Date/Time: Mon, 21 Apr 2025 13:14:32 +0000
Prices not updating on second instance/computer
View Count: 746
[2023-02-01 14:12:55] |
User968091 - Posts: 47 |
I installed Sierra on a second computer and I see that I am connected to the data feed with the green box in the top left but my prices are not updating. If I close out Sierra and bring it back up, it will catch up to the current time but then just sits with no new updates.
[2023-02-01 15:10:59] |
Sierra_Chart Engineering - Posts: 19285 |
This likely is due to what is explained here: Denali Exchange Data Feed: Connections Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-03 03:32:38] |
I have my live trading CQG feed connected on another computer and its still not updating. Its showing its connected but it's not updating.
[2023-02-03 10:59:01] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-02-03 10:59:16
[2023-02-03 21:56:50] |
Reading Internal Order ID file. | 2023-02-03 21:52:32.304 Reading Trade Orders file. | 2023-02-03 21:52:32.422 Reading Trade Positions file. | 2023-02-03 21:52:32.422 Reading Trade Account Data files. | 2023-02-03 21:52:32.423 Software version: 2466 64-bit | 2023-02-03 21:52:32.424 Primary Thread ID: 5104 | 2023-02-03 21:52:32.424 Usage end date: 2023-02-17 | 2023-02-03 21:52:32.424 Enabled for: Advanced Features 2. | 2023-02-03 21:52:32.424 Enabled for: Sierra Chart Historical Data Service. | 2023-02-03 21:52:32.424 Enabled for: Denali Real-Time Exchange Data Feed. | 2023-02-03 21:52:32.424 Enabled for: Delayed Denali Exchange Data Feed. | 2023-02-03 21:52:32.424 Enabled for exchange2: CME (Trading Account Required) | 2023-02-03 21:52:32.424 Enabled for exchange2: CBOT (Trading Account Required) | 2023-02-03 21:52:32.424 Enabled for exchange2: COMEX (Trading Account Required) | 2023-02-03 21:52:32.424 Enabled for exchange2: NYMEX (Trading Account Required) | 2023-02-03 21:52:32.424 Enabled for exchange2: fairx_exchange.data | 2023-02-03 21:52:32.424 Allow Support for Sierra Chart Data Feeds is enabled. | 2023-02-03 21:52:32.424 Current selected Data/Trading service: CQG WebAPI | 2023-02-03 21:52:32.424 Custom symbol settings values: enabled | 2023-02-03 21:52:32.424 Chart Update Interval: 500 | 2023-02-03 21:52:32.424 Intraday Data Storage Time Unit: 0 | 2023-02-03 21:52:32.424 Time Zone: +00:00:00 (UTC+00) | 2023-02-03 21:52:32.424 2023-02-03 21:52:32 Local computer time in UTC | 2023-02-03 21:52:32.424 2023-02-03 21:52:32 Local computer time in SC Time Zone | 2023-02-03 21:52:32.424 2023-02-03 21:52:33 Server time in UTC | 2023-02-03 21:52:32.424 Local computer UTC time and Server UTC time difference: 2 seconds. | 2023-02-03 21:52:32.424 Program path: C:\SierraChart\ | 2023-02-03 21:52:32.424 Data Files path: C:\SierraChart\Data\ | 2023-02-03 21:52:32.424 OS Version Number: 10.0 | 2023-02-03 21:52:32.424 Locale Setting: C | 2023-02-03 21:52:32.424 DLLs: UserContributedStudies_64.dll | 2023-02-03 21:52:32.424 Allowed protected custom studies: Ludwig Levels | 2023-02-03 21:52:32.424 Crash reporter started: true | 2023-02-03 21:52:32.424 Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 1. | 2023-02-03 21:52:32.443 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:52:32.487 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-02-03 21:52:32.672 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-02-03 21:52:32.672 Received 5 login tokens. | 2023-02-03 21:52:33.049 Symbol settings MD5 received. Request ID: 1. | 2023-02-03 21:52:34.491 Symbol settings are up-to-date for cqg. | 2023-02-03 21:52:34.491 Error getting list of user files to download. Response: ERROR: Downloading of files on startup is disabled. | HTTP status: Request completed with the HTTP response status code 200. | 2023-02-03 21:52:35.272 Files to Open on Startup | Opening file: FootprintCollection2.Cht | 2023-02-03 21:52:37.277 F.US.EPH23 Rev. 10t #4 | Reloading chart. | 2023-02-03 21:52:37.352 Searching for files containing LudwigLevels returned empty result. | 2023-02-03 21:52:37.358 * Error loading: C:\SierraChart\Data\LudwigLevels.dll. File not found or may be missing SCDLLName line. | 2023-02-03 21:52:37.358 F.US.ENQH23 Rev. 40t #3 | Reloading chart. | 2023-02-03 21:52:37.417 F.US.RTYH23 1.0 Range #5 | Reloading chart. | 2023-02-03 21:52:37.473 F.US.EPH23 [CBV] 3.75 Range #1 | Reloading chart. | 2023-02-03 21:52:37.536 F.US.EPH23 [CBV] 3.75 Range #1 | Performing continuous chart historical Daily data download for symbol F.US.EPH23 starting at last date in file. | 2023-02-03 21:52:37.538 Starting DelayedDownloadMonitoringTimer | 2023-02-03 21:52:37.538 Starting HDTimeoutTimer | 2023-02-03 21:52:37.538 Added historical Daily data request for F.US.EPH23 to the queue. | 2023-02-03 21:52:37.539 Triggering next historical data download in queue. | 2023-02-03 21:52:37.539 F.US.EPH23 [CBV] 3.75 Range #1 | Waiting for historical downloads to complete with the IDs: 1, | 2023-02-03 21:52:37.543 F.US.ENQH23 [CBV] Rev. 20t #2 | Reloading chart. | 2023-02-03 21:52:37.579 F.US.ENQH23 [CBV] Rev. 20t #2 | Performing continuous chart historical Daily data download for symbol F.US.ENQH23 starting at last date in file. | 2023-02-03 21:52:37.581 Added historical Daily data request for F.US.ENQH23 to the queue. | 2023-02-03 21:52:37.581 F.US.ENQH23 [CBV] Rev. 20t #2 | Waiting for historical downloads to complete with the IDs: 2, | 2023-02-03 21:52:37.586 F.US.CLEH23 [CBV] Rev. 10t #6 | Reloading chart. | 2023-02-03 21:52:37.615 F.US.CLEH23 [CBV] Rev. 10t #6 | Performing continuous chart historical Daily data download for symbol F.US.CLEH23 starting at last date in file. | 2023-02-03 21:52:37.620 Added historical Daily data request for F.US.CLEH23 to the queue. | 2023-02-03 21:52:37.620 F.US.CLEH23 [CBV] Rev. 10t #6 | Waiting for historical downloads to complete with the IDs: 3, | 2023-02-03 21:52:37.627 F.US.GCEJ23 [CBV] Rev. 10t #7 | Reloading chart. | 2023-02-03 21:52:37.643 F.US.GCEJ23 [CBV] Rev. 10t #7 | Performing continuous chart historical Daily data download for symbol F.US.GCEJ23 starting at last date in file. | 2023-02-03 21:52:37.656 Added historical Daily data request for F.US.GCEJ23 to the queue. | 2023-02-03 21:52:37.656 F.US.GCEJ23 [CBV] Rev. 10t #7 | Waiting for historical downloads to complete with the IDs: 4, | 2023-02-03 21:52:37.662 F.US.CLEH23 [CBV] 0.15 Range #8 | Reloading chart. | 2023-02-03 21:52:37.690 F.US.CLEH23 [CBV] 0.15 Range #8 | Waiting for historical downloads to complete with the IDs: 3, | 2023-02-03 21:52:37.696 F.US.EPH23 [CBV] 3.75 Range #9 | Reloading chart. | 2023-02-03 21:52:37.728 F.US.EPH23 [CBV] 3.75 Range #9 | Waiting for historical downloads to complete with the IDs: 1, | 2023-02-03 21:52:37.734 F.US.CLEH23 Rev. 10t #10 | Reloading chart. | 2023-02-03 21:52:37.786 F.US.GCEJ23 Rev. 10t #11 | Reloading chart. | 2023-02-03 21:52:37.858 F.US.RTYH23 Rev. 40t #12 | Reloading chart. | 2023-02-03 21:52:37.924 F.US.NGEH23 Rev. 10t #13 | Reloading chart. | 2023-02-03 21:52:38.003 Files to Open on Startup | Opening file: FootprintCollection2 (1).Cht | 2023-02-03 21:52:38.028 F.US.EPH23 Rev. 10t #4 | Reloading chart. | 2023-02-03 21:52:38.104 F.US.ENQH23 Rev. 40t #3 | Reloading chart. | 2023-02-03 21:52:38.165 F.US.ULAH23 10/32 Range #5 | Reloading chart. | 2023-02-03 21:52:38.192 F.US.EPH23 [CBV] 3.75 Range #1 | Reloading chart. | 2023-02-03 21:52:38.213 F.US.EPH23 [CBV] 3.75 Range #1 | Waiting for historical downloads to complete with the IDs: 1, | 2023-02-03 21:52:38.220 F.US.ENQH23 [CBV] Rev. 20t #2 | Reloading chart. | 2023-02-03 21:52:38.237 F.US.ENQH23 [CBV] Rev. 20t #2 | Waiting for historical downloads to complete with the IDs: 2, | 2023-02-03 21:52:38.243 Files to Open on Startup | Opening file: FootprintCollection2 (1).Cht | 2023-02-03 21:52:38.255 Files to Open on Startup | Opening file: Footprints.Cht | 2023-02-03 21:52:38.255 F.US.EPH23 5 Min #4 | Reloading chart. | 2023-02-03 21:52:38.301 F.US.ENQH23 Rev. 30t #3 | Reloading chart. | 2023-02-03 21:52:38.342 F.US.CLEH23 Rev. 10t #1 | Reloading chart. | 2023-02-03 21:52:38.404 F.US.CLEH23 0.10 Range #2 | Reloading chart. | 2023-02-03 21:52:38.422 F.US.CLEH23 0.10 Range #5 | Reloading chart. | 2023-02-03 21:52:38.440 F.US.CLEH23 0.10 Range #6 | Reloading chart. | 2023-02-03 21:52:38.456 F.US.CLEH23 0.10 Range #7 | Reloading chart. | 2023-02-03 21:52:38.474 Mapping F.US.EPH23 to ESH23. Service code: cme | 2023-02-03 21:52:38.505 Using symbol data fast lookup vector | 2023-02-03 21:52:38.505 HD Request # 1 | Downloading Historical Daily chart data for F.US.EPH23. Starting date: 2023-01-31. Service: cqg | 2023-02-03 21:52:38.506 Starting DelayedDownloadMonitoringTimer | 2023-02-03 21:52:38.604 Starting HDTimeoutTimer | 2023-02-03 21:52:38.604 Added historical Intraday data request for F.US.EPH23 to the queue. | 2023-02-03 21:52:38.604 Intraday data recording state for symbol F.US.EPH23 is set to download 'Pending'. | 2023-02-03 21:52:38.604 Triggering next historical data download in queue. | 2023-02-03 21:52:38.604 HD Request # 2 | Downloading Intraday chart data for F.US.EPH23 to the file F.US.EPH23.scid. Service: cme | 2023-02-03 21:52:38.604 HD Request # 2 | Download start date-time: 2023-02-03 03:28:24.000000. File last date-time: 2023-02-03 03:28:24.019000 | 2023-02-03 21:52:38.605 HD Request # 2 | Using server: ds26.sierracharts.com port 10149 | 2023-02-03 21:52:38.605 Mapping F.US.ENQH23 to NQH23. Service code: cme | 2023-02-03 21:52:38.611 Added historical Intraday data request for F.US.ENQH23 to the queue. | 2023-02-03 21:52:38.611 Intraday data recording state for symbol F.US.ENQH23 is set to download 'Pending'. | 2023-02-03 21:52:38.611 Triggering next historical data download in queue. | 2023-02-03 21:52:38.611 Mapping F.US.RTYH23 to RTYH23. Service code: cme | 2023-02-03 21:52:38.647 Added historical Intraday data request for F.US.RTYH23 to the queue. | 2023-02-03 21:52:38.647 Intraday data recording state for symbol F.US.RTYH23 is set to download 'Pending'. | 2023-02-03 21:52:38.647 Triggering next historical data download in queue. | 2023-02-03 21:52:38.647 Mapping F.US.CLEH23 to CLH23. Service code: nymex | 2023-02-03 21:52:38.650 Added historical Intraday data request for F.US.CLEH23 to the queue. | 2023-02-03 21:52:38.650 Intraday data recording state for symbol F.US.CLEH23 is set to download 'Pending'. | 2023-02-03 21:52:38.650 Triggering next historical data download in queue. | 2023-02-03 21:52:38.650 Mapping F.US.GCEJ23 to GCJ23. Service code: comex | 2023-02-03 21:52:38.658 Added historical Intraday data request for F.US.GCEJ23 to the queue. | 2023-02-03 21:52:38.658 Intraday data recording state for symbol F.US.GCEJ23 is set to download 'Pending'. | 2023-02-03 21:52:38.658 Triggering next historical data download in queue. | 2023-02-03 21:52:38.658 Mapping F.US.NGEH23 to NGH23. Service code: nymex | 2023-02-03 21:52:38.659 Added historical Intraday data request for F.US.NGEH23 to the queue. | 