Date/Time: Fri, 18 Apr 2025 16:37:32 +0000
does SIM trading work the same with Teton as with my previous feed?
View Count: 395
[2023-01-17 22:17:48] |
User566779 - Posts: 24 |
does SIM trading work the same with Teton as with my previous feed or do I need to make any changes?
[2023-01-17 22:28:35] |
John - SC Support - Posts: 39356 |
It depends on what Simulated trading you were doing. If you were using any of the Sierra Chart tools (simulation mode or simulated futures trading), then the process will be exactly the same. If you are referring to simulated trading through your broker (or trading service) then it will be different, as the Simulation service you will need to use will be one of the Sierra Chart options (Simulation Mode or Simulated Futures Trading). For more information on these options from Sierra Chart, refer to the following links: Trade Simulation Simulated Futures Trading Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
