Date/Time: Thu, 19 Sep 2024 01:05:07 +0000
You can not quit command from the chart
View Count: 1170
[2014-06-09 14:10:13] |
User68117 - Posts: 65 |
Hello, have a request regarding trading from the chart. I trade from DOM, where I enter a limit order, which I will show in a chart including PT and SL commands, unless you want to cancel the order and click on the "X" to exit the command, so to me there appears "cancell" but the command is still active. and if you cancel the IB and shut SierraChart, so I filled in when the market gets to him. Where do the error please? |
[2014-06-09 17:24:46] |
We are not clearly understanding this. Here are the instructions to cancel an order on the chart or Trade DOM: http://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#TradeDOMModifyingCanceling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-09 17:38:48] |
Into the deal of the DOM, but then store, which has been in the chart. When I close the command marked on screen "X", so my statement is still hanging in both the platform and the IB |
Snímek obrazovky 2014-06-09 v 19.28.32.png / V - Attached On 2014-06-09 17:36:45 UTC - Size: 832.69 KB - 347 views |
[2014-06-09 18:36:21] |
When you press the "X" button on the order line to cancel the order, does the status say "Pending Cancel"?
[2014-06-09 18:49:13] |
No, there is only "cancell" but nothing more happens. This happens only in Live mode. In simulated mode it works fine. There can be some problem between the connection of Sierra chart and IB (Interactive Brokers)? Date Time Of Last Edit: 2014-06-09 18:51:17
[2014-06-09 22:50:39] |
This is not clear for us. Go to the chart that has order lines on it and select Trade >> Attach Trade Window to Chart. Press the button that says Cancel All. After this provide an image of the chart by following these instructions here: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-10 11:20:33] |
Here I am sending how it behaves. In the first Screen enter the command Sell Limit. Hop me while i PT and SL command. Then click cancel in the Trade Window, press CancellAll - screen two. Cancels the PT and SL command, but the input command still hangs there. Then I press the graph on the "X" in a statement, which hangs - screen three. The graph in order to appear "Pendigo cancell." In IB command is still active. Where is the error? |
Snímek obrazovky 2014-06-10 v 12.07.25.png / V - Attached On 2014-06-10 11:18:11 UTC - Size: 784.94 KB - 348 views Snímek obrazovky 2014-06-10 v 12.07.39.png / V - Attached On 2014-06-10 11:19:17 UTC - Size: 776.43 KB - 359 views Snímek obrazovky 2014-06-10 v 12.07.50.png / V - Attached On 2014-06-10 11:19:36 UTC - Size: 631.43 KB - 339 views |
[2014-06-10 16:39:43] |
What we can see is that the initial order that was sent, was not accepted by the IB Trader Workstation. Contact IB at this email address: api@interactivebrokers.com You need to say that a new order for the NQ 201406 futures contract is not being acknowledged by the API. They will need to see your Trader Workstation log file. You need to ask them where that log file is located and send it to them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-16 08:51:55] |
Hello, please where can I find RotationFactor study TPO profile chart? thanks |
