP: 142.215.17.190. | 2023-02-07 11:01:30.641 Socket (9) | Socket gracefully closed by remote side. | 2023-02-07 11:01:30.843 Socket (9) | Closed. | 2023-02-07 11:01:30.843 HD Request # 50 | Setting DTC encoding to Binary VLS | 2023-02-07 11:01:31.069 HD Request # 50 | Sending historical data logon request message. | 2023-02-07 11:01:31.069 HD Request # 50 | Requesting Intraday data. Start date-time: 2023-02-07 11:01:10. Record interval: 0. Symbol: ESH23 | 2023-02-07 11:01:31.279 HD Request # 50 | Decompressing data. | 2023-02-07 11:01:31.489 HD Request # 50 | Receiving Intraday data for ESH23_FUT_CME starting at 2023-02-07 11:01:10.018000 | 2023-02-07 11:01:31.709 Socket (10) | CloseSocket call. | 2023-02-07 11:01:31.710 Socket (10) | Shutdown started. Waiting for graceful close. | 2023-02-07 11:01:31.710 Historical data download thread signaled to stop. | 2023-02-07 11:01:31.714 HD Request # 50 | Timestamp of first Intraday data file record written: 2023-02-07 11:01:10.481000. | 2023-02-07 11:01:31.714 HD Request # 50 | Received 3054 Intraday data records from 2023-02-07 11:01:10.018000 to 2023-02-07 11:01:31.949000 (21.9 seconds) and wrote 3008 records for ESH23_FUT_CME | 2023-02-07 11:01:31.714 HD Request # 50 | Add time&sales data | Remembered last file record date-time: 2023-02-07 19:01:31.949000 | 2023-02-07 11:01:31.717 Added 255 Time and Sales records to Intraday data file for ESH23_FUT_CME after download. | 2023-02-07 11:01:31.717 HD Request # 50 | Completion time: 1s. | 2023-02-07 11:01:31.717 HD Request # 50 | Intraday data download complete for ESH23_FUT_CME. Unique request ID: 50 | 2023-02-07 11:01:31.717 Removing historical data download ID 50. | 2023-02-07 11:01:31.717 Real-time Intraday chart data file updates started for ESH23_FUT_CME | 2023-02-07 11:01:31.717 Intraday chart data file opened for ESH23_FUT_CME | 2023-02-07 11:01:31.717 HD Request # 50 | Enabling Intraday chart updating for symbol. | 2023-02-07 11:01:31.717 Triggering next historical data download in queue. | 2023-02-07 11:01:31.717 No download requests in the queue to start downloads for. | 2023-02-07 11:01:31.717 Socket (10) | Socket gracefully closed by remote side. | 2023-02-07 11:01:31.920 Socket (10) | Closed. | 2023-02-07 11:01:31.920 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\ZBH23_FUT_CME.scid. Thread ID: 1444 | 2023-02-07 11:01:35.245 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\ZNH23_FUT_CME.scid. Thread ID: 1444 | 2023-02-07 11:01:35.245 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\UBH23_FUT_CME.scid. Thread ID: 1444 | 2023-02-07 11:01:35.245 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\NQH23_FUT_CME.scid. Thread ID: 1444 | 2023-02-07 11:01:35.245 Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\ESH23_FUT_CME.scid. Thread ID: 1444 | 2023-02-07 11:01:35.245 DTC Client socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2023-02-07 11:01:55.136 DTC Client socket (2) | Closed. | 2023-02-07 11:01:55.136 Updated verified funded futures trading account ending date to: 2023-03-09 19:02:21 | 2023-02-07 11:02:21.496 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: RTYH23_FUT_CME | 2023-02-07 11:02:21.496 Teton CME Order Routing | Received security definition for symbol RTYH23_FUT_CME | 2023-02-07 11:02:21.496 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: YMH23_FUT_CME | 2023-02-07 11:02:21.496 Teton CME Order Routing | Received security definition for symbol YMH23_FUT_CME | 2023-02-07 11:02:21.496 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: CLH23_FUT_CME | 2023-02-07 11:02:21.496 Teton CME Order Routing | Received security definition for symbol CLH23_FUT_CME | 2023-02-07 11:02:21.496 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZFH23_FUT_CME | 2023-02-07 11:02:21.496 Teton CME Order Routing | Received security definition for symbol ZFH23_FUT_CME | 2023-02-07 11:02:21.496 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: TNH23_FUT_CME | 2023-02-07 11:02:21.496 Teton CME Order Routing | Received security definition for symbol TNH23_FUT_CME | 2023-02-07 11:02:21.496 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZBH23_FUT_CME | 2023-02-07 11:02:21.496 Teton CME Order Routing | Received security definition for symbol ZBH23_FUT_CME | 2023-02-07 11:02:21.496 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6EH23_FUT_CME | 2023-02-07 11:02:21.496 Teton CME Order Routing | Received security definition for symbol 6EH23_FUT_CME | 2023-02-07 11:02:21.496 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZNH23_FUT_CME | 2023-02-07 11:02:21.496 Teton CME Order Routing | Received security definition for symbol ZNH23_FUT_CME | 2023-02-07 11:02:21.496 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: GCJ23_FUT_CME | 