2023-02-03 21:52:38.660 Intraday data recording state for symbol F.US.NGEH23 is set to download 'Pending'. | 2023-02-03 21:52:38.660 Triggering next historical data download in queue. | 2023-02-03 21:52:38.660 Socket (2) | Creating socket. | 2023-02-03 21:52:38.663 Socket (2) | New receive buffer size: 5242880 | 2023-02-03 21:52:38.663 Socket (2) | Connecting to IP: 142.215.17.188. | 2023-02-03 21:52:38.663 Mapping F.US.ULAH23 to UBH23. Service code: cbot | 2023-02-03 21:52:38.691 Added historical Intraday data request for F.US.ULAH23 to the queue. | 2023-02-03 21:52:38.691 Intraday data recording state for symbol F.US.ULAH23 is set to download 'Pending'. | 2023-02-03 21:52:38.691 Triggering next historical data download in queue. | 2023-02-03 21:52:38.691 HD Request # 2 | Setting DTC encoding to Binary VLS | 2023-02-03 21:52:38.778 HD Request # 2 | Sending historical data logon request message. | 2023-02-03 21:52:38.778 HD Request # 1 | Requesting historical Daily data for ESH23 starting at 2023-01-30. SC External HD service. | 2023-02-03 21:52:39.331 HD Request # 2 | Requesting Intraday data. Start date-time: 2023-02-03 03:28:24. Record interval: 0. Symbol: ESH23 | 2023-02-03 21:52:39.352 HD Request # 2 | Decompressing data. | 2023-02-03 21:52:39.404 HD Request # 2 | Receiving Intraday data for F.US.EPH23 starting at 2023-02-03 03:28:24.019000 | 2023-02-03 21:52:39.469 HD Request # 1 | Receiving historical Daily data for F.US.EPH23 starting at 2023-01-31. | 2023-02-03 21:52:39.564 HD Request # 1 | Writing historical Daily data to the file F.US.EPH23.dly. | 2023-02-03 21:52:39.564 HD Request # 1 | Bytes received: 244 | 2023-02-03 21:52:39.566 HD Request # 1 | Received 4 Daily data records from 2023-01-31 00:00:00 to 2023-02-02 00:00:00 (3.0 days) and wrote 3 records for F.US.EPH23 | 2023-02-03 21:52:39.566 HD Request # 1 | Completion time: 1s. | 2023-02-03 21:52:39.566 HD Request # 1 | Daily data download complete for F.US.EPH23. Unique request ID: 1 | 2023-02-03 21:52:39.566 Removing historical data download ID 1. | 2023-02-03 21:52:39.566 Triggering next historical data download in queue. | 2023-02-03 21:52:39.566 HD Request # 3 | Downloading Historical Daily chart data for F.US.ENQH23. Starting date: 2023-01-31. Service: cqg | 2023-02-03 21:52:39.567 HD Request # 2 | Timestamp of first Intraday data file record written: 2023-02-03 03:28:28.411000. | 2023-02-03 21:52:39.695 F.US.EPH23 [CBV] 3.75 Range #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-03 21:52:39.710 F.US.EPH23 [CBV] 3.75 Range #1 | Reloading chart. | 2023-02-03 21:52:39.712 F.US.EPH23 [CBV] 3.75 Range #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-03 21:52:39.726 F.US.EPH23 [CBV] 3.75 Range #9 | Reloading chart. | 2023-02-03 21:52:39.726 F.US.EPH23 [CBV] 3.75 Range #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-03 21:52:40.039 F.US.EPH23 [CBV] 3.75 Range #1 | Reloading chart. | 2023-02-03 21:52:40.040 F.US.EPH23 [CBV] 3.75 Range #9 | Reloading chart. | 2023-02-03 21:52:40.225 F.US.EPH23 [CBV] 3.75 Range #1 | Reloading chart. | 2023-02-03 21:52:40.232 HD Request # 3 | Requesting historical Daily data for NQH23 starting at 2023-01-30. SC External HD service. | 2023-02-03 21:52:40.469 CQG WebAPI | Connecting to server api.cqg.com | 2023-02-03 21:52:40.484 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2023-02-03 21:52:40.484 CQG WebSocket socket (3) | Creating socket. Using TLS 1.2. | 2023-02-03 21:52:40.499 CQG WebSocket socket (3) | New receive buffer size: 5242880 | 2023-02-03 21:52:40.499 CQG WebSocket socket (3) | Connecting to IP: 208.48.16.17. | 2023-02-03 21:52:40.499 F.US.EPH23 [CBV] 3.75 Range #1 | Reloading chart. | 2023-02-03 21:52:40.550 CQG WebSocket | Opening WebSocket. | 2023-02-03 21:52:40.569 CQG WebSocket | Sending WebSocket handshake. | 2023-02-03 21:52:40.569 HD Request # 3 | Receiving historical Daily data for F.US.ENQH23 starting at 2023-01-31. | 2023-02-03 21:52:40.672 HD Request # 3 | Writing historical Daily data to the file F.US.ENQH23.dly. | 2023-02-03 21:52:40.673 HD Request # 3 | Bytes received: 239 | 2023-02-03 21:52:40.674 HD Request # 3 | Received 4 Daily data records from 2023-01-31 00:00:00 to 2023-02-02 00:00:00 (3.0 days) and wrote 3 records for F.US.ENQH23 | 2023-02-03 21:52:40.674 HD Request # 3 | Completion time: 1s. | 2023-02-03 21:52:40.674 HD Request # 3 | Daily data download complete for F.US.ENQH23. Unique request ID: 2 | 2023-02-03 21:52:40.674 Removing historical data download ID 2. | 2023-02-03 21:52:40.674 Triggering next historical data download in queue. | 2023-02-03 21:52:40.674 HD Request # 4 | Downloading Historical Daily chart data for F.US.CLEH23. Starting date: 2023-01-31. Service: cqg | 2023-02-03 21:52:40.675 F.US.ENQH23 [CBV] Rev. 20t #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-03 21:52:40.746 F.US.ENQH23 [CBV] Rev. 20t #2 | Reloading chart. | 2023-02-03 21:52:40.747 CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2023-02-03 21:52:40.797 CQG WebSocket | Server header | Connection: upgrade | 2023-02-03 21:52:40.797 CQG WebSocket | Server header | Sec-WebSocket-Accept: nu27y/hct6K83RRwd+5KG1n2N7E= | 2023-02-03 21:52:40.797 CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2023-02-03 21:52:40.797 CQG WebSocket | Server header | Upgrade: websocket | 2023-02-03 21:52:40.797 CQG WebSocket | Server header | | 2023-02-03 21:52:40.797 CQG WebSocket | Web socket state is now open. | 2023-02-03 21:52:40.797 CQG WebAPI | WebSocket connected. | 2023-02-03 21:52:40.797 CQG WebAPI | Sending market data logon message. | 2023-02-03 21:52:40.797 CQG WebAPI | Base Time: 2023-01-07T07:45:17. 2023-01-07 07:45:17 | 2023-02-03 21:52:40.945 CQG WebAPI | Logon successful. Session Token = ifR5V26gUSJkaO7leR+tVuJg0A75xSth1ljyCaFZFOk6uLwlSvOjUQVz3zGmAmD53Ql211tj8qL | 2023-02-03 21:52:40.945 CQG WebAPI | Connected to server complete. | 2023-02-03 21:52:40.945 Triggering next historical data download in queue. | 2023-02-03 21:52:40.946 Triggering next historical data download in queue. | 2023-02-03 21:52:40.946 Triggering next historical data download in queue. | 2023-02-03 21:52:40.946 Triggering next historical data download in queue. | 2023-02-03 21:52:40.946 Updated verified funded futures trading account ending date to: 2023-03-05 21:52:40 | 2023-02-03 21:52:40.946 CQG WebAPI | Sending Trade Accounts request message. | 2023-02-03 21:52:40.955 No download requests in the queue to start downloads for. | 2023-02-03 21:52:40.955 No download requests in the queue to start downloads for. | 2023-02-03 21:52:40.955 Mapping F.US.ENQH23 to NQH23. Service code: cme | 2023-02-03 21:52:40.971 Using symbol data fast lookup vector | 2023-02-03 21:52:40.971 SC Data - All Services | Starting real-time market data updates for: F.US.ENQH23 (NQH23). ID: 1 Service code: cme | 2023-02-03 21:52:40.971 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 443 | 2023-02-03 21:52:40.971 CQG WebAPI | Sending symbol resolution request for F.US.ENQH23. ID: 798359 | 2023-02-03 21:52:40.974 SC Data - All Services | Requesting security definition data for: F.US.ENQH23 (NQH23). ID: 1 | 2023-02-03 21:52:40.974 Mapping F.US.EPH23 to ESH23. Service code: cme | 2023-02-03 21:52:40.997 SC Data - All Services | Starting real-time market data updates for: F.US.EPH23 (ESH23). ID: 2 Service code: cme | 2023-02-03 21:52:40.997 CQG WebAPI | Sending symbol resolution request for F.US.EPH23. ID: 798360 | 2023-02-03 21:52:40.997 SC Data - All Services | Requesting security definition data for: F.US.EPH23 (ESH23). ID: 2 | 2023-02-03 21:52:40.997 DTC Client socket (4) | Creating socket. | 2023-02-03 21:52:41.048 DTC Client socket (4) | New receive buffer size: 5242880 | 2023-02-03 21:52:41.048 DTC Client socket (4) | Connecting to IP: 142.215.17.190. | 2023-02-03 21:52:41.048 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQH23. Search Symbol: F.US.ENQH23. Request ID: 798359. Contract ID: 1. | 2023-02-03 21:52:41.134 CQG WebAPI | Brokerage name: AMP. Account Name: 110041 | 2023-02-03 21:52:41.134 Updated verified funded futures trading account ending date to: 2023-03-05 21:52:41 | 2023-02-03 21:52:41.134 CQG WebAPI | Sending collateral subscribe request. | 2023-02-03 21:52:41.134 SC Data - All Services | Network connection to server complete. | 2023-02-03 21:52:41.134 SC Data - All Services | Starting socket receive thread. | 2023-02-03 21:52:41.134 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-03 21:52:41.134 CQG WebAPI | Received symbol resolution report for symbol F.US.EPH23. Search Symbol: F.US.EPH23. Request ID: 798360. Contract ID: 2. | 2023-02-03 21:52:41.134 Mapping F.US.GCEJ23 to GCJ23. Service code: comex | 2023-02-03 21:52:41.136 SC Data - All Services | Starting real-time market data updates for: F.US.GCEJ23 (GCJ23). ID: 3 Service code: comex | 2023-02-03 21:52:41.136 CQG WebAPI | Sending symbol resolution request for F.US.GCEJ23. ID: 798362 | 2023-02-03 21:52:41.136 SC Data - All Services | Requesting security definition data for: F.US.GCEJ23 (GCJ23). ID: 3 | 2023-02-03 21:52:41.136 Mapping F.US.CLEH23 to CLH23. Service code: nymex | 2023-02-03 21:52:41.136 SC Data - All Services | Starting real-time market data updates for: F.US.CLEH23 (CLH23). ID: 4 Service code: nymex | 2023-02-03 21:52:41.136 CQG WebAPI | Sending symbol resolution request for F.US.CLEH23. ID: 798363 | 2023-02-03 21:52:41.136 SC Data - All Services | Requesting security definition data for: F.US.CLEH23 (CLH23). ID: 4 | 2023-02-03 21:52:41.136 Mapping F.US.RTYH23 to RTYH23. Service code: cme | 2023-02-03 21:52:41.167 SC Data - All Services | Starting real-time market data updates for: F.US.RTYH23 (RTYH23). ID: 5 Service code: cme | 2023-02-03 21:52:41.167 CQG WebAPI | Sending symbol resolution request for F.US.RTYH23. ID: 798364 | 2023-02-03 21:52:41.167 SC Data - All Services | Requesting security definition data for: F.US.RTYH23 (RTYH23). ID: 5 | 2023-02-03 21:52:41.167 Mapping F.US.NGEH23 to NGH23. Service code: nymex | 2023-02-03 21:52:41.199 SC Data - All Services | Starting real-time market data updates for: F.US.NGEH23 (NGH23). ID: 6 Service code: nymex | 2023-02-03 21:52:41.199 CQG WebAPI | Sending symbol resolution request for F.US.NGEH23. ID: 798365 | 2023-02-03 21:52:41.199 SC Data - All Services | Requesting security definition data for: F.US.NGEH23 (NGH23). ID: 6 | 2023-02-03 21:52:41.199 F.US.ENQH23 [CBV] Rev. 20t #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-03 21:52:41.204 F.US.ENQH23 [CBV] Rev. 20t #2 | Reloading chart. | 2023-02-03 21:52:41.205 SC Data - All Services | Setting DTC encoding to Binary VLS | 2023-02-03 21:52:41.339 SC Data - All Services | Sending logon request message. | 2023-02-03 21:52:41.339 CQG WebAPI | Received symbol resolution report for symbol F.US.GCEJ23. Search Symbol: F.US.GCEJ23. Request ID: 798362. Contract ID: 3. | 2023-02-03 21:52:41.339 CQG WebAPI | Received symbol resolution report for symbol F.US.CLEH23. Search