Date/Time: Wed, 23 Apr 2025 03:16:04 +0000
Chart load time
View Count: 428
[2023-02-02 18:20:43]
User423634 - Posts: 24
Hello I keep my Es chart on the same settings as all my other charts CL, Gc, etc. no continous contract on and not more than 50 days to load. Why does only my ES chart take much longer to load approx 10 seconds vs other charts will load right away???
[2023-02-02 22:35:03]
John - SC Support - Posts: 39428
There is more data to load. The ES trades more, and since you probably have the data stored at 1 tick (every trade) there simply is more to load.
[2023-03-31 04:17:07]
Quick question is there a way to change the font or size of the text in the "Modify Text" box on a horizontal line?
[2023-03-31 17:17:01]
To modify the size of the text that is displayed in the "Modify Text" window while you are typing it in, you need to change the "Text Windows" Font. Refer to the information here:
Graphics Settings: Text Windows - (current font name)
If you want to change the default text for the drawing itself (what is drawn after you select OK on the "Modify Text" window), then that is controlled by the option for Tools >> Tool Settings >> General >> Global Chart Drawing Font. Refer to the information here:
Chart Drawing Tools: Global Chart Drawing Font (Global Settings >> Tool Settings >> General >> Drawing Font)