2023-02-07 11:02:21.496 Teton CME Order Routing | Received security definition for symbol GCJ23_FUT_CME | 2023-02-07 11:02:21.496 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: UBH23_FUT_CME | 2023-02-07 11:02:21.496 Teton CME Order Routing | Received security definition for symbol UBH23_FUT_CME | 2023-02-07 11:02:21.496 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQH23_FUT_CME | 2023-02-07 11:02:21.496 Teton CME Order Routing | Received security definition for symbol NQH23_FUT_CME | 2023-02-07 11:02:21.496 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH23_FUT_CME | 2023-02-07 11:02:21.496 Teton CME Order Routing | Received security definition for symbol ESH23_FUT_CME | 2023-02-07 11:02:21.496 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: CLG23_FUT_CME | 2023-02-07 11:02:21.918 Teton CME Order Routing | Received security definition for symbol CLG23_FUT_CME | 2023-02-07 11:02:21.918 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: GCG23_FUT_CME | 2023-02-07 11:02:21.918 Teton CME Order Routing | Received security definition for symbol GCG23_FUT_CME | 2023-02-07 11:02:21.918 DTC Client socket (2) | Deleting network socket now after delay. | 2023-02-07 11:02:25.153 Teton CME Order Routing | Received final trade activity snapshot. Count=217. TradeAccount=44435 | 2023-02-07 11:03:03.387 DTC Client socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2023-02-07 11:03:25.158 DTC Client socket (1) | Closed. | 2023-02-07 11:03:25.158 DTC Client socket (4) | Timed out waiting for shutdown. Performing an immediate socket close. | 2023-02-07 11:03:25.158 DTC Client socket (4) | Closed. | 2023-02-07 11:03:25.158 DTC Client socket (6) | Timed out waiting for shutdown. Performing an immediate socket close. | 2023-02-07 11:03:25.158 DTC Client socket (6) | Closed. | 2023-02-07 11:03:25.158 |
[2023-02-07 19:11:45] |
And this: TradeActivity files query time: 0.007867 seconds. Entries: 0. Current queries: 1 | 2023-02-07 11:10:05.104 TradeActivity files query time: 0.004959 seconds. Entries: 0. Current queries: 1 | 2023-02-07 11:10:07.020 TradeActivity files query time: 0.004855 seconds. Entries: 0. Current queries: 1 | 2023-02-07 11:10:07.124 TradeActivity files query time: 0.004816 seconds. Entries: 0. Current queries: 1 | 2023-02-07 11:10:08.898 TradeActivity files query time: 0.004750 seconds. Entries: 0. Current queries: 1 | 2023-02-07 11:10:09.108 TradeActivity files query time: 0.007552 seconds. Entries: 0. Current queries: 1 | 2023-02-07 11:10:10.803 TradeActivity files query time: 0.004803 seconds. Entries: 0. Current queries: 1 | 2023-02-07 11:10:10.885 TradeActivity files query time: 0.004824 seconds. Entries: 0. Current queries: 1 | 2023-02-07 11:10:12.768 TradeActivity files query time: 0.004766 seconds. Entries: 0. Current queries: 1 | 2023-02-07 11:10:14.522 TradeActivity files query time: 0.007675 seconds. Entries: 0. Current queries: 1 | 2023-02-07 11:10:16.444 TradeActivity files query time: 0.007651 seconds. Entries: 0. Current queries: 1 | 2023-02-07 11:10:16.597 TradeActivity files query time: 0.008035 seconds. Entries: 6. Current queries: 1 | 2023-02-07 11:10:18.253 TradeActivity files query time: 0.004844 seconds. Entries: 6. Current queries: 1 | 2023-02-07 11:10:18.310 TradeActivity files query time: 0.004866 seconds. Entries: 2. Current queries: 1 | 2023-02-07 11:10:20.104 TradeActivity files query time: 0.007639 seconds. Entries: 2. Current queries: 1 | 2023-02-07 11:10:20.304 TradeActivity files query time: 0.005235 seconds. Entries: 0. Current queries: 1 | 2023-02-07 11:10:22.038 TradeActivity files query time: 0.004765 seconds. Entries: 0. Current queries: 1 | 2023-02-07 11:10:22.125 TradeActivity files query time: 0.004908 seconds. Entries: 0. Current queries: 1 | 2023-02-07 11:10:23.872 TradeActivity files query time: 0.007812 seconds. Entries: 0. Current queries: 1 | 2023-02-07 11:10:25.857 TradeActivity files query time: 0.004899 seconds. Entries: 0. Current queries: 1 | 2023-02-07 11:10:26.023 Order cancellation failed | Teton CME Order Routing (Order cancel reject). Info: Order cancellation failed | Order Cancel Reject. Text: This order is not in the book 'Order: 6411507240296 SenderCompID: 2WG9W5'. Internal Order ID: 70. Service Order ID: 1637947. Symbol: ESH23_FUT_CME. Account: XXXXXXX | 2023-02-07 11:10:26.419 * |
[2023-02-07 22:38:00] |
Sierra_Chart Engineering - Posts: 19285 |
We need a very precise information about this: when I cannot remove my orders I have this: How are you canceling the order? What is the Status of the order before you cancel? What is the status of the order after you cancel? We need to understand exactly what is happening.Otherwise, we really are lost about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