Symbol: F.US.CLEH23. Request ID: 798363. Contract ID: 4. | 2023-02-03 21:52:41.339 CQG WebAPI | Received symbol resolution report for symbol F.US.RTYH23. Search Symbol: F.US.RTYH23. Request ID: 798364. Contract ID: 5. | 2023-02-03 21:52:41.339 CQG WebAPI | Received symbol resolution report for symbol F.US.NGEH23. Search Symbol: F.US.NGEH23. Request ID: 798365. Contract ID: 6. | 2023-02-03 21:52:41.339 CQG WebAPI | Sending positions subscribe request. RequestID: 798366 | 2023-02-03 21:52:41.339 CQG WebAPI | Sending orders subscribe request. RequestID: 798367 | 2023-02-03 21:52:41.339 Mapping F.US.ULAH23 to UBH23. Service code: cbot | 2023-02-03 21:52:41.343 SC Data - All Services | Starting real-time market data updates for: F.US.ULAH23 (UBH23). ID: 7 Service code: cbot | 2023-02-03 21:52:41.343 CQG WebAPI | Sending symbol resolution request for F.US.ULAH23. ID: 798368 | 2023-02-03 21:52:41.343 SC Data - All Services | Requesting security definition data for: F.US.ULAH23 (UBH23). ID: 7 | 2023-02-03 21:52:41.343 F.US.ENQH23 [CBV] Rev. 20t #2 | Reloading chart. | 2023-02-03 21:52:41.344 CQG WebAPI | Received symbol resolution report for symbol F.US.ULAH23. Search Symbol: F.US.ULAH23. Request ID: 798368. Contract ID: 7. | 2023-02-03 21:52:41.453 HD Request # 4 | Requesting historical Daily data for CLH23 starting at 2023-01-30. SC External HD service. | 2023-02-03 21:52:41.584 F.US.ENQH23 [CBV] Rev. 20t #2 | Reloading chart. | 2023-02-03 21:52:41.716 HD Request # 4 | Receiving historical Daily data for F.US.CLEH23 starting at 2023-01-31. | 2023-02-03 21:52:41.799 HD Request # 4 | Writing historical Daily data to the file F.US.CLEH23.dly. | 2023-02-03 21:52:41.799 HD Request # 4 | Bytes received: 219 | 2023-02-03 21:52:41.805 HD Request # 4 | Received 4 Daily data records from 2023-01-31 00:00:00 to 2023-02-02 00:00:00 (3.0 days) and wrote 3 records for F.US.CLEH23 | 2023-02-03 21:52:41.805 HD Request # 4 | Completion time: 1s. | 2023-02-03 21:52:41.805 HD Request # 4 | Daily data download complete for F.US.CLEH23. Unique request ID: 3 | 2023-02-03 21:52:41.805 Removing historical data download ID 3. | 2023-02-03 21:52:41.805 Triggering next historical data download in queue. | 2023-02-03 21:52:41.805 HD Request # 5 | Downloading Historical Daily chart data for F.US.GCEJ23. Starting date: 2023-01-31. Service: cqg | 2023-02-03 21:52:41.806 SC Data - All Services | Received logon response. | 2023-02-03 21:52:42.052 SC Data - All Services | Server Name: RealTime Server. | 2023-02-03 21:52:42.052 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2023-02-03 21:52:42.052 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-02-03 21:52:42.052 SC Data - All Services | Waiting for socket receive thread to end | 2023-02-03 21:52:42.052 DTC Client socket (4) | CloseSocket call. | 2023-02-03 21:52:42.052 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:52:42.052 SC Data - All Services | Disconnected from the server. | 2023-02-03 21:52:42.052 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2023-02-03 21:52:42.052 DTC Client socket (4) | Socket gracefully closed by remote side. | 2023-02-03 21:52:42.108 DTC Client socket (4) | Closed. | 2023-02-03 21:52:42.108 F.US.CLEH23 [CBV] Rev. 10t #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-03 21:52:42.139 F.US.CLEH23 [CBV] Rev. 10t #6 | Reloading chart. | 2023-02-03 21:52:42.140 F.US.CLEH23 [CBV] 0.15 Range #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-03 21:52:42.371 F.US.CLEH23 [CBV] 0.15 Range #8 | Reloading chart. | 2023-02-03 21:52:42.371 Socket (2) | CloseSocket call. | 2023-02-03 21:52:42.387 Socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:52:42.387 Historical data download thread signaled to stop. | 2023-02-03 21:52:42.394 HD Request # 2 | Received 1474226 Intraday data records from 2023-02-03 03:28:24.019000 to 2023-02-03 21:52:40.568000 (18.4 hours) and wrote 1474225 records for F.US.EPH23 | 2023-02-03 21:52:42.394 HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2023-02-03 21:52:40.568000 | 2023-02-03 21:52:42.395 HD Request # 2 | Completion time: 4s. | 2023-02-03 21:52:42.396 HD Request # 2 | Intraday data download complete for F.US.EPH23. Unique request ID: 5 | 2023-02-03 21:52:42.396 Removing historical data download ID 5. | 2023-02-03 21:52:42.396 Real-time Intraday chart data file updates started for F.US.EPH23 | 2023-02-03 21:52:42.396 Intraday chart data file opened for F.US.EPH23 | 2023-02-03 21:52:42.396 HD Request # 2 | Enabling Intraday chart updating for symbol. | 2023-02-03 21:52:42.396 Triggering next historical data download in queue. | 2023-02-03 21:52:42.396 Initiating new historical data download for F.US.EPH23 to get the latest data since the download was started while not connected to primary service. | 2023-02-03 21:52:42.396 Added historical Intraday data request for F.US.EPH23 to the queue. | 2023-02-03 21:52:42.396 Intraday data recording state for symbol F.US.EPH23 is set to download 'Pending'. | 2023-02-03 21:52:42.396 Delaying start of download for F.US.EPH23. | 2023-02-03 21:52:42.396 Socket (2) | Socket gracefully closed by remote side. | 2023-02-03 21:52:42.447 Socket (2) | Closed. | 2023-02-03 21:52:42.447 HD Request # 5 | Requesting historical Daily data for GCJ23 starting at 2023-01-30. SC External HD service. | 2023-02-03 21:52:42.656 F.US.CLEH23 [CBV] Rev. 10t #6 | Reloading chart. | 2023-02-03 21:52:42.661 HD Request # 5 | Receiving historical Daily data for F.US.GCEJ23 starting at 2023-01-31. | 2023-02-03 21:52:42.814 HD Request # 5 | Writing historical Daily data to the file F.US.GCEJ23.dly. | 2023-02-03 21:52:42.814 HD Request # 5 | Bytes received: 232 | 2023-02-03 21:52:42.816 HD Request # 5 | Received 4 Daily data records from 2023-01-31 00:00:00 to 2023-02-02 00:00:00 (3.0 days) and wrote 3 records for F.US.GCEJ23 | 2023-02-03 21:52:42.816 HD Request # 5 | Completion time: 1s. | 2023-02-03 21:52:42.816 HD Request # 5 | Daily data download complete for F.US.GCEJ23. Unique request ID: 4 | 2023-02-03 21:52:42.816 Removing historical data download ID 4. | 2023-02-03 21:52:42.816 Triggering next historical data download in queue. | 2023-02-03 21:52:42.816 No download requests in the queue to start downloads for. | 2023-02-03 21:52:42.816 F.US.CLEH23 [CBV] 0.15 Range #8 | Reloading chart. | 2023-02-03 21:52:42.863 F.US.GCEJ23 [CBV] Rev. 10t #7 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-03 21:52:43.159 F.US.GCEJ23 [CBV] Rev. 10t #7 | Reloading chart. | 2023-02-03 21:52:43.160 F.US.GCEJ23 [CBV] Rev. 10t #7 | Reloading chart. | 2023-02-03 21:52:43.674 HD Request # 6 | Downloading Intraday chart data for F.US.EPH23 to the file F.US.EPH23.scid. Service: cme | 2023-02-03 21:53:11.642 HD Request # 6 | Download start date-time: 2023-02-03 21:52:40.000000. File last date-time: 2023-02-03 21:52:40.568000 | 2023-02-03 21:53:11.642 HD Request # 6 | Using server: ds28.sierracharts.com port 10150 | 2023-02-03 21:53:11.642 Socket (1) | Creating socket. | 2023-02-03 21:53:11.667 Socket (1) | New receive buffer size: 5242880 | 2023-02-03 21:53:11.667 Socket (1) | Connecting to IP: 142.215.18.147. | 2023-02-03 21:53:11.667 HD Request # 6 | Setting DTC encoding to Binary VLS | 2023-02-03 21:53:11.787 HD Request # 6 | Sending historical data logon request message. | 2023-02-03 21:53:11.787 SC Data - All Services | Connecting to the server ds23-2.sierracharts.com. Port 443 | 2023-02-03 21:53:12.051 DTC Client socket (2) | Creating socket. | 2023-02-03 21:53:12.074 DTC Client socket (2) | New receive buffer size: 5242880 | 2023-02-03 21:53:12.075 DTC Client socket (2) | Connecting to IP: 142.215.17.187. | 2023-02-03 21:53:12.075 SC Data - All Services | Network connection to server complete. | 2023-02-03 21:53:12.130 SC Data - All Services | Starting socket receive thread. | 2023-02-03 21:53:12.130 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-03 21:53:12.130 SC Data - All Services | Setting DTC encoding to Binary VLS | 2023-02-03 21:53:12.196 SC Data - All Services | Sending logon request message. | 2023-02-03 21:53:12.196 HD Request # 6 | Requesting Intraday data. Start date-time: 2023-02-03 21:52:40. Record interval: 0. Symbol: ESH23 | 2023-02-03 21:53:12.371 HD Request # 6 | Decompressing data. | 2023-02-03 21:53:12.429 HD Request # 6 | Receiving Intraday data for F.US.EPH23 starting at 2023-02-03 21:52:40.567000 | 2023-02-03 21:53:12.430 Socket (1) | CloseSocket call. | 2023-02-03 21:53:12.430 Socket (1) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:53:12.430 Historical data download thread signaled to stop. | 2023-02-03 21:53:12.430 HD Request # 6 | Timestamp of first Intraday data file record written: 2023-02-03 21:52:50.783000. | 2023-02-03 21:53:12.430 HD Request # 6 | Received 29 Intraday data records from 2023-02-03 21:52:40.567000 to 2023-02-03 21:53:08.863000 (28.3 seconds) and wrote 25 records for F.US.EPH23 | 2023-02-03 21:53:12.430 HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2023-02-03 21:53:08.863000 | 2023-02-03 21:53:12.431 HD Request # 6 | Completion time: 1s. | 2023-02-03 21:53:12.431 HD Request # 6 | Intraday data download complete for F.US.EPH23. Unique request ID: 12 | 2023-02-03 21:53:12.431 Removing historical data download ID 12. | 2023-02-03 21:53:12.431 Real-time Intraday chart data file updates started for F.US.EPH23 | 2023-02-03 21:53:12.431 Intraday chart data file opened for F.US.EPH23 | 2023-02-03 21:53:12.431 HD Request # 6 | Enabling Intraday chart updating for symbol. | 2023-02-03 21:53:12.431 Triggering next historical data download in queue. | 2023-02-03 21:53:12.431 HD Request # 7 | Downloading Intraday chart data for F.US.ENQH23 to the file F.US.ENQH23.scid. Service: cme | 2023-02-03 21:53:12.431 HD Request # 7 | Download start date-time: 2023-02-03 03:28:15.000000. File last date-time: 2023-02-03 03:28:15.863000 | 2023-02-03 21:53:12.431 HD Request # 7 | Using server: ds23.sierracharts.com port 10149 | 2023-02-03 21:53:12.431 Socket (4) | Creating socket. | 2023-02-03 21:53:12.431 Socket (4) | New receive buffer size: 5242880 | 2023-02-03 21:53:12.431 Socket (4) | Connecting to IP: 142.215.17.190. | 2023-02-03 21:53:12.431 Socket (1) | Socket gracefully closed by remote side. | 2023-02-03 21:53:12.488 Socket (1) | Closed. | 2023-02-03 21:53:12.488 HD Request # 7 | Setting DTC encoding to Binary VLS | 2023-02-03 21:53:12.553 HD Request # 7 | Sending historical data logon request message. | 2023-02-03 21:53:12.553 SC Data - All Services | Received logon response. | 2023-02-03 21:53:12.931 SC Data - All Services | Server Name: RealTime Server. | 2023-02-03 21:53:12.931 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2023-02-03 21:53:12.931 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-02-03 21:53:12.931 SC Data - All Services | Waiting for socket receive thread to end | 2023-02-03 21:53:12.931 DTC Client socket (2) | CloseSocket call. | 2023-02-03 21:53:12.931 