Date/Time: Fri, 13 Nov 2026 01:28:20 +0000
German Dax
View Count: 1863
| [2014-06-02 08:13:40] |
| User54027 - Posts: 128 |
Hello support The TPO value area and the volume value area indicators are not working for the Dax this am. Please come back to me urgently, this issue happens frequently on the Dax. Thanks |
| [2014-06-02 10:40:16] |
This does not make sense. These studies work very reliably and it does not make sense why you would have a problem frequently. You should have no problem at all. Most likely there is some misunderstanding of what you are seeing and/or about the Input settings you have set. We have insufficient information to help with this. We do not see an image of the chart and we do not know what settings you are using and we do not know what data is in the chart. You need to provide an image of the chart and it must only contain 1 single study you are having difficulty and no others. Otherwise, we cannot help. Here are the instructions to provide an image: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Once again, the chart must contain only one study. Tell us what the Input settings for the study are. We also need to know the Session Times you have set in Chart >>Chart Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-02 10:41:38
| [2014-06-02 11:03:23] |
http://www.sierrachart.com/image.php?l=1401706859458.png http://prntscr.com/3ox61q http://prntscr.com/3ox65d http://prntscr.com/3ox6cg |
| [2014-06-02 11:13:06] |
Uncheck Chart>> Chart Settings >> Load Weekend Data
| [2014-06-02 11:30:49] |
Thank you support.