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:53:12.931 SC Data - All Services | Disconnected from the server. | 2023-02-03 21:53:12.931 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2023-02-03 21:53:12.931 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-02-03 21:53:12.991 DTC Client socket (2) | Closed. | 2023-02-03 21:53:12.991 HD Request # 7 | Requesting Intraday data. Start date-time: 2023-02-03 03:28:15. Record interval: 0. Symbol: NQH23 | 2023-02-03 21:53:13.127 HD Request # 7 | Decompressing data. | 2023-02-03 21:53:13.187 HD Request # 7 | Receiving Intraday data for F.US.ENQH23 starting at 2023-02-03 03:28:15.863000 | 2023-02-03 21:53:13.385 HD Request # 7 | Timestamp of first Intraday data file record written: 2023-02-03 03:28:41.411000. | 2023-02-03 21:53:13.722 Socket (4) | CloseSocket call. | 2023-02-03 21:53:15.407 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:53:15.407 Historical data download thread signaled to stop. | 2023-02-03 21:53:15.408 HD Request # 7 | Received 688602 Intraday data records from 2023-02-03 03:28:15.863000 to 2023-02-03 21:53:13.129000 (18.4 hours) and wrote 688601 records for F.US.ENQH23 | 2023-02-03 21:53:15.408 HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2023-02-03 21:53:13.129000 | 2023-02-03 21:53:15.409 HD Request # 7 | Completion time: 3s. | 2023-02-03 21:53:15.409 HD Request # 7 | Intraday data download complete for F.US.ENQH23. Unique request ID: 6 | 2023-02-03 21:53:15.409 Removing historical data download ID 6. | 2023-02-03 21:53:15.409 Real-time Intraday chart data file updates started for F.US.ENQH23 | 2023-02-03 21:53:15.409 Intraday chart data file opened for F.US.ENQH23 | 2023-02-03 21:53:15.409 HD Request # 7 | Enabling Intraday chart updating for symbol. | 2023-02-03 21:53:15.409 Triggering next historical data download in queue. | 2023-02-03 21:53:15.409 HD Request # 8 | Downloading Intraday chart data for F.US.RTYH23 to the file F.US.RTYH23.scid. Service: cme | 2023-02-03 21:53:15.409 HD Request # 8 | Download start date-time: 2023-02-03 03:27:15.000000. File last date-time: 2023-02-03 03:27:15.927001 | 2023-02-03 21:53:15.409 HD Request # 8 | Using server: ds26.sierracharts.com port 10150 | 2023-02-03 21:53:15.409 Socket (1) | Creating socket. | 2023-02-03 21:53:15.409 Socket (1) | New receive buffer size: 5242880 | 2023-02-03 21:53:15.409 Socket (1) | Connecting to IP: 142.215.17.188. | 2023-02-03 21:53:15.409 Socket (4) | Socket gracefully closed by remote side. | 2023-02-03 21:53:15.461 Socket (4) | Closed. | 2023-02-03 21:53:15.461 HD Request # 8 | Setting DTC encoding to Binary VLS | 2023-02-03 21:53:15.530 HD Request # 8 | Sending historical data logon request message. | 2023-02-03 21:53:15.530 HD Request # 8 | Requesting Intraday data. Start date-time: 2023-02-03 03:27:15. Record interval: 0. Symbol: RTYH23 | 2023-02-03 21:53:16.120 HD Request # 8 | Decompressing data. | 2023-02-03 21:53:16.195 HD Request # 8 | Receiving Intraday data for F.US.RTYH23 starting at 2023-02-03 03:27:15.927000 | 2023-02-03 21:53:16.334 HD Request # 8 | Timestamp of first Intraday data file record written: 2023-02-03 03:28:55.666000. | 2023-02-03 21:53:16.510 Socket (1) | CloseSocket call. | 2023-02-03 21:53:16.889 Socket (1) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:53:16.889 Historical data download thread signaled to stop. | 2023-02-03 21:53:16.889 HD Request # 8 | Received 182261 Intraday data records from 2023-02-03 03:27:15.927000 to 2023-02-03 21:52:50.784002 (18.4 hours) and wrote 182259 records for F.US.RTYH23 | 2023-02-03 21:53:16.890 HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2023-02-03 21:52:50.784002 | 2023-02-03 21:53:16.890 HD Request # 8 | Completion time: 1s. | 2023-02-03 21:53:16.890 HD Request # 8 | Intraday data download complete for F.US.RTYH23. Unique request ID: 7 | 2023-02-03 21:53:16.890 Removing historical data download ID 7. | 2023-02-03 21:53:16.890 Real-time Intraday chart data file updates started for F.US.RTYH23 | 2023-02-03 21:53:16.890 Intraday chart data file opened for F.US.RTYH23 | 2023-02-03 21:53:16.890 HD Request # 8 | Enabling Intraday chart updating for symbol. | 2023-02-03 21:53:16.890 Triggering next historical data download in queue. | 2023-02-03 21:53:16.891 HD Request # 9 | Downloading Intraday chart data for F.US.CLEH23 to the file F.US.CLEH23.scid. Service: nymex | 2023-02-03 21:53:16.891 HD Request # 9 | Download start date-time: 2023-02-03 03:28:23.000000. File last date-time: 2023-02-03 03:28:23.948000 | 2023-02-03 21:53:16.891 HD Request # 9 | Using server: ds28.sierracharts.com port 10149 | 2023-02-03 21:53:16.891 Socket (2) | Creating socket. | 2023-02-03 21:53:16.891 Socket (2) | New receive buffer size: 5242880 | 2023-02-03 21:53:16.891 Socket (2) | Connecting to IP: 142.215.18.147. | 2023-02-03 21:53:16.891 Socket (1) | Socket gracefully closed by remote side. | 2023-02-03 21:53:16.948 Socket (1) | Closed. | 2023-02-03 21:53:16.948 HD Request # 9 | Setting DTC encoding to Binary VLS | 2023-02-03 21:53:17.006 HD Request # 9 | Sending historical data logon request message. | 2023-02-03 21:53:17.006 HD Request # 9 | Requesting Intraday data. Start date-time: 2023-02-03 03:28:23. Record interval: 0. Symbol: CLH23 | 2023-02-03 21:53:17.589 HD Request # 9 | Decompressing data. | 2023-02-03 21:53:17.644 HD Request # 9 | Receiving Intraday data for F.US.CLEH23 starting at 2023-02-03 03:28:23.583000 | 2023-02-03 21:53:17.762 HD Request # 9 | Timestamp of first Intraday data file record written: 2023-02-03 03:28:30.355000. | 2023-02-03 21:53:18.154 Socket (2) | CloseSocket call. | 2023-02-03 21:53:18.796 Socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:53:18.796 Historical data download thread signaled to stop. | 2023-02-03 21:53:18.806 HD Request # 9 | Received 266652 Intraday data records from 2023-02-03 03:28:23.583000 to 2023-02-03 21:53:16.114002 (18.4 hours) and wrote 266650 records for F.US.CLEH23 | 2023-02-03 21:53:18.806 HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2023-02-03 21:53:16.114002 | 2023-02-03 21:53:18.807 HD Request # 9 | Completion time: 2s. | 2023-02-03 21:53:18.807 HD Request # 9 | Intraday data download complete for F.US.CLEH23. Unique request ID: 8 | 2023-02-03 21:53:18.807 Removing historical data download ID 8. | 2023-02-03 21:53:18.807 Real-time Intraday chart data file updates started for F.US.CLEH23 | 2023-02-03 21:53:18.807 Intraday chart data file opened for F.US.CLEH23 | 2023-02-03 21:53:18.807 HD Request # 9 | Enabling Intraday chart updating for symbol. | 2023-02-03 21:53:18.807 Triggering next historical data download in queue. | 2023-02-03 21:53:18.807 HD Request # 10 | Downloading Intraday chart data for F.US.GCEJ23 to the file F.US.GCEJ23.scid. Service: comex | 2023-02-03 21:53:18.807 HD Request # 10 | Download start date-time: 2023-02-03 03:28:29.000000. File last date-time: 2023-02-03 03:28:29.690000 | 2023-02-03 21:53:18.807 HD Request # 10 | Using server: ds23.sierracharts.com port 10150 | 2023-02-03 21:53:18.807 Socket (1) | Creating socket. | 2023-02-03 21:53:18.807 Socket (1) | New receive buffer size: 5242880 | 2023-02-03 21:53:18.807 Socket (1) | Connecting to IP: 142.215.17.190. | 2023-02-03 21:53:18.807 Socket (2) | Socket gracefully closed by remote side. | 2023-02-03 21:53:18.850 Socket (2) | Closed. | 2023-02-03 21:53:18.850 HD Request # 10 | Setting DTC encoding to Binary VLS | 2023-02-03 21:53:18.936 HD Request # 10 | Sending historical data logon request message. | 2023-02-03 21:53:18.936 HD Request # 10 | Requesting Intraday data. Start date-time: 2023-02-03 03:28:29. Record interval: 0. Symbol: GCJ23 | 2023-02-03 21:53:19.511 HD Request # 10 | Decompressing data. | 2023-02-03 21:53:19.570 HD Request # 10 | Receiving Intraday data for F.US.GCEJ23 starting at 2023-02-03 03:28:29.690000 | 2023-02-03 21:53:19.705 HD Request # 10 | Timestamp of first Intraday data file record written: 2023-02-03 03:28:35.570000. | 2023-02-03 21:53:20.049 Socket (1) | CloseSocket call. | 2023-02-03 21:53:20.505 Socket (1) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:53:20.505 Historical data download thread signaled to stop. | 2023-02-03 21:53:20.505 HD Request # 10 | Received 217640 Intraday data records from 2023-02-03 03:28:29.690000 to 2023-02-03 21:53:12.485000 (18.4 hours) and wrote 217639 records for F.US.GCEJ23 | 2023-02-03 21:53:20.505 HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2023-02-03 21:53:12.485000 | 2023-02-03 21:53:20.506 HD Request # 10 | Completion time: 2s. | 2023-02-03 21:53:20.506 HD Request # 10 | Intraday data download complete for F.US.GCEJ23. Unique request ID: 9 | 2023-02-03 21:53:20.506 Removing historical data download ID 9. | 2023-02-03 21:53:20.506 Real-time Intraday chart data file updates started for F.US.GCEJ23 | 2023-02-03 21:53:20.506 Intraday chart data file opened for F.US.GCEJ23 | 2023-02-03 21:53:20.506 HD Request # 10 | Enabling Intraday chart updating for symbol. | 2023-02-03 21:53:20.506 Triggering next historical data download in queue. | 2023-02-03 21:53:20.506 HD Request # 11 | Downloading Intraday chart data for F.US.NGEH23 to the file F.US.NGEH23.scid. Service: nymex | 2023-02-03 21:53:20.506 HD Request # 11 | Download start date-time: 2023-02-03 03:27:59.000000. File last date-time: 2023-02-03 03:27:59.330000 | 2023-02-03 21:53:20.506 HD Request # 11 | Using server: ds26.sierracharts.com port 10149 | 2023-02-03 21:53:20.506 Socket (2) | Creating socket. | 2023-02-03 21:53:20.506 Socket (2) | New receive buffer size: 5242880 | 2023-02-03 21:53:20.506 Socket (2) | Connecting to IP: 142.215.17.188. | 2023-02-03 21:53:20.506 Socket (1) | Socket gracefully closed by remote side. | 2023-02-03 21:53:20.561 Socket (1) | Closed. | 2023-02-03 21:53:20.561 HD Request # 11 | Setting DTC encoding to Binary VLS | 2023-02-03 21:53:20.627 HD Request # 11 | Sending historical data logon request message. | 2023-02-03 21:53:20.627 HD Request # 11 | Requesting Intraday data. Start date-time: 2023-02-03 03:27:59. Record interval: 0. Symbol: NGH23 | 2023-02-03 21:53:21.218 HD Request # 11 | Decompressing data. | 2023-02-03 21:53:21.277 HD Request # 11 | Receiving Intraday data for F.US.NGEH23 starting at 2023-02-03 03:27:59.330000 | 2023-02-03 21:53:21.405 HD Request # 11 | Timestamp of first Intraday data file record written: 2023-02-03 03:28:52.946000. | 2023-02-03 21:53:21.653 Socket (2) | CloseSocket call. | 2023-02-03 21:53:21.668 Socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:53:21.668 Historical data download thread signaled to stop. | 2023-02-03 21:53:21.668 HD Request # 11 | Received 73038 Intraday data records from 2023-02-03 03:27:59.330000 to 2023-02-03 21:53:07.819001 (18.4 hours) and wrote 73037 records for F.US.NGEH23 | 2023-02-03 21:53:21.668 HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2023-02-03 21:53:07.819001 | 2023-02-03 21:53:21.668 HD Request # 11 | Completion time: 1s. | 2023-02-03 21:53:21.668 HD Request # 11 | Intraday data download complete for F.US.NGEH23. Unique request ID: 10 | 2023-02-03 21:53:21.668 Removing historical data download ID 10. | 2023-02-03 21:53:21.668 Real-time Intraday chart data file updates started for F.US.NGEH23 | 2023-02-03 21:53:21.668 Intraday chart data file opened for F.US.NGEH23 | 2023-02-03 21:53:21.668 HD Request # 11 | Enabling Intraday chart updating for symbol. | 2023-02-03 21:53:21.668 Triggering next historical data download in queue. | 2023-02-03 21:53:21.668 HD Request # 12 | Downloading Intraday chart data for F.US.ULAH23 to the file F.US.ULAH23.scid. Service: cbot | 2023-02-03 21:53:21.668 HD Request # 12 | Download start date-time: 2023-02-03 03:28:10.000000. File last date-time: 2023-02-03 03:28:10.480002 | 2023-02-03 21:53:21.669 HD Request # 12 | Using server: ds28.sierracharts.com port 10150 | 2023-02-03 21:53:21.669 Socket (1) | Creating socket. | 2023-02-03 21:53:21.669 Socket (1) | New receive buffer size: 5242880 | 2023-02-03 21:53:21.669 Socket (1) | Connecting to IP: 142.215.18.147. | 2023-02-03 21:53:21.669 Socket (2) | Socket gracefully closed by remote side. | 2023-02-03 21:53:21.727 Socket (2) | Closed. | 2023-02-03 21:53:21.727 HD Request # 12 | Setting DTC encoding to Binary VLS | 2023-02-03 21:53:21.798 HD Request # 12 | Sending historical data logon request message. | 2023-02-03 21:53:21.798 HD Request # 12 | Requesting Intraday data. Start date-time: 2023-02-03 03:28:10. Record interval: 0. Symbol: UBH23 | 2023-02-03 21:53:21.862 HD Request # 12 | Decompressing data. | 2023-02-03 21:53:21.925 HD Request # 12 | Receiving Intraday data for F.US.ULAH23 starting at 2023-02-03 03:28:10.480000 | 2023-02-03 21:53:22.063 HD Request # 12 | Timestamp of first Intraday data file record written: 2023-02-03 03:28:52.945000. | 2023-02-03 21:53:22.475 Socket (1) | CloseSocket call. | 2023-02-03 21:53:22.499 Socket (1) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:53:22.499 Historical data download thread signaled to stop. | 2023-02-03 21:53:22.499 HD Request # 12 | Received 98641 Intraday data records from 2023-02-03 03:28:10.480000 to 2023-02-03 21:53:06.987005 (18.4 hours) and wrote 98638 records for F.US.ULAH23 | 2023-02-03 21:53:22.500 HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2023-02-03 21:53:06.987005 | 2023-02-03 21:53:22.500 HD Request # 12 | Completion time: 1s. | 2023-02-03 21:53:22.500 HD Request # 12 | Intraday data download complete for F.US.ULAH23. Unique request ID: 11 | 2023-02-03 21:53:22.500 Removing historical data download ID 11. | 2023-02-03 21:53:22.500 Real-time Intraday chart data file updates started for F.US.ULAH23 | 2023-02-03 21:53:22.500 Intraday chart data file opened for F.US.ULAH23 | 2023-02-03 21:53:22.500 HD Request # 12 | Enabling Intraday chart updating for symbol. | 2023-02-03 21:53:22.500 Triggering next historical data download in queue. | 2023-02-03 21:53:22.500 No download requests in the queue to start downloads for. | 2023-02-03 21:53:22.500 Socket (1) | Socket gracefully closed by remote side. | 2023-02-03 21:53:22.558 Socket (1) | Closed. | 2023-02-03 21:53:22.558 SC Data - All Services | Connecting to the server ds26-2.sierracharts.com. Port 10048 | 2023-02-03 21:53:42.931 DTC Client socket (1) | Creating socket. | 2023-02-03 21:53:42.956 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-02-03 21:53:42.956 DTC Client socket (1) | Connecting to IP: 142.215.17.189. | 2023-02-03 21:53:42.956 SC Data - All Services | Network connection to server complete. | 2023-02-03 21:53:43.018 SC Data - All Services | Starting socket receive thread. | 2023-02-03 21:53:43.019 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-03 21:53:43.019 SC Data - All Services | Setting DTC encoding to Binary VLS | 2023-02-03 21:53:43.103 SC Data - All Services | Sending logon request message. | 2023-02-03 21:53:43.103 SC Data - All Services | Received logon response. | 2023-02-03 21:53:43.822 SC Data - All Services | Server Name: RealTime Server. | 2023-02-03 21:53:43.822 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2023-02-03 21:53:43.822 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-02-03 21:53:43.822 SC Data - All Services | Waiting for socket receive thread to end | 2023-02-03 21:53:43.822 DTC Client socket (1) | CloseSocket call. | 2023-02-03 21:53:43.822 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:53:43.822 SC Data - All Services | Disconnected from the server. | 2023-02-03 21:53:43.822 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2023-02-03 21:53:43.823 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-02-03 21:53:43.878 DTC Client socket (1) | Closed. | 2023-02-03 21:53:43.878 SC Data - All Services | Connecting to the server ds28.sierracharts.com. Port 10048 | 2023-02-03 21:54:13.810 DTC Client socket (1) | Creating socket. | 2023-02-03 21:54:13.811 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-02-03 21:54:13.811 DTC Client socket (1) | Connecting to IP: 142.215.18.147. | 2023-02-03 21:54:13.811 SC Data - All Services | Network connection to server complete. | 2023-02-03 21:54:13.866 SC Data - All Services | Starting socket receive thread. | 2023-02-03 21:54:13.866 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-03 21:54:13.867 SC Data - All Services | Setting DTC encoding to Binary VLS | 2023-02-03 21:54:13.950 SC Data - All Services | Sending logon request message. | 2023-02-03 21:54:13.950 SC Data - All Services | Received logon response. | 2023-02-03 21:54:14.670 SC Data - All Services | Server Name: RealTime Server. | 2023-02-03 21:54:14.670 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2023-02-03 21:54:14.670 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-02-03 21:54:14.670 SC Data - All Services | Waiting for socket receive thread to end | 2023-02-03 21:54:14.670 DTC Client socket (1) | CloseSocket call. | 2023-02-03 21:54:14.671 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:54:14.671 SC Data - All Services | Disconnected from the server. | 2023-02-03 21:54:14.671 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2023-02-03 21:54:14.671 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-02-03 21:54:14.728 DTC Client socket (1) | Closed. | 2023-02-03 21:54:14.728 SC Data - All Services | Connecting to the server ds13.sierracharts.com. Port 443 | 2023-02-03 21:54:44.683 DTC Client socket (1) | Creating socket. | 2023-02-03 21:54:44.714 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-02-03 21:54:44.714 DTC Client socket (1) | Connecting to IP: 162.251.232.244. | 2023-02-03 21:54:44.714 SC Data - All Services | Network connection to server complete. | 2023-02-03 21:54:44.744 SC Data - All Services | Starting socket receive thread. | 2023-02-03 21:54:44.744 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-03 21:54:44.744 SC Data - All Services | Setting DTC encoding to Binary VLS | 2023-02-03 21:54:44.784 SC Data - All Services | Sending logon request message. | 2023-02-03 21:54:44.784 SC Data - All Services | Received logon response. | 2023-02-03 21:54:44.831 SC Data - All Services | Server Name: RealTime Server. | 2023-02-03 21:54:44.831 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2023-02-03 21:54:44.831 SC Data - All Services | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. | 2023-02-03 21:54:44.831 SC Data - All Services | Waiting for socket receive thread to end | 2023-02-03 21:54:44.831 DTC Client socket (1) | CloseSocket call. | 2023-02-03 21:54:44.831 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:54:44.831 SC Data - All Services | Disconnected from the server. | 2023-02-03 21:54:44.831 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2023-02-03 21:54:44.831 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-02-03 21:54:44.859 DTC Client socket (1) | Closed. | 2023-02-03 21:54:44.859 SC Data - All Services | Connecting to the server ds28.sierracharts.com. Port 443 | 2023-02-03 21:54:46.828 DTC Client socket (1) | Creating socket. | 2023-02-03 21:54:46.828 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-02-03 21:54:46.828 DTC Client socket (1) | Connecting to IP: 142.215.18.147. | 2023-02-03 21:54:46.828 SC Data - All Services | Network connection to server complete. | 2023-02-03 21:54:46.887 SC Data - All Services | Starting socket receive thread. | 2023-02-03 21:54:46.887 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-03 21:54:46.888 SC Data - All Services | Setting DTC encoding to Binary VLS | 2023-02-03 21:54:46.975 SC Data - All Services | Sending logon request message. | 2023-02-03 21:54:46.975 SC Data - All Services | Received logon response. | 2023-02-03 21:54:47.700 SC Data - All Services | Server Name: RealTime Server. | 2023-02-03 21:54:47.700 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2023-02-03 21:54:47.700 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-02-03 21:54:47.700 SC Data - All Services | Waiting for socket receive thread to end | 2023-02-03 21:54:47.700 DTC Client socket (1) | CloseSocket call. | 2023-02-03 21:54:47.700 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:54:47.700 SC Data - All Services | Disconnected from the server. | 2023-02-03 21:54:47.700 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2023-02-03 21:54:47.700 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-02-03 21:54:47.763 DTC Client socket (1) | Closed. | 2023-02-03 21:54:47.763 File >> Disconnect selected. | 2023-02-03 21:54:48.115 CQG WebAPI | Sending Web API Logoff message. | 2023-02-03 21:54:48.120 CQG WebSocket socket (3) | CloseSocket call. | 2023-02-03 21:54:48.120 CQG WebSocket socket (3) | Max send buffers used during socket life: 3 | 2023-02-03 21:54:48.120 CQG WebSocket socket (3) | Max send buffer size during socket life: 309 | 2023-02-03 21:54:48.120 CQG WebSocket | WebSocket closed. | 2023-02-03 21:54:48.120 CQG WebAPI | WebSocket closed. | 2023-02-03 21:54:48.120 DTC Client socket (0) | CloseSocket call. | 2023-02-03 21:54:48.120 SC Data - All Services | Disconnected from the server. | 2023-02-03 21:54:48.120 CQG WebAPI | Disconnected. | 2023-02-03 21:54:48.120 CQG WebSocket socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2023-02-03 21:54:48.120 CQG WebSocket socket (3) | Write has completed. Shutdown being performed. | 2023-02-03 21:54:48.192 CQG WebSocket socket (3) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:54:48.192 CQG WebAPI | Connecting to server api.cqg.com | 2023-02-03 21:54:54.954 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2023-02-03 21:54:54.954 CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2023-02-03 21:54:54.997 CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2023-02-03 21:54:54.997 CQG WebSocket socket (1) | Connecting to IP: 208.48.16.17. | 2023-02-03 21:54:54.997 CQG WebSocket | Opening WebSocket. | 2023-02-03 21:54:55.074 CQG WebSocket | Sending WebSocket handshake. | 2023-02-03 21:54:55.074 CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2023-02-03 21:54:55.306 CQG WebSocket | Server header | Connection: upgrade | 2023-02-03 21:54:55.306 CQG WebSocket | Server header | Sec-WebSocket-Accept: H7Ln+iDCEbcwHsTMADIRkbBz3E4= | 2023-02-03 21:54:55.306 CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2023-02-03 21:54:55.306 CQG WebSocket | Server header | Upgrade: websocket | 2023-02-03 21:54:55.306 CQG WebSocket | Server header | | 2023-02-03 21:54:55.306 CQG WebSocket | Web socket state is now open. | 2023-02-03 21:54:55.306 CQG WebAPI | WebSocket connected. | 2023-02-03 21:54:55.306 CQG WebAPI | Sending market data logon message. | 2023-02-03 21:54:55.306 CQG WebAPI | Base Time: 2023-01-07T07:45:17. 2023-01-07 07:45:17 | 2023-02-03 21:54:55.429 CQG WebAPI | Logon successful. Session Token = hGKaysmfOOQT/icqwH0nbgd6DckJ3897lscpnwkYb5UpY3tDaxTk3IaLmUeaDv4AQ017a5/90eR | 2023-02-03 21:54:55.429 CQG WebAPI | Connected to server complete. | 2023-02-03 21:54:55.429 Triggering next historical data download in queue. | 2023-02-03 21:54:55.429 Triggering next historical data download in queue. | 2023-02-03 21:54:55.429 Triggering next historical data download in queue. | 2023-02-03 21:54:55.429 Triggering next historical data download in queue. | 2023-02-03 21:54:55.429 Updated verified funded futures trading account ending date to: 2023-03-05 21:54:55 | 2023-02-03 21:54:55.429 CQG WebAPI | Sending Trade Accounts request message. | 2023-02-03 21:54:55.434 No download requests in the queue to start downloads for. | 2023-02-03 21:54:55.434 No download requests in the queue to start downloads for. | 2023-02-03 21:54:55.434 No download requests in the queue to start downloads for. | 2023-02-03 21:54:55.434 No download requests in the queue to start downloads for. | 2023-02-03 21:54:55.434 Mapping F.US.CLEH23 to CLH23. Service code: nymex | 2023-02-03 21:54:55.558 Using symbol data fast lookup vector | 2023-02-03 21:54:55.558 SC Data - All Services | Starting real-time market data updates for: F.US.CLEH23 (CLH23). ID: 1 Service code: nymex | 2023-02-03 21:54:55.558 SC Data - All Services | Connecting to the server ds28-2.sierracharts.com. Port 443 | 2023-02-03 21:54:55.558 CQG WebAPI | Sending symbol resolution request for F.US.CLEH23. ID: 798370 | 2023-02-03 21:54:55.559 SC Data - All Services | Requesting security definition data for: F.US.CLEH23 (CLH23). ID: 1 | 2023-02-03 21:54:55.559 Added historical Intraday data request for F.US.CLEH23 to the queue. | 2023-02-03 21:54:55.559 Intraday data recording state for symbol F.US.CLEH23 is set to download 'Pending'. | 2023-02-03 21:54:55.559 Triggering next historical data download in queue. | 2023-02-03 21:54:55.559 Delaying start of download for F.US.CLEH23. | 2023-02-03 21:54:55.559 Mapping F.US.ENQH23 to NQH23. Service code: cme | 2023-02-03 21:54:55.559 SC Data - All Services | Starting real-time market data updates for: F.US.ENQH23 (NQH23). ID: 2 Service code: cme | 2023-02-03 21:54:55.559 CQG WebAPI | Sending symbol resolution request for F.US.ENQH23. ID: 798371 | 2023-02-03 21:54:55.559 SC Data - All Services | Requesting security definition data for: F.US.ENQH23 (NQH23). ID: 2 | 2023-02-03 21:54:55.559 Added historical Intraday data request for F.US.ENQH23 to the queue. | 2023-02-03 21:54:55.559 Intraday data recording state for symbol F.US.ENQH23 is set to download 'Pending'. | 2023-02-03 21:54:55.559 Triggering next historical data download in queue. | 2023-02-03 21:54:55.559 CQG WebAPI | Brokerage name: AMP. Account Name: 110041 | 2023-02-03 21:54:55.578 Updated verified funded futures trading account ending date to: 2023-03-05 21:54:55 | 2023-02-03 21:54:55.578 CQG WebAPI | Sending collateral subscribe request. | 2023-02-03 21:54:55.578 DTC Client socket (2) | Creating socket. | 2023-02-03 21:54:55.581 DTC Client socket (2) | New receive buffer size: 5242880 | 2023-02-03 21:54:55.581 DTC Client socket (2) | Connecting to IP: 142.215.18.148. | 2023-02-03 21:54:55.581 CQG WebAPI | Received symbol resolution report for symbol F.US.CLEH23. Search Symbol: F.US.CLEH23. Request ID: 798370. Contract ID: 1. | 2023-02-03 21:54:55.634 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQH23. Search Symbol: F.US.ENQH23. Request ID: 798371. Contract ID: 2. | 2023-02-03 21:54:55.638 SC Data - All Services | Network connection to server complete. | 2023-02-03 21:54:55.639 SC Data - All Services | Starting socket receive thread. | 2023-02-03 21:54:55.639 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-03 21:54:55.639 CQG WebAPI | Sending positions subscribe request. RequestID: 798373 | 2023-02-03 21:54:55.683 CQG WebAPI | Sending orders subscribe request. RequestID: 798374 | 2023-02-03 21:54:55.683 SC Data - All Services | Setting DTC encoding to Binary VLS | 2023-02-03 21:54:55.700 SC Data - All Services | Sending logon request message. | 2023-02-03 21:54:55.700 Mapping F.US.EPH23 to ESH23. Service code: cme | 2023-02-03 21:54:55.747 SC Data - All Services | Starting real-time market data updates for: F.US.EPH23 (ESH23). ID: 3 Service code: cme | 2023-02-03 21:54:55.747 CQG WebAPI | Sending symbol resolution request for F.US.EPH23. ID: 798375 | 2023-02-03 21:54:55.747 SC Data - All Services | Requesting security definition data for: F.US.EPH23 (ESH23). ID: 3 | 2023-02-03 21:54:55.747 Added historical Intraday data request for F.US.EPH23 to the queue. | 2023-02-03 21:54:55.747 Intraday data recording state for symbol F.US.EPH23 is set to download 'Pending'. | 2023-02-03 21:54:55.747 Triggering next historical data download in queue. | 2023-02-03 21:54:55.747 Mapping F.US.GCEJ23 to GCJ23. Service code: comex | 2023-02-03 21:54:55.774 SC Data - All Services | Starting real-time market data updates for: F.US.GCEJ23 (GCJ23). ID: 4 Service code: comex | 2023-02-03 21:54:55.774 CQG WebAPI | Sending symbol resolution request for F.US.GCEJ23. ID: 798376 | 2023-02-03 21:54:55.774 SC Data - All Services | Requesting security definition data for: F.US.GCEJ23 (GCJ23). ID: 4 | 2023-02-03 21:54:55.774 Added historical Intraday data request for F.US.GCEJ23 to the queue. | 2023-02-03 21:54:55.774 Intraday data recording state for symbol F.US.GCEJ23 is set to download 'Pending'. | 2023-02-03 21:54:55.774 Triggering next historical data download in queue. | 2023-02-03 21:54:55.774 Mapping F.US.RTYH23 to RTYH23. Service code: cme | 2023-02-03 21:54:55.775 SC Data - All Services | Starting real-time market data updates for: F.US.RTYH23 (RTYH23). ID: 5 Service code: cme | 2023-02-03 21:54:55.775 CQG WebAPI | Sending symbol resolution request for F.US.RTYH23. ID: 798377 | 2023-02-03 21:54:55.775 SC Data - All Services | Requesting security definition data for: F.US.RTYH23 (RTYH23). ID: 5 | 2023-02-03 21:54:55.775 Added historical Intraday data request for F.US.RTYH23 to the queue. | 2023-02-03 21:54:55.775 Intraday data recording state for symbol F.US.RTYH23 is set to download 'Pending'. | 2023-02-03 21:54:55.775 Triggering next historical data download in queue. | 2023-02-03 21:54:55.775 Mapping F.US.NGEH23 to NGH23. Service code: nymex | 2023-02-03 21:54:55.776 SC Data - All Services | Starting real-time market data updates for: F.US.NGEH23 (NGH23). ID: 6 Service code: nymex | 2023-02-03 21:54:55.776 CQG WebAPI | Sending symbol resolution request for F.US.NGEH23. ID: 798378 | 2023-02-03 21:54:55.776 SC Data - All Services | Requesting security definition data for: F.US.NGEH23 (NGH23). ID: 6 | 2023-02-03 21:54:55.776 Added historical Intraday data request for F.US.NGEH23 to the queue. | 2023-02-03 21:54:55.776 Intraday data recording state for symbol F.US.NGEH23 is set to download 'Pending'. | 2023-02-03 21:54:55.776 Triggering next historical data download in queue. | 2023-02-03 21:54:55.776 CQG WebAPI | Received symbol resolution report for symbol F.US.EPH23. Search Symbol: F.US.EPH23. Request ID: 798375. Contract ID: 3. | 2023-02-03 21:54:55.818 CQG WebAPI | Received symbol resolution report for symbol F.US.GCEJ23. Search Symbol: F.US.GCEJ23. Request ID: 798376. Contract ID: 4. | 2023-02-03 21:54:55.847 CQG WebAPI | Received symbol resolution report for symbol F.US.RTYH23. Search Symbol: F.US.RTYH23. Request ID: 798377. Contract ID: 5. | 2023-02-03 21:54:55.851 CQG WebAPI | Received symbol resolution report for symbol F.US.NGEH23. Search Symbol: F.US.NGEH23. Request ID: 798378. Contract ID: 6. | 2023-02-03 21:54:55.912 Mapping F.US.ULAH23 to UBH23. Service code: cbot | 2023-02-03 21:54:55.952 SC Data - All Services | Starting real-time market data updates for: F.US.ULAH23 (UBH23). ID: 7 Service code: cbot | 2023-02-03 21:54:55.952 CQG WebAPI | Sending symbol resolution request for F.US.ULAH23. ID: 798379 | 2023-02-03 21:54:55.952 SC Data - All Services | Requesting security definition data for: F.US.ULAH23 (UBH23). ID: 7 | 2023-02-03 21:54:55.952 Added historical Intraday data request for F.US.ULAH23 to the queue. | 2023-02-03 21:54:55.952 Intraday data recording state for symbol F.US.ULAH23 is set to download 'Pending'. | 2023-02-03 21:54:55.952 Triggering next historical data download in queue. | 2023-02-03 21:54:55.952 CQG WebAPI | Received symbol resolution report for symbol F.US.ULAH23. Search Symbol: F.US.ULAH23. Request ID: 798379. Contract ID: 7. | 2023-02-03 21:54:56.025 SC Data - All Services | Received logon response. | 2023-02-03 21:54:56.392 SC Data - All Services | Server Name: RealTime Server. | 2023-02-03 21:54:56.392 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2023-02-03 21:54:56.392 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-02-03 21:54:56.392 SC Data - All Services | Waiting for socket receive thread to end | 2023-02-03 21:54:56.392 DTC Client socket (2) | CloseSocket call. | 2023-02-03 21:54:56.392 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:54:56.392 SC Data - All Services | Disconnected from the server. | 2023-02-03 21:54:56.392 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2023-02-03 21:54:56.392 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-02-03 21:54:56.450 DTC Client socket (2) | Closed. | 2023-02-03 21:54:56.450 HD Request # 13 | Downloading Intraday chart data for F.US.CLEH23 to the file F.US.CLEH23.scid. Service: nymex | 2023-02-03 21:55:26.048 HD Request # 13 | Download start date-time: 2023-02-03 21:53:16.000000. File last date-time: 2023-02-03 21:53:16.114002 | 2023-02-03 21:55:26.048 HD Request # 13 | Using server: ds23.sierracharts.com port 10149 | 2023-02-03 21:55:26.050 Socket (2) | Creating socket. | 2023-02-03 21:55:26.050 Socket (2) | New receive buffer size: 5242880 | 2023-02-03 21:55:26.050 Socket (2) | Connecting to IP: 142.215.17.190. | 2023-02-03 21:55:26.050 HD Request # 13 | Setting DTC encoding to Binary VLS | 2023-02-03 21:55:26.176 HD Request # 13 | Sending historical data logon request message. | 2023-02-03 21:55:26.176 SC Data - All Services | Connecting to the server ds26.sierracharts.com. Port 10048 | 2023-02-03 21:55:26.392 DTC Client socket (4) | Creating socket. | 2023-02-03 21:55:26.392 DTC Client socket (4) | New receive buffer size: 5242880 | 2023-02-03 21:55:26.392 DTC Client socket (4) | Connecting to IP: 142.215.17.188. | 2023-02-03 21:55:26.392 SC Data - All Services | Network connection to server complete. | 2023-02-03 21:55:26.453 SC Data - All Services | Starting socket receive thread. | 2023-02-03 21:55:26.453 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-03 21:55:26.453 SC Data - All Services | Setting DTC encoding to Binary VLS | 2023-02-03 21:55:26.544 SC Data - All Services | Sending logon request message. | 2023-02-03 21:55:26.544 HD Request # 13 | Requesting Intraday data. Start date-time: 2023-02-03 21:53:16. Record interval: 0. Symbol: CLH23 | 2023-02-03 21:55:26.752 HD Request # 13 | Decompressing data. | 2023-02-03 21:55:26.813 HD Request # 13 | Receiving Intraday data for F.US.CLEH23 starting at 2023-02-03 21:53:16.108000 | 2023-02-03 21:55:26.813 Socket (2) | CloseSocket call. | 2023-02-03 21:55:26.813 Socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:55:26.813 Historical data download thread signaled to stop. | 2023-02-03 21:55:26.813 HD Request # 13 | Timestamp of first Intraday data file record written: 2023-02-03 21:53:19.808000. | 2023-02-03 21:55:26.813 HD Request # 13 | Received 88 Intraday data records from 2023-02-03 21:53:16.108000 to 2023-02-03 21:55:26.328000 (2.2 minutes) and wrote 81 records for F.US.CLEH23 | 2023-02-03 21:55:26.813 HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2023-02-03 21:55:26.328000 | 2023-02-03 21:55:26.814 HD Request # 13 | Completion time: 0s. | 2023-02-03 21:55:26.814 HD Request # 13 | Intraday data download complete for F.US.CLEH23. Unique request ID: 13 | 2023-02-03 21:55:26.814 Removing historical data download ID 13. | 2023-02-03 21:55:26.814 Real-time Intraday chart data file updates started for F.US.CLEH23 | 2023-02-03 21:55:26.814 Intraday chart data file opened for F.US.CLEH23 | 2023-02-03 21:55:26.814 HD Request # 13 | Enabling Intraday chart updating for symbol. | 2023-02-03 21:55:26.814 Triggering next historical data download in queue. | 2023-02-03 21:55:26.814 HD Request # 14 | Downloading Intraday chart data for F.US.ENQH23 to the file F.US.ENQH23.scid. Service: cme | 2023-02-03 21:55:26.814 HD Request # 14 | Download start date-time: 2023-02-03 21:53:13.000000. File last date-time: 2023-02-03 21:53:13.129000 | 2023-02-03 21:55:26.814 HD Request # 14 | Using server: ds26.sierracharts.com port 10150 | 2023-02-03 21:55:26.814 Socket (5) | Creating socket. | 2023-02-03 21:55:26.814 Socket (5) | New receive buffer size: 5242880 | 2023-02-03 21:55:26.814 Socket (5) | Connecting to IP: 142.215.17.188. | 2023-02-03 21:55:26.814 Socket (2) | Socket gracefully closed by remote side. | 2023-02-03 21:55:26.867 Socket (2) | Closed. | 2023-02-03 21:55:26.867 HD Request # 14 | Setting DTC encoding to Binary VLS | 2023-02-03 21:55:26.929 HD Request # 14 | Sending historical data logon request message. | 2023-02-03 21:55:26.929 SC Data - All Services | Received logon response. | 2023-02-03 21:55:27.264 SC Data - All Services | Server Name: RealTime Server. | 2023-02-03 21:55:27.264 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2023-02-03 21:55:27.264 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-02-03 21:55:27.264 SC Data - All Services | Waiting for socket receive thread to end | 2023-02-03 21:55:27.264 DTC Client socket (4) | CloseSocket call. | 2023-02-03 21:55:27.264 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:55:27.264 SC Data - All Services | Disconnected from the server. | 2023-02-03 21:55:27.264 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2023-02-03 21:55:27.264 DTC Client socket (4) | Socket gracefully closed by remote side. | 2023-02-03 21:55:27.322 DTC Client socket (4) | Closed. | 2023-02-03 21:55:27.322 HD Request # 14 | Requesting Intraday data. Start date-time: 2023-02-03 21:53:13. Record interval: 0. Symbol: NQH23 | 2023-02-03 21:55:27.505 HD Request # 14 | Decompressing data. | 2023-02-03 21:55:27.563 HD Request # 14 | Receiving Intraday data for F.US.ENQH23 starting at 2023-02-03 21:53:13.129000 | 2023-02-03 21:55:27.564 Socket (5) | CloseSocket call. | 2023-02-03 21:55:27.564 Socket (5) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:55:27.565 Historical data download thread signaled to stop. | 2023-02-03 21:55:27.565 HD Request # 14 | Timestamp of first Intraday data file record written: 2023-02-03 21:53:23.901000. | 2023-02-03 21:55:27.565 HD Request # 14 | Received 90 Intraday data records from 2023-02-03 21:53:13.129000 to 2023-02-03 21:55:20.439000 (2.1 minutes) and wrote 89 records for F.US.ENQH23 | 2023-02-03 21:55:27.565 HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2023-02-03 21:55:20.439000 | 2023-02-03 21:55:27.565 HD Request # 14 | Completion time: 1s. | 2023-02-03 21:55:27.565 HD Request # 14 | Intraday data download complete for F.US.ENQH23. Unique request ID: 14 | 2023-02-03 21:55:27.565 Removing historical data download ID 14. | 2023-02-03 21:55:27.565 Real-time Intraday chart data file updates started for F.US.ENQH23 | 2023-02-03 21:55:27.565 Intraday chart data file opened for F.US.ENQH23 | 2023-02-03 21:55:27.565 HD Request # 14 | Enabling Intraday chart updating for symbol. | 2023-02-03 21:55:27.565 Triggering next historical data download in queue. | 2023-02-03 21:55:27.565 HD Request # 15 | Downloading Intraday chart data for F.US.EPH23 to the file F.US.EPH23.scid. Service: cme | 2023-02-03 21:55:27.565 HD Request # 15 | Download start date-time: 2023-02-03 21:53:08.000000. File last date-time: 2023-02-03 21:53:08.863000 | 2023-02-03 21:55:27.565 HD Request # 15 | Using server: ds28.sierracharts.com port 10149 | 2023-02-03 21:55:27.565 Socket (2) | Creating socket. | 2023-02-03 21:55:27.565 Socket (2) | New receive buffer size: 5242880 | 2023-02-03 21:55:27.566 Socket (2) | Connecting to IP: 142.215.18.147. | 2023-02-03 21:55:27.566 Socket (5) | Socket gracefully closed by remote side. | 2023-02-03 21:55:27.623 Socket (5) | Closed. | 2023-02-03 21:55:27.623 HD Request # 15 | Setting DTC encoding to Binary VLS | 2023-02-03 21:55:27.682 HD Request # 15 | Sending historical data logon request message. | 2023-02-03 21:55:27.682 HD Request # 15 | Requesting Intraday data. Start date-time: 2023-02-03 21:53:08. Record interval: 0. Symbol: ESH23 | 2023-02-03 21:55:28.258 HD Request # 15 | Decompressing data. | 2023-02-03 21:55:28.316 HD Request # 15 | Receiving Intraday data for F.US.EPH23 starting at 2023-02-03 21:53:08.863000 | 2023-02-03 21:55:28.317 Socket (2) | CloseSocket call. | 2023-02-03 21:55:28.317 Socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:55:28.317 Historical data download thread signaled to stop. | 2023-02-03 21:55:28.317 HD Request # 15 | Timestamp of first Intraday data file record written: 2023-02-03 21:53:11.285000. | 2023-02-03 21:55:28.318 HD Request # 15 | Received 203 Intraday data records from 2023-02-03 21:53:08.863000 to 2023-02-03 21:55:27.503000 (2.3 minutes) and wrote 202 records for F.US.EPH23 | 2023-02-03 21:55:28.318 HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2023-02-03 21:55:27.503000 | 2023-02-03 21:55:28.318 HD Request # 15 | Completion time: 1s. | 2023-02-03 21:55:28.319 HD Request # 15 | Intraday data download complete for F.US.EPH23. Unique request ID: 15 | 2023-02-03 21:55:28.319 Removing historical data download ID 15. | 2023-02-03 21:55:28.319 Real-time Intraday chart data file updates started for F.US.EPH23 | 2023-02-03 21:55:28.319 Intraday chart data file opened for F.US.EPH23 | 2023-02-03 21:55:28.319 HD Request # 15 | Enabling Intraday chart updating for symbol. | 2023-02-03 21:55:28.319 Triggering next historical data download in queue. | 2023-02-03 21:55:28.319 HD Request # 16 | Downloading Intraday chart data for F.US.GCEJ23 to the file F.US.GCEJ23.scid. Service: comex | 2023-02-03 21:55:28.319 HD Request # 16 | Download start date-time: 2023-02-03 21:53:12.000000. File last date-time: 2023-02-03 21:53:12.485000 | 2023-02-03 21:55:28.319 HD Request # 16 | Using server: ds23.sierracharts.com port 10150 | 2023-02-03 21:55:28.319 Socket (4) | Creating socket. | 2023-02-03 21:55:28.319 Socket (4) | New receive buffer size: 5242880 | 2023-02-03 21:55:28.319 Socket (4) | Connecting to IP: 142.215.17.190. | 2023-02-03 21:55:28.319 Socket (2) | Socket gracefully closed by remote side. | 2023-02-03 21:55:28.376 Socket (2) | Closed. | 2023-02-03 21:55:28.376 HD Request # 16 | Setting DTC encoding to Binary VLS | 2023-02-03 21:55:28.448 HD Request # 16 | Sending historical data logon request message. | 2023-02-03 21:55:28.448 HD Request # 16 | Requesting Intraday data. Start date-time: 2023-02-03 21:53:12. Record interval: 0. Symbol: GCJ23 | 2023-02-03 21:55:29.025 HD Request # 16 | Decompressing data. | 2023-02-03 21:55:29.084 HD Request # 16 | Receiving Intraday data for F.US.GCEJ23 starting at 2023-02-03 21:53:12.485000 | 2023-02-03 21:55:29.085 Socket (4) | CloseSocket call. | 2023-02-03 21:55:29.085 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:55:29.085 Historical data download thread signaled to stop. | 2023-02-03 21:55:29.085 HD Request # 16 | Timestamp of first Intraday data file record written: 2023-02-03 21:53:24.621000. | 2023-02-03 21:55:29.085 HD Request # 16 | Received 89 Intraday data records from 2023-02-03 21:53:12.485000 to 2023-02-03 21:55:29.428004 (2.3 minutes) and wrote 88 records for F.US.GCEJ23 | 2023-02-03 21:55:29.085 HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2023-02-03 21:55:29.428004 | 2023-02-03 21:55:29.086 HD Request # 16 | Completion time: 1s. | 2023-02-03 21:55:29.086 HD Request # 16 | Intraday data download complete for F.US.GCEJ23. Unique request ID: 16 | 2023-02-03 21:55:29.086 Removing historical data download ID 16. | 2023-02-03 21:55:29.086 Real-time Intraday chart data file updates started for F.US.GCEJ23 | 2023-02-03 21:55:29.086 Intraday chart data file opened for F.US.GCEJ23 | 2023-02-03 21:55:29.086 HD Request # 16 | Enabling Intraday chart updating for symbol. | 2023-02-03 21:55:29.086 Triggering next historical data download in queue. | 2023-02-03 21:55:29.086 HD Request # 17 | Downloading Intraday chart data for F.US.RTYH23 to the file F.US.RTYH23.scid. Service: cme | 2023-02-03 21:55:29.086 HD Request # 17 | Download start date-time: 2023-02-03 21:52:50.000000. File last date-time: 2023-02-03 21:52:50.784002 | 2023-02-03 21:55:29.086 HD Request # 17 | Using server: ds26.sierracharts.com port 10149 | 2023-02-03 21:55:29.086 Socket (2) | Creating socket. | 2023-02-03 21:55:29.086 Socket (2) | New receive buffer size: 5242880 | 2023-02-03 21:55:29.086 Socket (2) | Connecting to IP: 142.215.17.188. | 2023-02-03 21:55:29.086 Socket (4) | Socket gracefully closed by remote side. | 2023-02-03 21:55:29.143 Socket (4) | Closed. | 2023-02-03 21:55:29.143 HD Request # 17 | Setting DTC encoding to Binary VLS | 2023-02-03 21:55:29.204 HD Request # 17 | Sending historical data logon request message. | 2023-02-03 21:55:29.204 HD Request # 17 | Requesting Intraday data. Start date-time: 2023-02-03 21:52:50. Record interval: 0. Symbol: RTYH23 | 2023-02-03 21:55:29.792 HD Request # 17 | Decompressing data. | 2023-02-03 21:55:29.855 HD Request # 17 | Receiving Intraday data for F.US.RTYH23 starting at 2023-02-03 21:52:50.784000 | 2023-02-03 21:55:29.856 Socket (2) | CloseSocket call. | 2023-02-03 21:55:29.856 Socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:55:29.856 Historical data download thread signaled to stop. | 2023-02-03 21:55:29.856 HD Request # 17 | Timestamp of first Intraday data file record written: 2023-02-03 21:53:35.112000. | 2023-02-03 21:55:29.857 HD Request # 17 | Received 27 Intraday data records from 2023-02-03 21:52:50.784000 to 2023-02-03 21:55:27.846000 (2.6 minutes) and wrote 24 records for F.US.RTYH23 | 2023-02-03 21:55:29.857 HD Request # 17 | Add time&sales data | Remembered last file record date-time: 2023-02-03 21:55:27.846000 | 2023-02-03 21:55:29.857 HD Request # 17 | Completion time: 0s. | 2023-02-03 21:55:29.857 HD Request # 17 | Intraday data download complete for F.US.RTYH23. Unique request ID: 17 | 2023-02-03 21:55:29.857 Removing historical data download ID 17. | 2023-02-03 21:55:29.857 Real-time Intraday chart data file updates started for F.US.RTYH23 | 2023-02-03 21:55:29.857 Intraday chart data file opened for F.US.RTYH23 | 2023-02-03 21:55:29.857 HD Request # 17 | Enabling Intraday chart updating for symbol. | 2023-02-03 21:55:29.857 Triggering next historical data download in queue. | 2023-02-03 21:55:29.857 HD Request # 18 | Downloading Intraday chart data for F.US.NGEH23 to the file F.US.NGEH23.scid. Service: nymex | 2023-02-03 21:55:29.857 HD Request # 18 | Download start date-time: 2023-02-03 21:53:07.000000. File last date-time: 2023-02-03 21:53:07.819001 | 2023-02-03 21:55:29.857 HD Request # 18 | Using server: ds28.sierracharts.com port 10150 | 2023-02-03 21:55:29.857 Socket (4) | Creating socket. | 2023-02-03 21:55:29.857 Socket (4) | New receive buffer size: 5242880 | 2023-02-03 21:55:29.857 Socket (4) | Connecting to IP: 142.215.18.147. | 2023-02-03 21:55:29.857 Socket (2) | Socket gracefully closed by remote side. | 2023-02-03 21:55:29.910 Socket (2) | Closed. | 2023-02-03 21:55:29.910 HD Request # 18 | Setting DTC encoding to Binary VLS | 2023-02-03 21:55:30.267 HD Request # 18 | Sending historical data logon request message. | 2023-02-03 21:55:30.267 HD Request # 18 | Requesting Intraday data. Start date-time: 2023-02-03 21:53:07. Record interval: 0. Symbol: NGH23 | 2023-02-03 21:55:30.842 HD Request # 18 | Decompressing data. | 2023-02-03 21:55:30.904 HD Request # 18 | Receiving Intraday data for F.US.NGEH23 starting at 2023-02-03 21:53:07.819000 | 2023-02-03 21:55:30.904 Socket (4) | CloseSocket call. | 2023-02-03 21:55:30.905 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:55:30.905 Historical data download thread signaled to stop. | 2023-02-03 21:55:30.905 HD Request # 18 | Timestamp of first Intraday data file record written: 2023-02-03 21:53:44.712000. | 2023-02-03 21:55:30.905 HD Request # 18 | Received 23 Intraday data records from 2023-02-03 21:53:07.819000 to 2023-02-03 21:55:26.589000 (2.3 minutes) and wrote 21 records for F.US.NGEH23 | 2023-02-03 21:55:30.905 HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2023-02-03 21:55:26.589000 | 2023-02-03 21:55:30.905 HD Request # 18 | Completion time: 1s. | 2023-02-03 21:55:30.905 HD Request # 18 | Intraday data download complete for F.US.NGEH23. Unique request ID: 18 | 2023-02-03 21:55:30.905 Removing historical data download ID 18. | 2023-02-03 21:55:30.905 Real-time Intraday chart data file updates started for F.US.NGEH23 | 2023-02-03 21:55:30.905 Intraday chart data file opened for F.US.NGEH23 | 2023-02-03 21:55:30.905 HD Request # 18 | Enabling Intraday chart updating for symbol. | 2023-02-03 21:55:30.905 Triggering next historical data download in queue. | 2023-02-03 21:55:30.906 HD Request # 19 | Downloading Intraday chart data for F.US.ULAH23 to the file F.US.ULAH23.scid. Service: cbot | 2023-02-03 21:55:30.906 HD Request # 19 | Download start date-time: 2023-02-03 21:53:06.000000. File last date-time: 2023-02-03 21:53:06.987005 | 2023-02-03 21:55:30.906 HD Request # 19 | Using server: ds23.sierracharts.com port 10149 | 2023-02-03 21:55:30.906 Socket (2) | Creating socket. | 2023-02-03 21:55:30.906 Socket (2) | New receive buffer size: 5242880 | 2023-02-03 21:55:30.906 Socket (2) | Connecting to IP: 142.215.17.190. | 2023-02-03 21:55:30.906 Socket (4) | Socket gracefully closed by remote side. | 2023-02-03 21:55:30.963 Socket (4) | Closed. | 2023-02-03 21:55:30.963 HD Request # 19 | Setting DTC encoding to Binary VLS | 2023-02-03 21:55:31.028 HD Request # 19 | Sending historical data logon request message. | 2023-02-03 21:55:31.028 HD Request # 19 | Requesting Intraday data. Start date-time: 2023-02-03 21:53:06. Record interval: 0. Symbol: UBH23 | 2023-02-03 21:55:31.087 HD Request # 19 | Decompressing data. | 2023-02-03 21:55:31.161 HD Request # 19 | Receiving Intraday data for F.US.ULAH23 starting at 2023-02-03 21:53:06.987000 | 2023-02-03 21:55:31.161 Socket (2) | CloseSocket call. | 2023-02-03 21:55:31.162 Socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:55:31.162 Historical data download thread signaled to stop. | 2023-02-03 21:55:31.162 HD Request # 19 | Timestamp of first Intraday data file record written: 2023-02-03 21:53:29.276000. | 2023-02-03 21:55:31.162 HD Request # 19 | Received 22 Intraday data records from 2023-02-03 21:53:06.987000 to 2023-02-03 21:55:12.722000 (2.1 minutes) and wrote 16 records for F.US.ULAH23 | 2023-02-03 21:55:31.162 HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2023-02-03 21:55:12.722000 | 2023-02-03 21:55:31.162 HD Request # 19 | Completion time: 1s. | 2023-02-03 21:55:31.163 HD Request # 19 | Intraday data download complete for F.US.ULAH23. Unique request ID: 19 | 2023-02-03 21:55:31.163 Removing historical data download ID 19. | 2023-02-03 21:55:31.163 Real-time Intraday chart data file updates started for F.US.ULAH23 | 2023-02-03 21:55:31.163 Intraday chart data file opened for F.US.ULAH23 | 2023-02-03 21:55:31.163 HD Request # 19 | Enabling Intraday chart updating for symbol. | 2023-02-03 21:55:31.163 Triggering next historical data download in queue. | 2023-02-03 21:55:31.163 No download requests in the queue to start downloads for. | 2023-02-03 21:55:31.163 Socket (2) | Socket gracefully closed by remote side. | 2023-02-03 21:55:31.218 Socket (2) | Closed. | 2023-02-03 21:55:31.218 SC Data - All Services | Connecting to the server ds28-2.sierracharts.com. Port 443 | 2023-02-03 21:55:57.267 DTC Client socket (2) | Creating socket. | 2023-02-03 21:55:57.267 DTC Client socket (2) | New receive buffer size: 5242880 | 2023-02-03 21:55:57.267 DTC Client socket (2) | Connecting to IP: 142.215.18.148. | 2023-02-03 21:55:57.267 SC Data - All Services | Network connection to server complete. | 2023-02-03 21:55:57.327 SC Data - All Services | Starting socket receive thread. | 2023-02-03 21:55:57.327 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-03 21:55:57.327 SC Data - All Services | Setting DTC encoding to Binary VLS | 2023-02-03 21:55:57.405 SC Data - All Services | Sending logon request message. | 2023-02-03 21:55:57.405 SC Data - All Services | Received logon response. | 2023-02-03 21:55:58.144 SC Data - All Services | Server Name: RealTime Server. | 2023-02-03 21:55:58.144 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2023-02-03 21:55:58.144 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-02-03 21:55:58.144 SC Data - All Services | Waiting for socket receive thread to end | 2023-02-03 21:55:58.144 DTC Client socket (2) | CloseSocket call. | 2023-02-03 21:55:58.144 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-03 21:55:58.144 SC Data - All Services | Disconnected from the server. | 2023-02-03 21:55:58.144 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2023-02-03 21:55:58.144 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-02-03 21:55:58.198 DTC Client socket (2) | Closed. | 2023-02-03 21:55:58.198 |
[2023-02-03 22:29:53] |
John - SC Support - Posts: 39362 |
The computer from which the above Message Log originates is setup to get the data from our Denali Exchange Data Feed as shown by the following line: Allow Support for Sierra Chart Data Feeds is enabled. | 2023-02-03 21:52:32.424
Since this option is set to Yes (enabled) this means that you are getting the data from us. This is why you are having the issue with multiple connections as noted in this line: SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
Note that we do not support data from CQG for the CME Group and EUREX. Therefore, the only way to get the data to this second computer would be to pay the second exchange fee for the CME Group data under our Denali Exchange Data Feed. Refer to the information/instructions here: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously Another option is to only use a single computer with multiple installations of Sierra Chart. You can have 3 separate installations accessing the Denali Exchange Data Feed at the same time at no extra cost. Refer to the information at the following links: Denali Exchange Data Feed: Denali Exchange Data Feed Connections on Same Computer Simultaneously Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-04 01:34:54] |
User968091 - Posts: 47 |
What is the point of having multiple installations of Sierra Chart on the same computer? Why wouldnt I just open additional windows, etc? Do you support Rithmic as a data feed for another computer? |
[2023-02-06 02:44:07] |
Sierra_Chart Engineering - Posts: 19285 |
The reasons for sub-instances are explained here: Using DTC Server for Data and Trading in Another Sierra Chart Instance Regarding Rithmic data, refer to here: Rithmic Trading Platform Service: Rithmic Support Policy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-02-06 02:44:24
[2023-02-07 03:48:23] |
I am able to connect to Rithimic on my other computer but the data isnt live unless I shut down my other computer. When I bring up the Denail computer now that data isnt live. I thought I was able to use a second instance of Sierra on another computer with another data feed that wasnt Denali?
[2023-02-07 15:37:38] |
Yes, you can do this. The most likely situation is that on the computer for which you want to get Rithmic data, you have not set the Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds to No. Be sure that option is set to No, and after you select OK to close that window then select File >> Disconnect followed by File >> Connect to Data Feed. That should resolve your issues with both systems. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-07 17:18:16] |
That worked. Thank you.
